hi,
I have font anti-aliasing set to enable, subpixel RGB, font hinting slight.
Chrome uses the subpixel RGB, but does not apply any hinting at all. Whereas Firefox correctly applies font hinting slight.
How do I rectify this?
p.s. can easily check using KMag. Zoom in and the bottom of letters like e should be perfectly flat if slight font hinting is enabled.
