Hello, I’m using Manjaro for a while (about 1 year), but last week it starts to freeze every day during my day use.
Today it freezes two times, while I was programming in VSCodium and running a pamac update, I think I get enough RAM and even Swap.
This is my system information:
Kernel: 5.15.50-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=c3b7eca5-d676-4ce5-9d1f-68ff908cf780 rw rootflags=subvol=@ quiet
splash apparmor=1 security=apparmor
resume=UUID=5ac071a8-3966-4919-80ae-7c42638c35da udev.log_priority=3
Desktop: GNOME v: 42.2 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: Dell product: Inspiron 5402 v: N/A
Mobo: Dell model: 0FJYHK v: A00 serial: <superuser required> UEFI: Dell
v: 1.8.0 date: 10/01/2021
ID-1: BAT0 charge: 47.0 Wh (100.0%) condition: 47.0/53.0 Wh (88.7%)
volts: 16.6 min: 15.0 model: BYD DELL TXD0316 type: Unknown serial: <filter>
status: full
Device-1: hid-dc:2c:26:07:76:d1-battery model: Keychron K1 serial: N/A
charge: N/A status: discharging
RAM: total: 15.36 GiB used: 4.52 GiB (29.5%)
RAM Report:
Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
arch: Tiger Lake built: 2020 process: Intel 10nm family: 6
model-id: 0x8C (140) stepping: 1 microcode: 0xA4
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2918 high: 3700 min/max: 400/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 1269 2: 3242 3: 3700
4: 3047 5: 3146 6: 2425 7: 3600 8: 2918 bogomips: 27040
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell
driver: i915 v: kernel arch: Gen12.1 process: Intel 10nm built: 2020-21
ports: active: HDMI-A-1,eDP-1 empty: DP-1 bus-ID: 0000:00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX330] vendor: Dell driver: nouveau
v: kernel non-free: 515.xx+ status: current (as of 2022-06) arch: Pascal
process: TSMC 16nm built: 2016-21 bus-ID: 0000:2b:00.0 chip-ID: 10de:1d16
class-ID: 0302
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-6:4 chip-ID: 0bda:5538 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.2
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
gpu: i915 display-ID: 0
Monitor-1: HDMI-A-1 model: AOC 27G2G5 serial: <filter> built: 2021
res: 1920x1080 dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23")
diag: 686mm (27") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: eDP-1 model: BOE Display 0x082e built: 2018 res: 1920x1080
dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 22.1.2
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
Sound Server-1: ALSA v: k5.15.50-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
IF-ID-1: br-2d0752672c98 state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: virbr0 state: down mac: <filter>
Message: Output throttled. IPs: 1; Limit: 10; Override: --limit [1-x;-1 all]
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 3-10:5 chip-ID: 8087:0aaa class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 249.62 GiB (52.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data
model: IM2P33F3A NVMe 512GB size: 476.94 GiB block-size: physical: 512 B
rev: 92103061 temp: 42.9 C scheme: GPT
ID-1: / raw-size: 459.74 GiB size: 459.74 GiB (100.00%)
used: 249.62 GiB (54.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: c3b7eca5-d676-4ce5-9d1f-68ff908cf780
used: 588 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: FF71-73AF
ID-3: /home raw-size: 459.74 GiB size: 459.74 GiB (100.00%)
ID-4: /var/cache raw-size: 459.74 GiB size: 459.74 GiB (100.00%)
ID-5: /var/log raw-size: 459.74 GiB size: 459.74 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.9 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 5ac071a8-3966-4919-80ae-7c42638c35da
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-2:2 info: Microsoft Classic IntelliMouse type: Mouse,HID
power: 200mA chip-ID: 045e:0823 class-ID: 0300
Device-2: 3-5:3 info: Shenzhen Goodix FingerPrint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 27c6:538d class-ID: ff00
Device-3: 3-6:4 info: Realtek Integrated_Webcam_HD type: Video
Device-4: 3-10:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 71.0 C mobo: N/A gpu: nouveau temp: 63.0 C
Fan Speeds (RPM): cpu: 4594
Processes: 339 Uptime: 18m wakeups: 4 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1
Packages: 1364 pacman: 1352 lib: 334 flatpak: 5 snap: 7 Shell: Zsh v: 5.9
running-in: terminator inxi: 3.3.19
Someone can help me, to fix this?
Thanks!
