Manjaro GNOME ( 17.0 )
release-final
gellivara
#42
Another question…how could I get the menu fonts darker or thinker like in the adwaita theme? I know this is an arc base theme…could I tweak it?
#43
Ops, i lost a part of your message … if you install the sonar desktop settings and the related app you have sonar… only you have to activate the systemd service for orca … i don’t remember fine because when helping sonar team we use a buildiso to test if all ( in our end) work fine ) and not remember se orca start after reboot without manual intervent :innocent:
#44
Hello @Ste74 - i followed the wiki to get rid of plymouth, only think I seem to not fully undertand is, how do I make x.org and gnome start now that the plymouth packages are removed?
#45
The best Manjaro release!!! Thank you guys for all your work! Gnome seems pretty solid and it’s now my default desktop environment. The only think I really hate is nautilus, so I use nemo instead (fortunately nemo can manage the desktop icons too).
#46
Sudo systemctl enable gdm.service -f
#47
why are the fonts more blurry than on the plasma edition?
#48
You probably have it set to Cantarell out of the box. It is a thicker font than the default in Plasma which is noto sans. If you switch the font, which I have the clarity is pretty much the same.
#49
Just did the fresh install. First boot was in 9 s, second boot already 8s :slight_smile: great job @Ste74. :slight_smile:
#50
ok I got it…noto sans font and breath gtk theme…looks better :slight_smile:
#51
is the pamac now support AUR in gnome edition?
#52
Yes, but i have leave also yaourt and all base-devel pkgs for building pkgs…
#53
What dm you have lightdm? I think you have to disable lightdm-plymouth.service and enable lightdm.service but also other suggestion is fine : switch to gdm for enable wsyland support also…
#54
It’s means that if I search the AUR software in Pamac, it should find the result right?
#55
Yes but you have to enable in the pamac preference or switch the button …
#56
Okay, thanks, I find that.
So this feature is kind of a GUI tool for yaourt if I am right?
#57
No is a gui wrapper of pacman with aur support :wink:
#58
if it’s wrapper of pacman, so it will install the binary file just like other apps in the official repo?
#59
I read the introduction of this native support, but I am not really understand the way it works
#60
Gnome being an official iso is good news, who can say no to more choices :slight_smile: . I just hope you guys are not taking on to much work to make this happen, i feel like you guys do more then enough for us as it is.
#61
multimedia codecs are pre installed???
