Manjaro GNOME after a fresh install dependency problem
I just installed a fresh Manjaro GNOME 42.4 and I’ve tried to update all my packages.
This is from Add/Remove Software:
could not satisfy dependencies:
- unable to satisfy dependency 'expat=2.4.8' required by lib32-expat
- unable to satisfy dependency 'libcap=2.65' required by lib32-libcap
- unable to satisfy dependency 'libbpf.so=0-64' required by qemu-system-x86
This is from terminal after running sudo pacman -Syyu
 core        164.1 KiB   122 KiB/s 00:01 [#############################################################################] 100%
 extra        1955.5 KiB  1430 KiB/s 00:01 [#############################################################################] 100%
 community        7.3 MiB  15.7 MiB/s 00:00 [#############################################################################] 100%
 multilib        180.5 KiB   965 KiB/s 00:00 [#############################################################################] 100%
resolving dependencies...
:: unable to satisfy dependency 'libbpf.so=0-64' required by qemu-system-x86
:: installing expat (2.4.9-1) breaks dependency 'expat=2.4.8' required by lib32-expat
:: installing libcap (2.66-1) breaks dependency 'libcap=2.65' required by lib32-libcap
Dose anyone what should I do?
Always refresh mirrors first on fresh install:
sudo pacman-mirrors -f5 && sudo pacman -Syyu
or
sudo pacman-mirrors -f5 && pamac update
The equivalent of that can be done from Pamac UI aka Add/Remove Software Preferences
Mirrors and then Database …
Thx, now is working :smiley:
