I have been using Manjaro xfce on my laptop for a few months now everything has been fine, but recently I have noticed that the laptop becomes very hot in a very short time and sometimes when using browser while installing a program the system freezes. I tried to monitor the cpu usage in task manager but nothing seemed un unusual. Is that a problemin the OS or the hardware itself?
I am not sure if I even have any fans! I never heard a sound from it since I bought this laptop. there isnāt even a fan related settings in the bios or anywhere else!
The freezeing could be caused by the combination of having only 4 GiB memory and no swap partition or swap file. Even if you do not intend to hibernate you should use a small swap file or partition, I would say of at least 2 GiB. Itās easy to implement it, just look into the wiki.
I check system temperatures by the simple command
sensors
I would check if this provides usable output in your case as well. If you really have no air blower (fan) than I would check temperatures from time to time.
I am having the same issue here.
My laptop is an intel i5 which used to run perfectly well some games [i used to use elementary os].
After i installed manjaro, it gets 1) very hot (temperature reaching 100c when running a heavy browser game), 2) very slow, and 3)CPU at high capacity.
I have read so much about all kinds of possible solutions dealing with cooling fans on my laptop (supposedly thats the issue? [specially because heat+i cant hear the cooling fan work]), but absolutely nothing works.
I have tried changing kernels (installing it, on boot screen changing the one Im going to use, etc.), didnt work.
I have tried TLP, POWERTOP, LMSENSORS, PWMCPONFIG, everything.
At PWMCONFIG, i reach a point where it says: ā/usr/sbin/pwmconfig: There are no pwm-capable sensor modules installedā. I have tried a possible solution (" fancontrol-under-ubuntu-14-04-resolving-usrsbinpwmconfig-there-are-no-pwm-capable-sensor-modules-installed "), didnt work to.
MY elementary os (in the another partition) got slow as well after this issue arrived.
I have tried to fix it in elementary os, but got nothing new too.
Is it due to manjaro not āāgeting my cooler to workāā?
COuld it be a coincidental hardware issue? (for instance, laptop fan suddenly not working�) PS: I cant see if it works, I dont know how to open a laptop and I think this is not a likely scenario.
Thank you, I made a 500MB swap partition hopefully this will solve the freezing problem.
When I checked the temperature as you said it was 53°C but I donāt know what caues it to be that high, it didnāt heat up like that when I was using windows 10. The main reason I choosed xfce is that itās light weight and wonāt consume much of the resources and it did at first. Something surely went wrong but I am not sure what is it.
OP has a hdd!! If more than 2 GiB swap are in use it will feel like the system is totally frozen⦠IMHO this wonāt be very helpful. But I agree, 500 MiB is probably not enough.
