Manjaro hangs on starting hostname | kernel 5.8.0-2
I predict this is because of the fact the nvidia drivers weren’t prepared for the new kernel. Any tips on how to debug? I would also like to just revert kernel if possible, I have access to the command line but don’t know the commands. Also google -> Manjaro is broken for some reason, is that just me?
p.s. lightdm fails
So it seems you have installed a new kernel but not the extramodules like matching Nvidia drivers? Normally a install via pamac or mhwd will add those extramodules when found from an older kernel. pacman simply doesn’t have that feature.
So list any package you may have installed and install the needed for your new kernel:
pacman -Q | grep nvidia
Google didn’t noticed that we have a new forum. It takes months until they pick up the change and move to archived.forum.manjaro.org. So if you search via google, you may add archived. before forum to get a valid result.
cool about the achrived bit :slight_smile:
here is the output of the above command
$ pacman -Q | grep nvidia
lib32-nvidia-440xx-utils 440.100-1
linux-latest-nvidia-440xx 5.7-2
linux414-nvidia-440xx 440.100-8
linux57-nvidia-440xx 440.100-11
linux58-nvidia-440xx 440.100-2
mhwd-nvidia-340xx 340.108-1
mhwd-nvidia-390xx 390.132-1
mhwd-nvidia-418xx 418.113-1
mhwd-nvidia-430xx 430.64-1.0
mhwd-nvidia-435xx 435.21-1.0
mhwd-nvidia-440xx 440.100-1
nvidia-prime 1.0-4
opencl-nvidia-340xx 340.108-1
when I try to install using mhwd it doesn’t work saying it’s already installed. would a messd up .bashrc file make this happen? I tried to mess with it which may have been a mistake. p.s. lightdm is what’s not starting, any way to see a more verbose readout?
for reference, the output from the install
$ sudo mhwd -a pci nonfree 0300
> Skipping already installed config 'video-hybrid-amd-nvidia-440xx-prime' for device: 0000:05:00.0 (0300:10de:128b) Display controller nVidia Corporation GK208B [GeForce GT 710]
> Skipping already installed config 'video-hybrid-amd-nvidia-440xx-prime' for device: 0000:04:00.0 (0300:1002:67df) Display controller ATI Technologies Inc Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
> Skipping already installed config 'video-hybrid-amd-nvidia-440xx-prime' for device: 0000:0d:00.0 (0300:10de:1c02) Display controller nVidia Corporation GP106 [GeForce GTX 1060 3GB]
EDIT
this may be helpful but maybe not, here’s the out of
$ journalctl -xe | grep lightdm
Aug 17 17:04:56 alita-manjaro kernel: audit: type=1400 audit(1597701896.610:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session//chromium" pid=454 comm="apparmor_parser"
Aug 17 17:04:56 alita-manjaro audit[454]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session" pid=454 comm="apparmor_parser"
Aug 17 17:04:56 alita-manjaro audit[454]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session//chromium" pid=454 comm="apparmor_parser"
-- Subject: A start job for unit lightdm.service has begun execution
-- A start job for unit lightdm.service has begun execution.
Aug 17 17:04:57 alita-manjaro dbus-daemon[944]: [system] Activating via systemd: service name='org.freedesktop.login1' unit='dbus-org.freedesktop.login1.service' requested by ':1.6' (uid=0 pid=990 comm="/usr/bin/lightdm " label="unconfined")
-- Subject: A start job for unit lightdm.service has finished successfully
-- A start job for unit lightdm.service has finished successfully.
Aug 17 17:04:59 alita-manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 17 17:04:59 alita-manjaro dbus-daemon[944]: [system] Activating via systemd: service name='org.freedesktop.Accounts' unit='accounts-daemon.service' requested by ':1.6' (uid=0 pid=990 comm="/usr/bin/lightdm " label="unconfined")
Aug 17 17:04:59 alita-manjaro systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
-- An ExecStart= process belonging to unit lightdm.service has exited.
Aug 17 17:04:59 alita-manjaro systemd[1]: lightdm.service: Failed with result 'exit-code'.
-- The unit lightdm.service has entered the 'failed' state with result 'exit-code'.
Aug 17 17:04:59 alita-manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Aug 17 17:04:59 alita-manjaro systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 1.
-- Automatic restarting of the unit lightdm.service has been scheduled, as the result for
-- Subject: A stop job for unit lightdm.service has finished
-- A stop job for unit lightdm.service has finished.
Aug 17 17:04:59 alita-manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 17 17:05:00 alita-manjaro systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 2.
Aug 17 17:05:00 alita-manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 17 17:05:00 alita-manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 17 17:05:00 alita-manjaro systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
Aug 17 17:05:00 alita-manjaro systemd[1]: lightdm.service: Failed with result 'exit-code'.
Aug 17 17:05:00 alita-manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Aug 17 17:05:00 alita-manjaro systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 3.
Aug 17 17:05:00 alita-manjaro kernel: audit: type=1130 audit(1597701900.627:81): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 17 17:05:00 alita-manjaro kernel: audit: type=1131 audit(1597701900.627:82): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 17 17:05:00 alita-manjaro kernel: audit: type=1130 audit(1597701900.634:83): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 17 17:05:00 alita-manjaro kernel: audit: type=1131 audit(1597701900.640:84): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Aug 17 17:05:00 alita-manjaro systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 4.
Aug 17 17:05:00 alita-manjaro kernel: audit: type=1130 audit(1597701900.990:85): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 17 17:05:00 alita-manjaro kernel: audit: type=1131 audit(1597701900.990:86): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 17 17:05:01 alita-manjaro kernel: audit: type=1130 audit(1597701900.997:87): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 17 17:05:01 alita-manjaro systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
Aug 17 17:05:01 alita-manjaro systemd[1]: lightdm.service: Failed with result 'exit-code'.
Aug 17 17:05:01 alita-manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Aug 17 17:05:01 alita-manjaro kernel: audit: type=1131 audit(1597701901.007:88): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Aug 17 17:05:01 alita-manjaro systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 5.
Aug 17 17:05:01 alita-manjaro audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 17 17:05:01 alita-manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 17 17:05:01 alita-manjaro systemd[1]: lightdm.service: Start request repeated too quickly.
-- Subject: A start job for unit lightdm.service has failed
-- A start job for unit lightdm.service has finished with a failure.
Aug 17 17:05:01 alita-manjaro kernel: audit: type=1130 audit(1597701901.360:89): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
propably too much info haha, but then output of
$ mhwd -l
> 0000:07:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
         network-r8168            2016.04.20                true            PCI
> 0000:05:00.0 (0300:10de:128b) Display controller nVidia Corporation:
video-hybrid-amd-nvidia-440xx-prime            2020.03.26               false            PCI
video-hybrid-amd-nvidia-435xx-prime            2020.03.26               false            PCI
    video-nvidia-440xx            2019.10.25               false            PCI
    video-nvidia-435xx            2019.10.25               false            PCI
    video-nvidia-430xx            2019.10.25               false            PCI
    video-nvidia-418xx            2019.10.25               false            PCI
    video-nvidia-390xx            2019.10.25               false            PCI
           video-linux            2018.05.04                true            PCI
> 0000:04:00.0 (0300:1002:67df) Display controller ATI Technologies Inc:
> 0000:0d:00.0 (0300:10de:1c02) Display controller nVidia Corporation:
linux58-nvidia-440xx is installed but you say that lightdm doesn’t start. So I assume that linux414 and linux57 work on your end. Based on your mhwd output you have three graphic cards, which is odd. So which card is working for you?
You can try to switch to the testing branch and update your system again:
https://wiki.manjaro.org/index.php?title=Switching_Branches
We simply have to know why the drivers can’t be loaded. However I also don’t read any issues regarding 440 driver series on our stable branch announcement yet, as you already have the latest packages installed as shown by branch-compare.
You might find something useful in the following logs:
[phil@development log]$ sudo ls /var/log/lightdm/
lightdm.log seat0-greeter.log x-0.log x-1.log
lightdm.log.old seat0-greeter.log.old x-0.log.old x-1.log.old
okay so it seems to be failing when launching the xserver for some reason; ah, there’s probably something wrong with xorg.conf; but for reference:
[+0.00s] DEBUG: XServer 0: Launching X Server
[+0.00s] DEBUG: Launching process 1526: /usr/bin/X :0 -seat seat0 -auth /run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
[+0.00s] DEBUG: XServer 0: Waiting for ready signal from X server :0
[+0.00s] DEBUG: Acquired bus name org.freedesktop.DisplayManager
[+0.00s] DEBUG: Registering seat with bus path /org/freedesktop/DisplayManager/Seat0
[+0.00s] DEBUG: Loading users from org.freedesktop.Accounts
[+0.00s] DEBUG: User /org/freedesktop/Accounts/User1000 added
[+0.01s] DEBUG: Process 1526 exited with return value 1
I’ll try resetting the original .conf file
that WAS the solution :smiley:
so in short, the following command line code solved the issue:
$ sudo nvidia-xconfig
I had previously done some stupid stuff without backing up…
thank you @phillim
I’m happy for you that you found your solution. Enjoy Manjaro and if you have issues with it, let us know.
