Manjaro GNOME ( 17.0 )
release-final
gellivara
#82
Hope you don’t lose your focus on Manjaro KDE edition.
#83
:slight_smile: :grinning: don’t worry, this is only another flavour of Manjaro . Nothing change :wink:
#84
Maybe you should start a new thread for your questions about what is starting up with the desktop and how to change it in the Gnome section of the forums.
Wait a second, is there a Gnome forum???
Anyway there is Tweak tool to change start up apps and there are also other ways, what are your needs?
#85
i think creating new thread is not necessary, if only this thread can handle my question…so why not???
my need is manage startup program with disable or let it enable :smiley:
but i didnt found on tweak tool till now
#86
Hi !
How can i remove the black theme of nautilus in the side bar ?
#87
Do you mean ? You can change the theme for gnome.
#88
Hi, strangely no !
For example if I switch to Arc Maia “Lighter” my nautilus keep a dark sidebar. I was just wondering if it was just a package to remove or if it was more deeper. Plus there is other Dark toutch here and there, like the gnome topbar.
#89
You have only to manage with theme and gnome tweak tools :
this is breath gtk theme with global theme disable and user theme shell set to default
#90
haha, i feel dumb… so this is the arc maia theme wo makes the dark :wink:
Cheers And congrats Manjaro Gnome is perfect !
#91
I’m very glad to see that my favourite DE is officially supported by my favourite distro ! And that my favourite theme is used ! (even if I don’t really like the green of the folders in the maia version ^^). I took advantage of the opportunity to reinstall my system. Now I have very few changes to make, it looks like what i’m expecting of a distro. It just lakes the Topicons plus plugin imo (to move icons from the little hiding bar at the bottom left to the top), and I prefer a simple Application menu over gnomenu.
All is working fine, great job ! (However with the live cd I had to click several times to open the installation software, as it was crashing as soon as opened.)
Thanks !
#92
My first time using manjaro, and I’m really impressed with the gnome version so far, a much better experience than I had using fedora 25
#93
Not trying to necrobump, but I seriously dislike the default GNOME setup, although I enjoy the improved support features on it. Did some light customizing to get it like XFCE4. After that, pure GNOME3 bliss. :+1:
#94
Agreed, what extensions are you using to make it like this?
#95
Topicons (plus), bottom bar, dash to dock, workspace indicator, weather, one of the many application menus, and maybe system monitor. I think I’m seeing at least those.
#96
I’d like to ask is the gdm/pulseaudio problem exists in Manjaro GNOME 17.0?
I have Manjaro XFCE and I’ve installed Gnome recently, but gdm’s pulseaudio is stealing my bluetooth devices. The only solution I know is described here: https://wiki.archlinux.org/index.php/Bluetooth_headset#Gnome_with_GDM
I would like to do clean install, forget such problems and start using my OS like a regular user (without “hacking” OS internals).
Marcin
#97
Ste74 something bad is with this release if you want to install on a partition with f2fs. after install i have
F2FS-fs (sda2): Cannot load crc32 driver
in another manjaro release i can install on f2fs partition and use in out the box
edit: If anyone wants to use on f2fs this is how i fix it:
run some livecd and in terminal type
sudo fdisk -l
mount your / partition in my cause it was sda2
mount /dev/sda2 /mnt
chroot /mnt/ /bin/bash/
mount /proc and /dev they will be need to update mkinitcpio
mount -t proc proc /proc
mount -t devtmpfs udev /dev
sudo nano /etc/mkinitcpio.conf
add this in MODULES line
MODULES="crc32 libcrc32c crc32c_generic crc32c-intel crc32-pclmul"
sudo mkinitcpio -p /etc/mkinitcpio.d/linux49.present
update-grub
#98
Hi , do you mean with other release : other 17.0 release or an old release ?
#99
other release like kde, deepin, xfce works on f2f2 in version 16.08, 16.10 and latest 17. i tested almost all DE and only in gnome i have problem this problem first time.
#100
Hi, @Ste74
Why gdm-plymouth has plymouth-legacy dependency, not plymouth ? I have installed plymouth with theme manjaro gnome 17.0. Can it be problem if I install gdm-plymouth with plymouth-legacy?
#101
Hi , no problem with -legacy :slight_smile: . we have called legacy but is the last 0.8 series if i remember correctly , normal plymouth is at 0.9 series but for us this version not work fine… only you are sure of install plymouth ? We have dropped plymouth in all new Iso because not have improvement the only benefit is a wonder screen during boot :grin:
