First off apologies for anything stupid I do or anything I miss. I have been using manjaro for a while, but am still quite a casual in terms of linux and it’s inner workings.
I’ve been using manjaro for a bit over a year at this point and have not had much issues until recently. Specifically this last week or 2 I’ve been having issues with random intermittent freezing of my display. Starting videos locally seems to be a consistent cause while youtube seems to do it more randomly, but it also randomly happens when snapping windows or even just grabbing a window. The freezes never last too long, maybe between 10-20 seconds, and while I can’t control anything (play/pause or such) audio will continue as if the system is functioning normally.
Sometimes it’s really bad, it will happen every few minutes, but sometimes a restart will clear it completely and it’ll be fine for the night.
I’ve been on and off going through forum posts since it started. I’ve verified my gpu drivers are updated, and installed disable c6 service to remedy any issues with c states. I ran memtest that’s available in grub. I have even fully reinstalled manjaro yet it persists.
I have no idea when it started, as I’ve made no notable changes to my system recently, and haven’t noticed any significant updates recently. I’d greatly appreciate any assistance on this. I’ve loved using manjaro, but this is making using my computer a giant pain.
Kernel: 6.12.17-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=cc24479b-9d6e-4c17-bfe6-2ddf5d248c49 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.3.2 tk: Qt v: N/A info: frameworks v: 6.11.0
Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF
serial: <superuser required>
Mobo: Gigabyte model: X570 AORUS ELITE serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: F37a
date: 02/16/2022
System RAM: total: 32 GiB available: 31.26 GiB used: 3.87 GiB (12.4%)
Device-1: Channel-A DIMM 0 type: no module installed
(unregistered) size: 16 GiB speed: 2133 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: G.Skill
part-no: F4-3600C16-16GTZNC serial: N/A
Device-3: Channel-B DIMM 0 type: no module installed
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 2 microcode: 0xA201210
Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2
smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB
desc: 12x512 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3598 min/max: 550/4951 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3598 2: 3598 3: 3598
4: 3598 5: 3598 6: 3598 7: 3598 8: 3598 9: 3598 10: 3598 11: 3598 12: 3598
13: 3598 14: 3598 15: 3598 16: 3598 17: 3598 18: 3598 19: 3598 20: 3598
21: 3598 22: 3598 23: 3598 24: 3598 bogomips: 177650
stibp succor svm_lock syscall tce topoext tsc tsc_scale umip user_shstk
v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
xtopology
affected
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21 [Radeon RX 6800/6800 XT
/ 6900 XT] vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2
code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-3
empty: DP-2,HDMI-A-1,Writeback-1 bus-ID: 0c:00.0 chip-ID: 1002:73bf
class-ID: 0300
compositor: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu d-rect: 7680x2880 display-ID: 0
Monitor-1: DP-1 pos: bottom-r model: Samsung Odyssey G93SC
serial: <filter> built: 2024 res: mode: 5120x1440 hz: 240 scale: 100% (1)
dpi: 82 gamma: 1.2 chroma: red: x: 0.682 y: 0.306 green: x: 0.227 y: 0.733
blue: x: 0.145 y: 0.047 white: x: 0.314 y: 0.329
size: 1193x336mm (46.97x13.23") diag: 1239mm (48.8") modes: 5120x1440,
3840x1080, 3840x2160, 2560x1440, 1920x1200, 1920x1080, 1600x1200,
1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800, 1280x720, 1024x768,
800x600, 720x480, 640x480
EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
unhandled CEA mode 96 3: parse_edid: unknown tag 112
Monitor-2: DP-3 pos: primary,top-left model: Acer XV272U serial: <filter>
built: 2019 res: mode: 2560x1440 hz: 144 scale: 178% (1.78) to: 1440x2560
dpi: 109 gamma: 1.2 chroma: red: x: 0.678 y: 0.310 green: x: 0.267
y: 0.663 blue: x: 0.149 y: 0.051 white: x: 0.314 y: 0.329
size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
modes: 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024,
1440x900, 1280x960, 1280x800, 1152x864, 1280x720, 1024x768, 832x624,
800x600, 720x576, 720x480, 640x480, 720x400
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6800 XT (radeonsi
navi21 LLVM 19.1.7 DRM 3.61 6.12.17-1-MANJARO) device-ID: 1002:73bf
memory: 15.62 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.304 layers: 7 device: 0 type: discrete-gpu name: AMD
Radeon RX 6800 XT (RADV NAVI21) driver: N/A device-ID: 1002:73bf
surfaces: xcb,xlib,wayland
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
bus-ID: 0c:00.1 chip-ID: 1002:ab28 class-ID: 0403
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Kingston HyperX SoloCast
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-3.1:4 chip-ID: 0951:170f class-ID: 0300
API: ALSA v: k6.12.17-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet 10-Gigabit X540-AT2 driver: ixgbe v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 4 link-max: lanes: 8 port: N/A bus-ID: 05:00.0
chip-ID: 8086:1528 class-ID: 0200
IF: enp5s0f0 state: up speed: 10000 Mbps duplex: full mac: <filter>
Device-2: Intel Ethernet 10-Gigabit X540-AT2 driver: ixgbe v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 4 link-max: lanes: 8 port: N/A bus-ID: 05:00.1
IF: enp5s0f1 state: down mac: <filter>
Device-3: Intel I211 Gigabit Network vendor: Gigabyte driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
IF: enp6s0 state: down mac: <filter>
Device-1: TP-Link TP-D@) UB500 Adapter driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:2 chip-ID: 2357:0604
Local Storage: total: 14.69 TiB used: 265.84 GiB (1.8%)
ID-1: /dev/nvme0n1 maj-min: 259:2 model: Predator SSD GM7000 4TB
size: 3.73 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 3.A.J.CR temp: 44.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO with
Heatsink 2TB size: 1.82 TiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QGXA7
temp: 44.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Silicon Power
model: SPCC Solid State Disk size: 1.86 TiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 6A0
scheme: MBR
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST8000DM004-2CX188
size: 7.28 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5425 serial: <filter> fw-rev: 0001 scheme: GPT
ID-1: / raw-size: 3.63 TiB size: 3.57 TiB (98.40%) used: 265.81 GiB (7.3%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:7 label: N/A
uuid: cc24479b-9d6e-4c17-bfe6-2ddf5d248c49
used: 30.7 MiB (32.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
label: N/A uuid: 3CE2-F9DD
ID-1: /dev/nvme0n1p2 maj-min: 259:4 size: 16 MiB fs: ext4 label: N/A
uuid: b57b9ff0-0426-4915-8ba9-1c1eb40cd0fc
ID-2: /dev/nvme0n1p3 maj-min: 259:5 size: 97.03 GiB fs: ntfs label: N/A
uuid: F85AF1755AF1314C
ID-3: /dev/nvme0n1p4 maj-min: 259:6 size: 522 MiB fs: ntfs label: N/A
uuid: 0CF6F115F6F0FFAE
ID-4: /dev/nvme1n1p1 maj-min: 259:1 size: 1.82 TiB fs: ext4
label: 980Pro Storage uuid: ceeb3e45-8d36-458b-ad39-6a50f865b234
ID-5: /dev/sda1 maj-min: 8:1 size: 1.86 TiB fs: ntfs label: SSD Storage
uuid: E2606B0E606AE92D
ID-6: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-7: /dev/sdb2 maj-min: 8:18 size: 7.28 TiB fs: ntfs
label: Internal Backup uuid: EA2EE6292EE5EE8F
Hub-2: 1-3:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-3.1:4 info: Kingston HyperX SoloCast type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
Device-2: 1-3.2:5 info: Keychron V6 type: keyboard,HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 3434:0361 class-ID: 0300
Hub-3: 1-3.3:6 info: Genesys Logic Hub ports: 4 rev: 2.1
Hub-4: 1-3.3.1:7 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 1-3.3.1.2:9 info: RealTek MCHOSE L7 Ultra type: mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0
chip-ID: 5253:1020 class-ID: 0300 serial: <filter>
Hub-5: 1-3.3.2:8 info: Genesys Logic Hub ports: 4 rev: 2.1
Hub-6: 1-3.3.3:10 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 1-4:3 info: Integrated Express IT8297 RGB LED Controller
type: keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
chip-ID: 048d:8297 class-ID: 0301
Hub-7: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-8: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-4:2 info: TP-Link TP-D@) UB500 Adapter type: bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 2357:0604 class-ID: e001 serial: <filter>
Hub-9: 3-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 3-6.1:4 info: Corsair iCUE Commander ST type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 1b1c:0c32 class-ID: 0300
serial: <filter>
Hub-10: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-11: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-12: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 47.9 C mobo: 34.0 C gpu: amdgpu temp: 57.0 C
mem: 56.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Packages: 1435 pm: pacman pkgs: 1430 libs: 469 tools: pamac pm: flatpak
pkgs: 5
1: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://mirrors.manjaro.org/repo/stable/$repo/$arch
3: https://muug.ca/mirror/manjaro/stable/$repo/$arch
4: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
5: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
6: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
7: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
8: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 474
1: cpu: 3.1% command: brave pid: 7789 mem: 264.8 MiB (0.8%)
2: cpu: 2.9% command: brave pid: 10173 mem: 226.1 MiB (0.7%)
3: cpu: 2.5% command: plasmashell pid: 1236 mem: 561.9 MiB (1.7%)
4: cpu: 2.2% command: brave pid: 4490 mem: 318.5 MiB (0.9%)
5: cpu: 2.1% command: brave pid: 4436 mem: 524.6 MiB (1.6%)
Memory top: 5 of 474
1: mem: 561.9 MiB (1.7%) command: plasmashell pid: 1236 cpu: 2.5%
2: mem: 524.6 MiB (1.6%) command: brave pid: 4436 cpu: 2.1%
3: mem: 382.7 MiB (1.1%) command: pamac-manager pid: 6847 cpu: 0.9%
4: mem: 321.6 MiB (1.0%) command: kwin_wayland pid: 956 cpu: 1.3%
5: mem: 318.5 MiB (0.9%) command: brave pid: 4490 cpu: 2.2%
Processes: 474 Power: uptime: 30m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
running-in: konsole inxi: 3.3.37
