Manjaro does not boot looks like whatever is inside boot partition is not installed
I have been playing around with installing different filesystems ext4,btrfs,xfs to figure out which one is the fastes for my sistuation with file transferes and, live video and audio recordings at the same time and so on.
after not having being able to figur out compleatley how to use subvolumes on external drives with btrfs, I decided I wanted to reinstall ext4 xfce manjaro, but I wanted the minimal version so I used architect.
(this error happens nomather what filesystem or the calamari installer I try to use exept btrfs on luks encryption)
everything looks to be installed properly until I go into gparted to have a look, then the boot partition tells me I have 512MiB avaliable but under the " used and unused" section it gives me a - saying nothing has been installed I guess.
the grub boot loader seems to work because I can choose if I want to boot into manjaro or windows or bios. (manjaro and windows is on 2 seperate nvme gen4 drives) but when I select manjaro
it gives me the common 1.55 through 10.55 No irq handler for vector message
plus this
/dev/nvme0n1p2: clean 254141/6553600 files. 2122888/26214488 blocks
after that it looks like it’s going to boot into manjarobut the screen just stays black with a normal flashing (_) and it stays like that until I force reboot the computer with the hardware button.
I have search other threds here on the forum but non of them seems to mee to have this exact problem.
Any help would be greatly apprechiated!
If I use th architect installer and try to install minimal manjaro without Luks encryption should the should the crypttab file have anything in it when I go to check it before I compleat the install?
Can you list a step by step of what you did to get to your current setup / system?
I’m trying to follow along, but it’s not clear if you’re using LUKS + BTRFS, or EXT4.
But the step by steps would be better to help troubleshoot.
@winnie
right now I have reinstalled Manjaro minimal with BTRFS and LUKS encrytption just because I konw that worked. and I have gotten Jack2 with Ardour to work proplerly.
but I have been trying to reinstall Manjaro (minimal) without LUKS encryption and with both EXT4 and XFS files system. From the architect installer I have also tried installing EXT4 Manjaro full with just the originale XFCE installer ande wipe disk letting the installer do everything, and I have tried to manual partitioning the drive and assiging XFS files as well through the XFCE installer.
Everything looks to be going right with the XFCE and Architect installers. I like to check gparted before doing the reboot and it shows that nothing was installed on the boot partition.
when I reboot, I get the grub bootloader where I can choose Manjaro, Windows, UEFI Setup When I choose Manjaro the screen goes black for as second then I get the
after a split second this message shows up onder ^^^ this one.
Then the screen goes black again (like it does before it shows the Manjaro loginscreen) but it stays black and never shows the loginscreen or anything, I have to press the physical reboot button on my tower.
as a side note, I know both installers work, because I have a Gen3 Adata nmve drive on the board as well that I have installed Manjaro on with both architect and XFCE installer just to make sure the installers was not corrupted somehow.
I’m suspecting maybe the LUKS encryption has something to do with it, but I cannot prove it, lol. because bot installers worked fine before the first time I installed Manjaro minimal with BTRFS and LUKS ecrtyption on the Sabrent Rocket plus dirve.
I made sure I have formatted the drive compleatly with minitools partition wizzard and I initialized it with ntfs just as a good measure before I got to install Manjaro with either installer as well.
The reason I want to go back to EXT4 and XFS is that I want to measure their transfere speeds with my own test file setup that is in my workload, becuase I don’t think the phoronix-test-suite is realy reperesentative of real life, It told me that I got transefer speeds of upwards of 5000MiBs on EXT4 and XFS but on BTRFS I only got a little over 300MiBs and when I tested on my own folder with a stop watch BTRFS is actually almost 10 seconds quicker on the same file. I wanted to try this test again without the encryption on EXT4 and XFS to make sure that that’s not killing the performance (it should not) I like to double check. I would stick with BTRFS if I could figur out how to use it properly and take full advantage of it.
I hope that clarifies it a little more.
What’s odd is that doing a full installation where you wipe the disk still doesn’t allow you to boot into Manajro. Previously using LUKS is irrelevant at that point since it’s a fresh installation.
Are you able to chroot into the installed system via a live USB? Maybe there is a misconfiguration of the boot files?
As a side note, it’s hard to benchmark file systems, since you need to consider cache and sync’s, and even that file managers will not honestly show you the true transfer speeds, let alone honestly tell you when a transfer is complete. (It could still be in the buffer, while it tells you “100% done”).
can you report
from USB iso manjaro
inxi -Fza
UPDATE: I can chroot into the system, and the EFI folder under boot is empty. Any idea what to do next?
That’s what I thought too. I used htop and timed the time it has the processor active along with the file manager info. I really want to love btrfs but I can t figure out how to use it properly when it comes to subvolumes and external drives so I figured It’s best to go back to old school file system.
I will try to reinstall and see if i can chroot into it, and let you know.
This is the output from inxi -Fza
System:    Kernel: 5.10.23-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
           parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=manjaro
           misolabel=MANJARO_XFCE_210 quiet systemd.show_status=1 apparmor=1 security=apparmor driver=free nouveau.modeset=1
           i915.modeset=1 radeon.modeset=1
           Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux
           base: Arch Linux
Machine:   Type: Desktop Mobo: Micro-Star model: MEG X570 UNIFY (MS-7C35) v: 2.0 serial: <filter> UEFI: American Megatrends
           v: A.60 date: 09/07/2020
CPU:       Info: 16-Core (2-Die) model: AMD Ryzen 9 3950X bits: 64 type: MT MCP MCM arch: Zen 2 family: 17 (23)
           model-id: 71 (113) stepping: N/A microcode: 8701021 cache: L2: 8 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 246526
           Speed: 3848 MHz min/max: N/A Core speeds (MHz): 1: 3848 2: 3840 3: 3854 4: 3845 5: 3847 6: 3858 7: 3836 8: 3836
           9: 3845 10: 3856 11: 3848 12: 3846 13: 3849 14: 3837 15: 3838 16: 3848 17: 3836 18: 3593 19: 3843 20: 3843 21: 3848
           22: 3834 23: 3822 24: 3842 25: 3835 26: 3848 27: 3831 28: 3844 29: 3834 30: 3837 31: 3848 32: 3844
           Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: conditional, RSB filling
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Vega 20 [Radeon VII] driver: amdgpu v: kernel bus-ID: 2f:00.0
           chip-ID: 1002:66af class-ID: 0300
           Display: x11 server: X.Org 1.20.10 driver: loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
           display-ID: :0.0 screens: 1
           Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.0x22.5") s-diag: 1165mm (45.9")
           Monitor-1: DisplayPort-2 res: 3840x2160 hz: 60 dpi: 163 size: 600x340mm (23.6x13.4") diag: 690mm (27.2")
           OpenGL: renderer: AMD Radeon VII (VEGA20 DRM 3.40.0 5.10.23-1-MANJARO LLVM 11.1.0) v: 4.6 Mesa 20.3.4
           direct render: Yes
Audio:     Device-1: Advanced Micro Devices [AMD/ATI] Vega 20 HDMI Audio [Radeon VII] driver: snd_hda_intel v: kernel
           bus-ID: 2f:00.1 chip-ID: 1002:ab20 class-ID: 0403
           Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
           v: kernel bus-ID: 31:00.4 chip-ID: 1022:1487 class-ID: 0403
           Device-3: Bose Bose USB Audio type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-6.2:7 chip-ID: 05a7:1020
           class-ID: 0300
           Sound Server-1: ALSA v: k5.10.23-1-MANJARO running: yes
           Sound Server-4: PipeWire v: 0.3.23 running: no
Network:   Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus-ID: 27:00.0
           IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
           Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: f000 bus-ID: 28:00.0 chip-ID: 8086:2723
           class-ID: 0280
           IF: wlo1 state: down mac: <filter>
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:2 chip-ID: 8087:0029 class-ID: e001
Drives:    Local Storage: total: 6.48 TiB used: 66.47 GiB (1.0%)
           ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Sabrent model: Rocket 4.0 Plus size: 931.51 GiB block-size:
           physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: RKT4P1.2 temp: 23.9 C
           scheme: GPT
           ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Sabrent model: Rocket 4.0 1TB size: 931.51 GiB block-size:
           physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: RKT401.2 temp: 33.9 C
           scheme: GPT
           ID-3: /dev/sda maj-min: 8:0 vendor: A-Data model: SU650NS38 size: 111.79 GiB block-size: physical: 512 B
           logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 202a scheme: GPT
           ID-4: /dev/sdf maj-min: 8:80 type: USB vendor: Western Digital model: WD My Book 25EE size: 3.64 TiB block-size:
           physical: 4096 B logical: 512 B serial: <filter> rev: 4009 scheme: GPT
           ID-5: /dev/sdg maj-min: 8:96 type: USB vendor: SanDisk model: Cruzer Slice size: 3.75 GiB block-size:
           physical: 512 B logical: 512 B serial: <filter> rev: 8.02 scheme: MBR
           ID-6: /dev/sdh maj-min: 8:112 type: USB vendor: Seagate model: ST1000LM024 HN-M101MBB size: 931.51 GiB block-size:
           physical: 512 B logical: 512 B rotation: 5400 rpm serial: <filter> rev: 0608 scheme: GPT
Swap:      Alert: No Swap data was found.
Sensors:   System Temperatures: cpu: 39.9 C mobo: N/A gpu: amdgpu temp: 34.0 C mem: 34.0 C
           Fan Speeds (RPM): N/A gpu: amdgpu fan: 840
Info:      Processes: 560 Uptime: 4m wakeups: 0 Memory: 31.34 GiB used: 1.73 GiB (5.5%) Init: systemd v: 247 tool: systemctl
           Compilers: gcc: N/A Packages: pacman: 1135 lib: 299 flatpak: 0 Shell: Bash v: 5.1.0 running-in: xfce4-terminal
           inxi: 3.3.03
any advice?
I guess I can just stay on btrfs and learn how to use it properly. lol but I really don’t like not knowing why something is not working the way it’s supposed to I’ll take all the help I can if you have any ideas.
Me neither… but it really difficult to say anything and even to follow your process. Honestly you write a lot of blabla (no offense) and provide tiny information.
What you have done step by step would be more useful.
Btw… we have no glass globes, even if someone write it. :stuck_out_tongue:
This could be more helpful :wink:
sudo parted -l
sudo blkid
cat /etc/fstab
sudo btrfs filesystem show
sudo btrfs subvolume list /path/to/mountpoint
Like @megavolt said, and no disrespect at all (I know how confusing installations and boot loaders can be), but right now it’s hard to follow along since we’re not really sure how you installed Manjaro, step by step.
Like the above example, it sounds as if you’re referring to two different PCs? I can’t tell if you mean that “right now” you have a working system that you installed Manjaro with BTRFS + LUKS.
As for an empty EFI directory, you made no mention of mounting it before/after chroot’ing?
none taken I thought I had done step by step. I’m gong to post my best attempt below here in a fresh comment of my step by step process. and I hope that is more step by step.
I really wish y’all had glass globes. lol
none taken I’m just happy y’all even bother to try to help!
I meant, when I was writing that post I had reinstalled Manjaro minimal with architect with BTRFS and Luks because that works for some reason, and I find it odd that that would work when none of the other methods seems to work.
I’ll try and clarify it a little more.
  1. it’s the same PC only one. with the architect installer I can install Manjaro minimal with BTRFS and Luke encryption on the same nvme0n1 drive. and it works like expected.
  2. If I try to use architect to install Manjaro minimal with either EXT4 or XFS on the same nvme0n1 drive it stops after the grub boot-loader appears on the monitor after the initial reboot.
  3. If I use the XFCE Manjaro installer on the same nvme0n1 drive with full wipe and letting the installer do everything. It stops after the grub boot-loader appears on the monitor after the initial reboot.
@megavolt @winnie
This is my attempted to make a detailed step by step of what I’m doing.
@megavolt when I try to split mine up like you did, it looks wired so I’m putting them all under one backtick
Manjaro XFCE installation
1. downloaded the XFCE Manjaro ISO from manjaro.org
2. made a bootable usb with rufus
3. rebooted the computer into the live Manjaro ISO USB
4. followed the installer and chose wipe drive alternative for partitioning. (no encryption)
5. after installation says it's done, checked the box for restart/reboot and clicked Done.
6. when rebooting I press F11 to get into my boot order and choose Manjaro (Sabrent rocket plus nvme0n1)
7. Grub boot-loader shows up for a second, then the screen goes black for a second
8. irc handler message shows up 1.55 through 10.55, screen goes black again after a second
9. instead of showing me the Manjaro welcome screen the monitor stays black and nothing happens.
10.booting into live USB ISO again.
(inside terminal from now on)
11. opening terminal, make myself a super user (su)
12. fdisk -l
13. mount /dev/nvme0n1p2 /mnt
14. mount /dev/nvme0n1p1 /mnt/boot
(lsblk = sucessfully mounted)
15. cd /mnt
16. ls
(bin boot desktopfs-pkgs.txt dev etc home lib lib64 lost+found mnt opt proc root rootfs-pkgs.txt run sbin snap srv sys tmp usr var)
17. chroot /mnt
18. cd boot/
19. ls (EFI)
20. cd EFI/
(boot Manjaro) <--now it's shwing these two folders.
21. cd boot/
ls (bootx64.efi)
22. cd ..
23. cd Manjaro/
ls (grubx64.efi)
24. cd ..
25. cd ..
26. cd ..
27. ls
28. cat /etc/fstab
(see output below)
29. cat mkinitcpio.d/linux5.10.preset
(see output below)
30. cd mtab/ OR cat mtab
(mtab: No such file or directory)
31. cd kernel/install.d/
(ls gives no output)
32. cd ..
33. cd ..
34. (etc) ls -la mtab is "flashing".
lrwxrwxrwx  1 root root     19 Jan 20 10:33 "mtab -> ../proc/self/mounts"
35. cat issue
Manjaro Linux \r  (\n) (\l)
36. cat fstab
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=7781-4DC1                            /boot/efi      vfat    umask=0077 0 2
UUID=4fad8629-3b52-49f9-b9cc-640e0d9942c6 /              ext4    defaults,noatime 0 1
37. cat linux510.preset
# mkinitcpio preset file for the 'linux510' package
ALL_config="/etc/mkinitcpio.conf"
ALL_kver="/boot/vmlinuz-5.10-x86_64"
PRESETS=('default' 'fallback')
#default_config="/etc/mkinitcpio.conf"
default_image="/boot/initramfs-5.10-x86_64.img"
#default_options=""
#fallback_config="/etc/mkinitcpio.conf"
fallback_image="/boot/initramfs-5.10-x86_64-fallback.img"
fallback_options="-S autodetect"
  1. use ventoy
  2. add option noapic
  3. its seems that video is not working , possible to open TTY ( Ctrl+Alt+F2 to F7 )
a) are you using 2 monitors ?
b) we should see errors in journalctl & Xorg , this is possible by chroot
sudo manjaro-chroot -a ( if filessystem is not btrfs )
journalctl -b -1 -g amdgpu (  -b0 current boot , -b -1 boot before , etc ... )
cat /var/log/Xorg.0.log | grep 'EE'
@stephane I’m only using 1 monitor.
I’m downloading ventoy now, is the option noapic on the ventoy instalation or is it a plugin/other file I need to download?
I have not tried TTY, will do this and report back.
I will try the chroot commands you posted and report back, on a new post asap. thank you.
In general this could a problem related to the gpu driver.
First thing: remove quiet from the kernel parameter: Kernel parameters - ArchWiki
Is there anything what failed at the boot process?
If the display-manager failed, then it has something to do with the configs of xorg in most cases.
Since you use a AMD GCN5 gpu, it is built into the kernel. Maybe there is some quirk… the display manager does not wait for the gpu or such things…
I bet there is something at /var/log/Xorg.0.log … That lists all logs at once:
 for x in /var/log/Xorg*; do echo -e "\n--- $x ---\n$(cat $x)"; done
If you can switch to another TTY, then try restart the display manager there:
sudo systemctl restart display-manager
[manjaro@manjaro ~]$ sudo manjaro-chroot -a
==> Detected systems:
 --> 0) ManjaroLinux
 --> 1) ManjaroLinux1
==> Select system to mount [0-1] :
0
==> Mounting (ManjaroLinux) [/dev/nvme0n1p2]
 --> mount: [/mnt]
 --> mount: [/mnt/boot/efi]
[manjaro /]# lsblk
NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
loop0         7:0    0    84M  1 loop
loop1         7:1    0 339.2M  1 loop
loop2         7:2    0   1.2G  1 loop
loop3         7:3    0 672.8M  1 loop
sda           8:0    0 111.8G  0 disk
|-sda1        8:1    0   300M  0 part
`-sda2        8:2    0 111.5G  0 part
sdf           8:80   0   3.6T  0 disk
`-sdf1        8:81   0   3.6T  0 part
sdg           8:96   1   3.7G  0 disk
|-sdg1        8:97   1   3.7G  0 part
| `-ventoy  254:0    0   2.4G  1 dm
`-sdg2        8:98   1    32M  0 part
sdh           8:112  0 931.5G  0 disk
`-sdh1        8:113  0 931.5G  0 part
nvme1n1     259:0    0 931.5G  0 disk
|-nvme1n1p1 259:1    0   100M  0 part
|-nvme1n1p2 259:2    0    16M  0 part
|-nvme1n1p3 259:3    0 930.9G  0 part
`-nvme1n1p4 259:4    0   505M  0 part
nvme0n1     259:5    0 931.5G  0 disk
|-nvme0n1p1 259:6    0   300M  0 part /boot/efi
`-nvme0n1p2 259:7    0 931.2G  0 part /
[manjaro /]# journalctl -b -1 -g amdgpu (  -b0 current boot , -b -1 boot before , etc ... )
bash: syntax error near unexpected token `('
[manjaro /]# cat /var/log/Xorg.0.log | grep 'EE'
[manjaro /]#
I only added in the lsblk command to make sure they got mounted.
the last cat command did not produce an output.but if I cat Xorg.0.log.old I get this if that helps?
[     2.924]
X.Org X Server 1.20.10
[     2.924] Build Operating System: Linux Manjaro Linux
[     2.924] Current Operating System: Linux ryzenbeast 5.10.23-1-MANJARO #1 SMP PREEMPT Thu Mar 11 18:47:18 UTC 2021 x86_64
[     2.924] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=4fad8629-3b52-49f9-b9cc-640e0d9942c6 rw quiet apparmor=1 security=apparmor udev.log_priority=3
[     2.924] Build Date: 16 December 2020  10:33:32PM
[     2.924]
[     2.924] Current version of pixman: 0.40.0
[     2.924] 	Before reporting problems, check http://wiki.x.org
[     2.924] Markers: (--) probed, (**) from config file, (==) default setting,
[     2.924] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Apr 15 03:24:38 2021
[     2.924] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     2.924] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     2.924] (==) No Layout section.  Using the first Screen section.
[     2.924] (==) No screen section available. Using defaults.
[     2.924] (**) |-->Screen "Default Screen Section" (0)
[     2.924] (**) |   |-->Monitor "<default monitor>"
[     2.924] (==) No monitor specified for screen "Default Screen Section".
[     2.924] (==) Automatically adding devices
[     2.924] (==) Automatically enabling devices
[     2.924] (==) Automatically adding GPU devices
[     2.924] (==) Automatically binding GPU devices
[     2.924] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     2.924] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     2.924] 	Entry deleted from font path.
[     2.924] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     2.924] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[     2.924] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[     2.924] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[     2.924] (==) ModulePath set to "/usr/lib/xorg/modules"
[     2.924] (II) The server relies on udev to provide the list of input devices.
[     2.924] (II) Module ABI versions:
[     2.924] 	X.Org ANSI C Emulation: 0.4
[     2.924] 	X.Org Video Driver: 24.1
[     2.924] 	X.Org XInput driver : 24.1
[     2.924] 	X.Org Server Extension : 10.0
[     2.925] (++) using VT number 7
[     2.925] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     2.927] (--) PCI:*(47@0:0:0) 1002:66af:1002:081e rev 193, Mem @ 0xd0000000/268435456, 0xe0000000/2097152, 0xfcd00000/524288, I/O @ 0x0000e000/256, BIOS @ 0x????????/131072
[     2.927] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     2.927] (II) LoadModule: "glx"
[     2.927] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     2.928] (II) Module glx: vendor="X.Org Foundation"
[     2.928] 	compiled for 1.20.10, module version = 1.0.0
[     2.928] 	ABI class: X.Org Server Extension, version 10.0
[     2.928] (==) Matched ati as autoconfigured driver 0
[     2.928] (==) Matched modesetting as autoconfigured driver 1
[     2.928] (==) Matched fbdev as autoconfigured driver 2
[     2.928] (==) Matched vesa as autoconfigured driver 3
[     2.928] (==) Assigned the driver to the xf86ConfigLayout
[     2.928] (II) LoadModule: "ati"
[     2.928] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[     2.928] (II) Module ati: vendor="X.Org Foundation"
[     2.928] 	compiled for 1.20.8, module version = 19.1.0
[     2.928] 	Module class: X.Org Video Driver
[     2.928] 	ABI class: X.Org Video Driver, version 24.1
[     2.928] (II) LoadModule: "radeon"
[     2.928] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[     2.928] (II) Module radeon: vendor="X.Org Foundation"
[     2.928] (II) LoadModule: "modesetting"
[     2.928] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[     2.928] (II) Module modesetting: vendor="X.Org Foundation"
[     2.928] 	compiled for 1.20.10, module version = 1.20.10
[     2.928] (II) LoadModule: "fbdev"
[     2.928] (WW) Warning, couldn't open module fbdev
[     2.929] (EE) Failed to load module "fbdev" (module does not exist, 0)
[     2.929] (II) LoadModule: "vesa"
[     2.929] (WW) Warning, couldn't open module vesa
[     2.929] (EE) Failed to load module "vesa" (module does not exist, 0)
[     2.929] (II) RADEON: Driver for ATI/AMD Radeon chipsets:
	ATI Radeon Mobility X600 (M24), ATI FireMV 2400,
	ATI Radeon Mobility X300 (M24), ATI FireGL M24 GL,
	ATI Radeon X600 (RV380), ATI FireGL V3200 (RV380),
	ATI Radeon IGP320 (A3), ATI Radeon IGP330/340/350 (A4),
	ATI Radeon 9500, ATI Radeon 9600TX, ATI FireGL Z1, ATI Radeon 9800SE,
	ATI Radeon 9800, ATI FireGL X2, ATI Radeon 9600, ATI Radeon 9600SE,
	ATI Radeon 9600XT, ATI FireGL T2, ATI Radeon 9650, ATI FireGL RV360,
	ATI Radeon 7000 IGP (A4+), ATI Radeon 8500 AIW,
	ATI Radeon IGP320M (U1), ATI Radeon IGP330M/340M/350M (U2),
	ATI Radeon Mobility 7000 IGP, ATI Radeon 9000/PRO, ATI Radeon 9000,
	ATI Radeon X800 (R420), ATI Radeon X800PRO (R420),
	ATI Radeon X800SE (R420), ATI FireGL X3 (R420),
	ATI Radeon Mobility 9800 (M18), ATI Radeon X800 SE (R420),
	ATI Radeon X800XT (R420), ATI Radeon X800 VE (R420),
	ATI Radeon X850 (R480), ATI Radeon X850 XT (R480),
	ATI Radeon X850 SE (R480), ATI Radeon X850 PRO (R480),
	ATI Radeon X850 XT PE (R480), ATI Radeon Mobility M7,
	ATI Mobility FireGL 7800 M7, ATI Radeon Mobility M6,
	ATI FireGL Mobility 9000 (M9), ATI Radeon Mobility 9000 (M9),
	ATI Radeon 9700 Pro, ATI Radeon 9700/9500Pro, ATI FireGL X1,
	ATI Radeon 9800PRO, ATI Radeon 9800XT,
	ATI Radeon Mobility 9600/9700 (M10/M11),
	ATI Radeon Mobility 9600 (M10), ATI Radeon Mobility 9600 (M11),
	ATI FireGL Mobility T2 (M10), ATI FireGL Mobility T2e (M11),
	ATI Radeon, ATI FireGL 8700/8800, ATI Radeon 8500, ATI Radeon 9100,
	ATI Radeon 7500, ATI Radeon VE/7000, ATI ES1000,
	ATI Radeon Mobility X300 (M22), ATI Radeon Mobility X600 SE (M24C),
	ATI FireGL M22 GL, ATI Radeon X800 (R423), ATI Radeon X800PRO (R423),
	ATI Radeon X800LE (R423), ATI Radeon X800SE (R423),
	ATI Radeon X800 XTP (R430), ATI Radeon X800 XL (R430),
	ATI Radeon X800 SE (R430), ATI Radeon X800 (R430),
	ATI FireGL V7100 (R423), ATI FireGL V5100 (R423),
	ATI FireGL unknown (R423), ATI Mobility FireGL V5000 (M26),
	ATI Mobility Radeon X700 XL (M26), ATI Mobility Radeon X700 (M26),
	ATI Radeon X550XTX, ATI Radeon 9100 IGP (A5),
	ATI Radeon Mobility 9100 IGP (U3), ATI Radeon XPRESS 200,
	ATI Radeon XPRESS 200M, ATI Radeon 9250, ATI Radeon 9200,
	ATI Radeon 9200SE, ATI FireMV 2200, ATI Radeon X300 (RV370),
	ATI Radeon X600 (RV370), ATI Radeon X550 (RV370),
	ATI FireGL V3100 (RV370), ATI FireMV 2200 PCIE (RV370),
	ATI Radeon Mobility 9200 (M9+), ATI Mobility Radeon X800 XT (M28),
	ATI Mobility FireGL V5100 (M28), ATI Mobility Radeon X800 (M28),
	ATI Radeon X850, ATI unknown Radeon / FireGL (R480),
	ATI Radeon X800XT (R423), ATI FireGL V5000 (RV410),
	ATI Radeon X700 XT (RV410), ATI Radeon X700 PRO (RV410),
	ATI Radeon X700 SE (RV410), ATI Radeon X700 (RV410),
	ATI Radeon X1800, ATI Mobility Radeon X1800 XT,
	ATI Mobility Radeon X1800, ATI Mobility FireGL V7200,
	ATI FireGL V7200, ATI FireGL V5300, ATI Mobility FireGL V7100,
	ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
	ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
	ATI Mobility Radeon X1400, ATI Radeon X1550 64-bit,
	ATI Mobility Radeon X1300, ATI Radeon X1300, ATI FireGL V3300,
	ATI FireGL V3350, ATI Mobility Radeon X1450,
	ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
	ATI FireMV 2250, ATI Radeon X1650, ATI Mobility FireGL V5200,
	ATI Mobility Radeon X1600, ATI Radeon X1300 XT/X1600 Pro,
	ATI FireGL V3400, ATI Mobility FireGL V5250,
	ATI Mobility Radeon X1700, ATI Mobility Radeon X1700 XT,
	ATI FireGL V5200, ATI Radeon X2300HD, ATI Mobility Radeon HD 2300,
	ATI Radeon X1950, ATI Radeon X1900, ATI AMD Stream Processor,
	ATI RV560, ATI Mobility Radeon X1900, ATI Radeon X1950 GT, ATI RV570,
	ATI FireGL V7400, ATI Radeon 9100 PRO IGP,
	ATI Radeon Mobility 9200 IGP, ATI Radeon X1200, ATI RS740,
	ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro,
	ATI Radeon HD 2900 GT, ATI FireGL V8650, ATI FireGL V8600,
	ATI FireGL V7600, ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
	ATI Radeon HD 4850 x2, ATI FirePro V8750 (FireGL),
	ATI FirePro V7760 (FireGL), ATI Mobility RADEON HD 4850,
	ATI Mobility RADEON HD 4850 X2, ATI FirePro RV770,
	AMD FireStream 9270, AMD FireStream 9250, ATI FirePro V8700 (FireGL),
	ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
	ATI FirePro M7750, ATI M98, ATI Mobility Radeon HD 4650,
	ATI Radeon RV730 (AGP), ATI Mobility Radeon HD 4670,
	ATI FirePro M5750, ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
	ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
	ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
	ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
	ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
	ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI RV610,
	ATI Radeon HD 2400 XT, ATI Radeon HD 2400 Pro,
	ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000, ATI Radeon HD 2350,
	ATI Mobility Radeon HD 2400 XT, ATI Mobility Radeon HD 2400,
	ATI RADEON E2400, ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
	ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
	ATI Mobility Radeon HD 3850 X2, ATI Mobility Radeon HD 3870,
	ATI Mobility Radeon HD 3870 X2, ATI Radeon HD3870 X2,
	ATI FireGL V7700, ATI Radeon HD3690, AMD Firestream 9170,
	ATI Radeon HD 4550, ATI Radeon RV710, ATI Radeon HD 4350,
	ATI Mobility Radeon 4300 Series, ATI Mobility Radeon 4500 Series,
	ATI FirePro RG220, ATI Mobility Radeon 4330, ATI RV630,
	ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
	ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
	ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
	ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
	ATI FireGL V3600, ATI Radeon HD 2600 LE,
	ATI Mobility FireGL Graphics Processor, ATI Radeon HD 3470,
	ATI Mobility Radeon HD 3430, ATI Mobility Radeon HD 3400 Series,
	ATI Radeon HD 3450, ATI Radeon HD 3430, ATI FirePro V3700,
	ATI FireMV 2450, ATI Radeon HD 3600 Series, ATI Radeon HD 3650 AGP,
	ATI Radeon HD 3600 PRO, ATI Radeon HD 3600 XT,
	ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
	ATI Mobility FireGL V5700, ATI Mobility FireGL V5725,
	ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
	ATI Radeon HD 3300 Graphics, ATI Radeon 3000 Graphics, SUMO, SUMO2,
	ATI Radeon HD 4200, ATI Radeon 4100, ATI Mobility Radeon HD 4200,
	ATI Mobility Radeon 4100, ATI Radeon HD 4290, ATI Radeon HD 4250,
	AMD Radeon HD 6310 Graphics, AMD Radeon HD 6250 Graphics,
	AMD Radeon HD 6300 Series Graphics,
	AMD Radeon HD 6200 Series Graphics, PALM, CYPRESS,
	ATI FirePro (FireGL) Graphics Adapter, AMD Firestream 9370,
	AMD Firestream 9350, ATI Radeon HD 5800 Series,
	ATI Radeon HD 5900 Series, ATI Mobility Radeon HD 5800 Series,
	ATI Radeon HD 5700 Series, ATI Radeon HD 6700 Series,
	ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
	ATI Radeon HD 5670, ATI Radeon HD 5570, ATI Radeon HD 5500 Series,
	REDWOOD, ATI Mobility Radeon Graphics, CEDAR, ATI FirePro 2270,
	ATI Radeon HD 5450, CAYMAN, AMD Radeon HD 6900 Series,
	AMD Radeon HD 6900M Series, Mobility Radeon HD 6000 Series, BARTS,
	AMD Radeon HD 6800 Series, AMD Radeon HD 6700 Series, TURKS, CAICOS,
	ARUBA, TAHITI, PITCAIRN, VERDE, OLAND, HAINAN, BONAIRE, KABINI,
	MULLINS, KAVERI, HAWAII
[     2.930] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[     2.930] (EE) open /dev/dri/card0: No such file or directory
[     2.930] (WW) Falling back to old probe method for modesetting
[     2.930] (EE) Screen 0 deleted because of no matching config section.
[     2.930] (II) UnloadModule: "modesetting"
[     2.930] (EE) Device(s) detected, but none match those in the config file.
[     2.930] (EE)
Fatal server error:
[     2.930] (EE) no screens found(EE)
[     2.930] (EE)
Please consult the The X.Org Foundation support
	 at http://wiki.x.org
 for help.
[     2.930] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[     2.930] (EE)
[     2.930] (EE) Server terminated with error (1). Closing log file.
That helps!
It loads the old radeon driver and not the amdgpu driver for what ever reason…
But here it has loaded the amdgpu driver:
You will need to add the modules to /etc/mkinitcpio.conf. Add there on the correct place:
MODULES=(amdgpu radeon)
This way it forces linux to load the amdgpu driver first as early as possible.
Then:
sudo mkinitcpio -P
EDIT: LOL posted at the same time xD
This is the output from < for x in /var/log/Xorg*; do echo -e “\n— $x —\n$(cat $x)”; done >
There is no other indications on the monitor about what failed during the boot process, or anything else.
I’m gonna read up on this and hopefully do it and then report back to you.^^
going to try this now. and report back^^
--- /var/log/Xorg.0.log ---
--- /var/log/Xorg.0.log.old ---
[     2.924]
[     2.924]
[     2.930] (EE)
Fatal server error:
[     2.930] (EE)
 for help.
[     2.930] (EE)
I see it says: ^^
Fatal server error:
[ 2.930] (EE)
I get this output from this command, sudo mkinitcpio -P
[manjaro /]# mkinitcpio -P
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default'
  -> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
==> ERROR: specified kernel image does not exist: `/boot/vmlinuz-5.10-x86_64'
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback'
  -> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
after I added amdgpu and radeon to the MODULES=" "
Did you install a kernel?
mhwd-kernel -li
But i guess you have to do a full upgrade…
pamac update --force-refresh
