Manjaro doesnt shut down correctly
When I shutdown, some apps still remain open (I think the one im focued on?) and the rest is just a black screen. If I close the open apps, there is just a black screen and my mouse, but manjaro doesnt seem to shut down.
Random logs that might maybe be helpful?
$ journalctl -b -1
(Removed beginning due to char limit, but I shut down my pc at 21:16:00 and left it running until 21:20:00 at which point I forced a shutdown)
Oct 28 21:16:01 chris systemd[855]: Created slice Slice /app/dbus-:1.2-org.kde.LogoutPrompt.
Oct 28 21:16:01 chris systemd[855]: Started dbus-:1.2-org.kde.LogoutPrompt@0.service.
Oct 28 21:16:03 chris systemd[855]: Created slice Slice /app/dbus-:1.2-org.kde.Shutdown.
Oct 28 21:16:03 chris systemd[855]: Started dbus-:1.2-org.kde.Shutdown@0.service.
Oct 28 21:16:03 chris kded6[948]: Service  ":1.44" unregistered
Oct 28 21:16:03 chris msm_kde_notifier[1137]: Shutting down MSM Notifier...
Oct 28 21:16:03 chris kded6[948]: Service  ":1.46" unregistered
Oct 28 21:16:03 chris plasmashell[963]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:136: TypeError: Cannot read property 'screenGeometry' of null
Oct 28 21:16:03 chris systemd[855]: dbus-:1.2-org.kde.LogoutPrompt@0.service: Main process exited, code=exited, status=1/FAILURE
Oct 28 21:16:03 chris systemd[855]: dbus-:1.2-org.kde.LogoutPrompt@0.service: Failed with result 'exit-code'.
Oct 28 21:16:03 chris systemd[855]: app-pamac\x2dtray\x2dplasma@autostart.service: Consumed 611ms CPU time, 69.2M memory peak.
Oct 28 21:16:03 chris plasmashell[963]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml:250: TypeError: Cannot read property 'plasmoid' of undefined
Oct 28 21:16:03 chris plasmashell[963]: org.kde.pulseaudio: No object for name "alsa_output.usb-Macronix_Razer_Barracuda_Pro_2.4_1234-00.analog-stereo"
Oct 28 21:16:03 chris plasmashell[963]: org.kde.pulseaudio: No object for name "alsa_input.usb-Macronix_Razer_Barracuda_Pro_2.4_1234-00.mono-fallback"
Oct 28 21:16:03 chris plasmashell[963]: QObject::startTimer: Timers can only be used with threads started with QThread
Oct 28 21:16:03 chris systemd[855]: plasma-plasmashell.service: Consumed 6.954s CPU time, 283.3M memory peak.
Oct 28 21:16:03 chris ksmserver[946]: org.kde.kf6.ksmserver: Connection rejected: ksmserver is shutting down
Oct 28 21:16:07 chris systemd[855]: app-org.xfce.mousepad@1be55a2dda9d4f7e8bdb6c3435a89046.service: Consumed 3.992s CPU time, 25.2M memory peak.
$ inxi -Fza
  Kernel: 6.10.13-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
    root=UUID=17112bd4-5fab-4b45-be7d-a3d5e93e61ea rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
  Type: Desktop Mobo: ASUSTeK model: ROG STRIX B360-F GAMING v: Rev 1.xx
    serial: <superuser required> part-nu: ASUS_MB_CNL uuid: <superuser required>
    UEFI: American Megatrends v: 2301 date: 07/10/2020
  Info: model: Intel Core i3-8350K bits: 64 type: MCP arch: Coffee Lake
    gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xB (11) microcode: 0xF6
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 smt: <unsupported> cache:
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 4000 min/max: 800/4000 scaling: driver: intel_pstate
    governor: powersave cores: 1: 4000 2: 4000 3: 4000 4: 4000 bogomips: 32013
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
  Type: itlb_multihit status: KVM: VMX unsupported
  Type: spectre_v2 mitigation: IBRS; IBPB: conditional; STIBP: disabled;
  Device-1: NVIDIA AD104 [GeForce RTX 4070 SUPER] driver: nouveau v: kernel
    non-free: 550.xx+ status: current (as of 2024-09) arch: Lovelace code: AD1xx
    process: TSMC n4 (5nm) built: 2022+ pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1
    empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 10de:2783 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: nouveau gpu: nouveau display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
    s-diag: 987mm (38.84") monitors: <missing: xrandr>
  Monitor-1: HDMI-A-1 model: Samsung S34J55x serial: <filter> built: 2020
    res: 3440x1440 dpi: 110 gamma: 1.2 size: 797x333mm (31.38x13.11")
    diag: 864mm (34") modes: max: 3440x1440 min: 720x400
  API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
    device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau x11:
    drv: nouveau inactive: wayland
  API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 24.2.4-arch1.0.1
    glx-v: 1.4 direct-render: yes renderer: NV194 device-ID: 10de:2783
    memory: 11.67 GiB unified: no
  API: Vulkan v: 1.3.295 layers: N/A device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 4070 SUPER (NVK AD104) driver: mesa nvk
    v: 24.2.4-arch1.0.1 device-ID: 10de:2783 surfaces: xcb,xlib
  Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
    v: kernel alternate: snd_soc_skl, snd_soc_avs, snd_sof_pci_intel_cnl
    bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
  Device-2: NVIDIA AD104 High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:22bc class-ID: 0403
  Device-3: Razer USA Barracuda Pro 2.4
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-6.1:3 chip-ID: 1532:053a class-ID: 0301
    serial: <filter>
  API: ALSA v: k6.10.13-3-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
  IF-ID-1: br-a36a7d871616 state: down mac: <filter>
  IF-ID-2: docker0 state: down mac: <filter>
  Local Storage: total: 25.47 TiB used: 28.96 GiB (0.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 4TB
    size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 34.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST22000NT001-3LS101
    size: 20.01 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: EN01
  ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD20EURX-63T0FY0 size: 1.82 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
    fw-rev: 0A80 scheme: GPT
  ID-1: / raw-size: 1.73 TiB size: 1.7 TiB (98.37%) used: 28.93 GiB (1.7%)
    fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
    used: 30.8 MiB (32.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 35.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Memory: total: 32 GiB available: 31.27 GiB used: 2.62 GiB (8.4%)
  Processes: 225 Power: uptime: 3m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Packages: pm: pacman pkgs: 1186 libs: 328 tools: pamac pm: flatpak pkgs: 0
    Compilers: N/A Shell: Zsh v: 5.9 default: Bash v: 5.2.37 running-in: konsole
    inxi: 3.3.36
Any input would be appreciated, thanks
I tried reverting to kernal 6.6.54-2 but same error occurs, this is a fresh install with the latest iso
Do you use saved session?
Have you tried without?
See 986987987907 other threads
This has nothing to do with your problem right now, but 6.10 is EOL… switch to 6.6 LTS or 6.11 is recommend right now.
“When session was manually saved” is what it was set to, ill try it with an empty session
Looks like that fixed it, thanks
