Sorry about that,
Here it is with new format :
Kernel: 6.1.131-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=5a593a3e-ca59-4a5a-9b8e-dd443e00f2b8 rw quiet splash
resume=UUID=a0054547-10c4-45a3-ad75-e91c54b56565 udev.log_priority=3
Desktop: KDE Plasma v: 6 tk: Qt v: N/A wm: kwin_x11 vt: 2 dm: SDDM
Type: Desktop Mobo: Gigabyte model: A520M DS3H serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: F17b
date: 02/08/2023
System RAM: total: 32 GiB available: 31.27 GiB used: 5.26 GiB (16.8%)
(unregistered) size: 8 GiB speed: 3600 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: TeamGroup
part-no: UD4-3600 serial: <filter>
Device-3: Channel-B DIMM 0 type: DDR4 detail: synchronous unbuffered
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 2 microcode: 0xA201210
Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2
smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB
desc: 12x512 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 2200 min/max: 2200/3700 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200 3: 2200
4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
13: 2200 14: 2200 15: 2200 16: 2200 17: 2200 18: 2200 19: 2200 20: 2200
21: 2200 22: 2200 23: 2200 24: 2200 bogomips: 177336
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spec_rstack_overflow mitigation: safe RET
affected
Device-1: Advanced Micro Devices [AMD/ATI] Navi 24 [Radeon RX 6400/6500
XT/6500M] vendor: Sapphire PULSE driver: amdgpu v: kernel arch: RDNA-2
code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: DP-1,HDMI-A-1 empty: none
bus-ID: 07:00.0 chip-ID: 1002:743f class-ID: 0300
Device-2: Linux Foundation EEM Gadget driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3.1:4
chip-ID: 1d6b:0102 class-ID: 0102
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 7680x2160 s-dpi: 96 s-size: 2032x571mm (80.00x22.48")
s-diag: 2111mm (83.1")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: right
model: ViewSonic VX3276-UHD serial: <filter> built: 2021 res: N/A dpi: 140
gamma: 1.2 size: 697x392mm (27.44x15.43") diag: 800mm (31.5") ratio: 16:9
modes: max: 3840x2160 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary,left
model: ViewSonic VX3276-UHD serial: <filter> built: 2020 res:
mode: 3840x2160 hz: 60 scale: 100% (1) dpi: 140 gamma: 1.2
size: 697x392mm (27.44x15.43") diag: 800mm (31.5") ratio: 16:9 modes:
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6500 XT (radeonsi
navi24 LLVM 19.1.7 DRM 3.49 6.1.131-1-MANJARO) device-ID: 1002:743f
memory: 3.91 GiB unified: no
API: Vulkan v: 1.4.304 layers: N/A device: 0 type: discrete-gpu name: AMD
Radeon RX 6500 XT (RADV NAVI24) driver: N/A device-ID: 1002:743f
surfaces: xcb,xlib
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
bus-ID: 07:00.1 chip-ID: 1002:ab28 class-ID: 0403
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Linux Foundation EEM Gadget driver: snd-usb-audio,uvcvideo
Device-4: JMTek LLC. KLIM Talk driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3.4:7
chip-ID: 0c76:1468 class-ID: 0300
API: ALSA v: k6.1.131-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.1 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active
with: pulseaudio-alsa type: plugin tools: pacat,pactl
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Info: services: mld, NetworkManager, systemd-timesyncd
Local Storage: total: 5.46 TiB used: 546.34 GiB (9.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B4QFXO7 temp: 35.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD40NMZW-11GX6S1 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 5400 serial: <filter> fw-rev: 4005 scheme: GPT
ID-1: / raw-size: 40 GiB size: 39.08 GiB (97.69%) used: 30.91 GiB (79.1%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 5a593a3e-ca59-4a5a-9b8e-dd443e00f2b8
used: 304 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: F982-B612
ID-3: /home raw-size: 250 GiB size: 245.02 GiB (98.01%)
used: 147.15 GiB (60.1%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: f25a6cda-c17b-4382-93da-e1805e2c89be
ID-4: /run/media/michel/Data raw-size: 625.01 GiB
size: 625.01 GiB (100.00%) used: 368.27 GiB (58.9%) fs: ntfs dev: /dev/sda5
maj-min: 8:5 label: Data uuid: 486BCE6128367233
ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: a0054547-10c4-45a3-ad75-e91c54b56565
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: 926B-A865
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 930.67 GiB fs: ntfs label: N/A
uuid: CEA86C6EA86C574D
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 740 MiB fs: ntfs label: N/A
uuid: 7E6A759F6A7554BD
ID-5: /dev/sdb1 maj-min: 8:17 size: 3.64 TiB fs: ntfs label: My Passport
uuid: 66A27E4AA27E1EAD
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 9 rev: 2.0
Device-1: 1-4:2 info: Integrated Express RGB LED Controller type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5702 class-ID: 0300
Device-2: 1-5:3 info: Wacom PTH-860 [Intuos Pro (L)] type: HID
driver: usbhid,wacom interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 056a:0358 class-ID: 0300
serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 3 rev: 3.1
Device-1: 3-2:2 info: Samsung ML-2950 Series type: printer driver: usblp
power: 2mA chip-ID: 04e8:330e class-ID: 0701 serial: <filter>
Hub-4: 3-3:3 info: Terminus Hub ports: 4 rev: 2.0
chip-ID: 1a40:0101 class-ID: 0900
Device-1: 3-3.1:4 info: Linux Foundation EEM Gadget type: video,audio
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA
Device-2: 3-3.2:5 info: Primax Wired USB Keyboard type: keyboard,HID
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
chip-ID: 0461:4e6e class-ID: 0300
Device-3: 3-3.3:6 info: Primax USB Optical Mouse type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1
chip-ID: 0461:4e84 class-ID: 0301
Device-4: 3-3.4:7 info: JMTek LLC. KLIM Talk type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Device-1: 4-1:2 info: Western Digital My Passport (WD40NMZW)
type: mass storage driver: usb-storage interfaces: 1 rev: 3.1
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 896mA
chip-ID: 1058:25e2 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 42.6 C mobo: N/A gpu: amdgpu temp: 39.0 C
mem: 40.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Processes: 407 Power: uptime: 1h 41m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,upowerd
Packages: 1732 pm: pacman pkgs: 1719 libs: 465 tools: pamac pm: flatpak
pkgs: 13 Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9
default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.37
I hope this is better,
Regards
