Hello. I installed manjaro kde today. I then made: sudo pacman -Syy, then, I installed binutils. Then I installed base devel. Then nearly everything stopped working, includin pacman, saying that glibc is missing. Please, what can I do?
Never do this without a u
at the end, you’d be highly risking a partial update, which is why you might be having issues.
To explain: Using y
refreshes your database from your mirrors. Your mirrors might have new package versions. Because you’re installing a package using -Syy
, it’s probably a new package version, but because you didn’t use -Syyu
, you have older versions of all of your packages and libraries that are incompatible.
pacman -S
is fine if you have already updated your system recently. To be safe, always use pacman -Syu
or pacman -Syyu
to install a package and update.
Try to refresh your mirrors and reupdate to see if that fixes anything
sudo pacman-mirrors -f 5 #updates mirrorlist and ranks by speed up to 5 mirrors
sudo pacman -Syyu #syncs, refreshes mirrors, updates
EDIT:
Missed this. Try doing this:
pamac upgrade
pamac
uses a different library than pacman
iirc, so it might work. It should be preinstalled on your system.
Worse comes to worst, I think the best option is to just reinstall Manjaro and remember to always use pacman -Syu
or pacman -Syyu
in the future.
