Manjaro freezing and output of journalctl
This is my output of journalctl -p 3 -xb, seems there are errors to solve but I dont know how.
[nicole@nicole-pc ~]$ journalctl -p 3 -xb
apr 14 23:16:55 nicole-pc kernel: DMAR: [Firmware Bug]: No firmware reserved region can cover this RMRR [0x000000009d800000-0x00000000>
apr 14 23:16:55 nicole-pc kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.LPCB.HEC.ECRD], AE_NOT_FOUND (20220331/ps>
apr 14 23:16:55 nicole-pc kernel: ACPI Error: Aborting method \_TZ.TZ00._TMP due to previous error (AE_NOT_FOUND) (20220331/psparse-52>
apr 14 23:16:55 nicole-pc kernel: ACPI Error: Aborting method \_TZ.TZ01._TMP due to previous error (AE_NOT_FOUND) (20220331/psparse-52>
apr 14 23:17:00 nicole-pc bluetoothd[784]: src/plugin.c:plugin_init() Failed to init vcp plugin
apr 14 23:17:00 nicole-pc bluetoothd[784]: src/plugin.c:plugin_init() Failed to init mcp plugin
apr 14 23:17:00 nicole-pc bluetoothd[784]: src/plugin.c:plugin_init() Failed to init bap plugin
apr 14 23:18:05 nicole-pc lightdm[1017]: gkr-pam: unable to locate daemon control file
apr 14 23:18:22 nicole-pc kernel: debugfs: File 'radeon_ring_gfx' in directory '0' already present!
apr 14 23:18:22 nicole-pc kernel: debugfs: File 'radeon_ring_cp1' in directory '0' already present!
apr 14 23:18:22 nicole-pc kernel: debugfs: File 'radeon_ring_cp2' in directory '0' already present!
apr 14 23:18:22 nicole-pc kernel: debugfs: File 'radeon_ring_dma1' in directory '0' already present!
apr 14 23:18:22 nicole-pc kernel: debugfs: File 'radeon_ring_dma2' in directory '0' already present!
apr 14 23:18:23 nicole-pc kernel: [drm:r600_ring_test [radeon]] *ERROR* radeon: ring 0 test failed (scratch(0x850C)=0xCAFEDEAD)
apr 14 23:18:23 nicole-pc kernel: [drm:si_resume [radeon]] *ERROR* si startup failed on resume
can you report
inxi -Fza
sudo mhwd-kernel -li
sudo mhwd -li
