This is my first post and I am happy to learn best practices.
I am aware that this is not the only post about Manjaro freezing, but at this point I think I need help as I don’t know what to try.
The symptom is:
I encounter freezes of the screen during runtime. The sound keeps playing and I can ssh into the computer, but it doesn’t respond to mouse or keyboard in a visible way.
When I tried to reboot with ssh it didn’t work, but the Numlock and Caps lights of my keyboard began to flash.
The REISUB keys don’t work.
Therefore I always press the power button for 6 seconds.
[ho@Holger ~]$ inxi --full --verbosity=7 --filter --no-host
System: Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A Console: tty 0 DM: LightDM 1.30.0 Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASUSTeK model: F2A85-M LE v: Rev X.0x serial: <filter> BIOS: American Megatrends v: 6504
date: 11/26/2014
Memory: RAM: total: 7.79 GiB used: 539.8 MiB (6.8%)
CPU: Topology: Quad Core model: AMD A10-5700 APU with Radeon HD Graphics bits: 64 type: MCP arch: Piledriver rev: 1
L2 cache: 2048 KiB bogomips: 27346
Speed: 1404 MHz min/max: 1400/3400 MHz boost: enabled Core speeds (MHz): 1: 1405 2: 1407 3: 1405 4: 1404
Flags: 3dnowprefetch abm aes aperfmperf apic arat avx bmi1 clflush cmov cmp_legacy constant_tsc cpb cpuid
cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid fma fma4 fpu fxsr fxsr_opt ht hw_pstate
ibs lahf_lm lbrv lm lwp mca mce misalignsse mmx mmxext monitor msr mtrr nodeid_msr nonstop_tsc nopl npt nrip_save
nx osvw pae pat pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni popcnt pse pse36 rdtscp
rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 svm svm_lock syscall tbm tce topoext tsc tsc_scale
vmcb_clean vme vmmcall wdt xop xsave
Graphics: Device-1: NVIDIA GK208 [GeForce GT 630 Rev. 2] vendor: ASUSTeK driver: nouveau v: kernel bus ID: 01:00.0
chip ID: 10de:1284
Display: server: X.org 1.20.8 driver: nouveau unloaded: modesetting alternate: fbdev,nv,vesa tty: 207x60
Message: Advanced graphics data unavailable in console. Try -G --display
Audio: Device-1: Advanced Micro Devices [AMD] FCH Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 00:14.2
chip ID: 1022:780d
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 01:00.1
chip ID: 10de:0e0f
Sound Server: ALSA v: k5.8.6-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK P8 series driver: r8169 v: kernel
port: d000 bus ID: 04:00.0 chip ID: 10ec:8168
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Drives: Local Storage: total: 1.85 TiB used: 46.61 GiB (2.5%)
ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB speed: 6.0 Gb/s serial: <filter> rev: 4B6Q
scheme: MBR
ID-2: /dev/sdb vendor: Western Digital model: WD10EZEX-00BN5A0 size: 931.51 GiB speed: 6.0 Gb/s rotation: 7200 rpm
serial: <filter> rev: 1A01 scheme: MBR
ID-3: /dev/sde type: USB vendor: Generic model: SDXC MMC size: 29.92 GiB serial: <filter> rev: 0.00 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH24NSB0 rev: LN01 dev-links: cdrom
Features: speed: 12 multisession: yes audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r,dvd-ram state: running
RAID: Message: No RAID data was found.
Partition: ID-1: / size: 62.50 GiB used: 11.16 GiB (17.9%) fs: ext4 dev: /dev/sda5 label: N/A
uuid: ccc31f2b-b6f7-41e5-a608-d452c7e20445
ID-2: /boot/efi size: 511.0 MiB used: 292 KiB (0.1%) fs: vfat dev: /dev/sda4 label: N/A uuid: 6E55-AB68
ID-3: /home size: 385.03 GiB used: 35.45 GiB (9.2%) fs: ext4 dev: /dev/sda7 label: N/A
uuid: e02051e8-80ba-4772-a9d9-d9a8974edfa7
Swap: Alert: No Swap data was found.
Unmounted: ID-1: /dev/sda1 size: 549.0 MiB fs: ntfs label: System-reserviert uuid: C268588A68587EDB
ID-2: /dev/sda2 size: 466.04 GiB fs: ntfs label: N/A uuid: 44705AED705AE4E8
ID-3: /dev/sda3 size: 1 KiB fs: <superuser/root required> label: N/A uuid: N/A
ID-4: /dev/sda6 size: 8.25 GiB fs: swap label: N/A uuid: 4ea43050-043f-4e4c-80d6-f0ce4740db38
ID-5: /dev/sdb1 size: 100.0 MiB fs: ntfs label: System-reserviert uuid: 56BE6F2CBE6F0439
ID-6: /dev/sdb2 size: 931.41 GiB fs: ntfs label: System uuid: F252755C5275270F
ID-7: /dev/sde1 size: 29.92 GiB fs: vfat label: EOS_DIGITAL uuid: 1F75-1762
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 5 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 3-0:1 info: Full speed (or root) Hub ports: 5 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 3-1:2 info: Integrated Express Multi Cardreader type: Mass Storage driver: usb-storage interfaces: 1
rev: 2.0 speed: 480 Mb/s chip ID: 048d:1345 serial: <filter>
Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s chip ID: 1d6b:0003
Hub: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s chip ID: 1d6b:0003
Hub: 7-0:1 info: Full speed (or root) Hub ports: 5 rev: 1.1 speed: 12 Mb/s chip ID: 1d6b:0001
Device-1: 7-1:2 info: Pixart Imaging Optical Mouse type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 1.1
speed: 1.5 Mb/s chip ID: 093a:2510
Hub: 8-0:1 info: Full speed (or root) Hub ports: 5 rev: 1.1 speed: 12 Mb/s chip ID: 1d6b:0001
Sensors: System Temperatures: cpu: 0.0 C mobo: N/A gpu: nouveau temp: 36 C
Info: Processes: 186 Uptime: 14m Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1161 Shell: Bash v: 5.0.18
running in: tty 0 (SSH) inxi: 3.1.05
[ho@Holger ~]$ sudo dmesg
[sudo] Passwort für ho:
[ 0.000000] Linux version 5.8.6-1-MANJARO (builder@db927223e331) (gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.35) #1 SMP PREEMPT Thu Sep 3 14:19:36 UTC 2020
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=ccc31f2b-b6f7-41e5-a608-d452c7e20445 rw loglevel=3 quiet
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Hygon HygonGenuine
[ 0.000000] Centaur CentaurHauls
[ 0.000000] zhaoxin Shanghai
[ 0.000000] random: get_random_u32 called from bsp_init_amd+0x2b3/0x2f0 with crng_init=0
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009e7ff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009e800-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000dd90afff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000dd90b000-0x00000000ddbeefff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ddbef000-0x00000000ddbfefff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000ddbff000-0x00000000ddcd8fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000ddcd9000-0x00000000de621fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000de622000-0x00000000de622fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000de623000-0x00000000de828fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000de829000-0x00000000dec57fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000dec58000-0x00000000deff3fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000deff4000-0x00000000deffffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100001000-0x000000021effffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.7 present.
[ 0.000000] DMI: System manufacturer System Product Name/F2A85-M LE, BIOS 6504 11/26/2014
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 3416.889 MHz processor
[ 0.000717] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000719] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000724] last_pfn = 0x21f000 max_arch_pfn = 0x400000000
[ 0.000729] MTRR default type: uncachable
[ 0.000729] MTRR fixed ranges enabled:
[ 0.000730] 00000-9FFFF write-back
[ 0.000731] A0000-BFFFF write-through
[ 0.000732] C0000-CEFFF write-protect
[ 0.000733] CF000-E7FFF uncachable
[ 0.000734] E8000-FFFFF write-protect
[ 0.000734] MTRR variable ranges enabled:
[ 0.000735] 0 base 000000000000 mask FFFF80000000 write-back
[ 0.000737] 1 base 000080000000 mask FFFFC0000000 write-back
[ 0.000738] 2 base 0000C0000000 mask FFFFE0000000 write-back
[ 0.000739] 3 base 0000DF000000 mask FFFFFF000000 uncachable
[ 0.000739] 4 disabled
[ 0.000740] 5 disabled
[ 0.000740] 6 disabled
[ 0.000741] 7 disabled
[ 0.000742] TOM2: 000000021f000000 aka 8688M
[ 0.001049] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.001139] total RAM covered: 3568M
[ 0.001652] Found optimal setting for mtrr clean up
[ 0.001654] gran_size: 64K chunk_size: 1G num_reg: 3 lose cover RAM: 0G
[ 0.001765] e820: update [mem 0xdf000000-0xffffffff] usable ==> reserved
[ 0.001769] last_pfn = 0xdf000 max_arch_pfn = 0x400000000
[ 0.005733] found SMP MP-table at [mem 0x000fd7f0-0x000fd7ff]
[ 0.031109] check: Scanning 1 areas for low memory corruption
[ 0.031113] Using GB pages for direct mapping
[ 0.031932] RAMDISK: [mem 0x36d95000-0x376c1fff]
[ 0.031940] ACPI: Early table checksum verification disabled
[ 0.031943] ACPI: RSDP 0x00000000000F0490 000024 (v02 ALASKA)
[ 0.031946] ACPI: XSDT 0x00000000DDBF7078 000064 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.031951] ACPI: FACP 0x00000000DDBFD8F8 00010C (v05 ALASKA A M I 01072009 AMI 00010013)
[ 0.031955] ACPI BIOS Warning (bug): Optional FADT field Pm2ControlBlock has valid Length but zero Address: 0x0000000000000000/0x1 (20200528/tbfadt-615)
[ 0.031959] ACPI: DSDT 0x00000000DDBF7170 006788 (v02 ALASKA A M I 00000000 INTL 20051117)
[ 0.031962] ACPI: FACS 0x00000000DDCCE080 000040
[ 0.031965] ACPI: APIC 0x00000000DDBFDA08 000072 (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.031968] ACPI: FPDT 0x00000000DDBFDA80 000044 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.031970] ACPI: MCFG 0x00000000DDBFDAC8 00003C (v01 ALASKA A M I 01072009 MSFT 00010013)
[ 0.031973] ACPI: SSDT 0x00000000DDBFE948 0004B7 (v02 AMD ANNAPURN 00000001 MSFT 04000000)
[ 0.031976] ACPI: HPET 0x00000000DDBFDB60 000038 (v01 ALASKA A M I 01072009 AMI 00000005)
[ 0.031979] ACPI: IVRS 0x00000000DDBFDB98 000070 (v02 AMD ANNAPURN 00000001 AMD 00000000)
[ 0.031981] ACPI: SSDT 0x00000000DDBFDC08 000D40 (v01 AMD ANNAPURN 00000001 AMD 00000001)
[ 0.031988] ACPI: Local APIC address 0xfee00000
[ 0.032040] No NUMA configuration found
[ 0.032040] Faking a node at [mem 0x0000000000000000-0x000000021effffff]
[ 0.032044] NODE_DATA(0) allocated [mem 0x21effa000-0x21effdfff]
[ 0.032069] Zone ranges:
[ 0.032070] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.032071] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.032072] Normal [mem 0x0000000100000000-0x000000021effffff]
[ 0.032073] Device empty
[ 0.032074] Movable zone start for each node
[ 0.032074] Early memory node ranges
[ 0.032075] node 0: [mem 0x0000000000001000-0x000000000009dfff]
[ 0.032076] node 0: [mem 0x0000000000100000-0x00000000dd90afff]
[ 0.032077] node 0: [mem 0x00000000de622000-0x00000000de622fff]
[ 0.032078] node 0: [mem 0x00000000de829000-0x00000000dec57fff]
[ 0.032079] node 0: [mem 0x00000000deff4000-0x00000000deffffff]
[ 0.032079] node 0: [mem 0x0000000100001000-0x000000021effffff]
[ 0.032233] Zeroed struct page in unavailable ranges: 13085 pages
[ 0.032234] Initmem setup node 0 [mem 0x0000000000001000-0x000000021effffff]
[ 0.032236] On node 0 totalpages: 2084067
[ 0.032237] DMA zone: 64 pages used for memmap
[ 0.032237] DMA zone: 21 pages reserved
[ 0.032238] DMA zone: 3997 pages, LIFO batch:0
[ 0.032275] DMA32 zone: 14134 pages used for memmap
[ 0.032275] DMA32 zone: 904519 pages, LIFO batch:63
[ 0.042453] Normal zone: 18368 pages used for memmap
[ 0.042454] Normal zone: 1175551 pages, LIFO batch:63
[ 0.055800] ACPI: PM-Timer IO Port: 0x808
[ 0.055803] ACPI: Local APIC address 0xfee00000
[ 0.055808] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.055816] IOAPIC[0]: apic_id 5, version 33, address 0xfec00000, GSI 0-23
[ 0.055818] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.055819] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.055820] ACPI: IRQ0 used by override.
[ 0.055821] ACPI: IRQ9 used by override.
[ 0.055823] Using ACPI (MADT) for SMP configuration information
[ 0.055824] ACPI: HPET id: 0x10228210 base: 0xfed00000
[ 0.055829] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.055847] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.055849] PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x0009efff]
[ 0.055850] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[ 0.055850] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[ 0.055851] PM: hibernation: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[ 0.055852] PM: hibernation: Registered nosave memory: [mem 0xdd90b000-0xddbeefff]
[ 0.055853] PM: hibernation: Registered nosave memory: [mem 0xddbef000-0xddbfefff]
[ 0.055854] PM: hibernation: Registered nosave memory: [mem 0xddbff000-0xddcd8fff]
[ 0.055854] PM: hibernation: Registered nosave memory: [mem 0xddcd9000-0xde621fff]
[ 0.055856] PM: hibernation: Registered nosave memory: [mem 0xde623000-0xde828fff]
[ 0.055857] PM: hibernation: Registered nosave memory: [mem 0xdec58000-0xdeff3fff]
[ 0.055858] PM: hibernation: Registered nosave memory: [mem 0xdf000000-0xfebfffff]
[ 0.055859] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.055860] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfec0ffff]
[ 0.055860] PM: hibernation: Registered nosave memory: [mem 0xfec10000-0xfec10fff]
[ 0.055861] PM: hibernation: Registered nosave memory: [mem 0xfec11000-0xfecfffff]
[ 0.055861] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed00fff]
[ 0.055862] PM: hibernation: Registered nosave memory: [mem 0xfed01000-0xfed7ffff]
[ 0.055862] PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xfed8ffff]
[ 0.055863] PM: hibernation: Registered nosave memory: [mem 0xfed90000-0xfeffffff]
[ 0.055863] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.055864] PM: hibernation: Registered nosave memory: [mem 0x100000000-0x100000fff]
[ 0.055865] [mem 0xdf000000-0xfebfffff] available for PCI devices
[ 0.055866] Booting paravirtualized kernel on bare hardware
[ 0.055869] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.059786] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:4 nr_node_ids:1
[ 0.060161] percpu: Embedded 56 pages/cpu s192512 r8192 d28672 u524288
[ 0.060168] pcpu-alloc: s192512 r8192 d28672 u524288 alloc=1*2097152
[ 0.060169] pcpu-alloc: [0] 0 1 2 3
[ 0.060190] Built 1 zonelists, mobility grouping on. Total pages: 2051480
[ 0.060191] Policy zone: Normal
[ 0.060192] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=ccc31f2b-b6f7-41e5-a608-d452c7e20445 rw loglevel=3 quiet
[ 0.061604] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.062292] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.062313] mem auto-init: stack:byref_all, heap alloc:on, heap free:off
[ 0.101046] Memory: 8083716K/8336268K available (14339K kernel code, 1480K rwdata, 4656K rodata, 1648K init, 3016K bss, 252552K reserved, 0K cma-reserved)
[ 0.101174] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.101188] ftrace: allocating 40167 entries in 157 pages
[ 0.115454] ftrace: allocated 157 pages with 5 groups
[ 0.115592] rcu: Preemptible hierarchical RCU implementation.
[ 0.115593] rcu: RCU dyntick-idle grace-period acceleration is enabled.
[ 0.115594] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
[ 0.115595] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.115596] Trampoline variant of Tasks RCU enabled.
[ 0.115596] Rude variant of Tasks RCU enabled.
[ 0.115597] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.115597] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.118479] NR_IRQS: 20736, nr_irqs: 456, preallocated irqs: 16
[ 0.118793] spurious 8259A interrupt: IRQ7.
[ 0.118810] Console: colour dummy device 80x25
[ 0.118814] printk: console [tty0] enabled
[ 0.118832] ACPI: Core revision 20200528
[ 0.118916] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[ 0.118928] APIC: Switch to symmetric I/O mode setup
[ 0.153860] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.168932] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x3140a1258d3, max_idle_ns: 440795265737 ns
[ 0.168937] Calibrating delay loop (skipped), value calculated using timer frequency.. 6836.51 BogoMIPS (lpj=11389630)
[ 0.168939] pid_max: default: 32768 minimum: 301
[ 0.168979] LSM: Security Framework initializing
[ 0.168984] Yama: becoming mindful.
[ 0.169030] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.169058] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.169322] Last level iTLB entries: 4KB 512, 2MB 1024, 4MB 512
[ 0.169323] Last level dTLB entries: 4KB 1024, 2MB 1024, 4MB 512, 1GB 0
[ 0.169326] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.169327] Spectre V2 : Mitigation: Full AMD retpoline
[ 0.169328] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.169329] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.169556] Freeing SMP alternatives memory: 32K
[ 0.281170] smpboot: CPU0: AMD A10-5700 APU with Radeon(tm) HD Graphics (family: 0x15, model: 0x10, stepping: 0x1)
[ 0.281307] Performance Events: Fam15h core perfctr, AMD PMU driver.
[ 0.281311] ... version: 0
[ 0.281312] ... bit width: 48
[ 0.281312] ... generic registers: 6
[ 0.281313] ... value mask: 0000ffffffffffff
[ 0.281313] ... max period: 00007fffffffffff
[ 0.281314] ... fixed-purpose events: 0
[ 0.281314] ... event mask: 000000000000003f
[ 0.281362] rcu: Hierarchical SRCU implementation.
[ 0.281842] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.281915] smp: Bringing up secondary CPUs ...
[ 0.282083] x86: Booting SMP configuration:
[ 0.282084] .... node #0, CPUs: #1 #2 #3
[ 0.285669] smp: Brought up 1 node, 4 CPUs
[ 0.285669] smpboot: Max logical packages: 1
[ 0.285669] smpboot: Total of 4 processors activated (27346.07 BogoMIPS)
[ 0.286514] devtmpfs: initialized
[ 0.286514] x86/mm: Memory block size: 128MB
[ 0.288977] PM: Registering ACPI NVS region [mem 0xddbff000-0xddcd8fff] (892928 bytes)
[ 0.288990] PM: Registering ACPI NVS region [mem 0xde623000-0xde828fff] (2121728 bytes)
[ 0.289145] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.289145] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.289145] pinctrl core: initialized pinctrl subsystem
[ 0.289145] PM: RTC time: 23:35:17, date: 2020-09-27
[ 0.289145] thermal_sys: Registered thermal governor 'fair_share'
[ 0.289145] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.289145] thermal_sys: Registered thermal governor 'step_wise'
[ 0.289145] thermal_sys: Registered thermal governor 'user_space'
[ 0.289145] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.289264] NET: Registered protocol family 16
[ 0.289509] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.289707] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.289910] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.289927] audit: initializing netlink subsys (disabled)
[ 0.289955] audit: type=2000 audit(1601249717.139:1): state=initialized audit_enabled=0 res=1
[ 0.289955] cpuidle: using governor ladder
[ 0.289955] cpuidle: using governor menu
[ 0.289955] ACPI: bus type PCI registered
[ 0.289955] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.289955] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.289955] PCI: not using MMCONFIG
[ 0.289955] PCI: Using configuration type 1 for base access
[ 0.289955] PCI: Using configuration type 1 for extended access
[ 0.292426] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.292426] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.292426] ACPI: Added _OSI(Module Device)
[ 0.292426] ACPI: Added _OSI(Processor Device)
[ 0.292426] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.292426] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.292426] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.292426] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.292426] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.298936] ACPI: 3 ACPI AML tables successfully acquired and loaded
[ 0.298936] ACPI: Interpreter enabled
[ 0.298936] ACPI: (supports S0 S3 S4 S5)
[ 0.298936] ACPI: Using IOAPIC for interrupt routing
[ 0.298936] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.298936] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
[ 0.298936] pmd_set_huge: Cannot satisfy [mem 0xe0000000-0xe0200000] with a huge-page mapping due to MTRR override.
[ 0.298936] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.302280] ACPI: Enabled 8 GPEs in block 00 to 1F
[ 0.308937] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.308937] acpi PNP0A03:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.308937] acpi PNP0A03:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME LTR DPC]
[ 0.308937] acpi PNP0A03:00: _OSC: OS now controls [AER PCIeCapability]
[ 0.309014] PCI host bridge to bus 0000:00
[ 0.309016] pci_bus 0000:00: root bus resource [io 0x0000-0x03af window]
[ 0.309017] pci_bus 0000:00: root bus resource [io 0x03e0-0x0cf7 window]
[ 0.309018] pci_bus 0000:00: root bus resource [io 0x03b0-0x03df window]
[ 0.309019] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.309020] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.309021] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff window]
[ 0.309022] pci_bus 0000:00: root bus resource [mem 0xf0000000-0xffffffff window]
[ 0.309023] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.309033] pci 0000:00:00.0: [1022:1410] type 00 class 0x060000
[ 0.309159] pci 0000:00:00.2: [1022:1419] type 00 class 0x080600
[ 0.309302] pci 0000:00:02.0: [1022:1412] type 01 class 0x060400
[ 0.309333] pci 0000:00:02.0: enabling Extended Tags
[ 0.309367] pci 0000:00:02.0: PME# supported from D0 D3hot D3cold
[ 0.309497] pci 0000:00:10.0: [1022:7812] type 00 class 0x0c0330
[ 0.309525] pci 0000:00:10.0: reg 0x10: [mem 0xfe106000-0xfe107fff 64bit]
[ 0.309637] pci 0000:00:10.0: PME# supported from D0 D3hot D3cold
[ 0.309766] pci 0000:00:10.1: [1022:7812] type 00 class 0x0c0330
[ 0.309794] pci 0000:00:10.1: reg 0x10: [mem 0xfe104000-0xfe105fff 64bit]
[ 0.309917] pci 0000:00:10.1: PME# supported from D0 D3hot D3cold
[ 0.312290] pci 0000:00:11.0: [1022:7801] type 00 class 0x010601
[ 0.312290] pci 0000:00:11.0: reg 0x10: [io 0xf040-0xf047]
[ 0.312290] pci 0000:00:11.0: reg 0x14: [io 0xf030-0xf033]
[ 0.312290] pci 0000:00:11.0: reg 0x18: [io 0xf020-0xf027]
[ 0.312290] pci 0000:00:11.0: reg 0x1c: [io 0xf010-0xf013]
[ 0.312290] pci 0000:00:11.0: reg 0x20: [io 0xf000-0xf00f]
[ 0.312290] pci 0000:00:11.0: reg 0x24: [mem 0xfe10c000-0xfe10c7ff]
[ 0.312290] pci 0000:00:12.0: [1022:7807] type 00 class 0x0c0310
[ 0.312290] pci 0000:00:12.0: reg 0x10: [mem 0xfe10b000-0xfe10bfff]
[ 0.312290] pci 0000:00:12.2: [1022:7808] type 00 class 0x0c0320
[ 0.312290] pci 0000:00:12.2: reg 0x10: [mem 0xfe10a000-0xfe10a0ff]
[ 0.312290] pci 0000:00:12.2: supports D1 D2
[ 0.312290] pci 0000:00:12.2: PME# supported from D0 D1 D2 D3hot
[ 0.312290] pci 0000:00:13.0: [1022:7807] type 00 class 0x0c0310
[ 0.312290] pci 0000:00:13.0: reg 0x10: [mem 0xfe109000-0xfe109fff]
[ 0.312290] pci 0000:00:13.2: [1022:7808] type 00 class 0x0c0320
[ 0.312290] pci 0000:00:13.2: reg 0x10: [mem 0xfe108000-0xfe1080ff]
[ 0.312290] pci 0000:00:13.2: supports D1 D2
[ 0.312290] pci 0000:00:13.2: PME# supported from D0 D1 D2 D3hot
[ 0.312290] pci 0000:00:14.0: [1022:780b] type 00 class 0x0c0500
[ 0.312290] pci 0000:00:14.2: [1022:780d] type 00 class 0x040300
[ 0.312290] pci 0000:00:14.2: reg 0x10: [mem 0xfe100000-0xfe103fff 64bit]
[ 0.312290] pci 0000:00:14.2: PME# supported from D0 D3hot D3cold
[ 0.312290] pci 0000:00:14.3: [1022:780e] type 00 class 0x060100
[ 0.312290] pci 0000:00:14.4: [1022:780f] type 01 class 0x060401
[ 0.312290] pci 0000:00:15.0: [1022:43a0] type 01 class 0x060400
[ 0.312290] pci 0000:00:15.0: enabling Extended Tags
[ 0.312290] pci 0000:00:15.0: supports D1 D2
[ 0.312290] pci 0000:00:15.1: [1022:43a1] type 01 class 0x060400
[ 0.312290] pci 0000:00:15.1: enabling Extended Tags
[ 0.312290] pci 0000:00:15.1: supports D1 D2
[ 0.312290] pci 0000:00:18.0: [1022:1400] type 00 class 0x060000
[ 0.312290] pci 0000:00:18.1: [1022:1401] type 00 class 0x060000
[ 0.312290] pci 0000:00:18.2: [1022:1402] type 00 class 0x060000
[ 0.312368] pci 0000:00:18.3: [1022:1403] type 00 class 0x060000
[ 0.312460] pci 0000:00:18.4: [1022:1404] type 00 class 0x060000
[ 0.312545] pci 0000:00:18.5: [1022:1405] type 00 class 0x060000
[ 0.312678] pci 0000:01:00.0: [10de:1284] type 00 class 0x030000
[ 0.312695] pci 0000:01:00.0: reg 0x10: [mem 0xfd000000-0xfdffffff]
[ 0.312706] pci 0000:01:00.0: reg 0x14: [mem 0xf0000000-0xf7ffffff 64bit pref]
[ 0.312716] pci 0000:01:00.0: reg 0x1c: [mem 0xf8000000-0xf9ffffff 64bit pref]
[ 0.312723] pci 0000:01:00.0: reg 0x24: [io 0xe000-0xe07f]
[ 0.312730] pci 0000:01:00.0: reg 0x30: [mem 0xfe000000-0xfe07ffff pref]
[ 0.312736] pci 0000:01:00.0: enabling Extended Tags
[ 0.312839] pci 0000:01:00.1: [10de:0e0f] type 00 class 0x040300
[ 0.312854] pci 0000:01:00.1: reg 0x10: [mem 0xfe080000-0xfe083fff]
[ 0.312894] pci 0000:01:00.1: enabling Extended Tags
[ 0.312986] pci 0000:00:02.0: ASPM: current common clock configuration is inconsistent, reconfiguring
[ 0.322315] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 0.322321] pci 0000:00:02.0: bridge window [io 0xe000-0xefff]
[ 0.322324] pci 0000:00:02.0: bridge window [mem 0xfd000000-0xfe0fffff]
[ 0.322328] pci 0000:00:02.0: bridge window [mem 0xf0000000-0xf9ffffff 64bit pref]
[ 0.322344] pci_bus 0000:02: extended config space not accessible
[ 0.322419] pci 0000:00:14.4: PCI bridge to [bus 02] (subtractive decode)
[ 0.322427] pci 0000:00:14.4: bridge window [io 0x0000-0x03af window] (subtractive decode)
[ 0.322429] pci 0000:00:14.4: bridge window [io 0x03e0-0x0cf7 window] (subtractive decode)
[ 0.322430] pci 0000:00:14.4: bridge window [io 0x03b0-0x03df window] (subtractive decode)
[ 0.322431] pci 0000:00:14.4: bridge window [io 0x0d00-0xffff window] (subtractive decode)
[ 0.322432] pci 0000:00:14.4: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[ 0.322433] pci 0000:00:14.4: bridge window [mem 0x000c0000-0x000dffff window] (subtractive decode)
[ 0.322435] pci 0000:00:14.4: bridge window [mem 0xf0000000-0xffffffff window] (subtractive decode)
[ 0.322481] pci 0000:00:15.0: PCI bridge to [bus 03]
[ 0.322573] pci 0000:04:00.0: [10ec:8168] type 00 class 0x020000
[ 0.322605] pci 0000:04:00.0: reg 0x10: [io 0xd000-0xd0ff]
[ 0.322635] pci 0000:04:00.0: reg 0x18: [mem 0xfa104000-0xfa104fff 64bit pref]
[ 0.322654] pci 0000:04:00.0: reg 0x20: [mem 0xfa100000-0xfa103fff 64bit pref]
[ 0.322779] pci 0000:04:00.0: supports D1 D2
[ 0.322780] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.322943] pci 0000:00:15.1: PCI bridge to [bus 04]
[ 0.322948] pci 0000:00:15.1: bridge window [io 0xd000-0xdfff]
[ 0.322955] pci 0000:00:15.1: bridge window [mem 0xfa100000-0xfa1fffff 64bit pref]
[ 0.323663] ACPI: PCI Interrupt Link [LNKA] (IRQs 4 5 6 7 10 11 14 15) *0
[ 0.323755] ACPI: PCI Interrupt Link [LNKB] (IRQs 4 5 6 7 10 11 14 15) *0
[ 0.323848] ACPI: PCI Interrupt Link [LNKC] (IRQs 4 5 6 7 10 11 14 15) *0
[ 0.323940] ACPI: PCI Interrupt Link [LNKD] (IRQs 4 10 11 14 15) *0
[ 0.324014] ACPI: PCI Interrupt Link [LNKE] (IRQs 4 5 6 7 10 11 14 15) *0
[ 0.324072] ACPI: PCI Interrupt Link [LNKF] (IRQs 4 5 6 7 10 11 14 15) *0
[ 0.324130] ACPI: PCI Interrupt Link [LNKG] (IRQs 4 5 6 7 10 11 14 15) *0
[ 0.324189] ACPI: PCI Interrupt Link [LNKH] (IRQs 4 5 6 7 10 11 14 15) *0
[ 0.325616] iommu: Default domain type: Translated
[ 0.325631] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[ 0.325631] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.325631] pci 0000:01:00.0: vgaarb: bridge control possible
[ 0.325631] vgaarb: loaded
[ 0.325834] SCSI subsystem initialized
[ 0.325857] libata version 3.00 loaded.
[ 0.325857] ACPI: bus type USB registered
[ 0.325857] usbcore: registered new interface driver usbfs
[ 0.325857] usbcore: registered new interface driver hub
[ 0.325857] usbcore: registered new device driver usb
[ 0.325857] pps_core: LinuxPPS API ver. 1 registered
[ 0.325857] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.325857] PTP clock support registered
[ 0.325857] EDAC MC: Ver: 3.0.0
[ 0.325857] NetLabel: Initializing
[ 0.325857] NetLabel: domain hash size = 128
[ 0.325857] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.325857] NetLabel: unlabeled traffic allowed by default
[ 0.325857] PCI: Using ACPI for IRQ routing
[ 0.333703] PCI: pci_cache_line_size set to 64 bytes
[ 0.333760] e820: reserve RAM buffer [mem 0x0009e800-0x0009ffff]
[ 0.333762] e820: reserve RAM buffer [mem 0xdd90b000-0xdfffffff]
[ 0.333763] e820: reserve RAM buffer [mem 0xde623000-0xdfffffff]
[ 0.333764] e820: reserve RAM buffer [mem 0xdec58000-0xdfffffff]
[ 0.333765] e820: reserve RAM buffer [mem 0xdf000000-0xdfffffff]
[ 0.333766] e820: reserve RAM buffer [mem 0x21f000000-0x21fffffff]
[ 0.335662] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.335666] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[ 0.337767] clocksource: Switched to clocksource tsc-early
[ 0.350666] VFS: Disk quotas dquot_6.6.0
[ 0.350681] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.350758] pnp: PnP ACPI init
[ 0.350917] system 00:00: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.350923] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.351002] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.351084] system 00:02: [mem 0xfeb80000-0xfebfffff] could not be reserved
[ 0.351088] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.351432] system 00:03: [io 0x04d0-0x04d1] has been reserved
[ 0.351434] system 00:03: [io 0x040b] has been reserved
[ 0.351435] system 00:03: [io 0x04d6] has been reserved
[ 0.351437] system 00:03: [io 0x0c00-0x0c01] has been reserved
[ 0.351438] system 00:03: [io 0x0c14] has been reserved
[ 0.351439] system 00:03: [io 0x0c50-0x0c51] has been reserved
[ 0.351440] system 00:03: [io 0x0c52] has been reserved
[ 0.351442] system 00:03: [io 0x0c6c] has been reserved
[ 0.351445] system 00:03: [io 0x0c6f] has been reserved
[ 0.351446] system 00:03: [io 0x0cd0-0x0cd1] has been reserved
[ 0.351448] system 00:03: [io 0x0cd2-0x0cd3] has been reserved
[ 0.351449] system 00:03: [io 0x0cd4-0x0cd5] has been reserved
[ 0.351450] system 00:03: [io 0x0cd6-0x0cd7] has been reserved
[ 0.351451] system 00:03: [io 0x0cd8-0x0cdf] has been reserved
[ 0.351453] system 00:03: [io 0x0800-0x089f] has been reserved
[ 0.351454] system 00:03: [io 0x0b20-0x0b3f] has been reserved
[ 0.351455] system 00:03: [io 0x0900-0x090f] has been reserved
[ 0.351456] system 00:03: [io 0x0910-0x091f] has been reserved
[ 0.351458] system 00:03: [io 0xfe00-0xfefe] has been reserved
[ 0.351460] system 00:03: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.351462] system 00:03: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.351463] system 00:03: [mem 0xfed80000-0xfed8ffff] has been reserved
[ 0.351465] system 00:03: [mem 0xfed61000-0xfed70fff] has been reserved
[ 0.351466] system 00:03: [mem 0xfec10000-0xfec10fff] has been reserved
[ 0.351468] system 00:03: [mem 0xfed00000-0xfed00fff] could not be reserved
[ 0.351470] system 00:03: [mem 0xff000000-0xffffffff] has been reserved
[ 0.351474] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.351680] system 00:04: [io 0x0300-0x031f] has been reserved
[ 0.351682] system 00:04: [io 0x0290-0x029f] has been reserved
[ 0.351683] system 00:04: [io 0x0230-0x023f] has been reserved
[ 0.351687] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.352101] pnp 00:05: [dma 0 disabled]
[ 0.352236] pnp 00:05: Plug and Play ACPI device, IDs PNP0400 (active)
[ 0.352264] pnp 00:06: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.352327] system 00:07: [io 0x04d0-0x04d1] has been reserved
[ 0.352331] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.352375] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.352423] pnp 00:09: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[ 0.352739] pnp 00:0a: [dma 0 disabled]
[ 0.352782] pnp 00:0a: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.352990] pnp: PnP ACPI: found 11 devices
[ 0.359454] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.359509] NET: Registered protocol family 2
[ 0.359676] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.359774] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.360009] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.360103] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.360259] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.360295] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.360394] NET: Registered protocol family 1
[ 0.360399] NET: Registered protocol family 44
[ 0.360416] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 0.360419] pci 0000:00:02.0: bridge window [io 0xe000-0xefff]
[ 0.360423] pci 0000:00:02.0: bridge window [mem 0xfd000000-0xfe0fffff]
[ 0.360426] pci 0000:00:02.0: bridge window [mem 0xf0000000-0xf9ffffff 64bit pref]
[ 0.360430] pci 0000:00:14.4: PCI bridge to [bus 02]
[ 0.360441] pci 0000:00:15.0: PCI bridge to [bus 03]
[ 0.360451] pci 0000:00:15.1: PCI bridge to [bus 04]
[ 0.360453] pci 0000:00:15.1: bridge window [io 0xd000-0xdfff]
[ 0.360458] pci 0000:00:15.1: bridge window [mem 0xfa100000-0xfa1fffff 64bit pref]
[ 0.360464] pci_bus 0000:00: resource 4 [io 0x0000-0x03af window]
[ 0.360465] pci_bus 0000:00: resource 5 [io 0x03e0-0x0cf7 window]
[ 0.360467] pci_bus 0000:00: resource 6 [io 0x03b0-0x03df window]
[ 0.360468] pci_bus 0000:00: resource 7 [io 0x0d00-0xffff window]
[ 0.360469] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000bffff window]
[ 0.360470] pci_bus 0000:00: resource 9 [mem 0x000c0000-0x000dffff window]
[ 0.360471] pci_bus 0000:00: resource 10 [mem 0xf0000000-0xffffffff window]
[ 0.360473] pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
[ 0.360474] pci_bus 0000:01: resource 1 [mem 0xfd000000-0xfe0fffff]
[ 0.360475] pci_bus 0000:01: resource 2 [mem 0xf0000000-0xf9ffffff 64bit pref]
[ 0.360476] pci_bus 0000:02: resource 4 [io 0x0000-0x03af window]
[ 0.360477] pci_bus 0000:02: resource 5 [io 0x03e0-0x0cf7 window]
[ 0.360479] pci_bus 0000:02: resource 6 [io 0x03b0-0x03df window]
[ 0.360480] pci_bus 0000:02: resource 7 [io 0x0d00-0xffff window]
[ 0.360481] pci_bus 0000:02: resource 8 [mem 0x000a0000-0x000bffff window]
[ 0.360482] pci_bus 0000:02: resource 9 [mem 0x000c0000-0x000dffff window]
[ 0.360483] pci_bus 0000:02: resource 10 [mem 0xf0000000-0xffffffff window]
[ 0.360484] pci_bus 0000:04: resource 0 [io 0xd000-0xdfff]
[ 0.360485] pci_bus 0000:04: resource 2 [mem 0xfa100000-0xfa1fffff 64bit pref]
[ 0.392064] pci 0000:00:12.0: quirk_usb_early_handoff+0x0/0x6d5 took 30321 usecs
[ 0.392275] pci 0000:00:12.2: PME# does not work under D3, disabling it
[ 0.418731] pci 0000:00:13.0: quirk_usb_early_handoff+0x0/0x6d5 took 25824 usecs
[ 0.418943] pci 0000:00:13.2: PME# does not work under D3, disabling it
[ 0.418986] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.419003] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[ 0.419051] PCI: CLS 64 bytes, default 64
[ 0.419099] Trying to unpack rootfs image as initramfs...
[ 0.542330] Freeing initrd memory: 9396K
[ 0.542543] pci 0000:00:02.0: Adding to iommu group 0
[ 0.542571] pci 0000:00:10.0: Adding to iommu group 1
[ 0.542583] pci 0000:00:10.1: Adding to iommu group 1
[ 0.542594] pci 0000:00:11.0: Adding to iommu group 2
[ 0.542613] pci 0000:00:12.0: Adding to iommu group 3
[ 0.542623] pci 0000:00:12.2: Adding to iommu group 3
[ 0.542643] pci 0000:00:13.0: Adding to iommu group 4
[ 0.542653] pci 0000:00:13.2: Adding to iommu group 4
[ 0.542676] pci 0000:00:14.0: Adding to iommu group 5
[ 0.542686] pci 0000:00:14.2: Adding to iommu group 5
[ 0.542697] pci 0000:00:14.3: Adding to iommu group 5
[ 0.542710] pci 0000:00:14.4: Adding to iommu group 6
[ 0.542730] pci 0000:00:15.0: Adding to iommu group 7
[ 0.542742] pci 0000:00:15.1: Adding to iommu group 7
[ 0.542790] pci 0000:00:18.0: Adding to iommu group 8
[ 0.542812] pci 0000:00:18.1: Adding to iommu group 8
[ 0.542824] pci 0000:00:18.2: Adding to iommu group 8
[ 0.542838] pci 0000:00:18.3: Adding to iommu group 8
[ 0.542849] pci 0000:00:18.4: Adding to iommu group 8
[ 0.542863] pci 0000:00:18.5: Adding to iommu group 8
[ 0.542869] pci 0000:01:00.0: Adding to iommu group 0
[ 0.542875] pci 0000:01:00.1: Adding to iommu group 0
[ 0.542881] pci 0000:04:00.0: Adding to iommu group 7
[ 0.543913] pci 0000:00:00.2: AMD-Vi: Found IOMMU cap 0x40
[ 0.543915] pci 0000:00:00.2: AMD-Vi: Extended features (0x800000853):
[ 0.543916] PreF PPR GT IA
[ 0.543918] AMD-Vi: Interrupt remapping enabled
[ 0.544069] AMD-Vi: Lazy IO/TLB flushing enabled
[ 0.546171] amd_uncore: AMD NB counters detected
[ 0.546249] LVT offset 0 assigned for vector 0x400
[ 0.546292] perf: AMD IBS detected (0x000000ff)
[ 0.546341] check: Scanning for low memory corruption every 60 seconds
[ 0.546697] Initialise system trusted keyrings
[ 0.546705] Key type blacklist registered
[ 0.546778] workingset: timestamp_bits=41 max_order=21 bucket_order=0
[ 0.548123] zbud: loaded
[ 0.558149] Key type asymmetric registered
[ 0.558151] Asymmetric key parser 'x509' registered
[ 0.558169] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.558226] io scheduler mq-deadline registered
[ 0.558227] io scheduler kyber registered
[ 0.558264] io scheduler bfq registered
[ 0.559060] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.559139] vesafb: mode is 640x480x32, linelength=2560, pages=0
[ 0.559139] vesafb: scrolling: redraw
[ 0.559141] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.559151] vesafb: framebuffer at 0xf9000000, mapped to 0x(____ptrval____), using 1216k, total 1216k
[ 0.559202] fbcon: Deferring console take-over
[ 0.559203] fb0: VESA VGA frame buffer device
[ 0.559272] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.559292] ACPI: Power Button [PWRB]
[ 0.559330] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.559362] ACPI: Power Button [PWRF]
[ 0.559418] ACPI: \_PR_.P000: Found 2 idle states
[ 0.559492] ACPI: \_PR_.P001: Found 2 idle states
[ 0.559567] ACPI: \_PR_.P002: Found 2 idle states
[ 0.559651] ACPI: \_PR_.P003: Found 2 idle states
[ 0.559957] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.560098] 00:0a: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 0.560871] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 0.561507] ahci 0000:00:11.0: version 3.0
[ 0.561866] ahci 0000:00:11.0: AHCI 0001.0300 32 slots 8 ports 6 Gbps 0xff impl SATA mode
[ 0.561871] ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp pio sxs
[ 0.562829] scsi host0: ahci
[ 0.562985] scsi host1: ahci
[ 0.563100] scsi host2: ahci
[ 0.563221] scsi host3: ahci
[ 0.563329] scsi host4: ahci
[ 0.563436] scsi host5: ahci
[ 0.563543] scsi host6: ahci
[ 0.563655] scsi host7: ahci
[ 0.563701] ata1: SATA max UDMA/133 abar m2048@0xfe10c000 port 0xfe10c100 irq 28
[ 0.563704] ata2: SATA max UDMA/133 abar m2048@0xfe10c000 port 0xfe10c180 irq 29
[ 0.563705] ata3: SATA max UDMA/133 abar m2048@0xfe10c000 port 0xfe10c200 irq 30
[ 0.563707] ata4: SATA max UDMA/133 abar m2048@0xfe10c000 port 0xfe10c280 irq 31
[ 0.563709] ata5: SATA max UDMA/133 abar m2048@0xfe10c000 port 0xfe10c300 irq 32
[ 0.563710] ata6: SATA max UDMA/133 abar m2048@0xfe10c000 port 0xfe10c380 irq 33
[ 0.563712] ata7: SATA max UDMA/133 abar m2048@0xfe10c000 port 0xfe10c400 irq 34
[ 0.563714] ata8: SATA max UDMA/133 abar m2048@0xfe10c000 port 0xfe10c480 irq 35
[ 0.563786] usbcore: registered new interface driver usbserial_generic
[ 0.563792] usbserial: USB Serial support registered for generic
[ 0.563821] rtc_cmos 00:06: RTC can wake from S4
[ 0.564048] rtc_cmos 00:06: registered as rtc0
[ 0.564075] rtc_cmos 00:06: setting system clock to 2020-09-27T23:35:17 UTC (1601249717)
[ 0.564100] rtc_cmos 00:06: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 0.564205] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.564280] drop_monitor: Initializing network drop monitor service
[ 0.564437] NET: Registered protocol family 10
[ 0.569474] Segment Routing with IPv6
[ 0.569476] RPL Segment Routing with IPv6
[ 0.569500] NET: Registered protocol family 17
[ 0.569554] x86/pm: family 0x15 cpu detected, MSR saving is needed during suspending.
[ 0.569840] microcode: CPU0: patch_level=0x06001119
[ 0.569844] microcode: CPU1: patch_level=0x06001119
[ 0.569852] microcode: CPU2: patch_level=0x06001119
[ 0.569859] microcode: CPU3: patch_level=0x06001119
[ 0.569900] microcode: Microcode Update Driver: v2.2.
[ 0.569905] IPI shorthand broadcast: enabled
[ 0.569912] sched_clock: Marking stable (539715138, 30179410)->(588102797, -18208249)
[ 0.570000] registered taskstats version 1
[ 0.570012] Loading compiled-in X.509 certificates
[ 0.573104] Loaded X.509 cert 'Build time autogenerated kernel key: 5996b3c054c5a5d45f30f3a31bd2b8088edb6449'
[ 0.574431] zswap: loaded using pool zstd/z3fold
[ 0.574656] Key type ._fscrypt registered
[ 0.574657] Key type .fscrypt registered
[ 0.574657] Key type fscrypt-provisioning registered
[ 0.575017] PM: Magic number: 4:519:606
[ 0.575174] RAS: Correctable Errors collector initialized.
[ 0.877667] ata8: SATA link down (SStatus 0 SControl 300)
[ 0.878529] ata7: SATA link down (SStatus 0 SControl 300)
[ 0.878556] ata5: SATA link down (SStatus 0 SControl 300)
[ 0.879421] ata6: SATA link down (SStatus 0 SControl 300)
[ 0.881001] ata4: SATA link down (SStatus 0 SControl 300)
[ 1.036256] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.036490] ata1.00: supports DRM functions and may not be fully accessible
[ 1.036920] ata1.00: ATA-11: Samsung SSD 860 EVO 1TB, RVT04B6Q, max UDMA/133
[ 1.036921] ata1.00: 1953525168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 1.038605] ata1.00: supports DRM functions and may not be fully accessible
[ 1.040405] ata1.00: configured for UDMA/133
[ 1.040536] scsi 0:0:0:0: Direct-Access ATA Samsung SSD 860 4B6Q PQ: 0 ANSI: 5
[ 1.040705] ata1.00: Enabling discard_zeroes_data
[ 1.040773] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 1.040784] sd 0:0:0:0: [sda] Write Protect is off
[ 1.040786] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.040803] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.040954] ata1.00: Enabling discard_zeroes_data
[ 1.041627] sda: sda1 sda2 sda3 < sda5 sda6 sda7 > sda4
[ 1.042065] ata1.00: Enabling discard_zeroes_data
[ 1.042722] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.043048] sd 0:0:0:0: [sda] supports TCG Opal
[ 1.043050] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.043257] ata3.00: ATA-9: WDC WD10EZEX-00BN5A0, 01.01A01, max UDMA/133
[ 1.043259] ata3.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 1.043826] ata3.00: configured for UDMA/133
[ 1.044232] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.046284] ata2.00: ATAPI: HL-DT-ST DVDRAM GH24NSB0, LN01, max UDMA/133
[ 1.047803] ata2.00: configured for UDMA/133
[ 1.053589] scsi 1:0:0:0: CD-ROM HL-DT-ST DVDRAM GH24NSB0 LN01 PQ: 0 ANSI: 5
[ 1.084234] scsi 2:0:0:0: Direct-Access ATA WDC WD10EZEX-00B 1A01 PQ: 0 ANSI: 5
[ 1.084460] sd 2:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 1.084461] sd 2:0:0:0: [sdb] 4096-byte physical blocks
[ 1.084472] sd 2:0:0:0: [sdb] Write Protect is off
[ 1.084474] sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 1.084491] sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.097569] sdb: sdb1 sdb2
[ 1.097954] sd 2:0:0:0: [sdb] Attached SCSI disk
[ 1.099429] Freeing unused decrypted memory: 2040K
[ 1.099917] Freeing unused kernel image (initmem) memory: 1648K
[ 1.109463] Write protecting the kernel read-only data: 22528k
[ 1.110142] Freeing unused kernel image (text/rodata gap) memory: 2044K
[ 1.110580] Freeing unused kernel image (rodata/data gap) memory: 1488K
[ 1.149540] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.149546] Run /init as init process
[ 1.149547] with arguments:
[ 1.149548] /init
[ 1.149549] with environment:
[ 1.149549] HOME=/
[ 1.149550] TERM=linux
[ 1.149551] BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
[ 1.226867] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[ 1.226869] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 1.227061] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.234746] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.237530] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.237531] Warning! ehci_hcd should always be loaded before uhci_hcd and ohci_hcd, not after
[ 1.238629] ehci-pci: EHCI PCI platform driver
[ 1.238822] QUIRK: Enable AMD PLL fix
[ 1.238848] ehci-pci 0000:00:12.2: EHCI Host Controller
[ 1.238854] ehci-pci 0000:00:12.2: new USB bus registered, assigned bus number 1
[ 1.238860] ehci-pci 0000:00:12.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[ 1.238870] ehci-pci 0000:00:12.2: debug port 1
[ 1.238932] ehci-pci 0000:00:12.2: irq 17, io mem 0xfe10a000
[ 1.252292] ehci-pci 0000:00:12.2: USB 2.0 started, EHCI 1.00
[ 1.252401] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[ 1.252403] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.252405] usb usb1: Product: EHCI Host Controller
[ 1.252407] usb usb1: Manufacturer: Linux 5.8.6-1-MANJARO ehci_hcd
[ 1.252409] usb usb1: SerialNumber: 0000:00:12.2
[ 1.252596] hub 1-0:1.0: USB hub found
[ 1.252607] hub 1-0:1.0: 5 ports detected
[ 1.252826] xhci_hcd 0000:00:10.0: xHCI Host Controller
[ 1.252834] xhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 2
[ 1.253010] xhci_hcd 0000:00:10.0: hcc params 0x014042c3 hci version 0x96 quirks 0x0000000000000608
[ 1.253343] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[ 1.253345] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.253347] usb usb2: Product: xHCI Host Controller
[ 1.253348] usb usb2: Manufacturer: Linux 5.8.6-1-MANJARO xhci-hcd
[ 1.253350] usb usb2: SerialNumber: 0000:00:10.0
[ 1.253509] hub 2-0:1.0: USB hub found
[ 1.253520] hub 2-0:1.0: 2 ports detected
[ 1.253683] ehci-pci 0000:00:13.2: EHCI Host Controller
[ 1.253693] ehci-pci 0000:00:13.2: new USB bus registered, assigned bus number 3
[ 1.253698] ehci-pci 0000:00:13.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[ 1.253703] xhci_hcd 0000:00:10.0: xHCI Host Controller
[ 1.253707] xhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 4
[ 1.253709] ehci-pci 0000:00:13.2: debug port 1
[ 1.253711] xhci_hcd 0000:00:10.0: Host supports USB 3.0 SuperSpeed
[ 1.253754] ehci-pci 0000:00:13.2: irq 17, io mem 0xfe108000
[ 1.256449] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.256497] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.08
[ 1.256499] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.256501] usb usb4: Product: xHCI Host Controller
[ 1.256503] usb usb4: Manufacturer: Linux 5.8.6-1-MANJARO xhci-hcd
[ 1.256505] usb usb4: SerialNumber: 0000:00:10.0
[ 1.256671] hub 4-0:1.0: USB hub found
[ 1.256686] hub 4-0:1.0: 2 ports detected
[ 1.265629] ehci-pci 0000:00:13.2: USB 2.0 started, EHCI 1.00
[ 1.265707] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[ 1.265709] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.265711] usb usb3: Product: EHCI Host Controller
[ 1.265713] usb usb3: Manufacturer: Linux 5.8.6-1-MANJARO ehci_hcd
[ 1.265715] usb usb3: SerialNumber: 0000:00:13.2
[ 1.265878] hub 3-0:1.0: USB hub found
[ 1.265888] hub 3-0:1.0: 5 ports detected
[ 1.266118] xhci_hcd 0000:00:10.1: xHCI Host Controller
[ 1.266128] xhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 5
[ 1.266301] xhci_hcd 0000:00:10.1: hcc params 0x014042c3 hci version 0x96 quirks 0x0000000000000608
[ 1.266647] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[ 1.266649] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.266651] usb usb5: Product: xHCI Host Controller
[ 1.266652] usb usb5: Manufacturer: Linux 5.8.6-1-MANJARO xhci-hcd
[ 1.266653] usb usb5: SerialNumber: 0000:00:10.1
[ 1.266765] hub 5-0:1.0: USB hub found
[ 1.266775] hub 5-0:1.0: 2 ports detected
[ 1.266923] xhci_hcd 0000:00:10.1: xHCI Host Controller
[ 1.266926] xhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 6
[ 1.266929] xhci_hcd 0000:00:10.1: Host supports USB 3.0 SuperSpeed
[ 1.267384] ohci-pci: OHCI PCI platform driver
[ 1.267591] ohci-pci 0000:00:12.0: OHCI PCI host controller
[ 1.267597] ohci-pci 0000:00:12.0: new USB bus registered, assigned bus number 7
[ 1.267643] ohci-pci 0000:00:12.0: irq 18, io mem 0xfe10b000
[ 1.269739] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.269784] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.08
[ 1.269787] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.269788] usb usb6: Product: xHCI Host Controller
[ 1.269790] usb usb6: Manufacturer: Linux 5.8.6-1-MANJARO xhci-hcd
[ 1.269792] usb usb6: SerialNumber: 0000:00:10.1
[ 1.270023] hub 6-0:1.0: USB hub found
[ 1.270036] hub 6-0:1.0: 2 ports detected
[ 1.276271] sr 1:0:0:0: [sr0] scsi3-mmc drive: 48x/12x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.276274] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.289270] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 1.300068] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
[ 1.326381] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.08
[ 1.326383] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.326384] usb usb7: Product: OHCI PCI host controller
[ 1.326385] usb usb7: Manufacturer: Linux 5.8.6-1-MANJARO ohci_hcd
[ 1.326387] usb usb7: SerialNumber: 0000:00:12.0
[ 1.326599] hub 7-0:1.0: USB hub found
[ 1.326611] hub 7-0:1.0: 5 ports detected
[ 1.326979] ohci-pci 0000:00:13.0: OHCI PCI host controller
[ 1.326984] ohci-pci 0000:00:13.0: new USB bus registered, assigned bus number 8
[ 1.327006] ohci-pci 0000:00:13.0: irq 18, io mem 0xfe109000
[ 1.346378] random: fast init done
[ 1.386358] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.08
[ 1.386360] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.386361] usb usb8: Product: OHCI PCI host controller
[ 1.386363] usb usb8: Manufacturer: Linux 5.8.6-1-MANJARO ohci_hcd
[ 1.386364] usb usb8: SerialNumber: 0000:00:13.0
[ 1.386513] hub 8-0:1.0: USB hub found
[ 1.386524] hub 8-0:1.0: 5 ports detected
[ 1.535705] tsc: Refined TSC clocksource calibration: 3416.999 MHz
[ 1.535713] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x3141096243e, max_idle_ns: 440795378425 ns
[ 1.535736] clocksource: Switched to clocksource tsc
[ 1.598955] usb 3-1: new high-speed USB device number 2 using ehci-pci
[ 1.730149] EXT4-fs (sda5): recovery complete
[ 1.730682] EXT4-fs (sda5): mounted filesystem with ordered data mode. Opts: (null)
[ 1.798950] usb 7-1: new low-speed USB device number 2 using ohci-pci
[ 1.835503] systemd[1]: systemd 246.4-1-manjaro running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 1.849140] systemd[1]: Detected architecture x86-64.
[ 1.879734] systemd[1]: Set hostname to <Holger>.
[ 1.949030] usb 3-1: New USB device found, idVendor=048d, idProduct=1345, bcdDevice= 1.00
[ 1.949032] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.949034] usb 3-1: Product: Mass Storage Device
[ 1.949035] usb 3-1: Manufacturer: Generic
[ 1.949036] usb 3-1: SerialNumber: 000000000000100
[ 1.983319] usb 7-1: New USB device found, idVendor=093a, idProduct=2510, bcdDevice= 1.00
[ 1.983322] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.983323] usb 7-1: Product: USB Optical Mouse
[ 1.983324] usb 7-1: Manufacturer: PixArt
[ 2.045385] systemd[1]: Queued start job for default target Graphical Interface.
[ 2.045641] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.046351] systemd[1]: Created slice system-getty.slice.
[ 2.046393] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.046630] systemd[1]: Created slice system-modprobe.slice.
[ 2.046642] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.046848] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 2.047111] systemd[1]: Created slice User and Session Slice.
[ 2.047174] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 2.047218] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.047383] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.047425] systemd[1]: Reached target Local Encrypted Volumes.
[ 2.047450] systemd[1]: Reached target Login Prompts.
[ 2.047482] systemd[1]: Reached target Remote File Systems.
[ 2.047497] systemd[1]: Reached target Slices.
[ 2.047521] systemd[1]: Reached target Swap.
[ 2.047594] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 2.047909] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 2.048111] systemd[1]: Listening on LVM2 poll daemon socket.
[ 2.050276] systemd[1]: Listening on Process Core Dump Socket.
[ 2.050390] systemd[1]: Listening on Journal Audit Socket.
[ 2.050471] systemd[1]: Listening on Journal Socket (/dev/log).
[ 2.050569] systemd[1]: Listening on Journal Socket.
[ 2.050669] systemd[1]: Listening on udev Control Socket.
[ 2.050737] systemd[1]: Listening on udev Kernel Socket.
[ 2.051650] systemd[1]: Mounting Huge Pages File System...
[ 2.052716] systemd[1]: Mounting POSIX Message Queue File System...
[ 2.054096] systemd[1]: Mounting Kernel Debug File System...
[ 2.055542] systemd[1]: Mounting Kernel Trace File System...
[ 2.055744] systemd[1]: Condition check resulted in Load AppArmor profiles being skipped.
[ 2.057186] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 2.058649] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 2.060084] systemd[1]: Starting Load Kernel Module drm...
[ 2.060160] systemd[1]: Condition check resulted in Load AppArmor profiles managed internally by snapd being skipped.
[ 2.062118] systemd[1]: Starting Set Up Additional Binary Formats...
[ 2.062223] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 2.065120] systemd[1]: Starting Load Kernel Modules...
[ 2.066762] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 2.066886] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[ 2.069765] systemd[1]: Starting Coldplug All udev Devices...
[ 2.069995] Linux agpgart interface v0.103
[ 2.077990] EXT4-fs (sda5): re-mounted. Opts: (null)
[ 2.080310] systemd[1]: Mounted Huge Pages File System.
[ 2.080429] systemd[1]: Mounted POSIX Message Queue File System.
[ 2.080529] systemd[1]: Mounted Kernel Debug File System.
[ 2.080628] systemd[1]: Mounted Kernel Trace File System.
[ 2.081319] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 2.081974] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 2.082652] systemd[1]: Finished Load Kernel Modules.
[ 2.082828] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 244 (systemd-binfmt)
[ 2.084163] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[ 2.084343] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[ 2.085871] systemd[1]: Mounting Kernel Configuration File System...
[ 2.085993] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[ 2.086633] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 2.088134] systemd[1]: Starting Apply Kernel Variables...
[ 2.088224] systemd[1]: Condition check resulted in Create System Users being skipped.
[ 2.089589] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 2.090875] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[ 2.091060] systemd[1]: Mounted Kernel Configuration File System.
[ 2.099739] systemd[1]: Finished Set Up Additional Binary Formats.
[ 2.100470] systemd[1]: Finished Apply Kernel Variables.
[ 2.102625] systemd[1]: Starting CLI Netfilter Manager...
[ 2.111392] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 2.112975] systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm.
[ 2.115014] systemd[1]: Starting Journal Service...
[ 2.116998] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 2.136072] systemd[1]: modprobe@drm.service: Succeeded.
[ 2.136675] systemd[1]: Finished Load Kernel Module drm.
[ 2.140171] systemd[1]: Finished CLI Netfilter Manager.
[ 2.160513] systemd[1]: Finished Coldplug All udev Devices.
[ 2.161667] systemd[1]: Starting Wait for udev To Complete Device Initialization...
[ 2.768115] systemd[1]: Started Journal Service.
[ 2.768222] audit: type=1130 audit(1601249719.698:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.782800] audit: type=1130 audit(1601249719.714:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.789917] audit: type=1130 audit(1601249719.721:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.823581] random: crng init done
[ 2.823584] random: 7 urandom warning(s) missed due to ratelimiting
[ 2.838056] audit: type=1130 audit(1601249719.768:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.903259] acpi_cpufreq: overriding BIOS provided _PSD data
[ 2.925168] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[ 2.925171] piix4_smbus 0000:00:14.0: Using register 0x2e for SMBus port selection
[ 2.925326] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
[ 2.936168] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[ 2.936292] sp5100-tco sp5100-tco: Using 0xfed80b00 for watchdog MMIO address
[ 2.943632] sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
[ 2.988111] parport_pc 00:05: reported by Plug and Play ACPI
[ 2.988186] parport0: PC-style at 0x378, irq 5 [PCSPP,TRISTATE]
[ 3.152579] input: PC Speaker as /devices/platform/pcspkr/input/input3
[ 3.169389] libphy: r8169: probed
[ 3.169754] r8169 0000:04:00.0 eth0: RTL8168f/8111f, 60:a4:4c:3f:26:6d, XID 480, IRQ 46
[ 3.169757] r8169 0000:04:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 3.201600] cryptd: max_cpu_qlen set to 1000
[ 3.229022] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 3.229030] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 3.244357] AVX version of gcm_enc/dec engaged.
[ 3.244360] AES CTR mode by8 optimization enabled
[ 3.250567] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:02.0/0000:01:00.1/sound/card1/input4
[ 3.250639] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:02.0/0000:01:00.1/sound/card1/input5
[ 3.250705] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:02.0/0000:01:00.1/sound/card1/input6
[ 3.250770] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:02.0/0000:01:00.1/sound/card1/input7
[ 3.250836] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:02.0/0000:01:00.1/sound/card1/input8
[ 3.255629] audit: type=1130 audit(1601249720.184:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.290422] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC887-VD: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[ 3.290425] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 3.290432] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 3.290434] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 3.290435] snd_hda_codec_realtek hdaudioC0D0: dig-out=0x11/0x1e
[ 3.290437] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 3.290439] snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
[ 3.290441] snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
[ 3.290443] snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
[ 3.304723] input: HD-Audio Generic Front Mic as /devices/pci0000:00/0000:00:14.2/sound/card0/input9
[ 3.304839] input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:14.2/sound/card0/input10
[ 3.304932] input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:14.2/sound/card0/input11
[ 3.305026] input: HD-Audio Generic Line Out as /devices/pci0000:00/0000:00:14.2/sound/card0/input12
[ 3.305138] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:14.2/sound/card0/input13
[ 3.307340] audit: type=1130 audit(1601249720.238:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-6E55\x2dAB68 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.339558] audit: type=1130 audit(1601249720.271:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-e02051e8\x2d80ba\x2d4772\x2da9d9\x2dd9a8974edfa7 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3.350883] ppdev: user-space parallel port driver
[ 3.356904] EXT4-fs (sda7): mounted filesystem with ordered data mode. Opts: (null)
[ 3.386788] r8169 0000:04:00.0 enp4s0: renamed from eth0
[ 3.408764] asus_wmi: ASUS WMI generic driver loaded
[ 3.443955] checking generic (f9000000 130000) vs hw (fd000000 1000000)
[ 3.443958] checking generic (f9000000 130000) vs hw (f0000000 8000000)
[ 3.443959] checking generic (f9000000 130000) vs hw (f8000000 2000000)
[ 3.443960] fb0: switching to nouveaufb from VESA VGA
[ 3.444085] nouveau 0000:01:00.0: vgaarb: deactivate vga console
[ 3.444157] nouveau 0000:01:00.0: NVIDIA GK208 (108040a1)
[ 3.448407] asus_wmi: Initialization: 0x0
[ 3.448455] asus_wmi: BIOS WMI version: 0.9
[ 3.448543] asus_wmi: SFUN value: 0x0
[ 3.448546] eeepc-wmi eeepc-wmi: Detected ASUSWMI, use DCTS
[ 3.459696] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input14
[ 3.459750] kvm: Nested Virtualization enabled
[ 3.459755] SVM: kvm: Nested Paging enabled
[ 3.463114] MCE: In-kernel MCE decoding enabled.
[ 3.466720] EDAC amd64: F15h detected (node 0).
[ 3.466729] EDAC amd64: Error: F1 not found: device 0x1601 (broken BIOS?)
[ 3.506274] EDAC amd64: F15h detected (node 0).
[ 3.506282] EDAC amd64: Error: F1 not found: device 0x1601 (broken BIOS?)
[ 3.540828] EDAC amd64: F15h detected (node 0).
[ 3.540837] EDAC amd64: Error: F1 not found: device 0x1601 (broken BIOS?)
[ 3.568816] nouveau 0000:01:00.0: bios: version 80.28.3e.00.0d
[ 3.569552] EDAC amd64: F15h detected (node 0).
[ 3.569560] EDAC amd64: Error: F1 not found: device 0x1601 (broken BIOS?)
[ 3.569684] nouveau 0000:01:00.0: fb: 2048 MiB DDR3
[ 4.341141] hid: raw HID events driver (C) Jiri Kosina
[ 4.358722] usbcore: registered new interface driver usbhid
[ 4.358725] usbhid: USB HID core driver
[ 4.367139] input: PixArt USB Optical Mouse as /devices/pci0000:00/0000:00:12.0/usb7/7-1/7-1:1.0/0003:093A:2510.0001/input/input15
[ 4.367328] hid-generic 0003:093A:2510.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-0000:00:12.0-1/input0
[ 4.383449] mousedev: PS/2 mouse device common for all mice
[ 4.663020] [TTM] Zone kernel: Available graphics memory: 4083142 KiB
[ 4.663024] [TTM] Zone dma32: Available graphics memory: 2097152 KiB
[ 4.663026] [TTM] Initializing pool allocator
[ 4.663035] [TTM] Initializing DMA pool allocator
[ 4.663075] nouveau 0000:01:00.0: DRM: VRAM: 2048 MiB
[ 4.663078] nouveau 0000:01:00.0: DRM: GART: 1048576 MiB
[ 4.663085] nouveau 0000:01:00.0: DRM: TMDS table version 2.0
[ 4.663089] nouveau 0000:01:00.0: DRM: DCB version 4.0
[ 4.663093] nouveau 0000:01:00.0: DRM: DCB outp 00: 01000f02 00020030
[ 4.663097] nouveau 0000:01:00.0: DRM: DCB outp 01: 02011f62 00020010
[ 4.663100] nouveau 0000:01:00.0: DRM: DCB outp 02: 02022f10 00000000
[ 4.663104] nouveau 0000:01:00.0: DRM: DCB conn 00: 00001031
[ 4.663107] nouveau 0000:01:00.0: DRM: DCB conn 01: 00002161
[ 4.663110] nouveau 0000:01:00.0: DRM: DCB conn 02: 00000200
[ 4.663781] nouveau 0000:01:00.0: DRM: MM: using COPY for buffer copies
[ 4.669283] usb-storage 3-1:1.0: USB Mass Storage device detected
[ 4.669603] scsi host8: usb-storage 3-1:1.0
[ 4.669812] usbcore: registered new interface driver usb-storage
[ 4.675181] usbcore: registered new interface driver uas
[ 4.675547] snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops nv50_audio_component_bind_ops [nouveau])
[ 4.675590] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 4.842224] nouveau 0000:01:00.0: DRM: allocated 1680x1050 fb: 0x80000, bo 000000002bb3c67e
[ 4.842317] fbcon: nouveaudrmfb (fb0) is primary device
[ 4.842318] fbcon: Deferring console take-over
[ 4.842321] nouveau 0000:01:00.0: fb0: nouveaudrmfb frame buffer device
[ 4.869558] [drm] Initialized nouveau 1.3.1 20120801 for 0000:01:00.0 on minor 0
[ 4.895326] audit: type=1130 audit(1601249721.824:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udev-settle comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 4.910370] fbcon: Taking over console
[ 4.959615] Console: switching to colour frame buffer device 210x65
[ 4.961579] audit: type=1130 audit(1601249721.891:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=zfs-import-scan comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.489204] loop: module loaded
[ 5.544487] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 5.586829] kauditd_printk_skb: 21 callbacks suppressed
[ 5.586831] audit: type=1130 audit(1601249722.518:32): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.712997] scsi 8:0:0:0: Direct-Access Generic Compact Flash 0.00 PQ: 0 ANSI: 2
[ 5.724292] audit: type=1130 audit(1601249722.654:33): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.757718] audit: type=1130 audit(1601249722.688:34): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.763054] RTL8211E Gigabit Ethernet r8169-400:00: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=r8169-400:00, irq=IGNORE)
[ 5.917770] r8169 0000:04:00.0 enp4s0: Link is Down
[ 6.060955] audit: type=1130 audit(1601249722.991:35): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.098590] audit: type=1130 audit(1601249723.028:36): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=accounts-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.133787] audit: type=1130 audit(1601249723.064:37): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.426414] audit: type=1130 audit(1601249723.358:38): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.712199] scsi 8:0:0:1: Direct-Access Generic SM/xD-Picture 0.00 PQ: 0 ANSI: 2
[ 6.729564] scsi 8:0:0:2: Direct-Access Generic SDXC/MMC 0.00 PQ: 0 ANSI: 2
[ 6.747164] scsi 8:0:0:3: Direct-Access Generic MS/MS-Pro/HG 0.00 PQ: 0 ANSI: 2
[ 6.750231] sd 8:0:0:2: [sde] 62748672 512-byte logical blocks: (32.1 GB/29.9 GiB)
[ 6.755218] sd 8:0:0:2: [sde] Write Protect is off
[ 6.755225] sd 8:0:0:2: [sde] Mode Sense: 03 00 00 00
[ 6.755837] sd 8:0:0:2: [sde] No Caching mode page found
[ 6.755842] sd 8:0:0:2: [sde] Assuming drive cache: write through
[ 6.763610] sd 8:0:0:0: [sdc] Attached SCSI removable disk
[ 6.774490] sd 8:0:0:1: [sdd] Attached SCSI removable disk
[ 6.775777] sd 8:0:0:3: [sdf] Attached SCSI removable disk
[ 6.787236] sde: sde1
[ 6.793817] sd 8:0:0:2: [sde] Attached SCSI removable disk
[ 6.839590] audit: type=1100 audit(1601249723.771:39): pid=854 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_faillock,pam_shells,pam_permit,pam_gnome_keyring acct="ho" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 6.842507] audit: type=1101 audit(1601249723.774:40): pid=854 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="ho" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 6.850252] audit: type=1103 audit(1601249723.781:41): pid=854 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_faillock,pam_shells,pam_permit,pam_gnome_keyring acct="ho" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 7.168491] fuse: init (API version 7.31)
[ 8.256377] r8169 0000:04:00.0 enp4s0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 8.256390] IPv6: ADDRCONF(NETDEV_CHANGE): enp4s0: link becomes ready
[ 10.591145] kauditd_printk_skb: 19 callbacks suppressed
[ 10.591147] audit: type=1131 audit(1601249727.521:61): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 10.610057] audit: type=1130 audit(1601249727.541:62): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 16.041468] audit: type=1131 audit(1601249732.971:63): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 35.759913] audit: type=1131 audit(1601249752.691:64): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 35.849164] audit: type=1334 audit(1601249752.781:65): prog-id=10 op=UNLOAD
[ 35.849170] audit: type=1334 audit(1601249752.781:66): prog-id=9 op=UNLOAD
[ 40.644903] audit: type=1131 audit(1601249757.574:67): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 210.843687] audit: type=1100 audit(1601249927.774:68): pid=1216 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="ho" exe="/usr/bin/sshd" hostname=192.168.2.34 addr=192.168.2.34 terminal=ssh res=success'
[ 210.854987] audit: type=1101 audit(1601249927.784:69): pid=1216 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="ho" exe="/usr/bin/sshd" hostname=192.168.2.34 addr=192.168.2.34 terminal=ssh res=success'
[ 210.856957] audit: type=1103 audit(1601249927.788:70): pid=1216 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="ho" exe="/usr/bin/sshd" hostname=192.168.2.34 addr=192.168.2.34 terminal=ssh res=success'
[ 210.857146] audit: type=1006 audit(1601249927.788:71): pid=1216 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
[ 210.876160] audit: type=1105 audit(1601249927.808:72): pid=1216 uid=0 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="ho" exe="/usr/bin/sshd" hostname=192.168.2.34 addr=192.168.2.34 terminal=ssh res=success'
[ 210.879417] audit: type=1103 audit(1601249927.811:73): pid=1218 uid=0 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="ho" exe="/usr/bin/sshd" hostname=192.168.2.34 addr=192.168.2.34 terminal=ssh res=success'
[ 278.104169] audit: type=1100 audit(1601249995.035:74): pid=1235 uid=1000 auid=1000 ses=3 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="ho" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 278.105453] audit: type=1101 audit(1601249995.035:75): pid=1235 uid=1000 auid=1000 ses=3 msg='op=PAM:accounting grantors=pam_permit,pam_time acct="ho" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 278.105749] audit: type=1110 audit(1601249995.038:76): pid=1235 uid=0 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 278.106669] audit: type=1105 audit(1601249995.038:77): pid=1235 uid=0 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ho@Holger ~]$ journalctl -r
-- Logs begin at Mon 2020-06-15 12:21:58 CEST, end at Mon 2020-09-28 00:29:26 CEST. --
Sep 28 00:29:26 Holger kernel: audit: type=1103 audit(1601245766.726:107): pid=3277 uid=0 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pa>
Sep 28 00:29:26 Holger audit[3277]: CRED_ACQ pid=3277 uid=0 auid=1000 ses=3 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="ho" exe="/usr>
Sep 28 00:29:26 Holger kernel: audit: type=1105 audit(1601245766.722:106): pid=3273 uid=0 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_lim>
Sep 28 00:29:26 Holger audit[3273]: USER_START pid=3273 uid=0 auid=1000 ses=3 msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_>
Sep 28 00:29:26 Holger systemd[1]: Started Session 3 of user ho.
Sep 28 00:29:26 Holger systemd-logind[604]: New session 3 of user ho.
Sep 28 00:29:26 Holger kernel: audit: type=1006 audit(1601245766.706:105): pid=3273 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
Sep 28 00:29:26 Holger kernel: audit: type=1103 audit(1601245766.706:104): pid=3273 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_shells,pam_failloc>
Sep 28 00:29:26 Holger sshd[3273]: pam_unix(sshd:session): session opened for user ho(uid=1000) by (uid=0)
Sep 28 00:29:26 Holger audit[3273]: CRED_ACQ pid=3273 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct>
Sep 28 00:29:26 Holger kernel: audit: type=1101 audit(1601245766.702:103): pid=3273 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_perm>
Sep 28 00:29:26 Holger sshd[3273]: Accepted password for ho from 2001:a62:14ee:801:ad47:4f4d:b429:2891 port 62213 ssh2
Sep 28 00:29:26 Holger sshd[3273]: pam_systemd_home(sshd:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Sep 28 00:29:26 Holger dbus-daemon[598]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not f>
Sep 28 00:29:26 Holger audit[3273]: USER_ACCT pid=3273 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="ho" exe="/u>
Sep 28 00:29:26 Holger dbus-daemon[598]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.45>
Sep 28 00:29:26 Holger kernel: audit: type=1100 audit(1601245766.679:102): pid=3273 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_shells,pam_>
Sep 28 00:29:26 Holger audit[3273]: USER_AUTH pid=3273 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faill>
Sep 28 00:24:32 Holger audit: BPF prog-id=20 op=UNLOAD
Sep 28 00:24:32 Holger kernel: audit: type=1334 audit(1601245472.199:101): prog-id=20 op=UNLOAD
Sep 28 00:24:32 Holger kernel: audit: type=1334 audit(1601245472.199:100): prog-id=21 op=UNLOAD
Sep 28 00:24:32 Holger audit: BPF prog-id=21 op=UNLOAD
Sep 28 00:24:32 Holger kernel: audit: type=1131 audit(1601245472.109:99): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/li>
Sep 28 00:24:32 Holger audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=>
Sep 28 00:24:32 Holger systemd[1]: systemd-hostnamed.service: Succeeded.
Sep 28 00:24:28 Holger kernel: CR2: 00007f2b7f89025c CR3: 0000000200964000 CR4: 00000000000406e0
Sep 28 00:24:28 Holger kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Sep 28 00:24:28 Holger kernel: FS: 00007f2b8fb75540(0000) GS:ffffa288d6d00000(0000) knlGS:0000000000000000
Sep 28 00:24:28 Holger kernel: R13: 0000000000000060 R14: ffffa287c0003500 R15: ffffa287c0003500
Sep 28 00:24:28 Holger kernel: R10: 0000000000000001 R11: 00000000000003ff R12: 943dd69e2784cb51
Sep 28 00:24:28 Holger kernel: RBP: 0000000000000dc0 R08: ffffb678c1781000 R09: ffffb678c0fbfbb4
Sep 28 00:24:28 Holger kernel: RDX: 00000000354b5002 RSI: 00000000354b5002 RDI: 00000000000310c0
Sep 28 00:24:28 Holger kernel: RAX: 943dd69e2784cb81 RBX: 0000000000000000 RCX: 00000000000310c0
Sep 28 00:24:28 Holger kernel: RSP: 0018:ffffb678c0fbfc18 EFLAGS: 00010286
Sep 28 00:24:28 Holger kernel: Code: 48 89 c8 65 48 03 05 d9 7a 16 5a 48 8b 70 08 48 39 f2 75 e7 4c 8b 20 4d 85 e4 0f 84 79 01 00 00 41 8b 47 20 49 8b 3f 4c 01 e0 <48> 8b 1>
Sep 28 00:24:28 Holger kernel: RIP: 0010:kmem_cache_alloc_trace+0x7e/0x220
Sep 28 00:24:28 Holger kernel: ---[ end trace bbf62cbe6ebe2057 ]---
Sep 28 00:24:28 Holger kernel: Modules linked in: fuse squashfs loop mousedev hid_generic usbhid hid uas usb_storage nouveau edac_mce_amd kvm_amd mxm_wmi nls_iso8859_1 nls_>
Sep 28 00:24:28 Holger kernel: R13: 000000000000000e R14: 000056533fc8ec10 R15: 000056533fc94950
Sep 28 00:24:28 Holger kernel: R10: 000056533fcc6690 R11: 0000000000000246 R12: 000056533fc9d460
Sep 28 00:24:28 Holger kernel: RBP: 00000000c0406481 R08: 000056533fc94950 R09: 000056533fcae468
Sep 28 00:24:28 Holger kernel: RDX: 00007fff569e46e0 RSI: 00000000c0406481 RDI: 000000000000000e
Sep 28 00:24:28 Holger kernel: RAX: ffffffffffffffda RBX: 00007fff569e46e0 RCX: 00007f2b8fe66f6b
Sep 28 00:24:28 Holger kernel: RSP: 002b:00007fff569e4678 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
Sep 28 00:24:28 Holger kernel: Code: 89 d8 49 8d 3c 1c 48 f7 d8 49 39 c4 72 b5 e8 1c ff ff ff 85 c0 78 ba 4c 89 e0 5b 5d 41 5c c3 f3 0f 1e fa b8 10 00 00 00 0f 05 <48> 3d 0>
Sep 28 00:24:28 Holger kernel: RIP: 0033:0x7f2b8fe66f6b
Sep 28 00:24:28 Holger kernel: entry_SYSCALL_64_after_hwframe+0x44/0xa9
Sep 28 00:24:28 Holger kernel: do_syscall_64+0x44/0x70
Sep 28 00:24:28 Holger kernel: __x64_sys_ioctl+0x16/0x20
Sep 28 00:24:28 Holger kernel: ksys_ioctl+0x82/0xc0
Sep 28 00:24:28 Holger kernel: nouveau_drm_ioctl+0x55/0xa0 [nouveau]
Sep 28 00:24:28 Holger kernel: ? nouveau_gem_ioctl_new+0xd0/0xd0 [nouveau]
Sep 28 00:24:28 Holger kernel: drm_ioctl+0x208/0x360 [drm]
Sep 28 00:24:28 Holger kernel: drm_ioctl_kernel+0xb2/0x100 [drm]
Sep 28 00:24:28 Holger kernel: nouveau_gem_ioctl_pushbuf+0xa7a/0x1180 [nouveau]
Sep 28 00:24:28 Holger kernel: nouveau_fence_new+0x33/0xb0 [nouveau]
Sep 28 00:24:28 Holger kernel: ? nouveau_fence_new+0x33/0xb0 [nouveau]
Sep 28 00:24:28 Holger kernel: Call Trace:
Sep 28 00:24:28 Holger kernel: Hardware name: System manufacturer System Product Name/F2A85-M LE, BIOS 6504 11/26/2014
Sep 28 00:24:28 Holger kernel: CPU: 2 PID: 684 Comm: Xorg Not tainted 5.8.6-1-MANJARO #1
Sep 28 00:24:28 Holger kernel: general protection fault, probably for non-canonical address 0x943dd69e2784cb81: 0000 [#1] PREEMPT SMP NOPTI
Sep 28 00:24:02 Holger systemd[1]: Started Hostname Service.
Sep 28 00:24:02 Holger kernel: audit: type=1130 audit(1601245442.056:98): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/li>
Sep 28 00:24:02 Holger audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname>
Sep 28 00:24:02 Holger dbus-daemon[598]: [system] Successfully activated service 'org.freedesktop.hostname1'
Sep 28 00:24:01 Holger systemd[1]: Starting Hostname Service...
Sep 28 00:24:01 Holger audit: BPF prog-id=21 op=LOAD
Sep 28 00:24:01 Holger audit: BPF prog-id=20 op=LOAD
Sep 28 00:24:01 Holger kernel: audit: type=1334 audit(1601245441.496:97): prog-id=21 op=LOAD
Sep 28 00:24:01 Holger kernel: audit: type=1334 audit(1601245441.496:96): prog-id=20 op=LOAD
Sep 28 00:24:01 Holger dbus-daemon[598]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested b>
Sep 28 00:17:29 Holger dbus-daemon[881]: [session uid=1000 pid=881] Successfully activated service 'org.freedesktop.thumbnails.Thumbnailer1'
Sep 28 00:17:28 Holger org.freedesktop.thumbnails.Thumbnailer1[3128]: Registered thumbnailer gsf-office-thumbnailer -i %i -o %o -s %s
Sep 28 00:17:28 Holger org.freedesktop.thumbnails.Thumbnailer1[3128]: Registered thumbnailer /usr/bin/gdk-pixbuf-thumbnailer -s %s %u %o
Sep 28 00:17:28 Holger org.freedesktop.thumbnails.Thumbnailer1[3128]: Registered thumbnailer heif-thumbnailer -s %s %i %o
Sep 28 00:17:28 Holger org.freedesktop.thumbnails.Thumbnailer1[3128]: Registered thumbnailer ffmpegthumbnailer -i %i -o %o -s %s -f
Sep 28 00:17:28 Holger dbus-daemon[881]: [session uid=1000 pid=881] Activating service name='org.freedesktop.thumbnails.Thumbnailer1' requested by ':1.16' (uid=1000 pid=959>
Sep 28 00:14:17 Holger rtkit-daemon[980]: Supervising 3 threads of 2 processes of 1 users.
Sep 28 00:12:57 Holger kernel: audit: type=1334 audit(1601244777.249:95): prog-id=18 op=UNLOAD
Sep 28 00:12:57 Holger kernel: audit: type=1334 audit(1601244777.249:94): prog-id=19 op=UNLOAD
Sep 28 00:12:57 Holger audit: BPF prog-id=18 op=UNLOAD
Sep 28 00:12:57 Holger audit: BPF prog-id=19 op=UNLOAD
Sep 28 00:12:57 Holger kernel: audit: type=1131 audit(1601244777.196:93): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/li>
Sep 28 00:12:57 Holger audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=>
Sep 28 00:12:57 Holger systemd[1]: systemd-hostnamed.service: Succeeded.
I have read this and found that I too have strange CPU temperatures jumping from 0.0 C to 10.0 C.
A while ago I tried different Kernels without much luck.
I noticed that in journalctl there is always a line reading
Is this a clue?
Thank you for reading this!
