Hello,
I installed Manjaro gnome on a laptop with low configs. I just did a fresh install with all default options (let the installer decide whatever is better).
I experience random system freeze where nothing works. Not even switching to tty and Sysrq. I have to hard reset by holding down power button. There is no defined pattern for this freeze. After reading many such similar posts, I tried to look into the swap space. However, I did not find one (I assume the partition type for swap will be “swap”)
here is my system config:
inxi
ystem:
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=973b9d6e-27e8-4db7-8311-9145072a59d2 ro quiet splash apparmor=1
Desktop: GNOME 40.3 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.0
Type: Laptop System: Acer product: Aspire R3-131T v: V1.15 serial: <filter>
Mobo: Acer model: Aspire R3-131T v: V1.15 serial: <filter> UEFI: Insyde
v: 1.15 date: 07/04/2016
ID-1: BAT0 charge: 19.4 Wh (58.3%) condition: 33.3/48.9 Wh (68.0%)
volts: 14.9 min: 15.2 model: PANASONIC AC14B3K type: Li-ion serial: <filter>
status: Discharging
RAM: total: 3.67 GiB used: 2.57 GiB (69.9%)
Info: Quad Core model: Intel Pentium N3710 bits: 64 type: MCP arch: Airmont
family: 6 model-id: 4C (76) stepping: 4 microcode: 411 cache: L2: 1024 KiB
bogomips: 12805
Speed: 480 MHz min/max: 480/2560 MHz Core speeds (MHz): 1: 480 2: 480 3: 658
4: 772
Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_perfmon bts clflush
cmov constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept erms
est flexpriority fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pclmulqdq pdcm pebs
pge pni popcnt pse pse36 pti rdrand rdtscp rep_good sep smep ss sse sse2
tsc_deadline_timer tsc_known_freq tsc_reliable vme vmx vnmi vpid xtopology
xtpr
Type: spec_store_bypass status: Not affected
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
Integrated Graphics
vendor: Acer Incorporated ALI driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:22b1 class-ID: 0300
Device-2: Chicony HD WebCam type: USB driver: uvcvideo bus-ID: 1-3:2
chip-ID: 04f2:b520 class-ID: 0e02
Display: wayland server: X.org 1.20.11 compositor: gnome-shell driver:
loaded: i915 note: n/a (using device driver) - try sudo/root display-ID: 0
OpenGL: renderer: Mesa DRI Intel HD Graphics 405 (BSW) v: 4.6 Mesa 21.1.5
compat-v: 3.0 direct render: Yes
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:2284 class-ID: 0403
Sound Server-1: ALSA v: k5.9.16-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.32 running: no
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 1000
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Intel Wireless 3165 driver: iwlwifi v: kernel port: 1000
bus-ID: 02:00.0 chip-ID: 8086:3165 class-ID: 0280
bus-ID: 1-5:4 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 465.76 GiB used: 280.38 GiB (60.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD5000LPCX-21VHAT0 size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 1A01 scheme: GPT
ID-1: / raw-size: 463.26 GiB size: 454.99 GiB (98.21%)
used: 280.37 GiB (61.6%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 973b9d6e-27e8-4db7-8311-9145072a59d2
used: 6.9 MiB (1.4%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: A582-C75D
ID-1: /dev/sda2 maj-min: 8:2 size: 2 GiB fs: swap label: N/A
uuid: 98546811-19a6-4a13-a56f-b53a99000024
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 7 rev: 2.0
Device-1: 1-3:2 info: Chicony HD WebCam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b520
class-ID: 0e02
Device-2: 1-4:3 info: Raydium Raydium Touch System type: HID
driver: hid-multitouch,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 96mA chip-ID: 2386:0401 class-ID: 0300
Device-3: 1-5:4 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 48.0 C mobo: N/A
Processes: 208 Uptime: 1h 25m wakeups: 1 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1324 lib: 391
flatpak: 0 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.06
Here are my partitions
fdisk -l
Device Start End Sectors Size Type
/dev/sda1 2048 1050623 1048576 512M EFI System
/dev/sda2 1050624 5244927 4194304 2G Linux filesystem
/dev/sda3 5244928 976773134 971528207 463.3G Linux filesystem
Is there a swap configured for my system? what is the 2GB of space taken by sda2?
Is there anything else I should look for?
Thanks.
