Manjaro freezes after approx. 30 minutes
Hi all,
since a few days (or maybe weeks) i have the problem, that my manjaro freezes after some time, some times minutes, sometimes approx. an hour.
I have updated my system yesterday completely with
sudo pacman -Syyu
But although everything is up to date it freezes.
Is there anything i can do to find out, what causes the freezing?
Is use this release
cat /etc/lsb-release
DISTRIB_ID=ManjaroLinux
DISTRIB_RELEASE=21.3.2
DISTRIB_CODENAME=Ruah
DISTRIB_DESCRIPTION=“Manjaro Linux”
Do you need more information?
Is it worth a try to change the kernel? At the moment i use Kernel 5.15.49_rt47-1 cause i do i lot of Audio (which requires i think a real time kernel).
Should i change over to 5.15.50-1 or better 5-18.0_rt11-1 (so that again i use a real time kernel)?
Best wishes
Daniel
Try the normal kernel and not the rt version. What makes you think you need the rt? Maybe it works anyway.
OK, i try the normal Kernel (5.15.50-1 ? Or higher?).
Audio fanatics say the audio applications work best with RT-Kernel.
I never questioned this, but now I will :wink:
