When I try to play some games after a while my whole system freezes. I have no idea why. On this machine I have dual-boot with Windows and I’ve never experienced problems like that. I tried to switch my Kernel to 5.4, but it doesn’t seem to fix the issue. The games I’ve tried: Verdun, Project Heartbeat, Hearts of Iron 4 (In this case I was able to play for like a minute before the music bugged and looped over 2 seconds, then after another minute whole system froze.), Shogo: Mobile Armor Division also froze, but after I’ve switched the kernel it seems to be working (aside from tons of jitter while looking around with mouse.)
Kernel: 5.4.150-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=52fbd92a-5447-4ec1-909d-8397414b2baa rw quiet apparmor=1
security=apparmor resume=UUID=751bdb66-392e-4c28-9a95-c4b793e60a74
udev.log_priority=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Micro-Star model: MPG Z390 GAMING EDGE AC (MS-7B17)
v: 2.0 serial: <filter> UEFI: American Megatrends v: A.B0 date: 10/12/2020
RAM: total: 15.57 GiB used: 3.73 GiB (24.0%)
Info: 8-Core model: Intel Core i7-9700KF bits: 64 type: MCP arch: Kaby Lake
note: check family: 6 model-id: 9E (158) stepping: C (12) microcode: EA
cache: L2: 12 MiB bogomips: 57616
Speed: 1564 MHz min/max: 800/4900 MHz Core speeds (MHz): 1: 1564 2: 1522
3: 3964 4: 1493 5: 2830 6: 1539 7: 2174 8: 3172
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp
hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
popcnt pse pse36 pts rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT disabled
Device-1: NVIDIA TU104 [GeForce RTX 2070 SUPER] vendor: ASUSTeK
driver: nvidia v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1e84 class-ID: 0300
Screen-1: 0 s-res: 2560x1440 s-dpi: 121 s-size: 536x302mm (21.1x11.9")
s-diag: 615mm (24.2")
Monitor-1: DP-0 res: 2560x1440 hz: 60 dpi: 123 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
OpenGL: renderer: NVIDIA GeForce RTX 2070 SUPER/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA TU104 HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f8 class-ID: 0403
Sound Server-1: ALSA v: k5.4.150-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.38 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
Device-2: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: 3.2.6-k port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
IF: eno2 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:7 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci1 rfk-id: 2 state: up address: see --recommends
Device-2: Edimax Edimax Bluetooth Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-9:5 chip-ID: 7392:c611 class-ID: e001 serial: <filter>
Report: ID: hci0 rfk-id: 1 state: up address: N/A
Local Storage: total: 3.92 TiB used: 2.05 TiB (52.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB1T0HBLR-00000
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: EXF7201Q scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: A-Data model: SX6000PNP
lanes: 4 type: SSD serial: <filter> rev: V9002s09 scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 PRO 256GB
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1B6Q scheme: MBR
Optical-1: /dev/sr0 vendor: ASUS model: DRW-24D5MT rev: 2.00
dev-links: cdrom
Features: speed: 12 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 936.45 GiB size: 920.67 GiB (98.32%)
used: 151.94 GiB (16.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 52fbd92a-5447-4ec1-909d-8397414b2baa
used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 1316-872E
ID-3: /mnt/6E2C84372C83F87B raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 793.01 GiB (42.6%) fs: ntfs dev: /dev/sda2 maj-min: 8:2 label: Beijing
uuid: 6E2C84372C83F87B
ID-4: /run/media/paturikoo/Jaxa raw-size: 238.38 GiB
size: 238.37 GiB (100.00%) used: 233.74 GiB (98.1%) fs: ntfs dev: /dev/sdb2
maj-min: 8:18 label: Jaxa uuid: EADA0482DA044D6F
ID-5: /run/media/paturikoo/Windows raw-size: 953.24 GiB
size: 953.24 GiB (100.00%) used: 919.12 GiB (96.4%) fs: ntfs
dev: /dev/nvme1n1p4 maj-min: 259:8 label: Windows uuid: E81055FB1055D0E4
ID-1: swap-1 type: partition size: 17.12 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 751bdb66-392e-4c28-9a95-c4b793e60a74
ID-1: /dev/nvme1n1p1 maj-min: 259:5 size: 529 MiB fs: ntfs
label: Odzyskiwanie uuid: AE283E40283E07BB
ID-2: /dev/nvme1n1p2 maj-min: 259:6 size: 100 MiB fs: vfat label: N/A
uuid: 743E-8106
ID-3: /dev/nvme1n1p3 maj-min: 259:7 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
ID-5: /dev/sdb1 maj-min: 8:17 size: 100 MiB fs: ntfs label: Berlin
uuid: AED089A9D089787B
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-3:2 info: Logitech G513 RGB MECHANICAL GAMING KEYBOARD
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 046d:c33c class-ID: 0300
serial: <filter>
Device-2: 1-4:3 info: Holtek USB Laser Game Mouse type: Mouse,Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 04d9:fa56 class-ID: 0300
Device-3: 1-7:4 info: Micro Star MYSTIC LIGHT type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 1462:1720 class-ID: 0300 serial: <filter>
Device-4: 1-9:5 info: Edimax Edimax Bluetooth Adapter type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Hub-2: 1-13:6 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-13.1:8 info: Realtek Mass Storage Device (Multicard Reader)
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 0bda:0151 class-ID: 0806
serial: <filter>
Hub-3: 1-13.2:9 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-14:7 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-4: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 50.0 C mobo: N/A gpu: nvidia temp: 33 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 26%
Processes: 273 Uptime: 22m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1449 pacman: 1442 lib: 395
flatpak: 7 Shell: Zsh v: 5.8 default: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.08
Any idea what might be the issue? I’m fairly new to Linux, though I have been using Pop!_os on laptop for about a year, though I’m not using it for games.
