Honestly, I wasn’t really sure what to title this topic because I’m having so many issues at once.
Earlier today I did a reboot and it took much longer than it usually does. Once it finally got to the end of the splash screen, the screen hung for a few minutes while Steam booted up and displayed where it normally does. It took probably five minutes for the splash screen to go away and for my taskbar and desktop to show up. Even after that, I had to wait probably another five minutes before anything was even usable because absolutely nothing was reacting to my inputs. After all that was said and done I was getting an error saying “Filesystem mounted at ‘/’ is not responding” along with another one about my other drive. Everything from then on seemed to go pretty smoothly but it’s really concerning me and annoying to have to wait ages to be able to use my computer.
I ran journalctl -b -p err
and here is the output:
Jun 03 20:30:45 Noelle-PC kernel: hid-generic 0003:0D8C:0005.0004: No inputs registered, leaving
Jun 04 02:26:14 Noelle-PC kernel:
Jun 04 02:26:15 Noelle-PC kernel: Bluetooth: hci0: BCM: firmware Patch file not found, tried:
Jun 04 02:26:15 Noelle-PC kernel: Bluetooth: hci0: BCM: 'brcm/BCM20702B0-19ff-0239.hcd'
Jun 04 02:26:15 Noelle-PC kernel: Bluetooth: hci0: BCM: 'brcm/BCM-19ff-0239.hcd'
Jun 04 02:26:15 Noelle-PC kernel: usb 1-1.6: 3:1: cannot get freq at ep 0x84
Jun 04 02:26:21 Noelle-PC kernel: usb 1-1.6: 3:1: cannot get freq at ep 0x84
Jun 04 02:56:44 Noelle-PC dolphin[2911]: inotify_add_watch(/var/log/private) failed: (Permission denied)
Jun 04 02:57:04 Noelle-PC dolphin[2911]: inotify_add_watch(/run/udisks2) failed: (Permission denied)
Jun 04 02:57:04 Noelle-PC dolphin[2911]: inotify_add_watch(/run/sudo) failed: (Permission denied)
Jun 04 02:57:05 Noelle-PC dolphin[2911]: inotify_add_watch(/run/systemd/propagate) failed: (Permission denied)
Jun 04 02:57:05 Noelle-PC dolphin[2911]: inotify_add_watch(/run/systemd/unit-root) failed: (Permission denied)
Jun 04 03:00:53 Noelle-PC dolphin[2911]: inotify_add_watch(/var/log/private) failed: (Permission denied)
Jun 04 03:03:27 Noelle-PC dolphin[2911]: inotify_add_watch(/var/log/private) failed: (Permission denied)
Jun 04 03:03:31 Noelle-PC dolphin[2911]: inotify_add_watch(/var/log/private) failed: (Permission denied)
Jun 04 03:03:35 Noelle-PC dolphin[2911]: inotify_add_watch(/var/tmp/systemd-private-723189545872410f81d0b1a60df04270-upower.service-9sBfr0) failed: (Permission denied)
Jun 04 03:03:35 Noelle-PC dolphin[2911]: inotify_add_watch(/var/tmp/systemd-private-723189545872410f81d0b1a60df04270-systemd-logind.service-hMdIkq) failed: (Permission denied)
Jun 04 03:03:35 Noelle-PC dolphin[2911]: inotify_add_watch(/var/tmp/systemd-private-723189545872410f81d0b1a60df04270-ModemManager.service-x6oltX) failed: (Permission denied)
Jun 04 03:03:35 Noelle-PC dolphin[2911]: inotify_add_watch(/var/tmp/systemd-private-723189545872410f81d0b1a60df04270-bluetooth.service-gABPPO) failed: (Permission denied)
Jun 04 03:03:35 Noelle-PC dolphin[2911]: inotify_add_watch(/var/tmp/systemd-private-723189545872410f81d0b1a60df04270-systemd-timesyncd.service-J4VxOy) failed: (Permission denied)
Jun 04 03:03:36 Noelle-PC dolphin[2911]: inotify_add_watch(/var/tmp/systemd-private-723189545872410f81d0b1a60df04270-upower.service-9sBfr0) failed: (Permission denied)
Jun 04 03:03:36 Noelle-PC dolphin[2911]: inotify_add_watch(/var/tmp/systemd-private-723189545872410f81d0b1a60df04270-systemd-logind.service-hMdIkq) failed: (Permission denied)
Jun 04 03:03:36 Noelle-PC dolphin[2911]: inotify_add_watch(/var/tmp/systemd-private-723189545872410f81d0b1a60df04270-ModemManager.service-x6oltX) failed: (Permission denied)
Jun 04 03:03:36 Noelle-PC dolphin[2911]: inotify_add_watch(/var/tmp/systemd-private-723189545872410f81d0b1a60df04270-bluetooth.service-gABPPO) failed: (Permission denied)
Jun 04 03:03:36 Noelle-PC dolphin[2911]: inotify_add_watch(/var/tmp/systemd-private-723189545872410f81d0b1a60df04270-systemd-timesyncd.service-J4VxOy) failed: (Permission denied)
Jun 04 03:03:37 Noelle-PC dolphin[2911]: inotify_add_watch(/var/tmp/systemd-private-723189545872410f81d0b1a60df04270-upower.service-9sBfr0) failed: (Permission denied)
Jun 04 03:03:38 Noelle-PC dolphin[2911]: inotify_add_watch(/var/tmp/systemd-private-723189545872410f81d0b1a60df04270-upower.service-9sBfr0) failed: (Permission denied)
Jun 04 03:03:39 Noelle-PC dolphin[2911]: inotify_add_watch(/var/tmp/systemd-private-723189545872410f81d0b1a60df04270-upower.service-9sBfr0) failed: (Permission denied)
Jun 04 03:03:39 Noelle-PC dolphin[2911]: inotify_add_watch(/var/tmp/systemd-private-723189545872410f81d0b1a60df04270-systemd-logind.service-hMdIkq) failed: (Permission denied)
Jun 04 03:03:39 Noelle-PC dolphin[2911]: inotify_add_watch(/var/tmp/systemd-private-723189545872410f81d0b1a60df04270-ModemManager.service-x6oltX) failed: (Permission denied)
Jun 04 03:03:39 Noelle-PC dolphin[2911]: inotify_add_watch(/var/tmp/systemd-private-723189545872410f81d0b1a60df04270-bluetooth.service-gABPPO) failed: (Permission denied)
Jun 04 03:03:39 Noelle-PC dolphin[2911]: inotify_add_watch(/var/tmp/systemd-private-723189545872410f81d0b1a60df04270-systemd-timesyncd.service-J4VxOy) failed: (Permission denied)
Jun 04 03:04:19 Noelle-PC dolphin[2911]: inotify_add_watch(/etc/sudoers.d) failed: (Permission denied)
Jun 04 03:04:19 Noelle-PC dolphin[2911]: inotify_add_watch(/etc/wireguard) failed: (Permission denied)
sudo dmesg --level emerg,alert,crit,err,warn
output:
[ 0.110646] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 1.961953] hid-generic 0003:0D8C:0005.0004: No inputs registered, leaving
[ 2.730231] vboxdrv: loading out-of-tree module taints kernel.
[ 2.767454] VBoxNetAdp: Successfully started.
[ 2.772613] VBoxNetFlt: Successfully started.
[ 3.025092] wmi_bus wmi_bus-PNP0C14:00: WQBC data block query control method not found
[ 3.187213] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20210730/utaddress-204)
[ 3.187223] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
[ 3.187227] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
[ 3.187230] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
[ 3.187233] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 3.300731] r8168 Copyright (C) 2021 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 3.891840] nvidia: module license 'NVIDIA' taints kernel.
[ 3.891845] Disabling lock debugging due to kernel taint
[ 4.021599] at24 0-0050: supply vcc not found, using dummy regulator
[ 4.046487] at24 0-0051: supply vcc not found, using dummy regulator
[ 4.047496] at24 0-0053: supply vcc not found, using dummy regulator
[ 4.084469] Bluetooth: hci0: BCM: firmware Patch file not found, tried:
[ 4.084470] Bluetooth: hci0: BCM: 'brcm/BCM20702B0-19ff-0239.hcd'
[ 4.084471] Bluetooth: hci0: BCM: 'brcm/BCM-19ff-0239.hcd'
[ 4.093193] usb 1-1.6: 3:1: cannot get freq at ep 0x84
[ 4.149782] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 510.73.05 Sat May 7 05:30:26 UTC 2022
[ 5.014387] nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
[ 5.126175] kauditd_printk_skb: 37 callbacks suppressed
[ 10.302299] ntfs3: sda2: volume is dirty and "force" flag is not set!
[ 10.565787] usb 1-1.6: 3:1: cannot get freq at ep 0x84
[ 10.569048] usb 1-1.6: 3:1: cannot get freq at ep 0x84
[ 10.772326] kauditd_printk_skb: 38 callbacks suppressed
[ 10.915680] ntfs3: sdb1: volume is dirty and "force" flag is not set!
Along with all this mess, I have noticed a couple other weird things. My monitor settings seem to be reset everytime I restart (refresh rate changes and monitors are misaligned) and icons in my system tray (for, say, Discord) are just completely gone. I have no idea what of these issues are related to each other or what I did but I figured they’d be worth mentioning anyway.
inxi info:
Kernel: 5.15.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=b1581353-f1b1-4e88-a51a-e2f4f4f5de19 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Dell product: OptiPlex 7010 v: 01
serial: <superuser required> Chassis: type: 15 serial: <superuser required>
Mobo: Dell model: 0GXM1W v: A02 serial: <superuser required> UEFI: Dell
v: A29 date: 06/28/2018
RAM: total: 7.72 GiB used: 3.81 GiB (49.3%)
RAM Report:
Info: model: Intel Core i5-3470 bits: 64 type: MCP arch: Ivy Bridge
family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 1830 high: 1957 min/max: 1600/3600 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1886 2: 1766 3: 1957
4: 1712 bogomips: 25548
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida
lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
rdrand rdtscp rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid
x2apic xsave xsaveopt xtopology xtpr
Type: l1tf
STIBP: disabled, RSB filling
Type: srbds status: Vulnerable: No microcode
Device-1: NVIDIA GP108 [GeForce GT 1030] vendor: Micro-Star MSI
driver: nvidia v: 510.73.05 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-05) arch: Pascal pcie: gen: 3 speed: 8 GT/s
lanes: 4 bus-ID: 01:00.0 chip-ID: 10de:1d01 class-ID: 0300
Device-2: WaveRider USB 2.0 Camera type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-1.6:5 chip-ID: 0c46:636b
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.1
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 92 s-size: 1060x301mm (41.73x11.85")
s-diag: 1102mm (43.38")
Monitor-1: DP-0 pos: primary,left res: 1920x1080 hz: 120 dpi: 92
size: 531x299mm (20.91x11.77") diag: 609mm (23.99") modes: N/A
Monitor-2: HDMI-0 pos: right res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
OpenGL: renderer: NVIDIA GeForce GT 1030/PCIe/SSE2
v: 4.6.0 NVIDIA 510.73.05 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Device-2: NVIDIA GP108 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 4
bus-ID: 01:00.1 chip-ID: 10de:0fb8 class-ID: 0403
Device-3: WaveRider USB 2.0 Camera type: USB
Device-4: Logitech G433 Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1:2 chip-ID: 046d:0a6d
class-ID: 0300 serial: <filter>
Device-5: C-Media Blue Snowball type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-2:3 chip-ID: 0d8c:0005
Sound Server-1: ALSA v: k5.15.41-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: no
Device-1: Intel 82579LM Gigabit Network vendor: Dell driver: e1000e
v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
vendor: TP-LINK TG-3468 driver: r8168 v: 8.049.02-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0
Device-1: Dynex Bluetooth 4.0 Adapter [Broadcom 1.12 BCM20702A0] type: USB
driver: btusb v: 0.8 bus-ID: 3-4:5 chip-ID: 19ff:0239 class-ID: fe01
serial: <filter>
Local Storage: total: 1.36 TiB used: 793.27 GiB (56.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WDBNCE5000PNC
type: SSD serial: <filter> rev: 20RL scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MQ04ABF100
type: HDD rpm: 5400 serial: <filter> rev: 1J scheme: GPT
ID-1: / raw-size: 185.86 GiB size: 182.77 GiB (98.34%)
used: 161.36 GiB (88.3%) fs: ext4 dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: b1581353-f1b1-4e88-a51a-e2f4f4f5de19
used: 29.5 MiB (30.7%) fs: vfat dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: FADE-C70B
ID-3: /run/media/noelle/04119d88-1d88-4b65-8b29-dab965773776
raw-size: 712.37 GiB size: 700.13 GiB (98.28%) used: 438.58 GiB (62.6%)
fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 04119d88-1d88-4b65-8b29-dab965773776
ID-4: /run/media/noelle/Windows Games raw-size: 219.14 GiB
size: 219.14 GiB (100.00%) used: 193.3 GiB (88.2%) fs: ntfs dev: /dev/sdb1
maj-min: 8:17 label: Windows Games uuid: 6E688C19688BDE69
ID-1: swap-1 type: file size: 3 GiB used: 14 MiB (0.5%) priority: -2
file: /swapfile
ID-1: /dev/sda1 maj-min: 8:1 size: 50 MiB fs: ntfs label: System Reserved
uuid: 542EBB982EBB721A
ID-2: /dev/sda2 maj-min: 8:2 size: 278.71 GiB fs: ntfs label: N/A
uuid: 8ACEBC24CEBC0A89
ID-3: /dev/sda3 maj-min: 8:3 size: 564 MiB fs: ntfs label: N/A
uuid: F2AC1E18AC1DD845
ID-4: /dev/sda5 maj-min: 8:5 size: 510 MiB fs: ntfs label: N/A
uuid: E2DEB2EDDEB2B8DD
Hub-1: 1-0:1 info: Full speed or root hub ports: 3 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.4:3 info: Wacom CTL-4100 [Intuos (S)] type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 056a:0374 class-ID: 0300 serial: <filter>
Device-2: 1-1.5:4 info: Logitech G402 Gaming Mouse type: Mouse,HID
power: 300mA chip-ID: 046d:c07e class-ID: 0300 serial: <filter>
Device-3: 1-1.6:5 info: WaveRider USB 2.0 Camera type: Video,Audio
power: 500mA chip-ID: 0c46:636b class-ID: 0102 serial: <filter>
Hub-3: 2-0:1 info: Full speed or root hub ports: 3 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:2 info: Logitech G433 Gaming Headset type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 046d:0a6d class-ID: 0300
serial: <filter>
Device-2: 3-2:3 info: C-Media Blue Snowball type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0005 class-ID: 0300
serial: <filter>
Device-3: 3-3:4 info: Logitech G512 RGB MECHANICAL GAMING KEYBOARD
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 046d:c33c class-ID: 0300
serial: <filter>
Device-4: 3-4:5
info: Dynex Bluetooth 4.0 Adapter [Broadcom 1.12 BCM20702A0] type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 19ff:0239 class-ID: fe01 serial: <filter>
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 60 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 48%
Processes: 231 Uptime: 52m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: 1625 note: see --pkg
pacman: 1588 lib: 486 flatpak: 34 snap: 3 Shell: Zsh v: 5.9 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.16
