I’ve just installed Manjaro kde in a dual boot. There are moments when the system freezes and I can’t do anything, especially this happens when I am turning off the pc. I think that this happens because of the graphic card’s drivers. I have a Nvidia gtx 950m, what drivers should I install?
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
Most likely the know power management bug for NVIDIA drivers. Try to find if you have messages in journalctl like GPU falling out of bus.
In this case solution is adding pcie_aspm=off intel_idle.max_cstate=1 in boot & run sudo nvidia-smi -pm 1. In most cases only the second command is enought to solve and both special for some cases in laptops.
i have same problem with freezing on a old lenovo laptop with Linux version 5.10.26-1-MANJARO with gnome graphics when transfer files from one partition on another and when connect wifi and vpn or bluetooth but i just press ctrl+esc and its start work so i dont need to to restart forcibly.
