My distro keeps freezing up, randomly, with different time intervals between several hours to several days. Doesn’t react to keyboard, or mouse. REISUB does not work (albeit I enabled and tested it). I disconnected and reconnected keyboard - keyboard did light up its RGB. I disconnected and reconnected monitor, and it said “No Signal”. Reviewing journalctl output, I get nothing - no crashes, nothing besides some bluetooth bs.
I have exhausted ideas I’ve been able to find. Did anyone encounter something exactly like this?
Here is my inxi --admin --verbosity=7 --filter --no-host --width output:
Kernel: 6.18.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
root=UUID=c8acbe4d-40dc-46d7-a39b-ccefa7cacd5b rw rootflags=subvol=@ quiet
splash udev.log_priority=3 pcie_aspm=off
Desktop: KDE Plasma v: 6.5.5 tk: Qt v: N/A info: frameworks v: 6.23.0
Type: Desktop System: Gigabyte product: B850 GAMING X WIFI6E v: -CF-WCP
serial: <superuser required>
Mobo: Gigabyte model: B850 GAMING X WIFI6E v: x.x
serial: <superuser required> uuid: <superuser required> Firmware: UEFI
vendor: American Megatrends LLC. v: F1 date: 09/24/2024
System RAM: total: 64 GiB available: 60.44 GiB used: 6.11 GiB (10.1%)
Device-1: Channel-A DIMM 0 type: no module installed
Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
(unregistered) size: 32 GiB speed: 6400 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMK64GX5M2B6400C32 serial: N/A
Device-3: Channel-B DIMM 0 type: no module installed
Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
Info: model: AMD Ryzen 7 9700X bits: 64 type: MT MCP arch: Zen 5 gen: 5
level: v4 note: check built: 2024+ process: TSMC n4 (4nm) family: 0x1A (26)
model-id: 0x44 (68) stepping: 0 microcode: 0xB40401C
smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 8 MiB
desc: 8x1024 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2993 min/max: 605/5582 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2993 2: 2993 3: 2993
4: 2993 5: 2993 6: 2993 7: 2993 8: 2993 9: 2993 10: 2993 11: 2993 12: 2993
13: 2993 14: 2993 15: 2993 16: 2993 bogomips: 121383
apic arat avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni
avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
avx512ifma avx512vbmi avx512vl avx_vnni bmi1 bmi2 bpext bus_lock_detect
cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov cmp_legacy constant_tsc
cpb cppc cpuid cpuid_fault cqm cqm_llc cqm_mbm_local cqm_mbm_total
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt
gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf lahf_lm lbrv
lm mba mca mce misalignsse mmx mmxext monitor movbe movdir64b movdiri msr
mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov
pae pat pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
rdrand rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse
sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_adjust tsc_scale umip user_shstk v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vnmi vpclmulqdq wbnoinvd
wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
Type: spec_rstack_overflow mitigation: IBPB on VMEXIT only
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not affected
Type: vmscape mitigation: IBPB on VMEXIT
Device-1: NVIDIA GB205 [GeForce RTX 5070] vendor: Gigabyte driver: nvidia
v: 590.48.01 alternate: nouveau,nova_core,nvidia_drm non-free: 550-580.xx+
status: current (as of 2025-11) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 5 speed: 32 GT/s lanes: 16
ports: active: none off: HDMI-A-2 empty: DP-4,DP-5,DP-6 bus-ID: 01:00.0
chip-ID: 10de:2f04 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Granite Ridge [Radeon Graphics]
vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none empty: DP-1, DP-2, DP-3, HDMI-A-1, Writeback-1
bus-ID: 11:00.0 chip-ID: 1002:13c0 class-ID: 0300 temp: 34.0 C
Display: x11 server: X.Org v: 21.1.21 with: Xwayland v: 24.1.9
compositor: kwin_x11 driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: radeonsi
gpu: nv_platform,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.70x13.46")
s-diag: 692mm (27.26")
Monitor-1: HDMI-A-2 mapped: HDMI-0 note: disabled
model: LG (GoldStar) ULTRAGEAR serial: <filter> built: 2024 res:
mode: 2560x1440 hz: 144 scale: 100% (1) dpi: 109 gamma: 1.2
size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9 modes:
max: 2560x1440 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 2 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 590.48.01
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 5070/PCIe/SSE2
memory: 11.66 GiB
API: Vulkan v: 1.4.341 layers: 4 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 5070 driver: nvidia v: 590.48.01
device-ID: 10de:2f04 surfaces: N/A device: 1 type: integrated-gpu name: AMD
Ryzen 7 9700X 8-Core Processor (RADV RAPHAEL_MENDOCINO) driver: mesa radv
v: 25.3.5-arch1.1 device-ID: 1002:13c0 surfaces: N/A
Device-1: NVIDIA GB205 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 5 speed: 32 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:2f80
class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
bus-ID: 11:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: Gigabyte
bus-ID: 11:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.18.12-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8852CE PCIe 802.11ax Wireless Network
driver: rtw89_8852ce v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000
bus-ID: 07:00.0 chip-ID: 10ec:c852 class-ID: 0280
IF: wlp7s0 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: c000 bus-ID: 08:00.0
IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:4 chip-ID: 0bda:0852
Local Storage: total: 4.55 TiB used: 94.62 GiB (2.0%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung model: SSD 990 EVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 126 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 0B2QKXJ7 temp: 46.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:7 vendor: Samsung
model: SSD 990 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 2B2QKXG7 temp: 44.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 43.9 C
scheme: GPT
ID-1: / raw-size: 860.45 GiB size: 860.45 GiB (100.00%)
used: 94.62 GiB (11.0%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:9
label: N/A uuid: c8acbe4d-40dc-46d7-a39b-ccefa7cacd5b
used: 668 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:8 label: N/A
uuid: 3D1A-E16F
ID-3: /home raw-size: 860.45 GiB size: 860.45 GiB (100.00%)
ID-4: /var/cache raw-size: 860.45 GiB size: 860.45 GiB (100.00%)
ID-5: /var/log raw-size: 860.45 GiB size: 860.45 GiB (100.00%)
ID-1: swap-1 type: partition size: 70.77 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:10 label: N/A
uuid: 84f258dd-bfd5-443f-8d2f-4898813c3f5a
ID-1: /dev/nvme0n1p1 maj-min: 259:3 size: 200 MiB fs: vfat label: N/A
uuid: 0016-866E
ID-2: /dev/nvme0n1p2 maj-min: 259:4 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:5 size: 1.82 TiB fs: ntfs label: N/A
uuid: 06B416D2B416C459
ID-4: /dev/nvme0n1p4 maj-min: 259:6 size: 735 MiB fs: ntfs label: N/A
uuid: 0058704B58704188
ID-5: /dev/nvme2n1p1 maj-min: 259:1 size: 1.82 TiB fs: ntfs label: N/A
uuid: C8D8D72ED8D71A10
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-5:2 info: Razer USA Basilisk V3 Pro 35K type: mouse,keyboard
driver: razermouse,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:00cc class-ID: 0301
serial: <filter>
Device-2: 1-6:3 info: Integrated Express GIGABYTE Device type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5711 class-ID: 0300
Device-3: 1-9:4 info: Realtek Bluetooth Radio type: bluetooth driver: btusb
interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 0bda:0852 class-ID: e001 serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 5-1:2 info: Razer USA Basilisk V3 Pro 35K type: mouse,keyboard
driver: razermouse,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 1532:00cd class-ID: 0300
serial: <filter>
Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-8: 7-1:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 7-1.2:3 info: Razer USA BlackWidow V4 75%
type: keyboard,mouse,HID driver: razerkbd,usbhid interfaces: 5 rev: 2.0
chip-ID: 1532:02a5 class-ID: 0300
System Temperatures: cpu: 41.0 C mobo: 32.0 C
Fan Speeds (rpm): N/A
GPU: device: nvidia screen: :0.0 temp: 44 C fan: 0% device: amdgpu
temp: 35.0 C
Processes: 491 Power: uptime: 2m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.11 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 259 default: graphical
tool: systemctl
Packages: pm: pacman pkgs: 1439 libs: 371 tools: pamac,yay pm: flatpak
pkgs: 0 Compilers: gcc: 15.2.1 Shell: Bash v: 5.3.9 default: Zsh v: 5.9
running-in: konsole inxi: 3.3.40
