I use Manjaro Gnome edition, My motherboard has onboard VGA, one of them is hdmi and other is VGA, it work good
Today our team lead buy Nvidia Geforce GT730 and I install, but after install after boot I can not see login screen and I can not login and use Manjarom but SSH and ctrl+alt+f2 working and I can use it, but I can not see login screen
I search around and I do these but nothing happen
nvidia driver ==================
sudo nano /etc/modprobe.d/blacklist-nouveau.conf
blacklist nouveau
options nouveau modeset=0
and
sudo cat /etc/mkinitcpio.conf
MODULES=(nvidia nvidia_modeset nvidia_uvm nvidia_drm)
and
sudo mkinitcpio -P
and
sudo rm /etc/X11/xorg.conf
sudo nvidia-xconfig
and I add this to grub
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash nvidia-drm.modeset=1 apparmor=1 security=apparmor udev.log_priority=3"
and
sudo update-grub
but nothing happpen
please help me to fix this
I have 2 monitors and I want use all of them with HDMI cable
Nvidia GT730 is not supported by latest version of nvidia drivers,
but legacy drivers (v470) can be installed by using either:
Manjaro Settings Manager - Hardware Configuration GUI to install video-nvidia-470xx
Or this command:
sudo mhwd -a pci nonfree 0300
Configure Graphics Cards - Manjaro Wiki
see also - Configure NVIDIA (non-free) settings and load them on Startup - Manjaro Wiki
Thank,
I install two monitor on onbaord VGA card not on Nvidia GT730 and I can login right now I see
sudo mhwd -a pci nonfree 0300 ✔ mostafa@faridi
> Using config 'video-hybrid-intel-nvidia-470xx-prime' for device: 0000:01:00.0 (0300:10de:1287) Display controller nVidia Corporation GK208B [GeForce GT 730]
> Using config 'video-hybrid-intel-nvidia-470xx-prime' for device: 0000:00:02.0 (0300:8086:3e92) Display controller Intel Corporation CoffeeLake-S GT2 [UHD Graphics 630]
Error: config 'video-hybrid-intel-nvidia-470xx-prime' conflicts with config(s): video-nvidia
Do I need edit bios too?
I also see
inxi -G 1 ✘ mostafa@faridi
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] driver: i915 v: kernel
Device-2: NVIDIA GK208B [GeForce GT 730] driver: N/A
Display: unspecified server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6
driver: X: loaded: nvidia gpu: i915 tty: 80x24 resolution: 1: 1024x768
2: 1920x1080
API: EGL v: 1.5 drivers: iris,swrast
platforms: gbm,wayland,surfaceless,device
API: OpenGL v: 4.6 compat-v: 4.5 vendor: mesa v: 25.0.5-arch1.1
note: console (EGL sourced) renderer: Mesa Intel UHD Graphics 630 (CFL
GT2), llvmpipe (LLVM 19.1.7 256 bits)
API: Vulkan v: 1.4.313 drivers: intel surfaces: N/A
Info: Tools: api: eglinfo, glxinfo, vulkaninfo gpu: corectrl,
nvidia-settings, nvidia-smi x11: xdpyinfo, xprop, xrandr
when I want remove I see
sudo mhwd -r pci video-nvidia 1 ✘ mostafa@faridi
> Removing video-nvidia...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/local/pci/video-nvidia/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
checking dependencies...
:: removing nvidia-utils breaks dependency 'nvidia-utils' required by python-nvidia-ml-py
:: removing nvidia-utils breaks dependency 'nvidia-utils' required by python-pynvml
Error: pacman failed!
Error: script failed!
From original post it seemed like this was a desktop system with a discrete GPU
my system has the same GPU
Device-1: NVIDIA GK208B [GeForce GT 730] driver: nvidia v: 470.256.02
$ mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia-470xx 2023.03.23 false PCI
video-nvidia
cannot be removed but it can replaced by another driver
try installing video-nvidia-470
sudo mhwd -i pci video-nvidia-470xx
If that does not work, reinstall the free driver
sudo mhwd -i pci video-linux
and revert all the changes made in original post. Manjaro tools for GPU drivers should create any system reconfigurations automatically, editing system files should not be necessary
I see
mhwd -li ✔ mostafa@faridi
video-nvidia 2025.01.13 false PCI
video-linux 2024.05.06 true PCI
~ sudo mhwd -r pci video-nvidia ✔ mostafa@faridi
~ sudo mhwd -i pci video-nvidia-470xx 1 ✘ mostafa@faridi
Error: config 'video-nvidia-470xx' conflicts with config(s): video-nvidia
~ sudo mhwd -i pci video-linux 1 ✘ mostafa@faridi
Warning: a version of config 'video-linux' is already installed!
Use -f/--force to force installation...
I do not know why I can not remove video-nvidia
The error messages are very clear, though.
So, you must remove python-pynvml
and python-nvidia-ml-py
first.
sudo pacman -Rns python-pynvm python-nvidia-ml-py
Thank you
Your guide save my life
system
Closed
24 May 2025 07:01
8
