Hi,
I have repurposed a mac mini (mid 2011) that has 16gb of memory installed. Originally, Apple stated that this machine would only work with 8gb max memory, however, it was discovered that it would work fine with 2x8gb memory modules. Under OSX, the system reports 16gb of memory.
Booted into Majaro 20.2 running under kernel 5.9.3-1, both DIMMs are being reported as 4gb. I have tried pulling each in turn and they each show as 4gb. These are both Cosair CMSA8GX3M2A1333C9 8gb 1.333mhz CL9 DDR3 So-DImms (Double checked)
As noted, I have removed and replaced the DIMMs and this is not an issue that one DIMM is not working and therefore only showing 8Gb because one DIMM is faulty. Both slots show 4Gb.
I would appreciate if someone could advise anything that I can do to get both DIMMs reported correctly with a total of 16Gb of memory.
For assistance, some data dumps:
$ sudo lshw -short
H/W path Device Class Description
system Macmini5,1 (System SKU#)
/0 bus Mac-8ED6AF5B48C039E1
/0/0 processor Intel(R) Core(TM) i5-2415M CPU @ 2.30GHz
/0/0/2 memory 32KiB L1 cache
/0/0/3 memory 256KiB L2 cache
/0/0/4 memory 3KiB L3 cache
/0/1 memory 32KiB L1 cache
/0/5 processor CPU
/0/5/7 memory 32KiB L1 cache
/0/5/8 memory 256KiB L2 cache
/0/5/9 memory 3KiB L3 cache
/0/6 memory 32KiB L1 cache
/0/a processor CPU
/0/a/c memory 32KiB L1 cache
/0/a/d memory 256KiB L2 cache
/0/a/e memory 3KiB L3 cache
/0/b memory 32KiB L1 cache
/0/f processor CPU
/0/f/11 memory 32KiB L1 cache
/0/f/12 memory 256KiB L2 cache
/0/f/13 memory 3KiB L3 cache
/0/10 memory 32KiB L1 cache
/0/14 memory 8GiB System Memory
/0/14/0 memory 4GiB SODIMM DDR3 Synchronous 1333 MHz (0.8 ns)
/0/14/1 memory 4GiB SODIMM DDR3 Synchronous 1333 MHz (0.8 ns)
/0/1a memory 1MiB BIOS
/0/100 bridge 2nd Generation Core Processor Family DRAM Controller
/0/100/1 bridge Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port
/0/100/1.1 bridge Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port
/0/100/1.1/0 bridge CV82524 Thunderbolt Controller [Light Ridge 4C 2010]
/0/100/1.1/0/0 bridge CV82524 Thunderbolt Controller [Light Ridge 4C 2010]
/0/100/1.1/0/0/0 generic CV82524 Thunderbolt Controller [Light Ridge 4C 2010]
/0/100/1.1/0/3 bridge CV82524 Thunderbolt Controller [Light Ridge 4C 2010]
/0/100/1.1/0/4 bridge CV82524 Thunderbolt Controller [Light Ridge 4C 2010]
/0/100/1.1/0/5 bridge CV82524 Thunderbolt Controller [Light Ridge 4C 2010]
/0/100/1.1/0/6 bridge CV82524 Thunderbolt Controller [Light Ridge 4C 2010]
/0/100/2 display 2nd Generation Core Processor Family Integrated Graphics Controller
/0/100/16 communication 6 Series/C200 Series Chipset Family MEI Controller #1
/0/100/1a bus 6 Series/C200 Series Chipset Family USB Universal Host Controller #5
/0/100/1a/1 usb3 bus UHCI Host Controller
/0/100/1a.7 bus 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2
/0/100/1a.7/1 usb1 bus EHCI Host Controller
/0/100/1a.7/1/1 bus 2.0 Hub
/0/100/1a.7/1/1/1 bus BRCM20702 Hub
/0/100/1a.7/1/1/1/3 communication Bluetooth USB Host Controller
/0/100/1b multimedia 6 Series/C200 Series Chipset Family High Definition Audio Controller
/0/100/1c bridge 6 Series/C200 Series Chipset Family PCI Express Root Port 1
/0/100/1c/0 enp2s0f0 network NetXtreme BCM57765 Gigabit Ethernet PCIe
/0/100/1c/0.1 mmc0 bus BCM57765/57785 SDXC/MMC Card Reader
/0/100/1c.1 bridge 6 Series/C200 Series Chipset Family PCI Express Root Port 2
/0/100/1c.1/0 wlp3s0b1 network BCM4331 802.11a/b/g/n
/0/100/1c.2 bridge 6 Series/C200 Series Chipset Family PCI Express Root Port 3
/0/100/1c.2/0 bridge XIO2213A/B/XIO2221 PCI Express to PCI Bridge [Cheetah Express]
/0/100/1c.2/0/0 bus XIO2213A/B/XIO2221 IEEE-1394b OHCI Controller [Cheetah Express]
/0/100/1d bus 6 Series/C200 Series Chipset Family USB Universal Host Controller #1
/0/100/1d/1 usb4 bus UHCI Host Controller
/0/100/1d.7 bus 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1
/0/100/1d.7/1 usb2 bus EHCI Host Controller
/0/100/1d.7/1/1 bus 2.0 Hub
/0/100/1d.7/1/1/1 input IR Receiver
/0/100/1d.7/1/1/2 input ELECOM TrackBall Mouse
/0/100/1f bridge HM65 Express Chipset LPC Controller
/0/100/1f.2 scsi0 storage 6 Series/C200 Series Chipset Family 6 port Mobile SATA AHCI Controller
/0/100/1f.2/0.0.0 /dev/sda disk 512GB ADATA SU800
/0/100/1f.2/0.0.0/1 volume 299MiB Windows FAT volume
/0/100/1f.2/0.0.0/2 /dev/sda2 volume 456GiB EXT4 volume
/0/100/1f.2/0.0.0/3 /dev/sda3 volume 9011MiB Linux swap volume
/0/100/1f.3 bus 6 Series/C200 Series Chipset Family SMBus Controller
/0/2 system PnP device PNP0103
/0/3 system Motherboard registers
/0/4 system AT Real-Time Clock
/0/7 generic PnP device APP000b
/0/8 system Motherboard registers
/0/9 system System Board
$ fwupdmgr get-devices --show-all-devices
WARNING: UEFI capsule updates not available or enabled
Macmini5,1
├─ Intel(R) Core™ i5-2415M CPU @ 2.30GHz:
│ Device ID: 4bde70ba4e39b28f9eab1628f9dd6e6244c03027
│ Current version: 0x0000002f
│ Vendor: Intel
│ GUIDs: b9a2dd81-159e-5537-a7db-e7101d164d3f
│ 30249f37-d140-5d3e-9319-186b1bd5cac3
│ 87b4a46c-74e8-5075-a2f0-8bb470d5cf18
│ 80fcd4ac-c2a2-55db-b4c9-973373b86677
│ Device Flags: • Internal device
├─2nd Generation Core Processor Family Integrated Graphics Controller:
│ Device ID: bbbf1ce3d1cf15550c3760b354592040292415bb
│ Current version: 09
│ Vendor: Intel Corporation (PCI:0x8086)
│ GUIDs: 7aae83fc-3b21-5f08-afa9-b4ba4f4ce313
│ 5c8121ca-ea47-57c9-9a85-dae063eaf715
│ ee71a144-d91f-5031-b68a-81be9275cff3
│ 59afc6d4-da1f-5528-8110-92cc3ba76fd3
│ • Cryptographic hash verification is available
├─ADATA SU800:
│ Device ID: 602b0a6cc821d155208724f0e22f8d111542b74c
│ Summary: ATA Drive
│ Current version: R0918B
│ Vendor: ADATA (ATA:0x1CC1)
│ GUIDs: aeddb02d-9251-5248-82a7-821b51d0d546
│ e63d3f4a-d45e-508b-8ebf-1d9d4e38eaa0
│ be73cb0c-8042-5b7a-9bbf-e55696a31073
│ • Updatable
│ • System requires external power source
│ • Needs a reboot after installation
│ • Device is usable for the duration of the update
└─Bluetooth USB Host Controller:
Device ID: dbac5febda21c37fd28598d9009cfcb44d50f60b
Current version: 1.56
Vendor: Apple Inc. (USB:0x05AC)
GUIDs: 09eeff63-19a9-57d1-b474-866607390312
4fcc74fb-79b8-51a5-9f47-f8ad10b9821e
Device Flags: • Updatable
$ sudo dmidecode -t memory
# dmidecode 3.3
Getting SMBIOS data from sysfs.
SMBIOS 2.4 present.
Handle 0x0014, DMI type 16, 15 bytes
Physical Memory Array
Use: System Memory
Error Correction Type: None
Maximum Capacity: 8 GB
Error Information Handle: Not Provided
Number Of Devices: 2
Handle 0x0016, DMI type 17, 27 bytes
Memory Device
Array Handle: 0x0014
Error Information Handle: No Error
Total Width: Unknown
Data Width: Unknown
Form Factor: SODIMM
Set: None
Locator: DIMM0
Bank Locator: BANK 0
Type: DDR3
Type Detail: Synchronous
Speed: 1333 MT/s
Manufacturer: 0x029E
Serial Number: 0x00000000
Asset Tag: Unknown
Part Number: 0x434D5341344758334D314131333333433920
Handle 0x0018, DMI type 17, 27 bytes
Memory Device
Data Width: Unknown
Form Factor: SODIMM
Set: None
Locator: DIMM0
Bank Locator: BANK 1
Type: DDR3
Speed: 1333 MT/s
Asset Tag: Unknown
$ inxi -Fazy
Kernel: 5.9.3-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=cadaf9b7-a85a-4041-8dbe-aeba94d2645c rw quiet apparmor=1
security=apparmor resume=UUID=94ad878d-f757-45af-a13e-24e666381689
udev.log_priority=3
Console: tty 0 DM: SDDM Distro: Manjaro Linux
Type: Laptop System: Apple product: Macmini5,1 v: 1.0 serial: <filter>
Chassis: type: 16 v: Mac-8ED6AF5B48C039E1 serial: <filter>
Mobo: Apple model: Mac-8ED6AF5B48C039E1 v: Macmini5,1 serial: <filter>
UEFI: Apple v: 135.0.0.0.0 date: 06/13/2019
Info: Dual Core model: Intel Core i5-2415M bits: 64 type: MT MCP
arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7 microcode: 2F
L2 cache: 3072 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 18366
Speed: 1340 MHz min/max: 800/2900 MHz Core speeds (MHz): 1: 1705 2: 991
3: 2693 4: 2693
Type: l1tf
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Apple driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0126
Display: server: X{dot}org 1.20.9 driver: intel unloaded: modesetting
alternate: fbdev,vesa tty: 132x87
Message: Advanced graphics data unavailable in console. Try -G --display
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1c20
Sound Server: ALSA v: k5.9.3-1-MANJARO
Device-1: Broadcom and subsidiaries NetXtreme BCM57765 Gigabit Ethernet PCIe
driver: tg3 v: kernel port: efa0 bus ID: 02:00.0 chip ID: 14e4:16b4
IF: enp2s0f0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Broadcom and subsidiaries BCM4331 802.11a/b/g/n
vendor: Apple AirPort Extreme driver: bcma-pci-bridge v: N/A modules: bcma
port: efa0 bus ID: 03:00.0 chip ID: 14e4:4331
IF-ID-1: docker0 state: down mac: <filter>
IF-ID-2: docker_gwbridge state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-3: veth86cc72c state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-4: veth95d2f1b state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-5: wlp3s0b1 state: down mac: <filter>
Local Storage: total: 476.94 GiB used: 86.71 GiB (18.2%)
ID-1: /dev/sda vendor: A-Data model: SU800 size: 476.94 GiB block size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 8B
scheme: GPT
ID-1: / raw size: 456.66 GiB size: 448.50 GiB (98.21%)
used: 86.71 GiB (19.3%) fs: ext4 dev: /dev/sda2
ID-1: swap-1 type: partition size: 8.80 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3
System Temperatures: cpu: 50.0 C mobo: N/A
Processes: 203 Uptime: 20m Memory: 7.69 GiB used: 766.5 MiB (9.7%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1421 apt: 0
pacman: 1410 lib: 369 flatpak: 0 snap: 11 Shell: Zsh v: 5.8
running in: tty 0 inxi: 3.1.08
$ cat /etc/os-release
NAME="Manjaro Linux"
ID=manjaro
ID_LIKE=arch
BUILD_ID=rolling
PRETTY_NAME="Manjaro Linux"
ANSI_COLOR="32;1;24;144;200"
LOGO=manjarolinux
$ lsb_release -a
LSB Version: n/a
Distributor ID: ManjaroLinux
Description: Manjaro Linux
Release: 20.2
Codename: Nibia
