Sound stopped working suddenly
Hi, I’m kinda new to Manjaro and suddenly after 5 months of usage, my audio stopped working. Manjaro shows that some sounds are here, but nothing comes from the computer.
Some computer specs:
  Kernel: 5.15.81-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=c4d3e5d3-3d20-4595-8176-07dcd5614be8 rw quiet apparmor=1
  Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: LENOVO product: 82AC v: Yoga Slim 7 15ITL05
    serial: <superuser required> Chassis: type: 10 v: Yoga Slim 7 15ITL05
  Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
    UEFI: LENOVO v: FBCN24WW date: 02/05/2021
  ID-1: BAT1 charge: 63.2 Wh (98.1%) condition: 64.4/71.0 Wh (90.7%)
    volts: 17.3 min: 15.4 model: Celxpert L19C4PF5 type: Li-poly serial: <filter>
    status: N/A cycles: 102
  Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
    microcode: 0xA6
    L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 12 MiB
    desc: 1x12 MiB
  Speed (MHz): avg: 858 high: 1078 min/max: 400/4700 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1078 2: 891 3: 441 4: 947
    5: 951 6: 983 7: 614 8: 960 bogomips: 44864
    prctl and seccomp
  Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
    driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
    ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:9a49 class-ID: 0300
  Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
    bus-ID: 3-6:4 chip-ID: 04f2:b6cb class-ID: fe01 serial: <filter>
  Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
    loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
    screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: BOE Display 0x08b9 built: 2019 res: 1920x1080
    hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 22.2.4 renderer: Mesa Intel Xe Graphics (TGL GT2)
    direct render: Yes
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
    driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 3-1.4.3:8
    bus-ID: 00:1f.3 chip-ID: 17ef:3099 chip-ID: 8086:a0c8 class-ID: 0102
    class-ID: 0401
  Device-2: Lenovo USB-C Mini Dock type: USB driver: snd-usb-audio
  Sound API: ALSA v: k5.15.81-1-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.61 running: yes
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
    chip-ID: 8086:a0f0 class-ID: 0280
  Device-2: Lenovo Mini Dock type: USB driver: cdc_ether bus-ID: 2-2.1:3
    chip-ID: 17ef:3098 class-ID: 0a00 serial: <filter>
  IF: enp0s13f0u2u1c2 state: up speed: 1000 Mbps duplex: half mac: <filter>
  Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-10:6
    chip-ID: 8087:0026 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
  Local Storage: total: 953.87 GiB used: 394.68 GiB (41.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
    SDBPNTY-1T00-1101 size: 953.87 GiB block-size: physical: 512 B
    rev: 11170001 temp: 39.9 C scheme: GPT
  ID-1: / raw-size: 831.52 GiB size: 817.39 GiB (98.30%)
    used: 394.63 GiB (48.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 43.7 MiB (14.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 44.0 C mobo: N/A
  Processes: 262 Uptime: 1m wakeups: 19 Memory: 15.43 GiB
  used: 2.92 GiB (18.9%) Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1674
  pm: pacman pkgs: 1635 libs: 406 tools: pamac pm: flatpak pkgs: 26 pm: snap
  pkgs: 13 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: yakuake
  inxi: 3.3.24
I missed this topic and apparently, there was a fix for that. Thanks a lot :slight_smile:
