Manjaro i3 16.10
community-edition
i3
#21
Thx. lxappearance-gtk3 in conflict with default lxappearance should i intall it ? Is the default color scheme saved ?
#22
The regular lxappearance is fine. You don’t need to install the -gtk3 version to be able to change gtk3 theming :slight_smile: Color scheme of i3 elemeints is defined in the i3 config, the settings for dmenu are in ~/.dmenurc and the rest is defined by the gtk-theme you set in lxapearance.
#23
So what i need to do ?
#24
Open lxappearance (with dmenu for example) and set your font size… :slight_smile:
#25
Hi sorry for dummy question but have one more.
How i can use styles for terminal when i change my shell from bash to .oh my zsh
#26
