sudo manjaro-downgrade xz --ala-url 'https://archive.archlinux.org','https://manjaro.tuxboy.eu'
or
sudo manjaro-downgrade xz --ala-url 'https://manjaro.tuxboy.eu'
or
Time after the command and before the list with the choice of versions appears ~ 90 seconds.
But without using manjaro.tuxboy.eu time after the command and before the list with the choice of versions appears ~ 4 seconds.
Problem with different packages. Package âxzâ is shown as an example.
Why is search on manjaro.tuxboy.eu so slow?
$ ping archive.archlinux.org -c 4
PING archive.archlinux.org (49.12.124.107) 56(84) bytes of data.
64 bytes from archive.archlinux.org (49.12.124.107): icmp_seq=1 ttl=56 time=66.6 ms
64 bytes from archive.archlinux.org (49.12.124.107): icmp_seq=2 ttl=56 time=67.7 ms
64 bytes from archive.archlinux.org (49.12.124.107): icmp_seq=3 ttl=56 time=66.7 ms
64 bytes from archive.archlinux.org (49.12.124.107): icmp_seq=4 ttl=56 time=66.8 ms
$ ping manjaro.tuxboy.eu -c 4
PING manjaro.tuxboy.eu (67.217.62.48) 56(84) bytes of data.
64 bytes from 67.217.62.48: icmp_seq=1 ttl=45 time=147 ms
64 bytes from 67.217.62.48: icmp_seq=2 ttl=45 time=147 ms
64 bytes from 67.217.62.48: icmp_seq=3 ttl=45 time=147 ms
64 bytes from 67.217.62.48: icmp_seq=4 ttl=45 time=147 ms
I didnât know the package existed - I have always thought downgrading is unsupported hence
First of all - downgrading is unsupported - and should be avoided.
Second - you cannot compare the two archives.
The archlinux archive is using an organized structure, possibly designed for the use of the downgrade script.
The manjaro archive is simply an archive of packages, there is no database files, only packages and the only structure is the branch structure.
I know the archive exist - I have downloaded some old openbox packages no longer in the repo - and the repo only contains packages explicit provided by Manjaro - if there is an overlap with the Arch archive it is because the package has been built/rebuilt to accommodate for something specific to Manjaro.
I donât know if it is all intended to be used by the downgrade script.
As far as I understand, the latest version of manjaro-downgrade 2.3 uses this âby defaultâ.
Because of this, I noticed the problem of slow search when using the default syntax:
Also the address âmanjaro.tuxboy.euâ was included in the downgrade.conf.pacnew file along with âarchive.archlinux.orgâ.
This address was probably not used by the âmanjaro-downgradeâ script before (unttil 2026).
The downgrade search is taking longer for the manjaro archive.
$ time sudo downgrade systemd --ala-url 'https://archive.archlinux.org'
Invalid choice
Unable to downgrade systemd
real 0m3,979s
user 0m0,007s
sys 0m0,009s
$ time sudo downgrade systemd --ala-url 'https://manjaro.tuxboy.eu'
Invalid choice
real 0m39,755s
user 0m0,014s
sys 0m0,015s
I do think this is due to the different archive structures of the two archives.
It simply takes longer to parse the output from the manjaro archive page.
That does not exit the running program. It simply suspends the process while keeping it in memory and waiting for a resume command.
In order to interrupt a running process whereby the process is terminated, you need CtrlC, and if itâs a communication protocol that you want to sign out of â which includes a terminal with a command prompt awaiting shell commands â then itâs CtrlD (end-of-transmission).
Oh, of course thatâs right. Thanks for correcting.
time sudo LC_ALL=C manjaro-downgrade systemd --ala-url 'https://archive.archlinux.org'
Invalid choice
real 0m3.771s
user 0m0.026s
sys 0m0.025s
