Manjaro grub theme not working after today's Unstable update
The Manjaro grub theme stopped working for me after todays updates.
Waiting for someone to blindly ask questions is also counter-productive – typically, nobody has a :crystal_ball: at their disposal – Instead, please help others to make informed suggestions, based on information you provide.
inxi --filter --verbosity=8
inxi -zv8
You haven’t mentioned what actions, if any, you have taken so far after you read through this month’s [Unstable Update] October 2026 announcement.
There are quite a few posts regarding the latest grub updates in this month’s announcement.
Also:
Apologies, I had forgotten proper etiquette. I will do my due diligence and respond properly.
After digging though all the content you all suggested, I tried the pertinent fixes for my computer but didn’t find a solution that helped.
I added this line to grub since my system uses MBR:
GRUB_DISABLE_UEFI_FIRMWARE=true
I tried commenting out this line in grub because it does’t appear to be needed for btrfs anymore:
GRUB_SAVEDEFAULT=true
here is the output of inxi:
❯ inxi --filter --verbosity=8
  Kernel: 7.3.0-rc7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-7.3-x86_64
    root=UUID=aa338583-810e-4542-a4d0-95030fcebef5 rw rootflags=subvol=@
    quiet loglevel=3 rd.udev.log_level=3
  Desktop: KDE Plasma v: 6.7.5 tk: Qt v: N/A info: frameworks v: 6.31.0
    wm: kwin_wayland vt: 2 dm: N/A Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: ASRock model: 970DE3/U3S3 serial: <superuser required>
    uuid: <superuser required> Firmware: BIOS vendor: American Megatrends
    v: P1.70 date: 04/08/2013
  System RAM: total: 16 GiB available: 15.59 GiB used: 3.49 GiB (22.4%)
  Array-1: capacity: 32 GiB note: est. slots: 4 modules: 2 EC: None
  Device-1: DIMM0 type: no module installed
  Device-2: DIMM1 type: no module installed
  Device-3: DIMM2 type: N/A size: 8 GiB speed: 800 MT/s volts: N/A
    width (bits): data: 64 total: 64 manufacturer: Corsair
    part-no: CMD16GX3M2A1866C9 serial: N/A
  Device-4: DIMM3 type: N/A size: 8 GiB speed: 800 MT/s volts: N/A
  Info: model: AMD FX-8150 bits: 64 type: MCP arch: Bulldozer level: v2
    built: 2011 process: GF 32nm family: 0x15 (21) model-id: 1 stepping: 2
    microcode: 0x600063E
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 8 smt: <unsupported> cache:
    L1: 384 KiB desc: d-8x16 KiB; i-4x64 KiB L2: 8 MiB desc: 4x2 MiB L3: 8 MiB
    desc: 1x8 MiB
  Speed (MHz): avg: 1400 min/max: 1400/3600 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1400 3: 1400
    4: 1400 5: 1400 6: 1400 7: 1400 8: 1400 bogomips: 57715
  Flags: 3dnowprefetch abm aes aperfmperf apic arat avx clflush cmov
    cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists
    extapic extd_apicid flushbyasid fma4 fpu fxsr fxsr_opt ht hw_pstate ibpb
    ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor msr mtrr
    nodeid_msr nonstop_tsc nopl npt nrip_save nx osvw pae pat pausefilter
    pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni popcnt pse
    pse36 rdtscp rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3
    svm svm_lock syscall topoext tsc tsc_scale vmcb_clean vme vmmcall wdt xop
    xsave
  Type: vmscape status: Not affected
  Device-1: Advanced Micro Devices [AMD/ATI] Lexa PRO [Radeon
    540/540X/550/550X / RX 540X/550/550X] driver: amdgpu v: kernel arch: GCN-4
    code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 2
    speed: 5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s ports: active: DP-1
    empty: DVI-D-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 1002:699f class-ID: 0300
    temp: 43.0 C
  Display: wayland server: X.org v: 1.21.1.25 with: Xwayland v: 24.1.14
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: 0
  Monitor-1: DP-1 model: Acer KA272 serial: <filter> built: 2020 res:
    mode: 1920x1080 hz: 75 scale: 100% (1) dpi: 82 gamma: 1.2 chroma: red:
    x: 0.639 y: 0.337 green: x: 0.314 y: 0.624 blue: x: 0.149 y: 0.055 white:
    x: 0.314 y: 0.329 size: 598x336mm (23.54x13.23") diag: 686mm (27")
    ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960,
    1280x800, 1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576,
    720x480, 640x480, 720x400
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi wayland:
    drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 vendor: amd mesa v: 26.2.4-arch1.1 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon RX 550 / 550 Series (radeonsi
    polaris12 ACO DRM 3.64 7.3.0-rc7-1-MANJARO) device-ID: 1002:699f
    memory: 3.91 GiB unified: no display-ID: :0.0
  API: Vulkan v: 1.4.363 layers: 9 device: 0 type: discrete-gpu name: AMD
    Radeon RX 550 / 550 Series (RADV POLARIS12) driver: mesa radv
    v: 26.2.4-arch1.1 device-ID: 1002:699f surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] SBx00 Azalia vendor: ASRock
    driver: snd_hda_intel v: kernel bus-ID: 00:14.2 chip-ID: 1002:4383
    class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Baffin HDMI/DP Audio [Radeon
    RX 550 640SP / 560/560X] driver: snd_hda_intel v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1
    chip-ID: 1002:aae0 class-ID: 0403
  Device-3: Jieli USB Composite Device
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 2-2:3 chip-ID: 4c4a:4155 class-ID: 0300
  API: ALSA v: k7.3.0-rc7-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.9 status: active with: 1: pipewire-pulse
    vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: e800 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp5s0 state: down mac: <filter>
  Device-2: MediaTek Wireless_Device driver: mt7921u type: USB rev: 3.2
    speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 11-2:3 chip-ID: 0e8d:7961
    class-ID: 0000 serial: <filter>
  Info: services: iwd, NetworkManager, systemd-timesyncd
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 6-3:3 chip-ID: 0bda:8771
  Local Storage: total: 1.94 TiB used: 229.52 GiB (11.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: M4-CT128M4SSD2
    size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 040H scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM006-2DM164
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC26 scheme: MBR
  ID-1: / raw-size: 119.24 GiB size: 119.24 GiB (100.00%)
    used: 28.83 GiB (24.2%) fs: btrfs dev: /dev/sda1 maj-min: 8:1 label: Manjaro
    uuid: aa338583-810e-4542-a4d0-95030fcebef5
  ID-2: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
    used: 200.69 GiB (10.8%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17 label: Home
    uuid: d37ba7c9-3171-4e16-aee5-6c4ddfc3b325
  ID-3: /var/cache raw-size: 119.24 GiB size: 119.24 GiB (100.00%)
  ID-4: /var/log raw-size: 119.24 GiB size: 119.24 GiB (100.00%)
  Hub-1: 1-0:1 info: full speed or root hub ports: 6 rev: 2.0
  Hub-2: 2-0:1 info: full speed or root hub ports: 3 rev: 1.1
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001
  Device-1: 2-1:2 info: Cyber Power System CP1500 AVR UPS type: HID
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 50mA
    chip-ID: 0764:0501 class-ID: 0300
  Device-2: 2-2:3 info: Jieli USB Composite Device type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
  Hub-3: 3-0:1 info: full speed or root hub ports: 6 rev: 2.0
  Device-1: 3-4:2 info: Genesys Logic Multislot Card Reader/Writer
    type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
    chip-ID: 05e3:0716 class-ID: 0806 serial: <filter>
  Hub-4: 4-0:1 info: full speed or root hub ports: 3 rev: 1.1
  Hub-5: 5-0:1 info: full speed or root hub ports: 3 rev: 1.1
  Hub-6: 6-0:1 info: full speed or root hub ports: 3 rev: 1.1
  Device-1: 6-3:3 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
  Hub-7: 7-0:1 info: full speed or root hub ports: 2 rev: 1.1
  Hub-8: 8-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-9: 9-0:1 info: super-speed hub ports: 2 rev: 3.0
  Hub-10: 10-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-11: 10-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1
  Hub-12: 11-0:1 info: super-speed hub ports: 4 rev: 3.0
  Hub-13: 11-1:2 info: Genesys Logic Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
  Device-1: 11-2:3 info: MediaTek Wireless_Device type: Network
    driver: mt7921u interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
    mode: 3.2 gen-1x1 power: 160mA chip-ID: 0e8d:7961 class-ID: 0000
    serial: <filter>
  System Temperatures: cpu: 40.5 C mobo: 37.0 C gpu: amdgpu temp: 43.0 C
  Fan Speeds (rpm): fan-1: 1124 fan-2: 980 fan-3: 1201
  Power: 12v: N/A 5v: N/A 3.3v: 3.33 vbat: 3.38 gpu: amdgpu watts: 5.26
  Packages: 1551 pm: pacman pkgs: 1546 libs: 403 tools: pamac pm: flatpak
    pkgs: 5
    1: https://manjaro.mirror.garr.it/manjaro/unstable/$repo/$arch
    2: https://southfront.mm.fcix.net/manjaro/unstable/$repo/$arch
    3: https://mirror.datacenter.by/pub/mirrors/manjaro/unstable/$repo/$arch
    4: https://mirrors.manjaro.org/repo/unstable/$repo/$arch
    5: https://mirror.it4i.cz/manjaro/unstable/$repo/$arch
    6: https://mirror.informatik.tu-freiberg.de/manjaro/unstable/$repo/$arch
    7: https://muug.ca/mirror/manjaro/unstable/$repo/$arch
    8: https://nocix.mm.fcix.net/manjaro/unstable/$repo/$arch
    9: https://mirrors.atlas.net.co/manjaro/unstable/$repo/$arch
    10: https://ftp.caliu.cat/manjaro/unstable/$repo/$arch
    11: https://manjaro.mirror-services.net/pub/unstable/$repo/$arch
    12: https://mirror.dimensiondata.com/mirrors/manjaro.org/unstable/$repo/$arch
    13: https://mirror.math.princeton.edu/pub/manjaro/unstable/$repo/$arch
    14: https://cofractal-ewr.mm.fcix.net/manjaro/unstable/$repo/$arch
    15: https://mirror.xenyth.net/manjaro/unstable/$repo/$arch
    16: https://mirrors.zju.edu.cn/manjaro/unstable/$repo/$arch
    17: https://mirror.xeonbd.com/manjaro/unstable/$repo/$arch
    18: https://mirror.bakertelekom.fr/manjaro/unstable/$repo/$arch
    19: https://mirror.dkm.cz/manjaro/unstable/$repo/$arch
    20: https://mirror.init7.net/manjaro/unstable/$repo/$arch
    21: https://ftp.tu-chemnitz.de/pub/linux/manjaro/unstable/$repo/$arch
    22: https://ftp.linux.org.tr/manjaro/unstable/$repo/$arch
    23: https://ftp.psnc.pl/linux/manjaro/unstable/$repo/$arch
    24: https://mirrors.up.pt/pub/manjaro/unstable/$repo/$arch
    25: https://manjaro.mirror.wearetriple.com/unstable/$repo/$arch
    26: https://ftp.yz.yamagata-u.ac.jp/pub/linux/manjaro/unstable/$repo/$arch
    27: https://mirrors.cicku.me/manjaro/unstable/$repo/$arch
    28: https://mirrors.ucr.ac.cr/manjaro/unstable/$repo/$arch
    29: https://codingflyboy.mm.fcix.net/manjaro/unstable/$repo/$arch
    30: https://mirrors.ocf.berkeley.edu/manjaro/unstable/$repo/$arch
    31: https://mirror.fcix.net/manjaro/unstable/$repo/$arch
    32: https://repo.ialab.dsu.edu/manjaro/unstable/$repo/$arch
    33: https://mirrors.netix.net/manjaro/unstable/$repo/$arch
    34: https://mirrors.sonic.net/manjaro/unstable/$repo/$arch
    35: https://ohioix.mm.fcix.net/manjaro/unstable/$repo/$arch
    36: https://mirrors.gigenet.com/manjaro/unstable/$repo/$arch
    37: https://manjaro.c3sl.ufpr.br/unstable/$repo/$arch
    38: https://ipng.mm.fcix.net/manjaro/unstable/$repo/$arch
    39: https://mirrors.ft.uam.es/manjaro/unstable/$repo/$arch
    40: https://volico.mm.fcix.net/manjaro/unstable/$repo/$arch
    41: https://ask4.mm.fcix.net/manjaro/unstable/$repo/$arch
    42: https://mirror.koddos.net/manjaro/unstable/$repo/$arch
    43: https://mirror.yandex.ru/mirrors/manjaro/unstable/$repo/$arch
    44: https://forksystems.mm.fcix.net/manjaro/unstable/$repo/$arch
    45: https://irltoolkit.mm.fcix.net/manjaro/unstable/$repo/$arch
    46: https://distrohub.kyiv.ua/manjaro/unstable/$repo/$arch
    47: https://manjaro.grena.ge/unstable/$repo/$arch
    48: https://mirror.phoepsilonix.love/manjaro/unstable/$repo/$arch
    49: https://mirror.alpix.eu/manjaro/unstable/$repo/$arch
    50: https://ftp.snt.utwente.nl/pub/linux/manjaro/unstable/$repo/$arch
    51: https://ct.mirror.garr.it/mirrors/manjaro/unstable/$repo/$arch
    52: https://mirror.netcologne.de/manjaro/unstable/$repo/$arch
    53: http://ftp.dei.uc.pt/pub/linux/manjaro/unstable/$repo/$arch
    54: https://manjaro.mirrors.lavatech.top/unstable/$repo/$arch
    55: https://fosszone.csd.auth.gr/manjaro/unstable/$repo/$arch
    56: https://gsl-syd.mm.fcix.net/manjaro/unstable/$repo/$arch
    57: https://ftp.halifax.rwth-aachen.de/manjaro/unstable/$repo/$arch
    58: https://mirror.alwyzon.net/manjaro/unstable/$repo/$arch
    59: https://ftp.gwdg.de/pub/linux/manjaro/unstable/$repo/$arch
    60: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/unstable/$repo/$arch
    61: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/unstable/$repo/$arch
    62: https://ftpmirror1.infania.net/mirror/manjaro/unstable/$repo/$arch
    63: https://mirrors.eric.ovh/manjaro/unstable/$repo/$arch
    64: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/unstable/$repo/$arch
    65: https://kartolo.sby.datautama.net.id/manjaro/unstable/$repo/$arch
    66: https://opencolo.mm.fcix.net/manjaro/unstable/$repo/$arch
    67: http://ftp.uni-kl.de/pub/linux/manjaro/unstable/$repo/$arch
    68: https://mirror.23m.com/manjaro/unstable/$repo/$arch
    69: https://mirror.raiolanetworks.com/manjaro/unstable/$repo/$arch
    70: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/unstable/$repo/$arch
    71: https://ftp.lysator.liu.se/pub/manjaro/unstable/$repo/$arch
    72: https://ziply.mm.fcix.net/manjaro/unstable/$repo/$arch
    73: https://mirror.dc.uz/manjaro/unstable/$repo/$arch
    74: https://mirror.hiesoft.net/manjaro/unstable/$repo/$arch
    75: http://ossmirror.mycloud.services/os/linux/manjaro/unstable/$repo/$arch
    76: https://mirror.freedif.org/Manjaro/unstable/$repo/$arch
    77: https://coresite.mm.fcix.net/manjaro/unstable/$repo/$arch
    78: https://ftp.belnet.be/mirrors/manjaro/repos/unstable/$repo/$arch
    79: https://free.nchc.org.tw/manjaro/unstable/$repo/$arch
    80: https://nnenix.mm.fcix.net/manjaro/unstable/$repo/$arch
    81: https://mirrors2.manjaro.org/unstable/$repo/$arch
    82: https://manjaro.mirror.liquidtelecom.com/unstable/$repo/$arch
    83: https://ba.mirror.garr.it/mirrors/manjaro/unstable/$repo/$arch
    84: https://mirror.futureweb.be/manjaro/unstable/$repo/$arch
Processes:
  CPU top: 5 of 346
  1: cpu: 100% command: ps pid: 2800 mem: 3.78 MiB (0.0%)
  2: cpu: 29.0% command: brave pid: 2249 mem: 314.0 MiB (1.9%)
  3: cpu: 20.4% command: brave pid: 1821 mem: 455.1 MiB (2.8%)
  4: cpu: 17.4% command: brave pid: 2685 mem: 274.6 MiB (1.7%)
  5: cpu: 14.8% command: brave pid: 1871 mem: 190.0 MiB (1.1%)
  Memory top: 5 of 346
  1: mem: 975.4 MiB (6.1%) command: clamd pid: 709 cpu: 5.6%
  2: mem: 455.1 MiB (2.8%) command: brave pid: 1821 cpu: 20.4%
  3: mem: 376.5 MiB (2.3%) command: brave pid: 1947 cpu: 10.9%
  4: mem: 369.2 MiB (2.3%) command: plasmashell pid: 1361 cpu: 3.1%
  5: mem: 324.7 MiB (2.0%) command: brave pid: 2525 cpu: 6.7%
  Processes: 346 Power: uptime: 4m states: freeze,standby,mem,disk
    suspend: deep avail: s2idle,shallow wakeups: 0 hibernate: platform
    avail: shutdown, reboot, suspend, test_resume image: 6.21 GiB
    services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd
    v: 261 default: graphical tool: systemctl
  Compilers: gcc: 16.2.1 Shell: Zsh v: 5.9.2 running-in: konsole
    inxi: 3.3.41
here are the boot log errors:
Oct 13 21:19:44 Bulldozer kernel: ACPI BIOS Warning (bug): Optional FADT field Pm2ControlBlock has valid Length but zero Address: 0x0000000000000000/0x1 (20260408/tbfadt-614)
Oct 13 21:19:44 Bulldozer kernel: mtrr: your CPUs had inconsistent variable MTRR settings
Oct 13 21:19:44 Bulldozer kernel: virt/tdx: TDX not supported by the host platform
Oct 13 21:19:44 Bulldozer kernel: amd_pstate: the _CPC object is not present in SBIOS or ACPI disabled
Oct 13 21:19:44 Bulldozer kernel: caller pci_map_rom+0x6b/0x1a0 mapping multiple BARs
Oct 13 21:19:44 Bulldozer kernel: amdgpu 0000:01:00.0: [drm] Failed to setup vendor infoframe on connector DP-1: -22
Oct 13 21:19:45 Bulldozer kernel: ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B08 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B0F (\SOR1) (20260408/utaddress-204)
Oct 13 21:19:45 Bulldozer kernel: sp5100-tco sp5100-tco: Failed to reserve MMIO or alternate MMIO region
Oct 13 21:19:45 Bulldozer kernel: sp5100-tco sp5100-tco: probe with driver sp5100-tco failed with error -16
Oct 13 21:19:45 Bulldozer (udev-worker)[457]: 6-3:1.0: Process '/bin/sh -c 'echo enabled > /sys/devices/pci0000:00/0000:00:13.1/usb6/6-3/6-3:1.0/power/wakeup'' failed with exit code 1.
Oct 13 21:19:45 Bulldozer (udev-worker)[462]: 6-3:1.1: Process '/bin/sh -c 'echo enabled > /sys/devices/pci0000:00/0000:00:13.1/usb6/6-3/6-3:1.1/power/wakeup'' failed with exit code 1.
Oct 13 21:19:45 Bulldozer (udev-worker)[451]: cfg80211: Process '/usr/bin/set-wireless-regdom' failed with exit code 1.
Oct 13 21:19:46 Bulldozer (modprobe)[711]: lm_sensors.service: Referenced but unset environment variable evaluates to an empty string: BUS_MODULES
Oct 13 21:19:47 Bulldozer dbus-broker-launch[704]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
Oct 13 21:19:48 Bulldozer NetworkManager[706]: <warn>  [1791940788.6476] device (/net/connman/iwd/0): error setting IPv4 forwarding to '0': Success
Oct 13 21:19:48 Bulldozer dbus-broker-launch[869]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Oct 13 21:19:48 Bulldozer dbus-broker-launch[869]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Oct 13 21:19:48 Bulldozer dbus-broker-launch[869]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Oct 13 21:19:49 Bulldozer kwin_wayland[871]: Device AMD Radeon RX 550 / 550 Series (RADV POLARIS12) misses required Vulkan extensions
Oct 13 21:19:49 Bulldozer kwin_wayland[871]: VK_EXT_image_drm_format_modifier
Oct 13 21:19:50 Bulldozer dbus-broker-launch[704]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
Oct 13 21:19:50 Bulldozer plasma-login-wallpaper[903]: The backend got an unknown wallpaper provider type. The wallpaper will now fall back to the default. Please check your wallpaper configuration!
Oct 13 21:19:51 Bulldozer wireplumber[907]: default: Failed to get percentage from UPower: org.freedesktop.DBus.Error.NameHasNoOwner
Oct 13 21:19:51 Bulldozer plasma-login-greeter[902]: qrc:/qt/qml/org/kde/plasma/login/GreeterState.qml:79: TypeError: Cannot read property 'LoginState' of undefined
Oct 13 21:19:51 Bulldozer plasma-login-greeter[902]: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.27'
Oct 13 21:20:06 Bulldozer dbus-broker[705]: A security policy denied :1.3 to send method call /midi/profile:org.bluez.GattProfile1.Release to :1.29.
Oct 13 21:20:10 Bulldozer (udev-worker)[1031]: 6-3:1.0: Process '/bin/sh -c 'echo enabled > /sys/devices/pci0000:00/0000:00:13.1/usb6/6-3/6-3:1.0/power/wakeup'' failed with exit code 1.
Oct 13 21:20:10 Bulldozer (udev-worker)[1033]: 6-3:1.1: Process '/bin/sh -c 'echo enabled > /sys/devices/pci0000:00/0000:00:13.1/usb6/6-3/6-3:1.1/power/wakeup'' failed with exit code 1.
Oct 13 21:20:22 Bulldozer kwin_wayland[871]: Failed to open /dev/input/event16 device (No such device)
Oct 13 21:20:27 Bulldozer dbus-broker-launch[1132]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
Oct 13 21:20:27 Bulldozer dbus-broker-launch[1132]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
Oct 13 21:20:27 Bulldozer dbus-broker-launch[1132]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
Oct 13 21:20:28 Bulldozer kwin_wayland[1148]: Device AMD Radeon RX 550 / 550 Series (RADV POLARIS12) misses required Vulkan extensions
Oct 13 21:20:28 Bulldozer kwin_wayland[1148]: VK_EXT_image_drm_format_modifier
Oct 13 21:20:32 Bulldozer plasmalogin[831]: Auth: plasmalogin-helper exited with 255
Oct 13 21:20:34 Bulldozer org_kde_powerdevil[1394]: [  1394][  0.180654] (i2c_ioctl_reader1             ) Error in ioctl() read, rc=-1, errno=EREMOTEIO(-121): Remote I/O error, device=/dev/i2c-4
Oct 13 21:20:34 Bulldozer org_kde_powerdevil[1394]: [  1394][  0.282692] (i2c_ioctl_reader1             ) Error in ioctl() read, rc=-1, errno=EREMOTEIO(-121): Remote I/O error, device=/dev/i2c-4
Oct 13 21:20:34 Bulldozer org_kde_powerdevil[1394]: [  1394][  0.384788] (i2c_ioctl_reader1             ) Error in ioctl() read, rc=-1, errno=EREMOTEIO(-121): Remote I/O error, device=/dev/i2c-4
Oct 13 21:20:34 Bulldozer org_kde_powerdevil[1394]: [  1394] Watching for DPMS state changes unimplemented
Oct 13 21:20:34 Bulldozer org_kde_powerdevil[1394]: [  1394][  0.403557] (ddca_get_display_refs         ) Called with include_invalid_displays=false
Oct 13 21:20:34 Bulldozer org_kde_powerdevil[1394]: [  1394][  0.403575] (ddca_get_display_refs         ) Returning DDCA_Display_Ref list:
Oct 13 21:20:34 Bulldozer backlighthelper[1445]: no kernel backlight interface found
Oct 13 21:20:34 Bulldozer org_kde_powerdevil[1394]: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Oct 13 21:20:34 Bulldozer org_kde_powerdevil[1394]: org.kde.powerdevil.backlighthelper.brightness failed
Oct 13 21:20:35 Bulldozer kwin_wayland[1148]: The main thread was hanging temporarily!
Oct 13 21:20:35 Bulldozer org_kde_powerdevil[1394]: Handle button events action could not check for screen configuration
Oct 13 21:20:35 Bulldozer org_kde_powerdevil[1394]: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Oct 13 21:20:37 Bulldozer kernel: warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Oct 13 21:20:37 Bulldozer /usr/lib/xdg-desktop-portal[1486]: Choosing gtk.portal for org.freedesktop.impl.portal.Lockdown as a last-resort fallback
Oct 13 21:20:38 Bulldozer ksmserver[1348]: Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for 'org.kde.ksmserver'")
Oct 13 21:20:38 Bulldozer gmenudbusmenuproxy[1391]: Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for 'org.kde.gmenudbusmenuproxy'")
Oct 13 21:20:38 Bulldozer xembedsniproxy[1395]: Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for 'org.kde.xembedsniproxy'")
Oct 13 21:20:38 Bulldozer polkit-kde-authentication-agent-1[1393]: Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: Unable to open /proc/1393/root")
Oct 13 21:20:38 Bulldozer org_kde_powerdevil[1394]: Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for 'org.kde.org_kde_powerdevil'")
Oct 13 21:20:38 Bulldozer kactivitymanagerd[1379]: Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for 'org.kde.ActivityManager'")
Oct 13 21:20:38 Bulldozer org_kde_powerdevil[1394]: Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: Connection already associated with an application ID")
Oct 13 21:20:38 Bulldozer msm_kde_notifier[1473]: Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for ''")
Oct 13 21:20:38 Bulldozer kaccess[1392]: Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: Connection already associated with an application ID")
Oct 13 21:20:38 Bulldozer xdg-desktop-portal-kde[1581]: Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: Connection already associated with an application ID")
Oct 13 21:20:38 Bulldozer kdeconnectd[1474]: Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: Connection already associated with an application ID")
Oct 13 21:20:38 Bulldozer pamac-tray-plasma[1491]: Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for ''")
Oct 13 21:20:38 Bulldozer ksplashqml[1153]: Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for ''")
Oct 13 21:20:38 Bulldozer plasmashell[1361]: Member visible of the object PlasmaQuick::Dialog overrides a member of the base object. Consider renaming it or adding final or override specifier
Oct 13 21:20:38 Bulldozer ksecretd[1079]: Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: Connection already associated with an application ID")
Oct 13 21:20:39 Bulldozer kded6[1350]: Failed to connect to Bolt manager DBus interface:
Oct 13 21:20:39 Bulldozer plasmashell[1361]: Member enabled of the object DeclarativeDropArea overrides a member of the base object. Consider renaming it or adding final or override specifier
Oct 13 21:20:39 Bulldozer kconf_update[1643]: /usr/share/kconf_update/breath2tobreath.upd defined Version=5 but Version=6 was expected
Oct 13 21:20:39 Bulldozer kded6[1350]: PendingCall Error: "The name is not activatable"
Oct 13 21:20:39 Bulldozer kded6[1350]: Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: Connection already associated with an application ID")
Oct 13 21:20:40 Bulldozer plasmashell[1361]: Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: Connection already associated with an application ID")
Oct 13 21:20:46 Bulldozer plasmashell[1361]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Oct 13 21:24:05 Bulldozer kernel: amdgpu 0000:01:00.0: Disabling VM faults because of PRT request!
Oct 13 21:39:14 Bulldozer baloo_file_extractor[3410]: Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for 'org.kde.baloo'")
Oct 13 21:40:20 Bulldozer baloo_file_extractor[3457]: Failed to register with host portal QDBusError("org.freedesktop.portal.Error.Failed", "Could not register app ID: App info not found for 'org.kde.baloo'")
Oct 13 21:41:32 Bulldozer kioworker[3366]: Creating trash for "/" failed - no permission?
Oct 13 21:41:35 Bulldozer kioworker[3366]: Creating trash for "/" failed - no permission?
Oct 13 21:42:19 Bulldozer kioworker[3366]: Creating trash for "/" failed - no permission?
Mod Edit pasted the pastebin content with the </> button area.
Here are the contents of my grub file:
# GRUB boot loader configuration
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet loglevel=3 rd.udev.log_level=3"
GRUB_CMDLINE_LINUX=""
#GRUB_ENABLE_CRYPTODISK=y
# Set to 'countdown' or 'menu' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT_STYLE=hidden
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors.  Used by normal and wallpaper
# modes only.  Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
#GRUB_SAVEDEFAULT=false
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
GRUB_DISABLE_OS_PROBER=false
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
#GRUB_ROOT_FS_RO=true
If you want to see the grub menu at boot, then you should change that to:
GRUB_TIMEOUT_STYLE=menu
Also, you may want to display the menu for longer than 5 seconds to allow you enough time to select the boot option. You can do this by changing the following line to something like 10 or 15 (seconds):
Make sure that you run sudo update-grub after making any changes to /etc/default/grub.
Edit 2026-10-14T02:50:00Z: there have been a couple of grub pacnew files after recent updates, as my pacman history shows:
[2026-10-07T09:35:56+1100] [ALPM] warning: /etc/default/grub installed as /etc/default/grub.pacnew
[2026-10-08T12:31:16+1100] [ALPM] warning: /etc/default/grub installed as /etc/default/grub.pacnew
It looks to me like you might have replaced your original /etc/default/grub file with the pacnew, rather than reviewed & merged any changes.
Understood. I have learned the hard way that its best to use the manjaro pacnew checker :slightly_smiling_face: I didn’t find any stray pacnew files, but my log does show the same as yours.
❯ grep '\.pacnew' /var/log/pacman.log
[2026-05-02T08:40:19-0400] [ALPM] warning: /etc/mkinitcpio.conf installed as /etc/mkinitcpio.conf.pacnew
[2026-05-30T23:42:33-0400] [ALPM] warning: /etc/plymouth/plymouthd.conf installed as /etc/plymouth/plymouthd.conf.pacnew
[2026-06-25T21:25:26-0400] [ALPM] warning: /etc/plymouth/plymouthd.conf installed as /etc/plymouth/plymouthd.conf.pacnew
[2026-07-26T20:53:14-0400] [ALPM] warning: /etc/locale.gen installed as /etc/locale.gen.pacnew
[2026-08-15T08:35:17-0400] [ALPM] warning: /etc/tpm2-tss/fapi-profiles/P_ECCP384SHA384.json installed as /etc/tpm2-tss/fapi-profiles/P_ECCP384SHA384.json.pacnew
[2026-08-15T08:35:17-0400] [ALPM] warning: /etc/tpm2-tss/fapi-profiles/P_RSA3072SHA384.json installed as /etc/tpm2-tss/fapi-profiles/P_RSA3072SHA384.json.pacnew
[2026-10-08T17:48:55-0400] [ALPM] warning: /etc/default/grub installed as /etc/default/grub.pacnew
Maybe you have a problem with SDDM.
I would try to migrate to Plasma Login Manager by:
$ sudo pacman -Syu plasma-login-manager
$ systemctl disable sddm
$ systemctl enable plasmalogin
$ sudo pacman -Rsn sddm-kcm sddm
It had been recommended for a while already in unstable branch announcements:
@Wollie
Thank you for the reply! I switched to Plasma login manager shortly after It came out. I removed sddm afterwards
@scotty65
I found an old post from 2021 Manjaro bootsplash manager thinking it may help solve my problem. Sadly its no longer in the repo’s.
Mod edit: Consecutive posts merged; @mentions and spacer added.
At the moment I am a little confused as to what the actual issue is.
Is it to do with grub, which provides the boot options, such as the menu where you select which kernel/OS you want to boot into?
Or is it plymouth, which provides the splash screen when booting into the kernel?
Or is it sddm, which is where you type your username/password to load the desktop environment (Plasma, Gnome etc) after the kernel has loaded?
Your linking to the Bootsplash Manager topic has me thinking that the issue is actually to do with Plymouth, not GRUB or SDDM.
Perhaps your best option at this time would be to disable Plymouth (as I did many years ago). You can do it by changing your boot parameters in /etc/default/grub & editing the /etc/mkinitcpio.conf file - instructions can be found here:
I would recommend that you also remove "quiet" from the GRUB_CMDLINE_LINUX_DEFAULT= parameters, so that you will see the system messages as the system boots up and shuts down. It looks a lot better (to me) than a blank screen while the kernel is loading.
As I narrow down potential problems I should clarify that its the plymouth manjaro splash screen that quit working. Strange thing is I did the same updates to my laptop and it still works just fine, the main difference is that my PC uses MBR and laptop uses UEFI.
@scotty65
I have gotten it working again. I made sure “quiet splash” was in my grub config. I also after doing some hunting, the search engine AI suggested that the plymouth hook needed to be earlier in the hooks for mkintcpio.conf. I moved plymouth a few hooks to the left and added amdgpu to modules and ran “sudo grub-mkconfig -o /boot/grub/grub.cfg”.
# vim:set ft=sh:
# MODULES
# The following modules are loaded before any boot hooks are
# run.  Advanced users may wish to specify all system modules
# in this array.  For instance:
#     MODULES=(usbhid xhci_hcd)
MODULES=(amdgpu)
##   NOTE: If you have /usr on a separate partition, you MUST include the
#    usr and fsck hooks.
HOOKS=(base udev autodetect microcode plymouth kms modconf block keyboard keymap filesystems resume fsck)
You don’t need that as the amdgpu driver is built into the kernel and automatically loaded at boot. I removed it from my /etc/mkinitcpio.conf file a long time ago.
Have you been ignoring your .pacnew files? You’re still using the busybox HOOKS rather than the systemd ones, which Arch (and thus Manjaro) moved to quite some time ago. Your system will still boot fine with the busybox HOOKS though, so you don’t have to make the changes immediately if you don’t want to.
You also probably don’t need the resume HOOK, as you have no swap space set up for your device, so I am assuming you do not hibernate it (since swap is required for hibernation).
Here are the uncommented lines in my AMD mini-PC’s /etc/mkinitcpio.conf file as a comparison (remember - I don’t have plymouth installed, so that entry is missing from my HOOKS):
MODULES=()
BINARIES=()
FILES=()
HOOKS=(systemd autodetect microcode modconf kms keyboard sd-vconsole block filesystems fsck)
I address the pacnew files immediately after updates. I will remove amdgpu from modules. Thank you for helping me get pointed in the right direction.
For future reference, Manjaro has a simpler script for that:
sudo update-grub
I know, i’m just nostagic and it pops up quickly in the zsh shell when you start typing :slight_smile:
