Ok after manjaro stayed dead for a few days, it unexpectedly launched today as Lxqt live system:
So here the requested files:
1. for the installed Manjaro xfce system
1.1 /home/username/.xsession.errors
/usr/bin/iceauth: creating new authority file /run/user/1000/ICEauthority
gpg-agent: a gpg-agent is already running - not starting a new one
(wrapper-2.0:1453): libnotify-WARNING **: 02:36:29.341: Failed to connect to proxy
(wrapper-2.0:1450): Gtk-WARNING **: 02:36:29.455: Negative content width -1 (allocation 1, extents 1x1) while allocating gadget (node button, owner GtkToggleButton)
(wrapper-2.0:1453): Gtk-WARNING **: 02:36:29.489: Negative content width -1 (allocation 1, extents 1x1) while allocating gadget (node button, owner PulseaudioButton)
** (xfce4-clipman:1484): WARNING **: 02:36:29.813: Unable to register GApplication: An object is already exported for the interface org.gtk.Application at /org/xfce/clipman
(xfce4-clipman:1484): GLib-GIO-CRITICAL **: 02:36:29.813: g_application_get_is_remote: assertion 'application->priv->is_registered' failed
(xfce4-clipman:1484): GLib-WARNING **: 02:36:29.813: g_set_application_name() called multiple times
** (xfce4-power-manager:1503): WARNING **: 02:36:29.816: Failed to get name owner: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Could not get owner of name 'org.freedesktop.PowerManagement': no such name
** (xfce4-power-manager:1503): WARNING **: 02:36:29.817: Failed to get name owner: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Could not get owner of name 'org.xfce.PowerManager': no such name
(xfce4-power-manager:1503): libnotify-WARNING **: 02:36:29.861: Failed to connect to proxy
(nm-applet:1493): libnotify-WARNING **: 02:36:29.892: Failed to connect to proxy
(pamac-tray:1499): Gdk-CRITICAL **: 02:36:29.977: gdk_window_thaw_toplevel_updates: assertion 'window->update_and_descendants_freeze_count > 0' failed
(xfce4-power-manager:1503): GLib-GObject-WARNING **: 02:36:30.188: ../glib/gobject/gsignal.c:2614: signal 'Changed' is invalid for instance '0x555847d1e320' of type 'GDBusProxy'
(xfce4-power-manager:1503): xfce4-power-manager-WARNING **: 02:36:30.203: could not map keysym 1008ffa8 to keycode
** (xfce4-power-manager:1503): WARNING **: 02:36:30.208: No outputs have backlight property
(xfce4-power-manager:1503): xfce4-power-manager-WARNING **: 02:36:30.216: It seems the kernel brightness switch handling value was not restored properly on exit last time, xfce4-power-manager will try to restore it this time.
xfce4-power-manager-Message: 02:36:30.241: Set kernel brightness switch to 0
(xfce4-power-manager:1503): xfce4-power-manager-WARNING **: 02:36:30.248: Failed to get keyboard max brightness level : GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface “org.freedesktop.UPower.KbdBacklight” on object at path /org/freedesktop/UPower/KbdBacklight
blueman-applet 02.36.30 WARNING PluginManager:148 __load_plugin: Not loading PPPSupport because its conflict has higher priority
DEBUG:root:_DATA_DIR is /usr/share/application-utility
DEBUG:root:_PREF_FILE is /usr/share/application-utility/preferences.json
DEBUG:root:self.file is {'desktop': '', 'main': '/usr/share/application-utility/default.json'}
INFO:root:json to merge : /usr/share/application-utility/default.json
DEBUG:root:json : /tmp/manjaro-hello-preferences.json
blueman-applet 02.36.30 WARNING PluginManager:148 __load_plugin: Not loading DhcpClient because its conflict has higher priority
(wrapper-2.0:1452): libsystray-CRITICAL **: 02:36:30.622: sn_item_invalidate: assertion 'item->properties_proxy != NULL' failed
WARNING:root:File not exist ? /usr/share/application-utility/xfce.json
DEBUG:root:
--- read data.json with FILTERS ---
DEBUG:root:my desktop: xfce
DEBUG:root:filter :
DEBUG:root:groups : *
DEBUG:root: filter app: Epiphany ['advanced'] <
DEBUG:root: filter app: Falkon ['advanced'] <
DEBUG:root: filter app: Konqueror ['advanced'] <
DEBUG:root: filter app: Claws Mail ['advanced'] <
DEBUG:root: filter app: Atom ['advanced'] <
DEBUG:root: filter app: Vim ['advanced'] <
DEBUG:root: filter app: Visual Studio Code OSS ['advanced'] <
DEBUG:root: filter app: Gnome builder ['advanced'] <
DEBUG:root:filter group : File Sharing ['advanced'] <
DEBUG:root: filter app: Grsync ['advanced'] <
DEBUG:root: filter app: Borg ['advanced'] <
DEBUG:root:filter group : System Tools ['advanced'] <
DEBUG:root:filter group : Virtual Computing ['advanced'] <
DEBUG:root:
DEBUG:root:filter :
DEBUG:root:
DEBUG:root:filter :
xfsettingsd: Another instance took over. Leaving...
** Message: 02:36:59.899: updates_checker.vala:71: check updates
** Message: 02:37:04.960: updates_checker.vala:101: 1 updates found
###!!! [Parent][RunMessage] Error: Channel closing: too late to send/recv, messages will be lost
xfce4-power-manager-Message: 03:14:16.976: Restored brightness switch value to: 1
1.2 /home/username/.local/share/xorg/Xorg.1.log
does not exist
All to find there is:
manjaro@manjaro-lxqt: /run/media/manjaro/c9410574-a125-4309-a65c-bd08ec0e8627/stjerne/.local/share ls
flatpak gvfs-metadata icc inxi keyrings recently-used.xbel
Instead I can provide /var/log/Xorg.1.log. Hope this might help:
[ 5.282]
X.Org X Server 1.20.11
[ 5.282] Build Operating System: Linux Manjaro Linux
[ 5.282] Current Operating System: Linux reiknar 5.12.0-1-MANJARO #1 SMP PREEMPT Mon Apr 12 05:45:30 UTC 2021 x86_64
[ 5.282] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64 root=UUID=2ed44c5c-7587-4c08-9f5d-a7f01c695674 rw processor.max_cstate=5 rcu_nocbs=0-7 amd_iommu=on iommu=pt
[ 5.282] Build Date: 13 April 2021 04:11:08PM
[ 5.282]
[ 5.282] Current version of pixman: 0.40.0
[ 5.282] Before reporting problems, check http://wiki.x.org
[ 5.282] Markers: (--) probed, (**) from config file, (==) default setting,
[ 5.282] (==) Log file: "/var/log/Xorg.0.log", Time: Sat May 1 16:44:02 2021
[ 5.282] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 5.282] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 5.282] (==) No Layout section. Using the first Screen section.
[ 5.282] (==) No screen section available. Using defaults.
[ 5.282] (**) |-->Screen "Default Screen Section" (0)
[ 5.282] (**) | |-->Monitor "<default monitor>"
[ 5.282] (==) No monitor specified for screen "Default Screen Section".
[ 5.282] (==) Automatically adding devices
[ 5.282] (==) Automatically enabling devices
[ 5.282] (==) Automatically adding GPU devices
[ 5.282] (==) Automatically binding GPU devices
[ 5.282] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 5.282] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 5.282] Entry deleted from font path.
[ 5.282] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 5.282] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 5.283] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 5.283] Entry deleted from font path.
[ 5.283] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 5.283] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 5.283] (II) The server relies on udev to provide the list of input devices.
[ 5.283] (II) Module ABI versions:
[ 5.283] X.Org ANSI C Emulation: 0.4
[ 5.283] X.Org Video Driver: 24.1
[ 5.283] X.Org XInput driver : 24.1
[ 5.283] X.Org Server Extension : 10.0
[ 5.283] (++) using VT number 7
[ 5.283] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 5.288] (--) PCI:*(10@0:0:0) 1002:15dd:103c:83e9 rev 211, Mem @ 0xa0000000/268435456, 0xb0000000/2097152, 0xb0600000/524288, I/O @ 0x00002000/256, BIOS @ 0x????????/131072
[ 5.288] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 5.288] (II) LoadModule: "glx"
[ 5.288] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 5.290] (II) Module glx: vendor="X.Org Foundation"
[ 5.290] compiled for 1.20.11, module version = 1.0.0
[ 5.290] ABI class: X.Org Server Extension, version 10.0
[ 5.290] (==) Matched ati as autoconfigured driver 0
[ 5.290] (==) Matched modesetting as autoconfigured driver 1
[ 5.290] (==) Matched fbdev as autoconfigured driver 2
[ 5.290] (==) Matched vesa as autoconfigured driver 3
[ 5.290] (==) Assigned the driver to the xf86ConfigLayout
[ 5.290] (II) LoadModule: "ati"
[ 5.290] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[ 5.290] (II) Module ati: vendor="X.Org Foundation"
[ 5.290] compiled for 1.20.8, module version = 19.1.0
[ 5.290] Module class: X.Org Video Driver
[ 5.290] ABI class: X.Org Video Driver, version 24.1
[ 5.291] (II) LoadModule: "radeon"
[ 5.291] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[ 5.292] (II) Module radeon: vendor="X.Org Foundation"
[ 5.292] compiled for 1.20.8, module version = 19.1.0
[ 5.292] Module class: X.Org Video Driver
[ 5.292] ABI class: X.Org Video Driver, version 24.1
[ 5.292] (II) LoadModule: "modesetting"
[ 5.292] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 5.292] (II) Module modesetting: vendor="X.Org Foundation"
[ 5.292] compiled for 1.20.11, module version = 1.20.11
[ 5.292] (II) LoadModule: "fbdev"
[ 5.292] (WW) Warning, couldn't open module fbdev
[ 5.292] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 5.292] (II) LoadModule: "vesa"
[ 5.292] (WW) Warning, couldn't open module vesa
[ 5.292] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 5.292] (II) RADEON: Driver for ATI/AMD Radeon chipsets:
ATI Radeon Mobility X600 (M24), ATI FireMV 2400,
ATI Radeon Mobility X300 (M24), ATI FireGL M24 GL,
ATI Radeon X600 (RV380), ATI FireGL V3200 (RV380),
ATI Radeon IGP320 (A3), ATI Radeon IGP330/340/350 (A4),
ATI Radeon 9500, ATI Radeon 9600TX, ATI FireGL Z1, ATI Radeon 9800SE,
ATI Radeon 9800, ATI FireGL X2, ATI Radeon 9600, ATI Radeon 9600SE,
ATI Radeon 9600XT, ATI FireGL T2, ATI Radeon 9650, ATI FireGL RV360,
ATI Radeon 7000 IGP (A4+), ATI Radeon 8500 AIW,
ATI Radeon IGP320M (U1), ATI Radeon IGP330M/340M/350M (U2),
ATI Radeon Mobility 7000 IGP, ATI Radeon 9000/PRO, ATI Radeon 9000,
ATI Radeon X800 (R420), ATI Radeon X800PRO (R420),
ATI Radeon X800SE (R420), ATI FireGL X3 (R420),
ATI Radeon Mobility 9800 (M18), ATI Radeon X800 SE (R420),
ATI Radeon X800XT (R420), ATI Radeon X800 VE (R420),
ATI Radeon X850 (R480), ATI Radeon X850 XT (R480),
ATI Radeon X850 SE (R480), ATI Radeon X850 PRO (R480),
ATI Radeon X850 XT PE (R480), ATI Radeon Mobility M7,
ATI Mobility FireGL 7800 M7, ATI Radeon Mobility M6,
ATI FireGL Mobility 9000 (M9), ATI Radeon Mobility 9000 (M9),
ATI Radeon 9700 Pro, ATI Radeon 9700/9500Pro, ATI FireGL X1,
ATI Radeon 9800PRO, ATI Radeon 9800XT,
ATI Radeon Mobility 9600/9700 (M10/M11),
ATI Radeon Mobility 9600 (M10), ATI Radeon Mobility 9600 (M11),
ATI FireGL Mobility T2 (M10), ATI FireGL Mobility T2e (M11),
ATI Radeon, ATI FireGL 8700/8800, ATI Radeon 8500, ATI Radeon 9100,
ATI Radeon 7500, ATI Radeon VE/7000, ATI ES1000,
ATI Radeon Mobility X300 (M22), ATI Radeon Mobility X600 SE (M24C),
ATI FireGL M22 GL, ATI Radeon X800 (R423), ATI Radeon X800PRO (R423),
ATI Radeon X800LE (R423), ATI Radeon X800SE (R423),
ATI Radeon X800 XTP (R430), ATI Radeon X800 XL (R430),
ATI Radeon X800 SE (R430), ATI Radeon X800 (R430),
ATI FireGL V7100 (R423), ATI FireGL V5100 (R423),
ATI FireGL unknown (R423), ATI Mobility FireGL V5000 (M26),
ATI Mobility Radeon X700 XL (M26), ATI Mobility Radeon X700 (M26),
ATI Radeon X550XTX, ATI Radeon 9100 IGP (A5),
ATI Radeon Mobility 9100 IGP (U3), ATI Radeon XPRESS 200,
ATI Radeon XPRESS 200M, ATI Radeon 9250, ATI Radeon 9200,
ATI Radeon 9200SE, ATI FireMV 2200, ATI Radeon X300 (RV370),
ATI Radeon X600 (RV370), ATI Radeon X550 (RV370),
ATI FireGL V3100 (RV370), ATI FireMV 2200 PCIE (RV370),
ATI Radeon Mobility 9200 (M9+), ATI Mobility Radeon X800 XT (M28),
ATI Mobility FireGL V5100 (M28), ATI Mobility Radeon X800 (M28),
ATI Radeon X850, ATI unknown Radeon / FireGL (R480),
ATI Radeon X800XT (R423), ATI FireGL V5000 (RV410),
ATI Radeon X700 XT (RV410), ATI Radeon X700 PRO (RV410),
ATI Radeon X700 SE (RV410), ATI Radeon X700 (RV410),
ATI Radeon X1800, ATI Mobility Radeon X1800 XT,
ATI Mobility Radeon X1800, ATI Mobility FireGL V7200,
ATI FireGL V7200, ATI FireGL V5300, ATI Mobility FireGL V7100,
ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
ATI Mobility Radeon X1400, ATI Radeon X1550 64-bit,
ATI Mobility Radeon X1300, ATI Radeon X1300, ATI FireGL V3300,
ATI FireGL V3350, ATI Mobility Radeon X1450,
ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
ATI FireMV 2250, ATI Radeon X1650, ATI Mobility FireGL V5200,
ATI Mobility Radeon X1600, ATI Radeon X1300 XT/X1600 Pro,
ATI FireGL V3400, ATI Mobility FireGL V5250,
ATI Mobility Radeon X1700, ATI Mobility Radeon X1700 XT,
ATI FireGL V5200, ATI Radeon X2300HD, ATI Mobility Radeon HD 2300,
ATI Radeon X1950, ATI Radeon X1900, ATI AMD Stream Processor,
ATI RV560, ATI Mobility Radeon X1900, ATI Radeon X1950 GT, ATI RV570,
ATI FireGL V7400, ATI Radeon 9100 PRO IGP,
ATI Radeon Mobility 9200 IGP, ATI Radeon X1200, ATI RS740,
ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro,
ATI Radeon HD 2900 GT, ATI FireGL V8650, ATI FireGL V8600,
ATI FireGL V7600, ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
ATI Radeon HD 4850 x2, ATI FirePro V8750 (FireGL),
ATI FirePro V7760 (FireGL), ATI Mobility RADEON HD 4850,
ATI Mobility RADEON HD 4850 X2, ATI FirePro RV770,
AMD FireStream 9270, AMD FireStream 9250, ATI FirePro V8700 (FireGL),
ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
ATI FirePro M7750, ATI M98, ATI Mobility Radeon HD 4650,
ATI Radeon RV730 (AGP), ATI Mobility Radeon HD 4670,
ATI FirePro M5750, ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI RV610,
ATI Radeon HD 2400 XT, ATI Radeon HD 2400 Pro,
ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000, ATI Radeon HD 2350,
ATI Mobility Radeon HD 2400 XT, ATI Mobility Radeon HD 2400,
ATI RADEON E2400, ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
ATI Mobility Radeon HD 3850 X2, ATI Mobility Radeon HD 3870,
ATI Mobility Radeon HD 3870 X2, ATI Radeon HD3870 X2,
ATI FireGL V7700, ATI Radeon HD3690, AMD Firestream 9170,
ATI Radeon HD 4550, ATI Radeon RV710, ATI Radeon HD 4350,
ATI Mobility Radeon 4300 Series, ATI Mobility Radeon 4500 Series,
ATI FirePro RG220, ATI Mobility Radeon 4330, ATI RV630,
ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
ATI FireGL V3600, ATI Radeon HD 2600 LE,
ATI Mobility FireGL Graphics Processor, ATI Radeon HD 3470,
ATI Mobility Radeon HD 3430, ATI Mobility Radeon HD 3400 Series,
ATI Radeon HD 3450, ATI Radeon HD 3430, ATI FirePro V3700,
ATI FireMV 2450, ATI Radeon HD 3600 Series, ATI Radeon HD 3650 AGP,
ATI Radeon HD 3600 PRO, ATI Radeon HD 3600 XT,
ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
ATI Mobility FireGL V5700, ATI Mobility FireGL V5725,
ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
ATI Radeon HD 3300 Graphics, ATI Radeon 3000 Graphics, SUMO, SUMO2,
ATI Radeon HD 4200, ATI Radeon 4100, ATI Mobility Radeon HD 4200,
ATI Mobility Radeon 4100, ATI Radeon HD 4290, ATI Radeon HD 4250,
AMD Radeon HD 6310 Graphics, AMD Radeon HD 6250 Graphics,
AMD Radeon HD 6300 Series Graphics,
AMD Radeon HD 6200 Series Graphics, PALM, CYPRESS,
ATI FirePro (FireGL) Graphics Adapter, AMD Firestream 9370,
AMD Firestream 9350, ATI Radeon HD 5800 Series,
ATI Radeon HD 5900 Series, ATI Mobility Radeon HD 5800 Series,
ATI Radeon HD 5700 Series, ATI Radeon HD 6700 Series,
ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
ATI Radeon HD 5670, ATI Radeon HD 5570, ATI Radeon HD 5500 Series,
REDWOOD, ATI Mobility Radeon Graphics, CEDAR, ATI FirePro 2270,
ATI Radeon HD 5450, CAYMAN, AMD Radeon HD 6900 Series,
AMD Radeon HD 6900M Series, Mobility Radeon HD 6000 Series, BARTS,
AMD Radeon HD 6800 Series, AMD Radeon HD 6700 Series, TURKS, CAICOS,
ARUBA, TAHITI, PITCAIRN, VERDE, OLAND, HAINAN, BONAIRE, KABINI,
MULLINS, KAVERI, HAWAII
[ 5.298] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 5.298] (EE) open /dev/dri/card0: No such file or directory
[ 5.299] (WW) Falling back to old probe method for modesetting
[ 5.299] (EE) open /dev/dri/card0: No such file or directory
[ 5.299] (EE) Screen 0 deleted because of no matching config section.
[ 5.299] (II) UnloadModule: "modesetting"
[ 5.299] (EE) Device(s) detected, but none match those in the config file.
[ 5.299] (EE)
Fatal server error:
[ 5.299] (EE) no screens found(EE)
[ 5.299] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 5.299] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 5.299] (EE)
[ 5.301] (EE) Server terminated with error (1). Closing log file.
2. for the lxqt live system.
2.1 /home/username/.xsession.errors
warning: database file for 'core' does not exist (use '-Sy' to download)
warning: database file for 'extra' does not exist (use '-Sy' to download)
warning: database file for 'community' does not exist (use '-Sy' to download)
warning: database file for 'multilib' does not exist (use '-Sy' to download)
blueman-applet 15.24.33 WARNING PluginManager:148 __load_plugin: Not loading DhcpClient because its conflict has higher priority
blueman-applet 15.24.33 WARNING PluginManager:148 __load_plugin: Not loading PPPSupport because its conflict has higher priority
[Notice] Started
(pamac-tray:1804): Gdk-CRITICAL **: 15:24:34.566: gdk_window_thaw_toplevel_updates: assertion 'window->update_and_descendants_freeze_count > 0' failed
** Message: 13:25:03.796: updates_checker.vala:64: check updates
** Message: 13:25:36.585: updates_checker.vala:94: 365 updates found
polkit-agent-helper-1: pam_authenticate failed: Permission denied
(process:1794): GLib-GObject-CRITICAL **: 13:30:21.237: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
(process:1794): GLib-GObject-CRITICAL **: 13:30:35.592: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
2.2 /home/username/.local/share/xorg/Xorg.1.log
Does not exist. Instead again /var/log/Xorg.1.log:
[ 19.531]
X.Org X Server 1.20.10
[ 19.531] Build Operating System: Linux Manjaro Linux
[ 19.531] Current Operating System: Linux manjaro-lxqt 5.9.16-1-MANJARO #1 SMP PREEMPT Mon Dec 21 22:00:46 UTC 2020 x86_64
[ 19.531] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=de tz=UTC misobasedir=manjaro misolabel=MANJARO_LXQT_2021 quiet systemd.show_status=1 driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
[ 19.531] Build Date: 16 December 2020 10:33:32PM
[ 19.531]
[ 19.531] Current version of pixman: 0.40.0
[ 19.531] Before reporting problems, check http://wiki.x.org
[ 19.531] Markers: (--) probed, (**) from config file, (==) default setting,
[ 19.531] (==) Log file: "/var/log/Xorg.0.log", Time: Sat May 1 15:24:29 2021
[ 19.533] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 19.533] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 19.536] (==) No Layout section. Using the first Screen section.
[ 19.536] (==) No screen section available. Using defaults.
[ 19.536] (**) |-->Screen "Default Screen Section" (0)
[ 19.536] (**) | |-->Monitor "<default monitor>"
[ 19.536] (==) No monitor specified for screen "Default Screen Section".
[ 19.536] (==) Automatically adding devices
[ 19.536] (==) Automatically enabling devices
[ 19.536] (==) Automatically adding GPU devices
[ 19.536] (==) Automatically binding GPU devices
[ 19.536] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 19.537] (WW) The directory "/usr/share/fonts/misc" does not exist.
[ 19.537] Entry deleted from font path.
[ 19.537] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[ 19.537] (Run 'mkfontdir' on "/usr/share/fonts/TTF").
[ 19.537] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 19.537] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 19.537] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 19.537] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 19.537] (==) FontPath set to:
[ 19.537] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 19.537] (II) The server relies on udev to provide the list of input devices.
[ 19.537] (II) Module ABI versions:
[ 19.537] X.Org ANSI C Emulation: 0.4
[ 19.537] X.Org Video Driver: 24.1
[ 19.537] X.Org XInput driver : 24.1
[ 19.537] X.Org Server Extension : 10.0
[ 19.538] (++) using VT number 7
[ 19.538] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 19.539] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 19.548] (--) PCI:*(10@0:0:0) 1002:15dd:103c:83e9 rev 211, Mem @ 0xa0000000/268435456, 0xb0000000/2097152, 0xb0600000/524288, I/O @ 0x00002000/256, BIOS @ 0x????????/131072
[ 19.549] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 19.549] (II) LoadModule: "glx"
[ 19.549] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 19.556] (II) Module glx: vendor="X.Org Foundation"
[ 19.556] compiled for 1.20.10, module version = 1.0.0
[ 19.556] ABI class: X.Org Server Extension, version 10.0
[ 19.556] (II) Applying OutputClass "AMDgpu" to /dev/dri/card0
[ 19.556] loading driver: amdgpu
[ 19.556] (==) Matched amdgpu as autoconfigured driver 0
[ 19.556] (==) Matched ati as autoconfigured driver 1
[ 19.556] (==) Matched modesetting as autoconfigured driver 2
[ 19.556] (==) Matched fbdev as autoconfigured driver 3
[ 19.556] (==) Matched vesa as autoconfigured driver 4
[ 19.556] (==) Assigned the driver to the xf86ConfigLayout
[ 19.556] (II) LoadModule: "amdgpu"
[ 19.556] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[ 19.557] (II) Module amdgpu: vendor="X.Org Foundation"
[ 19.557] compiled for 1.20.8, module version = 19.1.0
[ 19.557] Module class: X.Org Video Driver
[ 19.557] ABI class: X.Org Video Driver, version 24.1
[ 19.557] (II) LoadModule: "ati"
[ 19.557] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[ 19.557] (II) Module ati: vendor="X.Org Foundation"
[ 19.562] (II) LoadModule: "modesetting"
[ 19.562] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 19.563] (II) Module modesetting: vendor="X.Org Foundation"
[ 19.563] compiled for 1.20.10, module version = 1.20.10
[ 19.563] Module class: X.Org Video Driver
[ 19.563] ABI class: X.Org Video Driver, version 24.1
[ 19.563] (II) LoadModule: "fbdev"
[ 19.563] (WW) Warning, couldn't open module fbdev
[ 19.563] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 19.563] (II) LoadModule: "vesa"
[ 19.564] (WW) Warning, couldn't open module vesa
[ 19.564] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 19.564] (II) AMDGPU: Driver for AMD Radeon:
All GPUs supported by the amdgpu kernel driver
[ 19.564] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 19.609] (II) AMDGPU(0): [KMS] Kernel modesetting enabled.
[ 19.610] (WW) Falling back to old probe method for modesetting
[ 19.610] (II) AMDGPU(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 19.610] (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[ 19.610] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[ 19.610] (==) AMDGPU(0): Default visual is TrueColor
[ 19.610] (==) AMDGPU(0): RGB weight 888
[ 19.610] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[ 19.610] (--) AMDGPU(0): Chipset: "AMD Radeon(TM) Vega 11 Graphics" (ChipID = 0x15dd)
[ 19.610] (II) Loading sub module "fb"
[ 19.610] (II) LoadModule: "fb"
[ 19.610] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 19.611] (II) Module fb: vendor="X.Org Foundation"
[ 19.611] compiled for 1.20.10, module version = 1.0.0
[ 19.611] ABI class: X.Org ANSI C Emulation, version 0.4
[ 19.611] (II) Loading sub module "dri2"
[ 19.611] (II) LoadModule: "dri2"
[ 19.611] (II) Module "dri2" already built-in
[ 20.160] (II) Loading sub module "glamoregl"
[ 20.160] (II) LoadModule: "glamoregl"
[ 20.160] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 20.164] (II) Module glamoregl: vendor="X.Org Foundation"
[ 20.164] compiled for 1.20.10, module version = 1.0.1
[ 20.164] ABI class: X.Org ANSI C Emulation, version 0.4
[ 20.186] (II) AMDGPU(0): glamor X acceleration enabled on AMD Radeon(TM) Vega 11 Graphics (RAVEN, DRM 3.39.0, 5.9.16-1-MANJARO, LLVM 11.0.1)
[ 20.186] (II) AMDGPU(0): glamor detected, initialising EGL layer.
[ 20.186] (==) AMDGPU(0): TearFree property default: auto
[ 20.186] (==) AMDGPU(0): VariableRefresh: disabled
[ 20.186] (II) AMDGPU(0): KMS Pageflipping: enabled
[ 20.186] (II) AMDGPU(0): Output DisplayPort-0 has no monitor section
[ 20.187] (II) AMDGPU(0): Output DisplayPort-1 has no monitor section
[ 20.187] (II) AMDGPU(0): Output DisplayPort-2 has no monitor section
[ 20.188] (II) AMDGPU(0): Output DisplayPort-3 has no monitor section
[ 20.212] (II) AMDGPU(0): EDID for output DisplayPort-0
[ 20.212] (II) AMDGPU(0): EDID for output DisplayPort-1
[ 20.212] (II) AMDGPU(0): Manufacturer: HSP Model: 0 Serial#: 0
[ 20.212] (II) AMDGPU(0): Year: 2020 Week: 23
[ 20.212] (II) AMDGPU(0): EDID Version: 1.4
[ 20.212] (II) AMDGPU(0): Digital Display Input
[ 20.213] (II) AMDGPU(0): 10 bits per channel
[ 20.213] (II) AMDGPU(0): Digital interface is DisplayPort
[ 20.213] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 62 vert.: 34
[ 20.213] (II) AMDGPU(0): Gamma: 2.20
[ 20.213] (II) AMDGPU(0): DPMS capabilities: StandBy Suspend Off
[ 20.213] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4 YCrCb 4:2:2
[ 20.213] (II) AMDGPU(0): First detailed timing is preferred mode
[ 20.213] (II) AMDGPU(0): Preferred mode is native pixel format and refresh rate
[ 20.213] (II) AMDGPU(0): redX: 0.633 redY: 0.340 greenX: 0.311 greenY: 0.633
[ 20.213] (II) AMDGPU(0): blueX: 0.158 blueY: 0.061 whiteX: 0.313 whiteY: 0.329
[ 20.213] (II) AMDGPU(0): Supported established timings:
[ 20.213] (II) AMDGPU(0): 720x400@70Hz
[ 20.213] (II) AMDGPU(0): 640x480@60Hz
[ 20.213] (II) AMDGPU(0): 640x480@67Hz
[ 20.213] (II) AMDGPU(0): 640x480@72Hz
[ 20.213] (II) AMDGPU(0): 640x480@75Hz
[ 20.213] (II) AMDGPU(0): 800x600@56Hz
[ 20.213] (II) AMDGPU(0): 800x600@60Hz
[ 20.213] (II) AMDGPU(0): 800x600@72Hz
[ 20.213] (II) AMDGPU(0): 800x600@75Hz
[ 20.213] (II) AMDGPU(0): 832x624@75Hz
[ 20.213] (II) AMDGPU(0): 1024x768@60Hz
[ 20.213] (II) AMDGPU(0): 1024x768@70Hz
[ 20.213] (II) AMDGPU(0): 1024x768@75Hz
[ 20.213] (II) AMDGPU(0): 1280x1024@75Hz
[ 20.213] (II) AMDGPU(0): 1152x864@75Hz
[ 20.213] (II) AMDGPU(0): Manufacturer's mask: 0
[ 20.213] (II) AMDGPU(0): Supported standard timings:
[ 20.213] (II) AMDGPU(0): #0: hsize: 1920 vsize 1440 refresh: 60 vid: 16593
[ 20.213] (II) AMDGPU(0): #1: hsize: 1920 vsize 1200 refresh: 60 vid: 209
[ 20.213] (II) AMDGPU(0): #2: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 20.213] (II) AMDGPU(0): #3: hsize: 1600 vsize 900 refresh: 60 vid: 49321
[ 20.213] (II) AMDGPU(0): #4: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 20.213] (II) AMDGPU(0): #5: hsize: 1280 vsize 800 refresh: 60 vid: 129
[ 20.213] (II) AMDGPU(0): #6: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 20.213] (II) AMDGPU(0): #7: hsize: 1024 vsize 768 refresh: 60 vid: 16481
[ 20.213] (II) AMDGPU(0): Supported detailed timing:
[ 20.213] (II) AMDGPU(0): clock: 533.2 MHz Image Size: 621 x 341 mm
[ 20.213] (II) AMDGPU(0): h_active: 3840 h_sync: 3888 h_sync_end 3920 h_blank_end 4000 h_border: 0
[ 20.213] (II) AMDGPU(0): v_active: 2160 v_sync: 2163 v_sync_end 2168 v_blanking: 2222 v_border: 0
[ 20.213] (II) AMDGPU(0): Serial No:
[ 20.213] (II) AMDGPU(0): Ranges: V min: 56 V max: 75 Hz, H min: 30 H max: 135 kHz, PixClock max 605 MHz
[ 20.213] (II) AMDGPU(0): Monitor name: HC281UPB
[ 20.213] (II) AMDGPU(0): clock: 594.0 MHz Image Size: 621 x 341 mm
[ 20.213] (II) AMDGPU(0): h_active: 3840 h_sync: 4016 h_sync_end 4104 h_blank_end 4400 h_border: 0
[ 20.213] (II) AMDGPU(0): v_active: 2160 v_sync: 2168 v_sync_end 2178 v_blanking: 2250 v_border: 0
[ 20.213] (II) AMDGPU(0): clock: 297.0 MHz Image Size: 621 x 341 mm
[ 20.213] (II) AMDGPU(0): clock: 241.5 MHz Image Size: 621 x 341 mm
[ 20.213] (II) AMDGPU(0): h_active: 2560 h_sync: 2608 h_sync_end 2640 h_blank_end 2720 h_border: 0
[ 20.213] (II) AMDGPU(0): v_active: 1440 v_sync: 1442 v_sync_end 1447 v_blanking: 1481 v_border: 0
[ 20.213] (II) AMDGPU(0): clock: 148.5 MHz Image Size: 621 x 341 mm
[ 20.213] (II) AMDGPU(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 20.213] (II) AMDGPU(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 20.213] (II) AMDGPU(0): clock: 74.2 MHz Image Size: 621 x 341 mm
[ 20.213] (II) AMDGPU(0): h_active: 1280 h_sync: 1390 h_sync_end 1430 h_blank_end 1650 h_border: 0
[ 20.213] (II) AMDGPU(0): v_active: 720 v_sync: 725 v_sync_end 730 v_blanking: 750 v_border: 0
[ 20.213] (II) AMDGPU(0): Number of EDID sections to follow: 1
[ 20.213] (II) AMDGPU(0): EDID (in hex):
[ 20.213] (II) AMDGPU(0): 00ffffffffffff002270000000000000
[ 20.213] (II) AMDGPU(0): 171e0104b53e2278fa08a5a2574fa228
[ 20.213] (II) AMDGPU(0): 0f5054bfef80d140d100d1c0a9c08180
[ 20.213] (II) AMDGPU(0): 810081c061404dd000a0f0703e803020
[ 20.213] (II) AMDGPU(0): 35006d552100001e000000ff000a2020
[ 20.213] (II) AMDGPU(0): 20202020202020202020000000fd0038
[ 20.213] (II) AMDGPU(0): 4b1e873c000a202020202020000000fc
[ 20.213] (II) AMDGPU(0): 0048433238315550420a20202020012a
[ 20.213] (II) AMDGPU(0): 020319f14c10605f5e5d01851f041312
[ 20.213] (II) AMDGPU(0): 0323097f078301000008e80030f2705a
[ 20.213] (II) AMDGPU(0): 80b0588a006d552100001e04740030f2
[ 20.213] (II) AMDGPU(0): 705a80b0588a006d552100001e565e00
[ 20.213] (II) AMDGPU(0): a0a0a02950302025006d552100001a02
[ 20.213] (II) AMDGPU(0): 3a801871382d40582c45006d55210000
[ 20.213] (II) AMDGPU(0): 1e011d007251d01e206e2855006d5521
[ 20.213] (II) AMDGPU(0): 00001e000000000000000000000000a0
[ 20.213] (II) AMDGPU(0): Printing probed modes for output DisplayPort-1
[ 20.213] (II) AMDGPU(0): Modeline "3840x2160"x60.0 533.25 3840 3888 3920 4000 2160 2163 2168 2222 +hsync +vsync (133.3 kHz eP)
[ 20.213] (II) AMDGPU(0): Modeline "3840x2160"x60.0 594.00 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (135.0 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "3840x2160"x50.0 594.00 3840 4896 4984 5280 2160 2168 2178 2250 +hsync +vsync (112.5 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "3840x2160"x59.9 593.41 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (134.9 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "3840x2160"x30.0 297.00 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (67.5 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "3840x2160"x25.0 297.00 3840 4896 4984 5280 2160 2168 2178 2250 +hsync +vsync (56.2 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "3840x2160"x24.0 297.00 3840 5116 5204 5500 2160 2168 2178 2250 +hsync +vsync (54.0 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "3840x2160"x30.0 296.70 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (67.4 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "3840x2160"x24.0 296.70 3840 5116 5204 5500 2160 2168 2178 2250 +hsync +vsync (53.9 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "2560x1440"x60.0 241.50 2560 2608 2640 2720 1440 1442 1447 1481 +hsync -vsync (88.8 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "1920x1440"x60.0 234.00 1920 2048 2256 2600 1440 1441 1444 1500 -hsync +vsync (90.0 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "1920x1200"x59.9 193.25 1920 2056 2256 2592 1200 1203 1209 1245 -hsync +vsync (74.6 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "1600x1200"x60.0 533.25 1600 3888 3920 4000 1200 2163 2168 2222 +hsync +vsync (133.3 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "1680x1050"x60.0 533.25 1680 3888 3920 4000 1050 2163 2168 2222 +hsync +vsync (133.3 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "1600x900"x60.0 108.00 1600 1624 1704 1800 900 901 904 1000 +hsync +vsync (60.0 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "1440x900"x60.0 533.25 1440 3888 3920 4000 900 2163 2168 2222 +hsync +vsync (133.3 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 20.213] (II) AMDGPU(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 20.213] (II) AMDGPU(0): EDID for output DisplayPort-2
[ 20.214] (II) AMDGPU(0): EDID for output DisplayPort-3
[ 20.214] (II) AMDGPU(0): Manufacturer: HSP Model: 0 Serial#: 0
[ 20.214] (II) AMDGPU(0): Year: 2020 Week: 23
[ 20.214] (II) AMDGPU(0): EDID Version: 1.4
[ 20.214] (II) AMDGPU(0): Digital Display Input
[ 20.214] (II) AMDGPU(0): 10 bits per channel
[ 20.214] (II) AMDGPU(0): Digital interface is DisplayPort
[ 20.214] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 62 vert.: 34
[ 20.214] (II) AMDGPU(0): Gamma: 2.20
[ 20.214] (II) AMDGPU(0): DPMS capabilities: StandBy Suspend Off
[ 20.214] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4 YCrCb 4:2:2
[ 20.214] (II) AMDGPU(0): First detailed timing is preferred mode
[ 20.214] (II) AMDGPU(0): Preferred mode is native pixel format and refresh rate
[ 20.214] (II) AMDGPU(0): redX: 0.633 redY: 0.340 greenX: 0.311 greenY: 0.633
[ 20.214] (II) AMDGPU(0): blueX: 0.158 blueY: 0.061 whiteX: 0.313 whiteY: 0.329
[ 20.214] (II) AMDGPU(0): Supported established timings:
[ 20.214] (II) AMDGPU(0): 720x400@70Hz
[ 20.214] (II) AMDGPU(0): 640x480@60Hz
[ 20.214] (II) AMDGPU(0): 640x480@67Hz
[ 20.214] (II) AMDGPU(0): 640x480@72Hz
[ 20.214] (II) AMDGPU(0): 640x480@75Hz
[ 20.214] (II) AMDGPU(0): 800x600@56Hz
[ 20.214] (II) AMDGPU(0): 800x600@60Hz
[ 20.214] (II) AMDGPU(0): 800x600@72Hz
[ 20.214] (II) AMDGPU(0): 800x600@75Hz
[ 20.214] (II) AMDGPU(0): 832x624@75Hz
[ 20.214] (II) AMDGPU(0): 1024x768@60Hz
[ 20.214] (II) AMDGPU(0): 1024x768@70Hz
[ 20.214] (II) AMDGPU(0): 1024x768@75Hz
[ 20.214] (II) AMDGPU(0): 1280x1024@75Hz
[ 20.214] (II) AMDGPU(0): 1152x864@75Hz
[ 20.214] (II) AMDGPU(0): Manufacturer's mask: 0
[ 20.214] (II) AMDGPU(0): Supported standard timings:
[ 20.214] (II) AMDGPU(0): #0: hsize: 1920 vsize 1440 refresh: 60 vid: 16593
[ 20.214] (II) AMDGPU(0): #1: hsize: 1920 vsize 1200 refresh: 60 vid: 209
[ 20.214] (II) AMDGPU(0): #2: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 20.214] (II) AMDGPU(0): #3: hsize: 1600 vsize 900 refresh: 60 vid: 49321
[ 20.214] (II) AMDGPU(0): #4: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 20.214] (II) AMDGPU(0): #5: hsize: 1280 vsize 800 refresh: 60 vid: 129
[ 20.214] (II) AMDGPU(0): #6: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 20.214] (II) AMDGPU(0): #7: hsize: 1024 vsize 768 refresh: 60 vid: 16481
[ 20.214] (II) AMDGPU(0): Supported detailed timing:
[ 20.214] (II) AMDGPU(0): clock: 533.2 MHz Image Size: 621 x 341 mm
[ 20.214] (II) AMDGPU(0): h_active: 3840 h_sync: 3888 h_sync_end 3920 h_blank_end 4000 h_border: 0
[ 20.214] (II) AMDGPU(0): v_active: 2160 v_sync: 2163 v_sync_end 2168 v_blanking: 2222 v_border: 0
[ 20.214] (II) AMDGPU(0): Serial No:
[ 20.214] (II) AMDGPU(0): Ranges: V min: 56 V max: 75 Hz, H min: 30 H max: 135 kHz, PixClock max 605 MHz
[ 20.214] (II) AMDGPU(0): Monitor name: HC281UPB
[ 20.214] (II) AMDGPU(0): clock: 594.0 MHz Image Size: 621 x 341 mm
[ 20.214] (II) AMDGPU(0): h_active: 3840 h_sync: 4016 h_sync_end 4104 h_blank_end 4400 h_border: 0
[ 20.214] (II) AMDGPU(0): v_active: 2160 v_sync: 2168 v_sync_end 2178 v_blanking: 2250 v_border: 0
[ 20.214] (II) AMDGPU(0): clock: 297.0 MHz Image Size: 621 x 341 mm
[ 20.214] (II) AMDGPU(0): clock: 241.5 MHz Image Size: 621 x 341 mm
[ 20.214] (II) AMDGPU(0): h_active: 2560 h_sync: 2608 h_sync_end 2640 h_blank_end 2720 h_border: 0
[ 20.214] (II) AMDGPU(0): v_active: 1440 v_sync: 1442 v_sync_end 1447 v_blanking: 1481 v_border: 0
[ 20.214] (II) AMDGPU(0): clock: 148.5 MHz Image Size: 621 x 341 mm
[ 20.214] (II) AMDGPU(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 20.214] (II) AMDGPU(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 20.214] (II) AMDGPU(0): clock: 74.2 MHz Image Size: 621 x 341 mm
[ 20.214] (II) AMDGPU(0): h_active: 1280 h_sync: 1390 h_sync_end 1430 h_blank_end 1650 h_border: 0
[ 20.214] (II) AMDGPU(0): v_active: 720 v_sync: 725 v_sync_end 730 v_blanking: 750 v_border: 0
[ 20.214] (II) AMDGPU(0): Number of EDID sections to follow: 1
[ 20.214] (II) AMDGPU(0): EDID (in hex):
[ 20.214] (II) AMDGPU(0): 00ffffffffffff002270000000000000
[ 20.214] (II) AMDGPU(0): 171e0104b53e2278fa08a5a2574fa228
[ 20.214] (II) AMDGPU(0): 0f5054bfef80d140d100d1c0a9c08180
[ 20.214] (II) AMDGPU(0): 810081c061404dd000a0f0703e803020
[ 20.214] (II) AMDGPU(0): 35006d552100001e000000ff000a2020
[ 20.214] (II) AMDGPU(0): 20202020202020202020000000fd0038
[ 20.214] (II) AMDGPU(0): 4b1e873c000a202020202020000000fc
[ 20.214] (II) AMDGPU(0): 0048433238315550420a20202020012a
[ 20.214] (II) AMDGPU(0): 020319f14c10605f5e5d01851f041312
[ 20.214] (II) AMDGPU(0): 0323097f078301000008e80030f2705a
[ 20.214] (II) AMDGPU(0): 80b0588a006d552100001e04740030f2
[ 20.214] (II) AMDGPU(0): 705a80b0588a006d552100001e565e00
[ 20.214] (II) AMDGPU(0): a0a0a02950302025006d552100001a02
[ 20.214] (II) AMDGPU(0): 3a801871382d40582c45006d55210000
[ 20.214] (II) AMDGPU(0): 1e011d007251d01e206e2855006d5521
[ 20.214] (II) AMDGPU(0): 00001e000000000000000000000000a0
[ 20.214] (II) AMDGPU(0): Printing probed modes for output DisplayPort-3
[ 20.214] (II) AMDGPU(0): Modeline "3840x2160"x60.0 533.25 3840 3888 3920 4000 2160 2163 2168 2222 +hsync +vsync (133.3 kHz eP)
[ 20.214] (II) AMDGPU(0): Modeline "3840x2160"x60.0 594.00 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (135.0 kHz e)
[ 20.214] (II) AMDGPU(0): Modeline "3840x2160"x50.0 594.00 3840 4896 4984 5280 2160 2168 2178 2250 +hsync +vsync (112.5 kHz e)
[ 20.214] (II) AMDGPU(0): Modeline "3840x2160"x59.9 593.41 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (134.9 kHz e)
[ 20.214] (II) AMDGPU(0): Modeline "3840x2160"x30.0 297.00 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (67.5 kHz e)
[ 20.214] (II) AMDGPU(0): Modeline "3840x2160"x25.0 297.00 3840 4896 4984 5280 2160 2168 2178 2250 +hsync +vsync (56.2 kHz e)
[ 20.214] (II) AMDGPU(0): Modeline "3840x2160"x24.0 297.00 3840 5116 5204 5500 2160 2168 2178 2250 +hsync +vsync (54.0 kHz e)
[ 20.214] (II) AMDGPU(0): Modeline "3840x2160"x30.0 296.70 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (67.4 kHz e)
[ 20.214] (II) AMDGPU(0): Modeline "3840x2160"x24.0 296.70 3840 5116 5204 5500 2160 2168 2178 2250 +hsync +vsync (53.9 kHz e)
[ 20.214] (II) AMDGPU(0): Modeline "2560x1440"x60.0 241.50 2560 2608 2640 2720 1440 1442 1447 1481 +hsync -vsync (88.8 kHz e)
[ 20.214] (II) AMDGPU(0): Modeline "1920x1440"x60.0 234.00 1920 2048 2256 2600 1440 1441 1444 1500 -hsync +vsync (90.0 kHz e)
[ 20.214] (II) AMDGPU(0): Modeline "1920x1200"x59.9 193.25 1920 2056 2256 2592 1200 1203 1209 1245 -hsync +vsync (74.6 kHz e)
[ 20.214] (II) AMDGPU(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 20.214] (II) AMDGPU(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 20.214] (II) AMDGPU(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 20.214] (II) AMDGPU(0): Modeline "1600x1200"x60.0 533.25 1600 3888 3920 4000 1200 2163 2168 2222 +hsync +vsync (133.3 kHz e)
[ 20.214] (II) AMDGPU(0): Modeline "1680x1050"x60.0 533.25 1680 3888 3920 4000 1050 2163 2168 2222 +hsync +vsync (133.3 kHz e)
[ 20.214] (II) AMDGPU(0): Modeline "1600x900"x60.0 108.00 1600 1624 1704 1800 900 901 904 1000 +hsync +vsync (60.0 kHz e)
[ 20.214] (II) AMDGPU(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 20.214] (II) AMDGPU(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 20.214] (II) AMDGPU(0): Modeline "1440x900"x60.0 533.25 1440 3888 3920 4000 900 2163 2168 2222 +hsync +vsync (133.3 kHz e)
[ 20.214] (II) AMDGPU(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
[ 20.214] (II) AMDGPU(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 20.214] (II) AMDGPU(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 20.214] (II) AMDGPU(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 20.214] (II) AMDGPU(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 20.215] (II) AMDGPU(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 20.215] (II) AMDGPU(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 20.215] (II) AMDGPU(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 20.215] (II) AMDGPU(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 20.215] (II) AMDGPU(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 20.215] (II) AMDGPU(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 20.215] (II) AMDGPU(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 20.215] (II) AMDGPU(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 20.215] (II) AMDGPU(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 20.215] (II) AMDGPU(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 20.215] (II) AMDGPU(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 20.215] (II) AMDGPU(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 20.215] (II) AMDGPU(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 20.215] (II) AMDGPU(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 20.215] (II) AMDGPU(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 20.215] (II) AMDGPU(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 20.215] (II) AMDGPU(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 20.215] (II) AMDGPU(0): Output DisplayPort-0 disconnected
[ 20.215] (II) AMDGPU(0): Output DisplayPort-1 connected
[ 20.215] (II) AMDGPU(0): Output DisplayPort-2 disconnected
[ 20.215] (II) AMDGPU(0): Output DisplayPort-3 connected
[ 20.215] (II) AMDGPU(0): Using spanning desktop for initial modes
[ 20.215] (II) AMDGPU(0): Output DisplayPort-1 using initial mode 3840x2160 +0+0
[ 20.215] (II) AMDGPU(0): Output DisplayPort-3 using initial mode 3840x2160 +3840+0
[ 20.215] (II) AMDGPU(0): mem size init: gart size :bf6d1000 vram size: s:3cc50000 visible:3cc50000
[ 20.215] (==) AMDGPU(0): DPI set to (96, 96)
[ 20.215] (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
[ 20.215] (II) Loading sub module "ramdac"
[ 20.215] (II) LoadModule: "ramdac"
[ 20.215] (II) Module "ramdac" already built-in
[ 20.215] (II) UnloadModule: "modesetting"
[ 20.215] (II) Unloading modesetting
[ 20.215] (II) AMDGPU(0): [DRI2] Setup complete
[ 20.215] (II) AMDGPU(0): [DRI2] DRI driver: radeonsi
[ 20.215] (II) AMDGPU(0): [DRI2] VDPAU driver: radeonsi
[ 20.373] (II) AMDGPU(0): Front buffer pitch: 30720 bytes
[ 20.376] (II) AMDGPU(0): SYNC extension fences enabled
[ 20.376] (II) AMDGPU(0): Present extension enabled
[ 20.376] (==) AMDGPU(0): DRI3 enabled
[ 20.376] (==) AMDGPU(0): Backing store enabled
[ 20.376] (II) AMDGPU(0): Direct rendering enabled
[ 20.453] (II) AMDGPU(0): Use GLAMOR acceleration.
[ 20.453] (II) AMDGPU(0): Acceleration enabled
[ 20.453] (==) AMDGPU(0): DPMS enabled
[ 20.453] (==) AMDGPU(0): Silken mouse disabled
[ 20.453] (II) AMDGPU(0): Set up textured video (glamor)
[ 20.479] (II) Initializing extension Generic Event Extension
[ 20.479] (II) Initializing extension SHAPE
[ 20.479] (II) Initializing extension MIT-SHM
[ 20.479] (II) Initializing extension XInputExtension
[ 20.479] (II) Initializing extension XTEST
[ 20.479] (II) Initializing extension BIG-REQUESTS
[ 20.480] (II) Initializing extension SYNC
[ 20.480] (II) Initializing extension XKEYBOARD
[ 20.480] (II) Initializing extension XC-MISC
[ 20.480] (II) Initializing extension SECURITY
[ 20.480] (II) Initializing extension XFIXES
[ 20.480] (II) Initializing extension RENDER
[ 20.480] (II) Initializing extension RANDR
[ 20.480] (II) Initializing extension COMPOSITE
[ 20.481] (II) Initializing extension DAMAGE
[ 20.481] (II) Initializing extension MIT-SCREEN-SAVER
[ 20.481] (II) Initializing extension DOUBLE-BUFFER
[ 20.481] (II) Initializing extension RECORD
[ 20.481] (II) Initializing extension DPMS
[ 20.481] (II) Initializing extension Present
[ 20.481] (II) Initializing extension DRI3
[ 20.481] (II) Initializing extension X-Resource
[ 20.481] (II) Initializing extension XVideo
[ 20.482] (II) Initializing extension XVideo-MotionCompensation
[ 20.482] (II) Initializing extension GLX
[ 20.486] (II) AIGLX: Loaded and initialized radeonsi
[ 20.486] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 20.486] (II) Initializing extension XFree86-VidModeExtension
[ 20.486] (II) Initializing extension XFree86-DGA
[ 20.486] (II) Initializing extension XFree86-DRI
[ 20.486] (II) Initializing extension DRI2
[ 20.487] (II) AMDGPU(0): Setting screen physical size to 2032 x 571
[ 20.628] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 20.628] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 20.628] (**) Power Button: Applying InputClass "system-keyboard"
[ 20.628] (II) LoadModule: "libinput"
[ 20.628] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 20.632] (II) Module libinput: vendor="X.Org Foundation"
[ 20.632] compiled for 1.20.8, module version = 0.30.0
[ 20.632] Module class: X.Org XInput Driver
[ 20.632] ABI class: X.Org XInput driver, version 24.1
[ 20.632] (II) Using input driver 'libinput' for 'Power Button'
[ 20.632] (**) Power Button: always reports core events
[ 20.632] (**) Option "Device" "/dev/input/event1"
[ 20.632] (**) Option "_source" "server/udev"
[ 20.643] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 20.643] (II) event1 - Power Button: device is a keyboard
[ 20.643] (II) event1 - Power Button: device removed
[ 20.670] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 20.670] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 20.670] (**) Option "xkb_model" "pc105"
[ 20.670] (**) Option "xkb_layout" "de"
[ 20.670] (WW) Option "xkb_variant" requires a string value
[ 20.670] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 20.695] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 20.695] (II) event1 - Power Button: device is a keyboard
[ 20.696] (II) config/udev: Adding input device Video Bus (/dev/input/event2)
[ 20.696] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 20.696] (**) Video Bus: Applying InputClass "system-keyboard"
[ 20.696] (II) Using input driver 'libinput' for 'Video Bus'
[ 20.696] (**) Video Bus: always reports core events
[ 20.696] (**) Option "Device" "/dev/input/event2"
[ 20.696] (**) Option "_source" "server/udev"
[ 20.698] (II) event2 - Video Bus: is tagged by udev as: Keyboard
[ 20.698] (II) event2 - Video Bus: device is a keyboard
[ 20.698] (II) event2 - Video Bus: device removed
[ 20.777] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:2c/LNXVIDEO:00/input/input2/event2"
[ 20.777] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 20.777] (**) Option "xkb_model" "pc105"
[ 20.777] (**) Option "xkb_layout" "de"
[ 20.777] (WW) Option "xkb_variant" requires a string value
[ 20.777] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 20.779] (II) event2 - Video Bus: is tagged by udev as: Keyboard
[ 20.779] (II) event2 - Video Bus: device is a keyboard
[ 20.780] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 20.780] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 20.780] (**) Power Button: Applying InputClass "system-keyboard"
[ 20.780] (II) Using input driver 'libinput' for 'Power Button'
[ 20.780] (**) Power Button: always reports core events
[ 20.780] (**) Option "Device" "/dev/input/event0"
[ 20.780] (**) Option "_source" "server/udev"
[ 20.781] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 20.781] (II) event0 - Power Button: device is a keyboard
[ 20.781] (II) event0 - Power Button: device removed
[ 20.817] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 20.817] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[ 20.817] (**) Option "xkb_model" "pc105"
[ 20.817] (**) Option "xkb_layout" "de"
[ 20.817] (WW) Option "xkb_variant" requires a string value
[ 20.817] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 20.819] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 20.819] (II) event0 - Power Button: device is a keyboard
[ 20.820] (II) config/udev: Adding input device PixArt HP USB Optical Mouse (/dev/input/event5)
[ 20.820] (**) PixArt HP USB Optical Mouse: Applying InputClass "libinput pointer catchall"
[ 20.820] (II) Using input driver 'libinput' for 'PixArt HP USB Optical Mouse'
[ 20.820] (**) PixArt HP USB Optical Mouse: always reports core events
[ 20.820] (**) Option "Device" "/dev/input/event5"
[ 20.820] (**) Option "_source" "server/udev"
[ 20.824] (II) event5 - PixArt HP USB Optical Mouse: is tagged by udev as: Mouse
[ 20.824] (II) event5 - PixArt HP USB Optical Mouse: device is a pointer
[ 20.824] (II) event5 - PixArt HP USB Optical Mouse: device removed
[ 20.897] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.2/0000:01:00.0/usb1/1-3/1-3:1.0/0003:03F0:094A.0003/input/input7/event5"
[ 20.897] (II) XINPUT: Adding extended input device "PixArt HP USB Optical Mouse" (type: MOUSE, id 9)
[ 20.897] (**) Option "AccelerationScheme" "none"
[ 20.897] (**) PixArt HP USB Optical Mouse: (accel) selected scheme none/0
[ 20.897] (**) PixArt HP USB Optical Mouse: (accel) acceleration factor: 2.000
[ 20.897] (**) PixArt HP USB Optical Mouse: (accel) acceleration threshold: 4
[ 20.901] (II) event5 - PixArt HP USB Optical Mouse: is tagged by udev as: Mouse
[ 20.901] (II) event5 - PixArt HP USB Optical Mouse: device is a pointer
[ 20.903] (II) config/udev: Adding input device PixArt HP USB Optical Mouse (/dev/input/mouse0)
[ 20.903] (II) No input driver specified, ignoring this device.
[ 20.903] (II) This device may have been added with another device file.
[ 20.905] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=3 (/dev/input/event10)
[ 20.905] (II) No input driver specified, ignoring this device.
[ 20.905] (II) This device may have been added with another device file.
[ 20.905] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=7 (/dev/input/event11)
[ 20.906] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=8 (/dev/input/event12)
[ 20.906] (II) No input driver specified, ignoring this device.
[ 20.906] (II) This device may have been added with another device file.
[ 20.908] (II) config/udev: Adding input device Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU (/dev/input/event3)
[ 20.908] (**) Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU: Applying InputClass "libinput keyboard catchall"
[ 20.908] (**) Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU: Applying InputClass "system-keyboard"
[ 20.908] (II) Using input driver 'libinput' for 'Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU'
[ 20.908] (**) Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU: always reports core events
[ 20.908] (**) Option "Device" "/dev/input/event3"
[ 20.908] (**) Option "_source" "server/udev"
[ 20.911] (II) event3 - Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU: is tagged by udev as: Keyboard
[ 20.911] (II) event3 - Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU: device is a keyboard
[ 20.911] (II) event3 - Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU: device removed
[ 20.950] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0a:00.3/usb4/4-4/4-4:1.0/0003:03F0:2B4A.0001/input/input3/event3"
[ 20.950] (II) XINPUT: Adding extended input device "Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU" (type: KEYBOARD, id 10)
[ 20.950] (**) Option "xkb_model" "pc105"
[ 20.950] (**) Option "xkb_layout" "de"
[ 20.950] (WW) Option "xkb_variant" requires a string value
[ 20.950] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 20.953] (II) event3 - Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU: is tagged by udev as: Keyboard
[ 20.953] (II) event3 - Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU: device is a keyboard
[ 20.955] (II) config/udev: Adding input device Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU Consumer Control (/dev/input/event4)
[ 20.955] (**) Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 20.955] (**) Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU Consumer Control: Applying InputClass "system-keyboard"
[ 20.955] (II) Using input driver 'libinput' for 'Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU Consumer Control'
[ 20.955] (**) Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU Consumer Control: always reports core events
[ 20.955] (**) Option "Device" "/dev/input/event4"
[ 20.955] (**) Option "_source" "server/udev"
[ 20.958] (II) event4 - Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU Consumer Control: is tagged by udev as: Keyboard
[ 20.958] (II) event4 - Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU Consumer Control: device is a keyboard
[ 20.959] (II) event4 - Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU Consumer Control: device removed
[ 21.004] (II) libinput: Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU Consumer Control: needs a virtual subdevice
[ 21.004] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0a:00.3/usb4/4-4/4-4:1.1/0003:03F0:2B4A.0002/input/input4/event4"
[ 21.004] (II) XINPUT: Adding extended input device "Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU Consumer Control" (type: MOUSE, id 11)
[ 21.004] (**) Option "AccelerationScheme" "none"
[ 21.004] (**) Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU Consumer Control: (accel) selected scheme none/0
[ 21.004] (**) Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU Consumer Control: (accel) acceleration factor: 2.000
[ 21.004] (**) Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU Consumer Control: (accel) acceleration threshold: 4
[ 21.007] (II) event4 - Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU Consumer Control: is tagged by udev as: Keyboard
[ 21.007] (II) event4 - Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU Consumer Control: device is a keyboard
[ 21.008] (II) config/udev: Adding input device Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU System Control (/dev/input/event6)
[ 21.008] (**) Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU System Control: Applying InputClass "libinput keyboard catchall"
[ 21.008] (**) Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU System Control: Applying InputClass "system-keyboard"
[ 21.008] (II) Using input driver 'libinput' for 'Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU System Control'
[ 21.008] (**) Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU System Control: always reports core events
[ 21.009] (**) Option "Device" "/dev/input/event6"
[ 21.009] (**) Option "_source" "server/udev"
[ 21.011] (II) event6 - Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU System Control: is tagged by udev as: Keyboard
[ 21.012] (II) event6 - Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU System Control: device is a keyboard
[ 21.012] (II) event6 - Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU System Control: device removed
[ 21.043] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0a:00.3/usb4/4-4/4-4:1.1/0003:03F0:2B4A.0002/input/input5/event6"
[ 21.044] (II) XINPUT: Adding extended input device "Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU System Control" (type: KEYBOARD, id 12)
[ 21.044] (**) Option "xkb_model" "pc105"
[ 21.044] (**) Option "xkb_layout" "de"
[ 21.044] (WW) Option "xkb_variant" requires a string value
[ 21.044] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 21.047] (II) event6 - Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU System Control: is tagged by udev as: Keyboard
[ 21.047] (II) event6 - Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU System Control: device is a keyboard
[ 21.049] (II) config/udev: Adding input device Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU (/dev/input/event7)
[ 21.049] (**) Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU: Applying InputClass "libinput keyboard catchall"
[ 21.049] (**) Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU: Applying InputClass "system-keyboard"
[ 21.049] (II) Using input driver 'libinput' for 'Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU'
[ 21.049] (**) Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU: always reports core events
[ 21.049] (**) Option "Device" "/dev/input/event7"
[ 21.049] (**) Option "_source" "server/udev"
[ 21.052] (II) event7 - Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU: is tagged by udev as: Keyboard
[ 21.052] (II) event7 - Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU: device is a keyboard
[ 21.052] (II) event7 - Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU: device removed
[ 21.097] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0a:00.3/usb4/4-4/4-4:1.1/0003:03F0:2B4A.0002/input/input6/event7"
[ 21.097] (II) XINPUT: Adding extended input device "Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU" (type: KEYBOARD, id 13)
[ 21.097] (**) Option "xkb_model" "pc105"
[ 21.097] (**) Option "xkb_layout" "de"
[ 21.097] (WW) Option "xkb_variant" requires a string value
[ 21.097] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 21.100] (II) event7 - Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU: is tagged by udev as: Keyboard
[ 21.100] (II) event7 - Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU: device is a keyboard
[ 21.102] (II) config/udev: Adding input device HD-Audio Generic Mic (/dev/input/event13)
[ 21.102] (II) No input driver specified, ignoring this device.
[ 21.102] (II) This device may have been added with another device file.
[ 21.102] (II) config/udev: Adding input device HD-Audio Generic Front Headphone Front (/dev/input/event14)
[ 21.103] (II) config/udev: Adding input device HD-Audio Generic Front Headphone Surround (/dev/input/event15)
[ 21.103] (II) No input driver specified, ignoring this device.
[ 21.103] (II) This device may have been added with another device file.
[ 21.104] (II) config/udev: Adding input device PC Speaker (/dev/input/event8)
[ 21.104] (II) No input driver specified, ignoring this device.
[ 21.104] (II) This device may have been added with another device file.
[ 21.105] (II) config/udev: Adding input device HP WMI hotkeys (/dev/input/event9)
[ 21.105] (**) HP WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 21.105] (**) HP WMI hotkeys: Applying InputClass "system-keyboard"
[ 21.105] (II) Using input driver 'libinput' for 'HP WMI hotkeys'
[ 21.105] (**) HP WMI hotkeys: always reports core events
[ 21.105] (**) Option "Device" "/dev/input/event9"
[ 21.105] (**) Option "_source" "server/udev"
[ 21.106] (II) event9 - HP WMI hotkeys: is tagged by udev as: Keyboard Switch
[ 21.106] (II) event9 - HP WMI hotkeys: device is a keyboard
[ 21.106] (II) event9 - HP WMI hotkeys: device removed
[ 21.204] (**) Option "config_info" "udev:/sys/devices/virtual/input/input8/event9"
[ 21.204] (II) XINPUT: Adding extended input device "HP WMI hotkeys" (type: KEYBOARD, id 14)
[ 21.204] (**) Option "xkb_model" "pc105"
[ 21.204] (**) Option "xkb_layout" "de"
[ 21.204] (WW) Option "xkb_variant" requires a string value
[ 21.204] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 21.205] (II) event9 - HP WMI hotkeys: is tagged by udev as: Keyboard Switch
[ 21.205] (II) event9 - HP WMI hotkeys: device is a keyboard
[ 21.213] (**) Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 21.213] (**) Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU Consumer Control: Applying InputClass "system-keyboard"
[ 21.213] (II) Using input driver 'libinput' for 'Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU Consumer Control'
[ 21.213] (**) Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU Consumer Control: always reports core events
[ 21.213] (**) Option "Device" "/dev/input/event4"
[ 21.214] (**) Option "_source" "_driver/libinput"
[ 21.214] (II) libinput: Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU Consumer Control: is a virtual subdevice
[ 21.214] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:0a:00.3/usb4/4-4/4-4:1.1/0003:03F0:2B4A.0002/input/input4/event4"
[ 21.214] (II) XINPUT: Adding extended input device "Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU Consumer Control" (type: KEYBOARD, id 15)
[ 21.214] (**) Option "xkb_model" "pc105"
[ 21.214] (**) Option "xkb_layout" "de"
[ 21.214] (WW) Option "xkb_variant" requires a string value
[ 21.214] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 22.588] (II) AMDGPU(0): EDID vendor "HSP", prod id 0
[ 22.588] (II) AMDGPU(0): Using EDID range info for horizontal sync
[ 22.588] (II) AMDGPU(0): Using EDID range info for vertical refresh
[ 22.588] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 22.588] (II) AMDGPU(0): Modeline "3840x2160"x0.0 533.25 3840 3888 3920 4000 2160 2163 2168 2222 +hsync +vsync (133.3 kHz eP)
[ 22.588] (II) AMDGPU(0): Modeline "3840x2160"x0.0 594.00 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (135.0 kHz e)
[ 22.588] (II) AMDGPU(0): Modeline "3840x2160"x0.0 297.00 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (67.5 kHz e)
[ 22.588] (II) AMDGPU(0): Modeline "2560x1440"x0.0 241.50 2560 2608 2640 2720 1440 1442 1447 1481 +hsync -vsync (88.8 kHz e)
[ 22.588] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 22.588] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 22.588] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 22.588] (II) AMDGPU(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 22.588] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 22.588] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 22.588] (II) AMDGPU(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 22.588] (II) AMDGPU(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 22.588] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 22.588] (II) AMDGPU(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 22.588] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 22.588] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 22.588] (II) AMDGPU(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 22.588] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 22.588] (II) AMDGPU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 22.588] (II) AMDGPU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 22.588] (II) AMDGPU(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 22.588] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 22.588] (II) AMDGPU(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 22.588] (II) AMDGPU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 22.588] (II) AMDGPU(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 22.588] (II) AMDGPU(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 22.588] (II) AMDGPU(0): Modeline "1920x1440"x0.0 234.00 1920 2048 2256 2600 1440 1441 1444 1500 -hsync +vsync (90.0 kHz e)
[ 22.588] (II) AMDGPU(0): Modeline "1920x1200"x0.0 193.25 1920 2056 2256 2592 1200 1203 1209 1245 -hsync +vsync (74.6 kHz e)
[ 22.588] (II) AMDGPU(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 22.588] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 22.588] (II) AMDGPU(0): Modeline "1280x800"x0.0 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
[ 22.590] (II) AMDGPU(0): EDID vendor "HSP", prod id 0
[ 22.590] (II) AMDGPU(0): Using hsync ranges from config file
[ 22.590] (II) AMDGPU(0): Using vrefresh ranges from config file
[ 22.590] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 22.590] (II) AMDGPU(0): Modeline "3840x2160"x0.0 533.25 3840 3888 3920 4000 2160 2163 2168 2222 +hsync +vsync (133.3 kHz eP)
[ 22.590] (II) AMDGPU(0): Modeline "3840x2160"x0.0 594.00 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (135.0 kHz e)
[ 22.590] (II) AMDGPU(0): Modeline "3840x2160"x0.0 297.00 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (67.5 kHz e)
[ 22.590] (II) AMDGPU(0): Modeline "2560x1440"x0.0 241.50 2560 2608 2640 2720 1440 1442 1447 1481 +hsync -vsync (88.8 kHz e)
[ 22.590] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 22.590] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 22.590] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 22.590] (II) AMDGPU(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 22.590] (II) AMDGPU(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 22.590] (II) AMDGPU(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 22.590] (II) AMDGPU(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 22.590] (II) AMDGPU(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 22.590] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 22.590] (II) AMDGPU(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 22.590] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 22.590] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 22.590] (II) AMDGPU(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 22.590] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 22.590] (II) AMDGPU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 22.590] (II) AMDGPU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 22.590] (II) AMDGPU(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 22.590] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 22.590] (II) AMDGPU(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 22.590] (II) AMDGPU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 22.590] (II) AMDGPU(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 22.590] (II) AMDGPU(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 22.590] (II) AMDGPU(0): Modeline "1920x1440"x0.0 234.00 1920 2048 2256 2600 1440 1441 1444 1500 -hsync +vsync (90.0 kHz e)
[ 22.590] (II) AMDGPU(0): Modeline "1920x1200"x0.0 193.25 1920 2056 2256 2592 1200 1203 1209 1245 -hsync +vsync (74.6 kHz e)
[ 22.590] (II) AMDGPU(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 22.590] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 22.590] (II) AMDGPU(0): Modeline "1280x800"x0.0 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz e)
[ 199.767] (EE) event5 - PixArt HP USB Optical Mouse: client bug: event processing lagging behind by 21ms, your system is too slow
[ 259.737] (EE) event5 - PixArt HP USB Optical Mouse: client bug: event processing lagging behind by 22ms, your system is too slow
[ 265.541] (EE) event5 - PixArt HP USB Optical Mouse: client bug: event processing lagging behind by 25ms, your system is too slow
[ 265.902] (EE) event5 - PixArt HP USB Optical Mouse: client bug: event processing lagging behind by 18ms, your system is too slow
[ 271.352] (EE) event5 - PixArt HP USB Optical Mouse: client bug: event processing lagging behind by 19ms, your system is too slow
[ 271.352] (EE) event5 - PixArt HP USB Optical Mouse: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 351.579] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-6ms), your system is too slow
[ 972.575] (EE) event3 - Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU: client bug: event processing lagging behind by 27ms, your system is too slow
[ 1172.871] (EE) event3 - Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU: client bug: event processing lagging behind by 25ms, your system is too slow
[ 1620.828] (EE) event3 - Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU: client bug: event processing lagging behind by 17ms, your system is too slow
[ 1695.389] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-7ms), your system is too slow
[ 1747.631] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-8ms), your system is too slow
[ 1759.459] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-11ms), your system is too slow
[ 1764.012] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-4ms), your system is too slow
[ 1920.700] (EE) event3 - Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU: client bug: event processing lagging behind by 19ms, your system is too slow
[ 1936.875] (EE) event3 - Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU: client bug: event processing lagging behind by 15ms, your system is too slow
[ 1936.875] (EE) event3 - Lite-On Technology Corp HP USB Slim Keyboard - Skylab EU: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 1938.501] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-11ms), your system is too slow
[ 2456.673] (EE) client bug: timer event5 debounce: scheduled expiry is in the past (-8ms), your system is too slow
[ 2456.673] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-21ms), your system is too slow
[ 2917.227] (EE) client bug: timer event5 debounce: scheduled expiry is in the past (-0ms), your system is too slow
[ 2917.227] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-13ms), your system is too slow
[ 2942.378] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-0ms), your system is too slow
[ 2957.228] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-9ms), your system is too slow
[ 3263.809] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-1ms), your system is too slow
[ 3271.893] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-12ms), your system is too slow
[ 3275.510] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-12ms), your system is too slow
[ 3337.462] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-12ms), your system is too slow
[ 3467.402] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-12ms), your system is too slow
