Manjaro does not boot after update
Today after updating the system and rebooted, the system does not boot.
I just get a message start pxe over ipv4.
It seems it does not see my ssd drive, where the system is installed.
grub-install /dev/nvme0n1
Installing for x86_64-efi platform.
grub-install: error: cannot find EFI directory
recheck all options in UEFI motherboard
  • secureBoot off
  • fast Boot off
  • no CSM or Legacy
  • all disks on AHCI ( no raid )
  • no Optane/RST
I did not changed anything in BIOS. So all should be fine.
boot USB live manjaro ( not your disk )
open a terminal and browser on this topic
and report
sudo manjaro-chroot -a
inxi  -Fxza
test -d /sys/firmware/efi && echo efi || echo bios
efibootmgr -v
parted -l
exit ( end of chroot )
[manjaro@manjaro ~]$ sudo manjaro-chroot -a
==> Mounting (ManjaroLinux) [/dev/nvme0n1p2]
 --> mount: [/mnt]
 --> mount: [/mnt/boot/efi]
mount: /mnt/boot/efi: special device /dev/disk/by-uuid/4E38-B482 does not exist.
12System:
  12Kernel 5.15.7-1-MANJARO x86_64 12bits 64 12compiler gcc 12v 11.1.0
    12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=hu tz=UTC misobasedir=manjaro
    misolabel=MANJARO_XFCE_2120 quiet systemd.show_status=1 apparmor=1 security=apparmor
    driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
  12Desktop Xfce 12info xfce4-panel 12wm xfwm 12dm N/A 12Distro Manjaro Linux 12base Arch Linux
12Machine:
  12Type Laptop 12System Dell 12product Dell G15 5510 12v N/A 12serial <filter> 12Chassis 12type 10
    12serial <filter>
  12Mobo Dell 12model 0983D5 12v A00 12serial <filter> 12UEFI Dell 12v 1.5.0 12date 07/02/2021
(upower:21): UPower-WARNING **: 09:25:16.348: Cannot connect to upowerd: Could not connect: No such file or directory
12Battery:
  12ID-1 BAT0 12charge 54.9 Wh (100.0%) 12condition 54.9/54.9 Wh (100.0%) 12volts 12.9 12min 11.4
    12model BYD DELL DVG8M14 12type Li-poly 12serial <filter> 12status Full
  12Device-1 hidpp_battery_0 12model Logitech Wireless Keyboard 12serial <filter> 12charge N/A
    12status N/A
12CPU:
  12Info 12model Intel Core i5-10200H 12bits 64 12type MT MCP 12arch Comet Lake 12family 6 12model-id 0xA5 (165)
    12stepping 2 12microcode 0xEA
  12Topology 12cpus 1x 12cores 4 12tpc 2 12threads 8 12smt enabled 12cache 12L1 256 KiB
    12desc d-4x32 KiB; i-4x32 KiB 12L2 1024 KiB 12desc 4x256 KiB 12L3 8 MiB 12desc 1x8 MiB
  12Speed (MHz) 12avg 900 12high 901 12min/max 800/4100 12base/boost 2772/2400 12scaling 12driver intel_pstate
    12governor powersave 12volts 0.8 V 12ext-clock 100 MHz 12cores 121 900 122 901 123 900 124 900 125 901 126 901 127 900
    128 900 12bogomips 38408
  12Flags avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
  12Vulnerabilities
  12Type itlb_multihit 12status KVM: VMX disabled
  12Type l1tf 12status Not affected
  12Type mds 12status Not affected
  12Type meltdown 12status Not affected
  12Type spec_store_bypass 12mitigation Speculative Store Bypass disabled via prctl and seccomp
  12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer sanitization
  12Type spectre_v2 12mitigation Enhanced IBRS, IBPB: conditional, RSB filling
  12Type srbds 12status Not affected
  12Type tsx_async_abort 12status Not affected
12Graphics:
  12Device-1 Intel 12vendor Dell 12driver i915 12v kernel 12bus-ID 00:02.0 12chip-ID 8086:9ba4 12class-ID 0300
  12Device-2 NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] 12vendor Dell 12driver nouveau 12v kernel
    12alternate nvidia_drm,nvidia 12bus-ID 01:00.0 12chip-ID 10de:1f9d 12class-ID 0300
  12Device-3 Realtek Integrated_Webcam_HD 12type USB 12driver uvcvideo 12bus-ID 1-5:4 12chip-ID 0bda:565c
    12class-ID 0e02 12serial <filter>
  12Display 12server X.org 1.21.1.2 12compositor xfwm4 12driver 12loaded modesetting,nvidia
    12resolution <missing: xdpyinfo>
  12OpenGL 12renderer Mesa Intel UHD Graphics (CML GT1) 12v 4.6 Mesa 21.3.2 12direct render Yes
12Audio:
  12Device-1 Intel Comet Lake PCH cAVS 12vendor Dell 12driver sof-audio-pci-intel-cnl
    12alternate snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl 12bus-ID 00:1f.3 12chip-ID 8086:06c8
    12class-ID 0401
  12Device-2 NVIDIA 12driver snd_hda_intel 12v kernel 12bus-ID 01:00.1 12chip-ID 10de:10fa 12class-ID 0403
  12Sound Server-1 ALSA 12v k5.15.7-1-MANJARO 12running yes
  12Sound Server-2 JACK 12v 1.9.19 12running no
  12Sound Server-3 PulseAudio 12v 15.0 12running yes
  12Sound Server-4 PipeWire 12v 0.3.42 12running no
12Network:
  12Device-1 Intel Comet Lake PCH CNVi WiFi 12driver iwlwifi 12v kernel 12bus-ID 00:14.3 12chip-ID 8086:06f0
    12class-ID 0280
  12IF wlp0s20f3 12state down 12mac <filter>
  12Device-2 Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet 12vendor Dell 12driver r8169
    12v kernel 12port 3000 12bus-ID 03:00.0 12chip-ID 10ec:8168 12class-ID 0200
  12IF enp3s0 12state up 12speed 100 Mbps 12duplex full 12mac <filter>
12Bluetooth:
  12Device-1 Intel AX201 Bluetooth 12type USB 12driver btusb 12v 0.8 12bus-ID 1-14:5 12chip-ID 8087:0026
    12class-ID e001
  12Report rfkill 12ID hci0 12rfk-id 1 12state down 12bt-service N/A 12rfk-block 12hardware no 12software yes
    12address see --recommends
12Drives:
  12Local Storage 12total 491.26 GiB 12used 126.38 GiB (25.7%)
  12SMART Message Required tool smartctl not installed. Check --recommends
  12ID-1 /dev/nvme0n1 12maj-min 259:0 12vendor Western Digital 12model PC SN530 NVMe WDC 512GB
    12size 476.94 GiB 12block-size 12physical 512 B 12logical 512 B 12speed 31.6 Gb/s 12lanes 4 12type SSD
    12serial <filter> 12rev 21112012 12temp 22.9 C
  12ID-2 /dev/sda 12maj-min 8:0 12type USB 12vendor SanDisk 12model Cruzer Blade 12size 14.32 GiB 12block-size
    12physical 512 B 12logical 512 B 12type N/A 12serial <filter> 12rev 1.00
12Partition:
  12ID-1 / 12raw-size 476.64 GiB 12size 468.09 GiB (98.21%) 12used 126.38 GiB (27.0%) 12fs ext4
    12block-size 4096 B 12dev /dev/nvme0n1p2 12maj-min 259:1
12Swap:
  12Alert No swap data was found.
12Sensors:
  12System Temperatures 12cpu 27.0 C 12pch 22.0 C 12mobo N/A 12gpu nouveau 12temp 20.0 C
  12Fan Speeds (RPM) N/A
12Info:
  12Processes 254 12Uptime 15h 38m 12wakeups 1330 12Memory 7.55 GiB 12used 2.19 GiB (29.0%) 12Init systemd
  12v 250 12tool systemctl 12Compilers 12gcc 11.1.0 12Packages 12pacman 1372 12lib 337 12flatpak 0
  12Client Unknown Client: systemd 12inxi 3.3.11
efi
BootCurrent: 0000
Timeout: 0 seconds
BootOrder: 0006,0000,0004,0003,0002,0001
Boot0000* UEFI SanDisk Cruzer Blade 4C530001130403106595	PciRoot(0x0)/Pci(0x14,0x0)/USB(2,0)/HD(2,MBR,0x5360931b,0x69744c,0x2000)/File(\EFI\Boot\BootX64.efi)N.....YM....R,Y.
Boot0001* ONBOARD NIC (IPV4)	PciRoot(0x0)/Pci(0x1d,0x0)/Pci(0x0,0x0)/MAC(601895266f9e,0)/IPv4(0.0.0.00.0.0.0,0,0)N.....YM....R,Y.
Boot0002* ONBOARD NIC (IPV6)	PciRoot(0x0)/Pci(0x1d,0x0)/Pci(0x0,0x0)/MAC(601895266f9e,0)/IPv6([::]:<->[::]:,0,0)N.....YM....R,Y.
Boot0003* UEFI HTTPs Boot	PciRoot(0x0)/Pci(0x1d,0x0)/Pci(0x0,0x0)/MAC(601895266f9e,0)/IPv4(0.0.0.00.0.0.0,0,0)/Uri()N.....YM....R,Y.
Boot0004* UEFI SanDisk Cruzer Blade 4C530001130403106595 2	PciRoot(0x0)/Pci(0x14,0x0)/USB(2,0)/CDROM(1,0x69744c,0x8000)/File(\EFI\Boot\BootX64.efi)N.....YM....R,Y.
Boot0006* Manjaro	HD(1,GPT,dc9cb55d-3f57-2842-85f9-e9aa716aadc5,0x1000,0x96000)/File(\EFI\Manjaro\grubx64.efi)
Model: SanDisk Cruzer Blade (scsi)
Disk /dev/sda: 15.4GB
Partition Table: msdos
Disk Flags:
Number  Start   End     Size    Type     File system  Flags
 2      3538MB  3543MB  4194kB  primary               esp
 1      3543MB  15.4GB  11.8GB  primary  fat32        lba
Model: PC SN530 NVMe WDC 512GB (nvme)
Disk /dev/nvme0n1: 512GB
Partition Table: gpt
Disk Flags:
Number  Start  End    Size   File system  Name  Flags
 2      317MB  512GB  512GB  ext4         root
I realized that I have no efi partition, so I created it.
Now I get the grub menu, but the system hangs during boot and finally I got into emergency mode.
What I see in the logs is
pmi_s Unable to find any system interface
wmi_bus-PNP0C14:02: WQBC data block query control method not found
Timed out waiting for device /dev/disk/by-uuid/4E38-B482
I fixed it by editing /etc/fstab
I do not get a login screen, but I can log into a tty and I see a lot of nvidia related errors in the logs.
  • flags ( on mountoint ) is Boot&esp ( that was missing before )
Disk Flags:
so perhaps redo install ?
Now it looks like this.
Disk Flags:
Disk Flags:
 1      1049kB  317MB  316MB  fat32              boot, esp
I try to avoid reinstalling the system as I am working on it for months and everything is already set up as I want.
this is a laptop
so you always boot on I915 video card , nvidia can be used by command prime.
can you report
sudo mhwd -li
sudo journalctl -b0 -g nvidia
[manjaro /]# sudo mhwd -li
> Installed PCI configs:
video-hybrid-intel-nvidia-prime            2021.12.18               false            PCI
[manjaro /]# sudo journalctl -b0 -g nvidia
-- No entries --
Ah I have no log entires as I am on a boot usb now. How do I get the logs of my system?
journalctl -b -1 -g nvidia
exit ( end-chroot )
Jan 06 11:46:24 rrd-dell kernel: audit: type=1400 audit(1641465984.396:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprob>
Jan 06 11:46:24 rrd-dell kernel: audit: type=1400 audit(1641465984.396:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprob>
Jan 06 11:46:24 rrd-dell audit[296]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=296 comm="apparmor_parser"
Jan 06 11:46:24 rrd-dell audit[296]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=296 comm="apparmor_pa>
Jan 06 11:46:24 rrd-dell systemd-modules-load[278]: Module 'nvidia' is deny-listed
Jan 06 11:46:24 rrd-dell systemd-modules-load[278]: Module 'nvidia_drm' is deny-listed
Jan 06 11:46:24 rrd-dell systemd-modules-load[278]: Module 'nvidia_uvm' is deny-listed
Jan 06 11:46:25 rrd-dell kernel: input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input11
Jan 06 11:46:25 rrd-dell kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input12
Jan 06 11:46:25 rrd-dell kernel: input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input13
Jan 06 11:46:25 rrd-dell kernel: input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input14
Jan 06 11:46:27 rrd-dell /usr/lib/gdm-x-session[1040]: (**) |-->Screen "nvidia" (0)
Jan 06 11:46:27 rrd-dell /usr/lib/gdm-x-session[1040]: (**) |   |-->Device "nvidia"
Jan 06 11:46:27 rrd-dell /usr/lib/gdm-x-session[1040]: (==) No monitor specified for screen "nvidia".
Jan 06 11:46:27 rrd-dell /usr/lib/gdm-x-session[1040]: (**) ModulePath set to "/usr/lib/nvidia,/usr/lib32/nvidia,/usr/lib32/nvidia/xorg/modules,/usr/lib32/xorg>
Jan 06 11:46:27 rrd-dell /usr/lib/gdm-x-session[1040]: (II) LoadModule: "nvidia"
Jan 06 11:46:27 rrd-dell /usr/lib/gdm-x-session[1040]: (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
Jan 06 11:46:27 rrd-dell /usr/lib/gdm-x-session[1040]: (II) Module nvidia: vendor="NVIDIA Corporation"
Jan 06 11:46:27 rrd-dell /usr/lib/gdm-x-session[1040]: (II) NVIDIA dlloader X Driver  495.44  Fri Oct 22 06:11:21 UTC 2021
Jan 06 11:46:27 rrd-dell /usr/lib/gdm-x-session[1040]: (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
Jan 06 11:46:27 rrd-dell kernel: nvidia: module license 'NVIDIA' taints kernel.
Jan 06 11:46:27 rrd-dell kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 508
Jan 06 11:46:27 rrd-dell kernel: nvidia 0000:01:00.0: enabling device (0000 -> 0003)
Jan 06 11:46:27 rrd-dell kernel: nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
Jan 06 11:46:27 rrd-dell kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  495.44  Fri Oct 22 06:13:12 UTC 2021
Jan 06 11:46:27 rrd-dell /usr/lib/gdm-x-session[1040]: (II) NVIDIA(0): Creating default Display subsection in Screen section
Jan 06 11:46:27 rrd-dell /usr/lib/gdm-x-session[1040]:         "nvidia" for depth/fbbpp 24/32
Jan 06 11:46:27 rrd-dell /usr/lib/gdm-x-session[1040]: (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
Jan 06 11:46:27 rrd-dell /usr/lib/gdm-x-session[1040]: (==) NVIDIA(0): RGB weight 888
Jan 06 11:46:27 rrd-dell /usr/lib/gdm-x-session[1040]: (==) NVIDIA(0): Default visual is TrueColor
Jan 06 11:46:27 rrd-dell /usr/lib/gdm-x-session[1040]: (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
Jan 06 11:46:27 rrd-dell /usr/lib/gdm-x-session[1040]: (**) Option "AllowNVIDIAGpuScreens"
Jan 06 11:46:27 rrd-dell /usr/lib/gdm-x-session[1040]: (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
Jan 06 11:46:27 rrd-dell /usr/lib/gdm-x-session[1040]: (**) NVIDIA(0): Option "Coolbits" "28"
Jan 06 11:46:27 rrd-dell /usr/lib/gdm-x-session[1040]: (**) NVIDIA(0): Enabling 2D acceleration
Jan 06 11:46:27 rrd-dell /usr/lib/gdm-x-session[1040]: (II) Loading sub module "glxserver_nvidia"
Jan 06 11:46:27 rrd-dell /usr/lib/gdm-x-session[1040]: (II) LoadModule: "glxserver_nvidia"
Jan 06 11:46:27 rrd-dell /usr/lib/gdm-x-session[1040]: (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
Jan 06 11:46:27 rrd-dell /usr/lib/gdm-x-session[1040]: (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
Jan 06 11:46:27 rrd-dell /usr/lib/gdm-x-session[1040]: (II) NVIDIA GLX Module  495.44  Fri Oct 22 06:08:29 UTC 2021
Jan 06 11:46:27 rrd-dell /usr/lib/gdm-x-session[1040]: (II) NVIDIA: The X server supports PRIME Render Offload.
Jan 06 11:46:28 rrd-dell kernel: nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  495.44  Fri Oct 22 06:05:22 UTC 2021
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (--) NVIDIA(0):     DFP-0
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (WW) NVIDIA: No DRM device: Direct render devices found but none could be
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (WW) NVIDIA:     used.
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (II) NVIDIA(0): NVIDIA GPU NVIDIA GeForce GTX 1650 (TU117-A) at PCI:1:0:0
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (II) NVIDIA(0):     (GPU-0)
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (--) NVIDIA(0): Memory: 4194304 kBytes
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (--) NVIDIA(0): VideoBIOS: 90.17.74.00.44
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (II) NVIDIA(0): Detected PCI Express Link width: 16X
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (--) NVIDIA(GPU-0): DFP-0: disconnected
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (==) NVIDIA(0):
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (==) NVIDIA(0):     will be used as the requested mode.
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (--) NVIDIA(0): No enabled display devices found; starting anyway because
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (--) NVIDIA(0):     AllowEmptyInitialConfiguration is enabled
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (II) NVIDIA(0): Validated MetaModes:
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (II) NVIDIA(0):     "NULL"
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (WW) NVIDIA(0): Unable to get display device for DPI computation.
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (WW) NVIDIA: Failed to bind sideband socket to
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (WW) NVIDIA:     '/var/run/nvidia-xdriver-221e91f7' Permission denied
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (II) NVIDIA:     access.
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (II) NVIDIA(0):     configuration option may not be set correctly.  When the
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (II) NVIDIA(0):     Config Options in the README.
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (II) NVIDIA(0): Setting mode "NULL"
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (==) NVIDIA(0): Disabling shared memory pixmaps
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (==) NVIDIA(0): Backing store enabled
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (==) NVIDIA(0): Silken mouse enabled
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (==) NVIDIA(0): DPMS enabled
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (II) NVIDIA(0): [DRI2] Setup complete
Jan 06 11:46:28 rrd-dell /usr/lib/gdm-x-session[1040]: (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
Jan 06 11:46:29 rrd-dell /usr/lib/gdm-x-session[1040]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event10)
Jan 06 11:46:29 rrd-dell /usr/lib/gdm-x-session[1040]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event11)
Jan 06 11:46:29 rrd-dell /usr/lib/gdm-x-session[1040]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event12)
Jan 06 11:46:29 rrd-dell /usr/lib/gdm-x-session[1040]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event13)
Jan 06 11:46:29 rrd-dell /usr/lib/gdm-x-session[1040]: (--) NVIDIA(GPU-0): DFP-0: disconnected
Jan 06 11:46:29 rrd-dell /usr/lib/gdm-x-session[1040]: (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
Jan 06 11:46:29 rrd-dell /usr/lib/gdm-x-session[1040]: (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
Jan 06 12:28:24 rrd-dell /usr/lib/gdm-x-session[1040]: (II) NVIDIA(GPU-0): Deleting GPU-0
they are blocked ( blocklist applied )
you should try in terminal
sudo manjaro-root -a
mhwd -a pci free 0300
mhwd -a pci nonfree 0300
exit ( end-chroot)
then reboot
It did not solved the problem.
Jan 06 14:53:27 rrd-dell kernel: audit: type=1400 audit(1641477207.370:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=303 comm="apparmor_pars
Jan 06 14:53:27 rrd-dell kernel: audit: type=1400 audit(1641477207.370:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=303 comm="apparmo
Jan 06 14:53:27 rrd-dell audit[303]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=303 comm="apparmor_parser"
Jan 06 14:53:27 rrd-dell audit[303]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=303 comm="apparmor_parser"
Jan 06 14:53:27 rrd-dell systemd-modules-load[285]: Module 'nvidia' is deny-listed
Jan 06 14:53:27 rrd-dell systemd-modules-load[285]: Module 'nvidia_drm' is deny-listed
Jan 06 14:53:27 rrd-dell systemd-modules-load[285]: Module 'nvidia_uvm' is deny-listed
Jan 06 14:53:28 rrd-dell kernel: input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input11
Jan 06 14:53:28 rrd-dell kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input12
Jan 06 14:53:28 rrd-dell kernel: input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input13
Jan 06 14:53:28 rrd-dell kernel: input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input14
Jan 06 14:53:30 rrd-dell /usr/lib/gdm-x-session[949]: (**) |-->Screen "nvidia" (0)
Jan 06 14:53:30 rrd-dell /usr/lib/gdm-x-session[949]: (**) |   |-->Device "nvidia"
Jan 06 14:53:30 rrd-dell /usr/lib/gdm-x-session[949]: (==) No monitor specified for screen "nvidia".
Jan 06 14:53:30 rrd-dell /usr/lib/gdm-x-session[949]: (**) ModulePath set to "/usr/lib/nvidia,/usr/lib32/nvidia,/usr/lib32/nvidia/xorg/modules,/usr/lib32/xorg/modules,/usr/lib64/nvidia/xorg
Jan 06 14:53:30 rrd-dell /usr/lib/gdm-x-session[949]: (II) LoadModule: "nvidia"
Jan 06 14:53:30 rrd-dell /usr/lib/gdm-x-session[949]: (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
Jan 06 14:53:30 rrd-dell /usr/lib/gdm-x-session[949]: (II) Module nvidia: vendor="NVIDIA Corporation"
Jan 06 14:53:30 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA dlloader X Driver  495.44  Fri Oct 22 06:11:21 UTC 2021
Jan 06 14:53:30 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
Jan 06 14:53:30 rrd-dell kernel: nvidia: module license 'NVIDIA' taints kernel.
Jan 06 14:53:30 rrd-dell kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 508
Jan 06 14:53:30 rrd-dell kernel: nvidia 0000:01:00.0: enabling device (0000 -> 0003)
Jan 06 14:53:30 rrd-dell kernel: nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
Jan 06 14:53:30 rrd-dell kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  495.44  Fri Oct 22 06:13:12 UTC 2021
Jan 06 14:53:30 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA(0): Creating default Display subsection in Screen section
Jan 06 14:53:30 rrd-dell /usr/lib/gdm-x-session[949]:         "nvidia" for depth/fbbpp 24/32
Jan 06 14:53:30 rrd-dell /usr/lib/gdm-x-session[949]: (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
Jan 06 14:53:30 rrd-dell /usr/lib/gdm-x-session[949]: (==) NVIDIA(0): RGB weight 888
Jan 06 14:53:30 rrd-dell /usr/lib/gdm-x-session[949]: (==) NVIDIA(0): Default visual is TrueColor
Jan 06 14:53:30 rrd-dell /usr/lib/gdm-x-session[949]: (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
Jan 06 14:53:30 rrd-dell /usr/lib/gdm-x-session[949]: (**) Option "AllowNVIDIAGpuScreens"
Jan 06 14:53:30 rrd-dell /usr/lib/gdm-x-session[949]: (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
Jan 06 14:53:30 rrd-dell /usr/lib/gdm-x-session[949]: (**) NVIDIA(0): Option "Coolbits" "28"
Jan 06 14:53:30 rrd-dell /usr/lib/gdm-x-session[949]: (**) NVIDIA(0): Enabling 2D acceleration
Jan 06 14:53:30 rrd-dell /usr/lib/gdm-x-session[949]: (II) Loading sub module "glxserver_nvidia"
Jan 06 14:53:30 rrd-dell /usr/lib/gdm-x-session[949]: (II) LoadModule: "glxserver_nvidia"
Jan 06 14:53:30 rrd-dell /usr/lib/gdm-x-session[949]: (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
Jan 06 14:53:30 rrd-dell /usr/lib/gdm-x-session[949]: (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
Jan 06 14:53:30 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA GLX Module  495.44  Fri Oct 22 06:08:29 UTC 2021
Jan 06 14:53:30 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA: The X server supports PRIME Render Offload.
Jan 06 14:53:31 rrd-dell kernel: nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  495.44  Fri Oct 22 06:05:22 UTC 2021
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (--) NVIDIA(0):     DFP-0
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (WW) NVIDIA: No DRM device: Direct render devices found but none could be
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (WW) NVIDIA:     used.
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA(0): NVIDIA GPU NVIDIA GeForce GTX 1650 (TU117-A) at PCI:1:0:0
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA(0):     (GPU-0)
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (--) NVIDIA(0): Memory: 4194304 kBytes
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (--) NVIDIA(0): VideoBIOS: 90.17.74.00.44
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA(0): Detected PCI Express Link width: 16X
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (--) NVIDIA(GPU-0): DFP-0: disconnected
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (==) NVIDIA(0):
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (==) NVIDIA(0):     will be used as the requested mode.
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (--) NVIDIA(0): No enabled display devices found; starting anyway because
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (--) NVIDIA(0):     AllowEmptyInitialConfiguration is enabled
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA(0): Validated MetaModes:
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA(0):     "NULL"
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (WW) NVIDIA(0): Unable to get display device for DPI computation.
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (WW) NVIDIA: Failed to bind sideband socket to
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (WW) NVIDIA:     '/var/run/nvidia-xdriver-8fc54020' Permission denied
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA:     access.
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA(0):     configuration option may not be set correctly.  When the
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA(0):     Config Options in the README.
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA(0): Setting mode "NULL"
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (==) NVIDIA(0): Disabling shared memory pixmaps
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (==) NVIDIA(0): Backing store enabled
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (==) NVIDIA(0): Silken mouse enabled
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (==) NVIDIA(0): DPMS enabled
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA(0): [DRI2] Setup complete
Jan 06 14:53:31 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
Jan 06 14:53:32 rrd-dell /usr/lib/gdm-x-session[949]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event8)
Jan 06 14:53:32 rrd-dell /usr/lib/gdm-x-session[949]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event9)
Jan 06 14:53:32 rrd-dell /usr/lib/gdm-x-session[949]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event10)
Jan 06 14:53:32 rrd-dell /usr/lib/gdm-x-session[949]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event11)
Jan 06 14:53:32 rrd-dell /usr/lib/gdm-x-session[949]: (--) NVIDIA(GPU-0): DFP-0: disconnected
Jan 06 14:53:32 rrd-dell /usr/lib/gdm-x-session[949]: (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
Jan 06 14:53:32 rrd-dell /usr/lib/gdm-x-session[949]: (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
Jan 06 14:53:58 rrd-dell /usr/lib/gdm-x-session[949]: (--) NVIDIA(GPU-0): DFP-0: disconnected
Jan 06 14:53:58 rrd-dell /usr/lib/gdm-x-session[949]: (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
Jan 06 14:53:58 rrd-dell /usr/lib/gdm-x-session[949]: (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
Jan 06 14:53:58 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA(0): Setting mode "NULL"
Jan 06 14:53:58 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
Jan 06 14:53:58 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
Jan 06 14:53:58 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA(0):     configuration option may not be set correctly.  When the
Jan 06 14:53:58 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
Jan 06 14:53:58 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
Jan 06 14:53:58 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
Jan 06 14:53:58 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
Jan 06 14:53:58 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA(0):     Config Options in the README.
Jan 06 14:56:25 rrd-dell /usr/lib/gdm-x-session[949]: (II) NVIDIA(GPU-0): Deleting GPU-0
Timeshif restore did not helped, so I run out of ideas. I try to save my files and reinstall Manjaro.
I face the same issue. Yesterday upgraded the system and today it failed to boot. I’m having NVidia card.
Solved the issue by following steps mentioned here.
root cause for my case:
python package build failed causing broken optimus manager.
Hope it helps.
It did not worked for me. I also have an nvidia (hybrid) system, so I guess my issue is also connacted.
I ended up reinstalling my system…
