System: Linux Falcon 6.12.11-1-MANJARO #1 SMP PREEMPT_DYNAMIC Thu, 23 Jan 2025 20:29:02 +0000 x86_64 GNU/Linux
Computer is hard crashing, instant power off intermittently. Anywhere from a few minutes up to hours.
Output from journalctl -b -1 -p err
Feb 05 11:58:52 Falcon kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP4.WLAN], AE_NOT_FOUND (20240827/dswload2-162)
Feb 05 11:58:52 Falcon kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20240827/psobject-220)
Feb 05 11:58:52 Falcon kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_TZ.THRM._SCP.CTYP], AE_NOT_FOUND (20240827/psargs-332)
Feb 05 11:58:52 Falcon kernel: ACPI Error: Aborting method \_TZ.THRM._SCP due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
Feb 05 11:58:52 Falcon kernel: amdgpu 0000:05:00.0: amdgpu: Secure display: Generic Failure.
Feb 05 11:58:52 Falcon kernel: amdgpu 0000:05:00.0: amdgpu: SECUREDISPLAY: query securedisplay TA failed. ret 0x0
Feb 05 11:58:51 Falcon systemd-modules-load[452]: Failed to find module 'nvidia-uvm'
Feb 05 11:58:54 Falcon (yncthing)[1340]: syncthing@gander7.service: Failed to determine user credentials: No such process
Feb 05 11:58:54 Falcon (yncthing)[1340]: syncthing@gander7.service: Failed at step USER spawning /usr/bin/syncthing: No such process
Feb 05 11:58:56 Falcon (yncthing)[1410]: syncthing@gander7.service: Failed to determine user credentials: No such process
Feb 05 11:58:56 Falcon (yncthing)[1410]: syncthing@gander7.service: Failed at step USER spawning /usr/bin/syncthing: No such process
Feb 05 11:58:57 Falcon (yncthing)[1414]: syncthing@gander7.service: Failed to determine user credentials: No such process
Feb 05 11:58:57 Falcon (yncthing)[1414]: syncthing@gander7.service: Failed at step USER spawning /usr/bin/syncthing: No such process
Feb 05 11:58:58 Falcon (yncthing)[1420]: syncthing@gander7.service: Failed to determine user credentials: No such process
Feb 05 11:58:58 Falcon (yncthing)[1420]: syncthing@gander7.service: Failed at step USER spawning /usr/bin/syncthing: No such process
Feb 05 11:58:59 Falcon systemd[1]: Failed to start Syncthing - Open Source Continuous File Synchronization for gander7.
Feb 05 11:59:00 Falcon dbus-broker-launch[1995]: Ignoring duplicate name 'org.freedesktop.FileManager1' in service file '/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service'
Feb 05 11:59:04 Falcon lightdm[2547]: gkr-pam: unable to locate daemon control file
Feb 05 11:59:05 Falcon dbus-broker-launch[2894]: Ignoring duplicate name 'org.freedesktop.FileManager1' in service file '/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service'
Feb 05 11:59:06 Falcon pulseaudio[3002]: Module "module-switch-on-connect" should be loaded once at most. Refusing to load.
Feb 05 11:59:06 Falcon pulseaudio[3002]: Module already loaded; ignoring.
Feb 05 11:59:10 Falcon systemd[2864]: Failed to start Syncthing - Open Source Continuous File Synchronization.
Output of free -h
total used free shared buff/cache available
Mem: 15Gi 3.5Gi 7.7Gi 139Mi 4.3Gi 11Gi
Swap: 8.8Gi 0B 8.8Gi
I don’t see anything here that could be the issue. I’m monitoring CPU usage, temperatures, free memory, but none of that shows an issue before it crashes that I’ve noticed so far.
Please help, it’s been weeks and it’s driving me nuts!
EDIT: sudo inxi --filter --verbosity=8
Output: Pastebin
Kernel: 6.12.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
clocksource: hpet avail: acpi_pm
root=UUID=edfbbb92-c119-41cf-a3b9-e981cf9b999f rw quiet splash apparmor=1
security=apparmor resume=UUID=57b94b3c-1473-43cc-ad6e-6345baf1ac87
udev.log_priority=3
Desktop: Xfce v: 4.20.0 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.20.0
with: xfce4-panel tools: light-locker dm: LightDM v: 1.32.0 Distro: Manjaro
base: Arch Linux
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15 FA506IH_TUF506IH
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: FA506IH v: 1.0 serial: <filter>
uuid: 4d4531a2-0397-4c4f-af26-e15c5c9d7f90 UEFI: American Megatrends
v: FA506IH.315 date: 01/29/2021
ID-1: BAT1 charge: 29.5 Wh (96.7%) condition: 30.5/48.1 Wh (63.4%)
volts: 12.0 min: 11.7 model: ASUS A32-K55 type: Li-ion serial: N/A
status: not charging
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 3
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
System RAM: total: 16 GiB available: 15.04 GiB used: 3.26 GiB (21.7%)
(unregistered) size: 8 GiB speed: 3200 MT/s volts: curr: 1.2 min: 1.2
max: 1.2 width (bits): data: 64 total: 64 manufacturer: Samsung
part-no: M471A1K43DB1-CWE serial: <filter>
Slot: 1 type: PCIe status: in use info: J3604 length: short volts: 3.3
bus-ID: 00:01.1 children: 1: 01:00.0 class-ID: 0300 type: display 2: 01:00.1
class-ID: 0403 type: audio
Slot: N/A type: N/A status: available info: M.2, J3711 length: short
volts: 3.3 bus-ID: 0200:00:01.2
Slot: N/A type: N/A status: available info: M.2, J3704 length: short
volts: 3.3 bus-ID: 0200:00:01.7
Slot: N/A type: N/A status: available info: M.2, J3709 length: short
volts: 3.3 bus-ID: 0200:00:01.5
Info: model: AMD Ryzen 7 4800H with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x860010D
desc: 8x512 KiB L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1400 min/max: 1400/2900 boost: enabled
base/boost: 2900/4300 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1400 2: 1400 3: 1400 4: 1400
5: 1400 6: 1400 7: 1400 8: 1400 9: 1400 10: 1400 11: 1400 12: 1400
13: 1400 14: 1400 15: 1400 16: 1400 bogomips: 92668
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs
ibs irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rapl rdpid
rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni skinit
smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm
svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xtopology
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
driver: N/A alternate: nouveau non-free: 550/565.xx+ status: current (as of
2025-01; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1f99 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Renoir [Radeon Vega Series /
Radeon Mobile Series] vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5
code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 05:00.0
chip-ID: 1002:1636 class-ID: 0300 temp: 46.0 C
Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 13d3:56a2
Display: x11 server: X.Org v: 21.1.15 with: Xwayland v: 24.1.4
compositor: xfwm4 v: 4.20.0 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 509x286mm (20.04x11.26")
s-diag: 584mm (22.99")
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x084d built: 2018 res:
mode: 1920x1080 hz: 144 scale: 100% (1) dpi: 142 gamma: 1.2 chroma: red:
x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059 white:
x: 0.314 y: 0.329 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800,
1280x720, 1024x768, 800x600, 640x480
device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
renoir LLVM 19.1.7 DRM 3.59 6.12.11-1-MANJARO) device-ID: 1002:1636
memory: 500 MiB unified: no
API: Vulkan v: 1.4.303 layers: 1 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: N/A device-ID: 1002:1636
surfaces: xcb,xlib
Info: Tools: api: eglinfo, glxinfo, vulkaninfo de: xfce4-display-settings
gpu: nvidia-smi x11: xdpyinfo, xprop, xrandr
Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-3: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-4: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.12.11-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: n/a (root, process) tools: pw-cli
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active (root, process)
with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0
chip-ID: 10ec:c822 class-ID: 0280
IF-ID-1: br-316c1e0a19d1 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v6: <filter> virtual: proto kernel_ll scope: link
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: veth9791f2f state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-4: vethb04ac86 state: up speed: 10000 Mbps duplex: full
mac: <filter>
Device-1: IMC Networks Bluetooth Radio driver: btusb v: 0.8 type: USB
rev: 1.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 13d3:3548
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.1
lmp-v: 10 status: discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 931.51 GiB used: 848.14 GiB (91.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 EVO 1TB
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 126 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 0B2QKXJ7 temp: 32.9 C
scheme: GPT
ID-1: / raw-size: 922.42 GiB size: 906.87 GiB (98.31%)
used: 848.14 GiB (93.5%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2 label: N/A uuid: edfbbb92-c119-41cf-a3b9-e981cf9b999f
used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: 18FC-87C0
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: no
dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 57b94b3c-1473-43cc-ad6e-6345baf1ac87
Device-1: 1-4:2 info: IMC Networks USB2.0 HD UVC WebCam type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 13d3:56a2 class-ID: 0e02
serial: <filter>
Device-1: 3-1:2 info: IMC Networks Bluetooth Radio type: bluetooth
driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 13d3:3548 class-ID: e001 serial: <filter>
System Temperatures: cpu: 53.9 C mobo: N/A gpu: amdgpu temp: 47.0 C
Fan Speeds (rpm): cpu: 2500
Packages: pm: pacman pkgs: 1650 libs: 495 tools: pamac,yay pm: flatpak
pkgs: 0
1: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
7: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
8: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 422
1: cpu: 43.5% command: firefox pid: 3669 mem: 530.4 MiB (3.4%)
2: cpu: 17.5% command: firefox pid: 4152 mem: 364.6 MiB (2.3%)
3: cpu: 7.2% command: Xorg pid: 1432 mem: 157.6 MiB (1.0%)
4: cpu: 6.7% command: firefox pid: 3766 mem: 239.2 MiB (1.5%)
5: cpu: 6.5% command: Mailspring pid: 3491 mem: 193.3 MiB (1.2%)
Memory top: 5 of 422
1: mem: 530.4 MiB (3.4%) command: firefox pid: 3669 cpu: 43.5%
2: mem: 364.6 MiB (2.3%) command: firefox pid: 4152 cpu: 17.5%
3: mem: 239.2 MiB (1.5%) command: firefox pid: 3766 cpu: 6.7%
4: mem: 235.3 MiB (1.5%) command: firefox pid: 3910 cpu: 5.0%
5: mem: 213.5 MiB (1.3%) command: firefox pid: 3919 cpu: 2.0%
Processes: 422 Power: uptime: 2m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.98 GiB services: upowerd,xfce4-power-manager
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Sudo (sudo) v: 1.9.16p2
default: Bash v: 5.2.37 running-in: xfce4-terminal inxi: 3.3.37
Mod Note: I’ve added your inxi
to your post to keep it in one place; saves switching tabs.
