Well, I don’t know if I should open a new topic or keep using this one. I’ll try using this one for now.
Even changing to 4.19 the error keeps happening, I removed nvidia drivers, it also keeps crashing. I can’t think of anything more, this is a fresh install and it crashes, so probably it’s a problem with my hardware or smth like that, but my windows is running smoothly.
Here is the journalctl --boot=-1 --priority=5 --no-pager
for the latest crash that happened 20 minutes ago. Maybe plasma is the problem? I thought of doing, once again, a fresh install but with gnome or xfce this time :((
jan 23 09:57:45 gabriel-fraga kernel: Linux version 6.1.1-1-MANJARO (builduser@fv-az191-932) (gcc (GCC) 12.2.0, GNU ld (GNU Binutils) 2.39.0) #1 SMP PREEMPT_DYNAMIC Wed Dec 21 23:21:50 UTC 2022
jan 23 09:57:45 gabriel-fraga kernel: Malformed early option 'acpi'
jan 23 09:57:45 gabriel-fraga kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64 root=UUID=1ba6ce48-7184-495a-b0ec-9d3c7020294f rw quiet splash udev.log_priority=3 acpi = off
jan 23 09:57:45 gabriel-fraga kernel: Unknown kernel command line parameters "splash = off BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64", will be passed to user space.
jan 23 09:57:45 gabriel-fraga kernel: random: crng init done
jan 23 09:57:45 gabriel-fraga kernel: audit: type=2000 audit(1674478661.146:1): state=initialized audit_enabled=0 res=1
jan 23 09:57:45 gabriel-fraga kernel: mtrr: your CPUs had inconsistent variable MTRR settings
jan 23 09:57:45 gabriel-fraga kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
jan 23 09:57:45 gabriel-fraga kernel: SCSI subsystem initialized
jan 23 09:57:45 gabriel-fraga kernel: Expanded resource Reserved due to conflict with PCI Bus 0000:00
jan 23 09:57:45 gabriel-fraga kernel: VFS: Disk quotas dquot_6.6.0
jan 23 09:57:45 gabriel-fraga kernel: pci 0000:00:00.2: can't derive routing for PCI INT A
jan 23 09:57:45 gabriel-fraga kernel: pci 0000:00:00.2: PCI INT A: not connected
jan 23 09:57:45 gabriel-fraga kernel: Initialise system trusted keyrings
jan 23 09:57:45 gabriel-fraga kernel: Key type blacklist registered
jan 23 09:57:45 gabriel-fraga kernel: integrity: Platform Keyring initialized
jan 23 09:57:45 gabriel-fraga kernel: integrity: Machine keyring initialized
jan 23 09:57:45 gabriel-fraga kernel: Key type asymmetric registered
jan 23 09:57:45 gabriel-fraga kernel: Asymmetric key parser 'x509' registered
jan 23 09:57:45 gabriel-fraga kernel: scsi 0:0:0:0: Direct-Access ATA ST2000LM007-1R81 ACM1 PQ: 0 ANSI: 5
jan 23 09:57:45 gabriel-fraga kernel: sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
jan 23 09:57:45 gabriel-fraga kernel: sd 0:0:0:0: [sda] 4096-byte physical blocks
jan 23 09:57:45 gabriel-fraga kernel: sd 0:0:0:0: [sda] Write Protect is off
jan 23 09:57:45 gabriel-fraga kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
jan 23 09:57:45 gabriel-fraga kernel: sd 0:0:0:0: [sda] Attached SCSI disk
jan 23 09:57:45 gabriel-fraga kernel: ahci 0000:39:00.0: failed stop FIS RX (-16)
jan 23 09:57:45 gabriel-fraga kernel: Loading compiled-in X.509 certificates
jan 23 09:57:45 gabriel-fraga kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 5c5acb36a23c86b35d7c1f3b43fac8d124b46bd9'
jan 23 09:57:45 gabriel-fraga kernel: Key type .fscrypt registered
jan 23 09:57:45 gabriel-fraga kernel: Key type fscrypt-provisioning registered
jan 23 09:57:45 gabriel-fraga kernel: scsi 1:0:0:0: Direct-Access ATA WDC WDS120G2G0A- 0000 PQ: 0 ANSI: 5
jan 23 09:57:45 gabriel-fraga kernel: sd 1:0:0:0: [sdb] 234455040 512-byte logical blocks: (120 GB/112 GiB)
jan 23 09:57:45 gabriel-fraga kernel: sd 1:0:0:0: [sdb] Write Protect is off
jan 23 09:57:45 gabriel-fraga kernel: sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
jan 23 09:57:45 gabriel-fraga kernel: sd 1:0:0:0: [sdb] Attached SCSI disk
jan 23 09:57:45 gabriel-fraga kernel: scsi 4:0:0:0: Direct-Access ATA WDC WD5000AAKX-0 1H15 PQ: 0 ANSI: 5
jan 23 09:57:45 gabriel-fraga kernel: sd 4:0:0:0: [sdc] 976773168 512-byte logical blocks: (500 GB/466 GiB)
jan 23 09:57:45 gabriel-fraga kernel: sd 4:0:0:0: [sdc] Write Protect is off
jan 23 09:57:45 gabriel-fraga kernel: sd 4:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
jan 23 09:57:45 gabriel-fraga kernel: sd 4:0:0:0: [sdc] Attached SCSI disk
jan 23 09:57:45 gabriel-fraga kernel: scsi 5:0:0:0: Direct-Access ATA TOSHIBA MK5076GS 1C PQ: 0 ANSI: 5
jan 23 09:57:45 gabriel-fraga kernel: sd 5:0:0:0: [sdd] 976773168 512-byte logical blocks: (500 GB/466 GiB)
jan 23 09:57:45 gabriel-fraga kernel: sd 5:0:0:0: [sdd] Write Protect is off
jan 23 09:57:45 gabriel-fraga kernel: sd 5:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
jan 23 09:57:45 gabriel-fraga kernel: sd 5:0:0:0: [sdd] Attached SCSI disk
jan 23 09:57:45 gabriel-fraga kernel: nvme nvme0: missing or invalid SUBNQN field.
jan 23 09:57:45 gabriel-fraga systemd[1]: tmp.mount: Directory /tmp to mount over is not empty, mounting anyway.
jan 23 09:57:45 gabriel-fraga kernel: audit: type=1130 audit(1674478665.666:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=plymouth-read-write comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jan 23 09:57:45 gabriel-fraga kernel: audit: type=1130 audit(1674478665.683:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jan 23 09:57:45 gabriel-fraga kernel: audit: type=1130 audit(1674478665.710:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jan 23 09:57:45 gabriel-fraga kernel: audit: type=1130 audit(1674478665.746:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=plymouth-start comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jan 23 09:57:45 gabriel-fraga kernel: audit: type=1130 audit(1674478665.823:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jan 23 09:57:45 gabriel-fraga kernel: audit: type=1130 audit(1674478665.916:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jan 23 09:57:45 gabriel-fraga kernel: audit: type=1127 audit(1674478665.943:8): pid=332 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
jan 23 09:57:45 gabriel-fraga kernel: audit: type=1130 audit(1674478665.970:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jan 23 09:57:45 gabriel-fraga kernel: audit: type=1130 audit(1674478665.976:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jan 23 09:57:45 gabriel-fraga kernel: ccp 0000:38:00.2: ccp enabled
jan 23 09:57:45 gabriel-fraga kernel: ccp 0000:38:00.2: psp: unable to access the device: you might be running a broken BIOS.
jan 23 09:57:46 gabriel-fraga polkitd[339]: Loading rules from directory /etc/polkit-1/rules.d
jan 23 09:57:46 gabriel-fraga polkitd[339]: Loading rules from directory /usr/share/polkit-1/rules.d
jan 23 09:57:46 gabriel-fraga polkitd[339]: Finished loading, compiling and executing 7 rules
jan 23 09:57:46 gabriel-fraga polkitd[339]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
jan 23 09:57:46 gabriel-fraga kernel: kauditd_printk_skb: 20 callbacks suppressed
jan 23 09:57:46 gabriel-fraga kernel: audit: type=1130 audit(1674478666.560:31): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jan 23 09:57:46 gabriel-fraga kernel: nouveau 0000:10:00.0: pmu: firmware unavailable
jan 23 09:57:47 gabriel-fraga sddm[395]: Failed to read display number from pipe
jan 23 09:57:47 gabriel-fraga sddm[395]: Attempt 1 starting the Display server on vt 1 failed
jan 23 09:57:51 gabriel-fraga kernel: audit: type=1100 audit(1674478671.470:32): pid=544 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
jan 23 09:57:51 gabriel-fraga kernel: audit: type=1101 audit(1674478671.470:33): pid=544 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
jan 23 09:57:51 gabriel-fraga kernel: audit: type=1103 audit(1674478671.473:34): pid=544 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
jan 23 09:57:51 gabriel-fraga kernel: audit: type=1130 audit(1674478671.533:35): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@964 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jan 23 09:57:51 gabriel-fraga systemd[546]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
jan 23 09:57:51 gabriel-fraga kernel: audit: type=1101 audit(1674478671.543:36): pid=546 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jan 23 09:57:51 gabriel-fraga kernel: audit: type=1103 audit(1674478671.543:37): pid=546 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
jan 23 09:57:51 gabriel-fraga kernel: audit: type=1006 audit(1674478671.543:38): pid=546 uid=0 old-auid=4294967295 auid=964 tty=(none) old-ses=4294967295 ses=1 res=1
jan 23 09:57:51 gabriel-fraga kernel: audit: type=1300 audit(1674478671.543:38): arch=c000003e syscall=1 success=yes exit=3 a0=9 a1=7fffd7f57480 a2=3 a3=7fffd7f57195 items=0 ppid=1 pid=546 auid=964 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd" key=(null)
jan 23 09:57:51 gabriel-fraga kernel: audit: type=1327 audit(1674478671.543:38): proctitle="(systemd)"
jan 23 09:57:51 gabriel-fraga kernel: kauditd_printk_skb: 1 callbacks suppressed
jan 23 09:57:51 gabriel-fraga kernel: audit: type=1130 audit(1674478671.733:40): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@964 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jan 23 09:57:51 gabriel-fraga systemd[546]: xdg-user-dirs-update.service: Main process exited, code=exited, status=1/FAILURE
jan 23 09:57:51 gabriel-fraga systemd[546]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
jan 23 09:57:51 gabriel-fraga systemd[546]: Failed to start Update XDG user dir configuration.
jan 23 09:57:51 gabriel-fraga kernel: audit: type=1105 audit(1674478671.740:41): pid=544 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_open grantors=pam_unix,pam_systemd acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
jan 23 09:57:51 gabriel-fraga sddm-greeter[555]: QFont::fromString: Invalid description '(empty)'
jan 23 09:57:51 gabriel-fraga sddm-greeter[555]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffd957601b0), parent's thread is QThread(0x55decc3d34b0), current thread is QThread(0x55decc556780)
jan 23 09:57:51 gabriel-fraga sddm-greeter[555]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
jan 23 09:57:52 gabriel-fraga udisksd[563]: udisks daemon version 2.9.4 starting
jan 23 09:57:52 gabriel-fraga kernel: audit: type=1130 audit(1674478672.230:42): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jan 23 09:57:52 gabriel-fraga udisksd[563]: Acquired the name org.freedesktop.UDisks2 on the system message bus
jan 23 09:57:52 gabriel-fraga kernel: audit: type=1334 audit(1674478672.233:43): prog-id=36 op=LOAD
jan 23 09:57:52 gabriel-fraga kernel: audit: type=1334 audit(1674478672.233:44): prog-id=37 op=LOAD
jan 23 09:57:52 gabriel-fraga kernel: audit: type=1130 audit(1674478672.310:45): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jan 23 09:57:52 gabriel-fraga sddm-greeter[555]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
jan 23 09:57:52 gabriel-fraga sddm-greeter[555]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
jan 23 09:57:52 gabriel-fraga sddm-greeter[555]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
jan 23 09:57:52 gabriel-fraga sddm-greeter[555]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
jan 23 09:57:52 gabriel-fraga sddm-greeter[555]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
jan 23 09:57:53 gabriel-fraga sddm-greeter[555]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
jan 23 09:57:53 gabriel-fraga sddm-greeter[555]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.24'
jan 23 09:57:53 gabriel-fraga kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP0.VGA.LCD._BCM.AFN7], AE_NOT_FOUND (20220331/psargs-330)
jan 23 09:57:53 gabriel-fraga kernel: ACPI Error: Aborting method \_SB.PCI0.GPP0.VGA.LCD._BCM due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
jan 23 09:57:53 gabriel-fraga kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GP17.VGA.LCD._BCM.AFN7], AE_NOT_FOUND (20220331/psargs-330)
jan 23 09:57:53 gabriel-fraga kernel: ACPI Error: Aborting method \_SB.PCI0.GP17.VGA.LCD._BCM due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
jan 23 09:57:56 gabriel-fraga kernel: audit: type=1131 audit(1674478676.230:46): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jan 23 09:57:57 gabriel-fraga kernel: audit: type=1100 audit(1674478677.386:47): pid=582 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="gcarvalhof" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
jan 23 09:57:57 gabriel-fraga kernel: audit: type=1101 audit(1674478677.390:48): pid=582 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="gcarvalhof" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
jan 23 09:57:57 gabriel-fraga kernel: audit: type=1103 audit(1674478677.390:49): pid=582 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="gcarvalhof" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
jan 23 09:57:57 gabriel-fraga kernel: audit: type=1006 audit(1674478677.390:50): pid=582 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
jan 23 09:57:57 gabriel-fraga kernel: audit: type=1300 audit(1674478677.390:50): arch=c000003e syscall=1 success=yes exit=4 a0=8 a1=7ffc90848590 a2=4 a3=7ffc908482a4 items=0 ppid=395 pid=582 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="sddm-helper" exe="/usr/lib/sddm/sddm-helper" key=(null)
jan 23 09:57:57 gabriel-fraga kernel: audit: type=1327 audit(1674478677.390:50): proctitle=2F7573722F6C69622F7364646D2F7364646D2D68656C706572002D2D736F636B6574002F746D702F7364646D2D6175746866333562376537342D626637612D343763312D613632342D323965356363653366333833002D2D69640031002D2D7374617274002F7573722F62696E2F7374617274706C61736D612D783131002D2D
jan 23 09:57:57 gabriel-fraga kernel: audit: type=1130 audit(1674478677.490:51): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jan 23 09:57:57 gabriel-fraga systemd[584]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[gcarvalhof] ruser=[<unknown>] rhost=[<unknown>]
jan 23 09:57:57 gabriel-fraga kernel: audit: type=1101 audit(1674478677.500:52): pid=584 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="gcarvalhof" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jan 23 09:57:57 gabriel-fraga kernel: audit: type=1103 audit(1674478677.500:53): pid=584 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="gcarvalhof" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
jan 23 09:57:57 gabriel-fraga kernel: audit: type=1006 audit(1674478677.500:54): pid=584 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
jan 23 09:57:58 gabriel-fraga ksplashqml[671]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
jan 23 09:57:58 gabriel-fraga ksplashqml[671]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:82:29: Unable to assign int to QEasingCurve
jan 23 09:57:58 gabriel-fraga ksmserver[721]: Qt: Session management error: networkIdsList argument is NULL
jan 23 09:57:58 gabriel-fraga kwalletd5[596]: kf.wallet.kwalletd: Wallet failed to get opened by PAM, error code is -9
jan 23 09:57:58 gabriel-fraga ksmserver[721]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.14'
jan 23 09:57:59 gabriel-fraga kwin_x11[724]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
jan 23 09:57:59 gabriel-fraga kwin_x11[724]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
jan 23 09:58:00 gabriel-fraga pipewire[807]: mod.rt: Can't find xdg-portal: (null)
jan 23 09:58:00 gabriel-fraga pipewire[807]: mod.rt: found session bus but no portal
jan 23 09:58:00 gabriel-fraga pipewire-media-session[809]: mod.rt: Can't find xdg-portal: (null)
jan 23 09:58:00 gabriel-fraga pipewire-media-session[809]: mod.rt: found session bus but no portal
jan 23 09:58:00 gabriel-fraga polkitd[339]: Registered Authentication Agent for unix-session:2 (system bus name :1.43 [/usr/lib/polkit-kde-authentication-agent-1], object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
jan 23 09:58:00 gabriel-fraga backlighthelper[835]: org.kde.powerdevil: no kernel backlight interface found
jan 23 09:58:00 gabriel-fraga org_kde_powerdevil[775]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
jan 23 09:58:00 gabriel-fraga plasmashell[761]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
jan 23 09:58:00 gabriel-fraga plasmashell[761]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
jan 23 09:58:00 gabriel-fraga org_kde_powerdevil[775]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
jan 23 09:58:00 gabriel-fraga kded5[723]: kscreen.kded: PowerDevil SuspendSession action not available!
jan 23 09:58:00 gabriel-fraga org_kde_powerdevil[775]: org.kde.powerdevil: Handle button events action could not check for screen configuration
jan 23 09:58:00 gabriel-fraga org_kde_powerdevil[775]: org.kde.powerdevil: The profile "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
jan 23 09:58:01 gabriel-fraga pamac-tray-plas[895]: updates_checker.vala:71: check updates
jan 23 09:58:01 gabriel-fraga pamac-tray-plas[895]: updates_checker.vala:101: 0 updates found
jan 23 09:58:01 gabriel-fraga plasmashell[761]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
jan 23 09:58:01 gabriel-fraga kdeconnectd[880]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
jan 23 09:58:01 gabriel-fraga kdeconnectd[880]: kdeconnect.plugin.battery: No Primary Battery detected on this system. This may be a bug.
jan 23 09:58:01 gabriel-fraga kdeconnectd[880]: kdeconnect.plugin.battery: Total quantity of batteries found: 0
jan 23 09:58:02 gabriel-fraga plasmashell[761]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
jan 23 09:58:03 gabriel-fraga pulseaudio[928]: stat('/etc/pulse/default.pa.d'): No such file or directory
jan 23 09:58:03 gabriel-fraga plasmashell[761]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:534:9: QML Label: Binding loop detected for property "height"
jan 23 09:58:03 gabriel-fraga plasmashell[761]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:499:13: QML Label: Binding loop detected for property "height"
jan 23 09:58:03 gabriel-fraga plasmashell[761]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
jan 23 09:58:03 gabriel-fraga plasmashell[761]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:556:5: QML Label: Binding loop detected for property "height"
jan 23 09:58:03 gabriel-fraga plasmashell[761]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
jan 23 09:58:03 gabriel-fraga plasmashell[761]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
jan 23 09:58:04 gabriel-fraga kwin_x11[724]: kwin_core: XCB error: 152 (BadDamage), sequence: 2130, resource id: 16777260, major code: 143 (DAMAGE), minor code: 3 (Subtract)
jan 23 09:58:04 gabriel-fraga plasmashell[761]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
jan 23 09:58:04 gabriel-fraga kwin_x11[724]: kwin_core: XCB error: 3 (BadWindow), sequence: 2154, resource id: 4194340, major code: 129 (SHAPE), minor code: 6 (Input)
jan 23 09:58:04 gabriel-fraga plasmashell[761]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
jan 23 09:58:04 gabriel-fraga plasmashell[761]: file:///usr/share/plasma/plasmoids/org.kde.plasma.mediacontroller/contents/ui/CompactRepresentation.qml:77: TypeError: Cannot read property 'implicitWidth' of null
jan 23 09:58:04 gabriel-fraga plasmashell[761]: file:///usr/share/plasma/plasmoids/org.kde.plasma.battery/contents/ui/CompactRepresentation.qml:58:17: Unable to assign [undefined] to int
jan 23 09:58:04 gabriel-fraga plasmashell[761]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55abd8e7aa60) QQmlContext(0x55abd8024860) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
jan 23 09:58:04 gabriel-fraga plasmashell[761]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
jan 23 09:58:04 gabriel-fraga plasmashell[761]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
jan 23 09:58:05 gabriel-fraga plasmashell[761]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
jan 23 09:58:06 gabriel-fraga plasmashell[761]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
jan 23 09:58:07 gabriel-fraga systemd[547]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
jan 23 09:58:07 gabriel-fraga kernel: kauditd_printk_skb: 8 callbacks suppressed
jan 23 09:58:07 gabriel-fraga kernel: audit: type=1131 audit(1674478687.753:61): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@964 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jan 23 09:58:07 gabriel-fraga plasmashell[761]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
jan 23 09:58:07 gabriel-fraga kernel: audit: type=1131 audit(1674478687.816:62): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@964 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jan 23 09:58:07 gabriel-fraga plasmashell[761]: file:///usr/lib/qt/qml/org/kde/plasma/workspace/calendar/InfiniteList.qml:43:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
jan 23 09:58:08 gabriel-fraga plasmashell[761]: file:///usr/lib/qt/qml/org/kde/plasma/workspace/calendar/InfiniteList.qml:43:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
jan 23 09:58:08 gabriel-fraga plasmashell[761]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
jan 23 09:58:08 gabriel-fraga plasmashell[761]: file:///usr/lib/qt/qml/org/kde/plasma/workspace/calendar/MonthView.qml:381: TypeError: Cannot read property 'cellHeight' of null
jan 23 09:58:09 gabriel-fraga plasmashell[761]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
jan 23 09:58:16 gabriel-fraga kernel: audit: type=1131 audit(1674478696.170:63): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jan 23 09:58:16 gabriel-fraga kernel: audit: type=1334 audit(1674478696.236:64): prog-id=0 op=UNLOAD
jan 23 09:58:16 gabriel-fraga kernel: audit: type=1334 audit(1674478696.236:65): prog-id=0 op=UNLOAD
jan 23 09:58:16 gabriel-fraga kernel: audit: type=1334 audit(1674478696.236:66): prog-id=0 op=UNLOAD
jan 23 09:58:25 gabriel-fraga kded5[723]: kf.bluezqt: PendingCall Error: "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken."
jan 23 09:58:25 gabriel-fraga dbus-daemon[338]: [system] Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
jan 23 09:58:25 gabriel-fraga pulseaudio[928]: GetManagedObjects() failed: org.freedesktop.DBus.Error.TimedOut: Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
jan 23 09:59:09 gabriel-fraga plasmashell[761]: kf.sonnet.core: No language dictionaries for the language: "en_US"
jan 23 09:59:09 gabriel-fraga plasmashell[761]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
jan 23 09:59:12 gabriel-fraga systemsettings[1525]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "width"
jan 23 09:59:12 gabriel-fraga systemsettings[1525]: QFSFileEngine::open: No file name specified
jan 23 09:59:12 gabriel-fraga systemsettings[1525]: kf.coreaddons.desktopparser: Error: Failed to open ""
jan 23 09:59:12 gabriel-fraga systemsettings[1525]: QFileDevice::seek: IODevice is not open
jan 23 09:59:12 gabriel-fraga systemsettings[1525]: kf.configwidgets: A widget named ' "kcfg_osdKbdLayoutChangedEnabled" ' was found but there is no setting named ' "osdKbdLayoutChangedEnabled" '
jan 23 09:59:12 gabriel-fraga systemsettings[1525]: kf.configwidgets: A widget named ' "kcfg_repeatRate" ' was found but there is no setting named ' "repeatRate" '
jan 23 09:59:12 gabriel-fraga systemsettings[1525]: kf.configwidgets: A widget named ' "kcfg_repeatDelay" ' was found but there is no setting named ' "repeatDelay" '
jan 23 09:59:12 gabriel-fraga systemsettings[1525]: kf.configwidgets: A widget named ' "kcfg_resetOldXkbOptions" ' was found but there is no setting named ' "resetOldXkbOptions" '
jan 23 09:59:12 gabriel-fraga systemsettings[1525]: kf.configwidgets: A widget named ' "kcfg_configureLayouts" ' was found but there is no setting named ' "configureLayouts" '
jan 23 09:59:14 gabriel-fraga systemsettings[1525]: QFSFileEngine::open: No file name specified
jan 23 09:59:14 gabriel-fraga systemsettings[1525]: kf.coreaddons.desktopparser: Error: Failed to open ""
jan 23 09:59:14 gabriel-fraga systemsettings[1525]: QFileDevice::seek: IODevice is not open
jan 23 09:59:47 gabriel-fraga kwin_x11[724]: kwin_core: XCB error: 152 (BadDamage), sequence: 31750, resource id: 16780012, major code: 143 (DAMAGE), minor code: 3 (Subtract)
jan 23 10:00:02 gabriel-fraga konsole[1551]: kf.xmlgui: Shortcut for action "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
jan 23 10:00:02 gabriel-fraga konsole[1551]: kf.xmlgui: Shortcut for action "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
jan 23 10:01:22 gabriel-fraga plasmashell[761]: kf.sonnet.core: No language dictionaries for the language: "en_US"
jan 23 10:01:24 gabriel-fraga kwalletd5[596]: Application ' "Slack" ' using kwallet without parent window!
jan 23 10:01:24 gabriel-fraga plasmashell[761]: kf.sonnet.core: No language dictionaries for the language: "en_US"
jan 23 10:01:28 gabriel-fraga plasmashell[761]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:433: Unable to assign [undefined] to QString
jan 23 10:01:31 gabriel-fraga ktraderclient5[3101]: kf.service.services: The desktop entry file "/usr/share/applications/nvidia-settings.desktop" has Type= "Application" but no Exec line
jan 23 10:01:31 gabriel-fraga ktraderclient5[3101]: kf.service.sycoca: Invalid Service : "/usr/share/applications/nvidia-settings.desktop"
jan 23 10:01:32 gabriel-fraga ktraderclient5[3122]: kf.service.services: The desktop entry file "/usr/share/applications/nvidia-settings.desktop" has Type= "Application" but no Exec line
jan 23 10:01:32 gabriel-fraga ktraderclient5[3122]: kf.service.sycoca: Invalid Service : "/usr/share/applications/nvidia-settings.desktop"
jan 23 10:01:32 gabriel-fraga plasmashell[761]: kf.service.services: The desktop entry file "/usr/share/applications/nvidia-settings.desktop" has Type= "Application" but no Exec line
jan 23 10:01:32 gabriel-fraga plasmashell[761]: kf.service.sycoca: Invalid Service : "/usr/share/applications/nvidia-settings.desktop"
jan 23 10:01:34 gabriel-fraga kdeconnectd[880]: kdeconnect.plugin.battery: No Primary Battery detected on this system. This may be a bug.
jan 23 10:01:34 gabriel-fraga kdeconnectd[880]: kdeconnect.plugin.battery: Total quantity of batteries found: 0
jan 23 10:01:34 gabriel-fraga kwin_x11[724]: kwin_core: XCB error: 152 (BadDamage), sequence: 58246, resource id: 16781672, major code: 143 (DAMAGE), minor code: 3 (Subtract)
jan 23 10:01:44 gabriel-fraga plasmashell[761]: file:///usr/share/plasma/plasmoids/org.kde.plasma.mediacontroller/contents/ui/CompactRepresentation.qml:77: TypeError: Cannot read property 'implicitWidth' of null
jan 23 10:01:49 gabriel-fraga dbus-daemon[338]: [system] Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
jan 23 10:02:40 gabriel-fraga plasmashell[761]: kf.sonnet.core: No language dictionaries for the language: "en_US"
jan 23 10:02:41 gabriel-fraga kwin_x11[724]: kwin_core: XCB error: 152 (BadDamage), sequence: 19821, resource id: 16784208, major code: 143 (DAMAGE), minor code: 3 (Subtract)
jan 23 10:02:57 gabriel-fraga dbus-daemon[338]: [system] Failed to activate service 'org.bluez': timed out (service_start_timeout=25000ms)
