Hi, since yesterday my Manjaro is running very slow and freezes, or when I click it takes a few seconds to react. here is some info from my laptop:
**inxi -Fxxx**
Host: dary Kernel: 5.10.109-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
v: 11.2.0 Desktop: GNOME v: 41.5 tk: GTK v: 3.24.33 wm: gnome-shell dm: GDM
v: 41.3 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 80K5 v: Lenovo Z41-70
serial: <superuser required> Chassis: type: 10 v: Lenovo Z41-70
Mobo: LENOVO model: Lenovo Z41-70 v: No DPK serial: <superuser required>
UEFI: LENOVO v: C2CN19WW(V2.00) date: 07/14/2015
ID-1: BAT1 charge: 37.6 Wh (100.0%) condition: 37.6/39.6 Wh (95.1%)
volts: 16.7 min: 14.9 model: LENOVO PABAS0241231 type: Li-ion serial: 41167
status: full
Info: dual core model: Intel Core i7-5500U bits: 64 type: MT MCP
smt: enabled arch: Broadwell rev: 4 cache: L1: 128 KiB L2: 512 KiB
L3: 4 MiB
Speed (MHz): avg: 2934 high: 2992 min/max: 500/3000 cores: 1: 2895
2: 2992 3: 2894 4: 2957 bogomips: 19161
Device-1: Intel HD Graphics 5500 vendor: Lenovo driver: i915 v: kernel
ports: active: HDMI-A-1,eDP-1 empty: DP-1 bus-ID: 00:02.0
chip-ID: 8086:1616 class-ID: 0300
Device-2: AMD Topaz XT [Radeon R7 M260/M265 / M340/M360 M440/M445 530/535
620/625 Mobile]
driver: amdgpu v: kernel pcie: speed: 2.5 GT/s lanes: 4 bus-ID: 04:00.0
chip-ID: 1002:6900 class-ID: 0380
Device-3: Chicony Lenovo EasyCamera type: USB driver: uvcvideo
bus-ID: 2-6:5 chip-ID: 04f2:b50f class-ID: 0e02 serial: 0001
Display: x11 server: X.Org v: 1.21.1.3 with: Xwayland v: 22.1.1
compositor: gnome-shell driver: X: loaded: amdgpu,modesetting
unloaded: radeon alternate: fbdev,vesa gpu: i915 display-ID: :1
screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
s-diag: 1055mm (41.54")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: right model: Dell S2719HS
serial: 8QQ2Y13 res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.54x13.23") diag: 686mm (27") modes: max: 1920x1080
min: 720x400
Monitor-2: eDP-1 pos: primary,left model: AU Optronics 0x1b3d
res: 1920x1080 hz: 60 dpi: 158 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") modes: 1920x1080
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Broadwell-U Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0
class-ID: 0403
Sound Server-1: ALSA v: k5.10.109-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1
port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0 state: down mac: f0:76:1c:dc:40:fe
Device-2: Intel Wireless 3160 driver: iwlwifi v: kernel pcie:
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:08b4 class-ID: 0280
IF: wlp3s0 state: up mac: e4:f8:9c:2d:78:ff
IF-ID-1: virbr0 state: down mac: 52:54:00:bb:f7:5e
bus-ID: 2-7:6 chip-ID: 8087:07dc class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 4 state: up
address: E4:F8:9C:2D:79:03
Local Storage: total: 931.51 GiB used: 455.1 GiB (48.9%)
ID-1: /dev/sda vendor: Western Digital model: WD10JPVX-08JC3T5
size: 931.51 GiB speed: 6.0 Gb/s type: HDD rpm: 5400
serial: WD-WX21AA4RNEJE rev: 1A05 scheme: GPT
ID-1: / size: 530.63 GiB used: 383.57 GiB (72.3%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 299.4 MiB used: 284 KiB (0.1%) fs: vfat
dev: /dev/sda1
System Temperatures: cpu: 53.0 C mobo: 27.8 C gpu: amdgpu temp: 40.0 C
Processes: 275 Uptime: 3h 9m wakeups: 6 Memory: 7.68 GiB
used: 2.39 GiB (31.1%) Init: systemd v: 250 Compilers: gcc: 11.2.0
clang: 13.0.1 Packages: 1874 pacman: 1868 flatpak: 6 Shell: Bash v: 5.1.16
running-in: terminator inxi: 3.3.15
**df -H**
Filesystem Size Used Avail Use% Mounted on
dev 4,2G 0 4,2G 0% /dev
run 4,2G 2,0M 4,2G 1% /run
/dev/sda2 570G 416G 126G 77% /
tmpfs 4,2G 65M 4,1G 2% /dev/shm
tmpfs 4,2G 7,2M 4,2G 1% /tmp
/dev/loop0 132k 132k 0 100% /var/lib/snapd/snap/bare/5
/dev/loop2 116M 116M 0 100% /var/lib/snapd/snap/core/12834
/dev/loop4 118M 118M 0 100% /var/lib/snapd/snap/core/12941
/dev/loop1 230M 230M 0 100% /var/lib/snapd/snap/code/93
/dev/loop3 230M 230M 0 100% /var/lib/snapd/snap/code/94
/dev/loop5 59M 59M 0 100% /var/lib/snapd/snap/core18/2284
/dev/loop7 66M 66M 0 100% /var/lib/snapd/snap/core20/1376
/dev/loop6 59M 59M 0 100% /var/lib/snapd/snap/core18/2344
/dev/loop8 123M 123M 0 100% /var/lib/snapd/snap/docker/1690
/dev/loop9 66M 66M 0 100% /var/lib/snapd/snap/core20/1405
/dev/loop11 171M 171M 0 100% /var/lib/snapd/snap/gnome-3-28-1804/145
/dev/loop10 123M 123M 0 100% /var/lib/snapd/snap/docker/1767
/dev/loop13 230M 230M 0 100% /var/lib/snapd/snap/gnome-3-34-1804/77
/dev/loop12 173M 173M 0 100% /var/lib/snapd/snap/gnome-3-28-1804/161
/dev/loop15 69M 69M 0 100% /var/lib/snapd/snap/gtk-common-themes/1519
/dev/loop14 69M 69M 0 100% /var/lib/snapd/snap/gtk-common-themes/1515
/dev/loop16 340M 340M 0 100% /var/lib/snapd/snap/kde-frameworks-5-qt-5-15-core20/14
/dev/loop18 47M 47M 0 100% /var/lib/snapd/snap/snapd/15314
/dev/loop17 46M 46M 0 100% /var/lib/snapd/snap/snapd/15177
/dev/loop20 69M 69M 0 100% /var/lib/snapd/snap/sublime-text/112
/dev/loop19 68M 68M 0 100% /var/lib/snapd/snap/sublime-text/110
/dev/sda1 314M 291k 314M 1% /boot/efi
/dev/sda3 413G 77G 315G 20% /mnt/E
tmpfs 826M 123k 825M 1% /run/user/1000
