Manjaro Gnome won´t start
Hello community,
I am new to Manjaro after using Ubuntu for a few years and would be glad to find some help :slight_smile:
so after a rocky road, full of calamares crashes Manjaro should be installed, but after I rebooted the finished installation, the grub shows up, but while proceeding the boot I just get stucked in the loading screen with 3 points…
My plan was to install a dual boot with windows and a full encrypted LVM for Manjaro,
This is my partiotintable:
nvme0n1             259:0    0 953,9G  0 disk
├─nvme0n1p1         259:1    0   300M  0 part
├─nvme0n1p2         259:2    0   1,8G  0 part
├─nvme0n1p3         259:3    0 699,3G  0 part
├─nvme0n1p4         259:4    0   525M  0 part
└─nvme0n1p5         259:5    0 251,9G  0 part
  └─nvme0n1p5_crypt 254:1    0 251,9G  0 crypt
    ├─system-root   254:2    0    80G  0 lvm
    └─system-home   254:3    0 171,9G  0 lvm
Things I tried, made use Legacy support is off, checked if the hibernate is still disabled on Windows, checked fstab and crypttab.
The reason why I think it could be my partition table, Is when I try to chroot with a live stick
`manjaro-chroot -a
I got this message
==> Mounting (ManjaroLinux) [/dev/mapper/system-root]
 --> mount: [/mnt]
 --> mount: [/mnt/boot/efi]
mount: /mnt/boot/efi: mount point does not exist.
       dmesg(1) may have more information after failed mount system call.
 --> mount: [/mnt/boot]
so I thought there is something wrong with my grub/efi installation (there the calamares installer used to crash before) so I tried this (I found it in the manjaro forum, this person seemed to have the same kind of error)
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
Then I got the output
grub-install: error: /boot/efi doesn’t look like an EFI partition.
This is my grub
GRUB boot loader configuration
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR="Manjaro"
grub-install: error: /boot/efi doesn't look like an EFI partition.
GRUB_CMDLINE_LINUX_DEFAULT=" splash apparmor=1 security=apparmor udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
#GRUB_ENABLE_CRYPTODISK=y
# Set to 'countdown' or 'menu' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT_STYLE=menu
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors.  Used by normal and wallpaper
# modes only.  Entries specified as foreground/background.
(I tried also with an uncommend cryptodisk entry but this didn’t changed anything)
And this is my output I got when I tried to reinstall
les/grubcfg/main.py"
2023-04-25 - 19:25:08 [6]: [PYTHON JOB]: Found gettext "de_DE" in "/usr/share/locale/de_DE"
2023-04-25 - 19:25:08 [6]:     .. Job description from pretty_name "grubcfg" = "GRUB konfigurieren."
2023-04-25 - 19:25:08 [6]:     .. Running ("sh", "-c", "which dracut")
2023-04-25 - 19:25:08 [6]:     .. Target cmd: ("sh", "-c", "which dracut") Exit code: 1 output:
 which: no dracut in (/usr/sbin:/usr/bin:/sbin:/bin:/root/bin)
2023-04-25 - 19:25:08 [6]:     .. Running ("sh", "-c", "which plymouth")
2023-04-25 - 19:25:08 [6]: virtual void Calamares::JobThread::run()
    Starting job "bootloader" ( 30 / 32 )
2023-04-25 - 19:25:08 [6]: virtual Calamares::JobResult Calamares::PythonJob::exec()
    Job file "/usr/lib/calamares/modules/bootloader/main.py"
2023-04-25 - 19:25:08 [6]:     .. Job description from pretty_name "bootloader" = "Installiere Bootloader."
2023-04-25 - 19:25:08 [6]: [PYTHON JOB]: "Bootloader: grub (efi)"
2023-04-25 - 19:25:08 [6]:     .. Running ("grub-install", "--target=x86_64-efi", "--efi-directory=/boot/efi", "--bootloader-id=Manjaro", "--force")
2023-04-25 - 19:25:10 [6]: [PYTHON JOB]: "UEFI Fallback: True"
2023-04-25 - 19:25:10 [6]: [PYTHON JOB]: "  .. installing 'bootx64.efi' fallback firmware"
2023-04-25 - 19:25:10 [6]:     .. Running ("grub-mkconfig", "-o", "/boot/grub/grub.cfg")
2023-04-25 - 19:25:10 [6]:     .. Target cmd: ("grub-mkconfig", "-o", "/boot/grub/grub.cfg") Exit code: 1 output:
 /usr/bin/grub-probe: error: cannot find a device for / (is /dev mounted?).
2023-04-25 - 19:25:10 [2]: WARNING: [PYTHON JOB]: "Command 'grub-mkconfig -o /boot/grub/grub.cfg' returned non-zero exit status 1."
2023-04-25 - 19:25:10 [6]: [PYTHON JOB]: "stdout:/usr/bin/grub-probe: error: cannot find a device for / (is /dev mounted?)."
2023-04-25 - 19:25:10 [6]: [PYTHON JOB]: "stderr:None"
2023-04-25 - 19:25:10 [6]: virtual void Calamares::JobThread::run()
    Skipping non-emergency job "postcfg"
2023-04-25 - 19:25:10 [6]:     ..  Skipping non-emergency job "Dateisysteme aushängen."
2023-04-25 - 19:25:10 [1]: void Calamares::ViewManager::onInstallationFailed(const QString&, const QString&)
    ERROR: Installation failed: "Fehler beim Installieren des Bootloaders"
2023-04-25 - 19:25:10 [6]:     .. - message: "Fehler beim Installieren des Bootloaders"
2023-04-25 - 19:25:10 [6]:     .. - details: Der Bootloader konnte nicht installiert werden. Der Installationsbefehl <pre>grub-mkconfig -o /boot/grub/grub.cfg</pre> erzeugte Fehlercode 1.
2023-04-25 - 19:25:10 [6]: void Calamares::ViewManager::onInstallationFailed(const QString&, const QString&)
    Calamares will quit when the dialog closes.
2023-04-25 - 19:25:10 [2]: QQmlExpression: Attempted to evaluate an expression in an invalid context
2023-04-25 - 19:25:10 [6]: void Config::doNotify(bool, bool)
    Notification not sent; completion: failed
So I guess it is something with /boot/efi and boot could be false flags format etc…
maybe something completely else. Anyway I try to Install and run Manjaro since 9 hours now and would be glad for any kind of help and be able to check my Mails soon :wink:
Moderator edit: Improved formatting for easier readability.
Tip: Use a spellchecker next time. :wink:
(Sorry, edited again with a spellchecker)
