I did a system update and my display on dual monitors is going out of phase every time I move a window or open a menu or just interacting.
I have a youtube video to show the problem.
intel 2500K
24GB of ram
Gigabyte RX570
KDE Plasma
Using the screenshot utility doesn’t capture the problem so it has be something between the gpu and software.
What I have done so far, disabled the KDE compositor and deleted X.org conf, chanage kernel from 5.10 to 5.13 and disabled one monitor, did not fix.
[ 5.911] (--) Log file renamed from "/var/log/Xorg.pid-852.log" to "/var/log/Xorg.0.log"
[ 5.913]
X.Org X Server 1.20.13
[ 5.913] Build Operating System: Linux Manjaro Linux
[ 5.913] Current Operating System: Linux rebel86 5.13.11-1-MANJARO #1 SMP PREEMPT Sun Aug 15 13:15:18 UTC 2021 x86_64
[ 5.913] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.13-x86_64 root=UUID=58da84de-c2fc-44cd-acc5-1945a49da60a rw quiet apparmor=1 security=apparmor udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff
[ 5.913] Build Date: 29 July 2021 08:07:46PM
[ 5.913]
[ 5.913] Current version of pixman: 0.40.0
[ 5.913] Before reporting problems, check http://wiki.x.org
[ 5.913] Markers: (--) probed, (**) from config file, (==) default setting,
[ 5.913] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Aug 20 14:18:20 2021
[ 5.915] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 5.915] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 5.916] (==) No Layout section. Using the first Screen section.
[ 5.916] (==) No screen section available. Using defaults.
[ 5.916] (**) |-->Screen "Default Screen Section" (0)
[ 5.916] (**) | |-->Monitor "<default monitor>"
[ 5.916] (==) No monitor specified for screen "Default Screen Section".
[ 5.916] (==) Automatically adding devices
[ 5.916] (==) Automatically enabling devices
[ 5.916] (==) Automatically adding GPU devices
[ 5.916] (==) Automatically binding GPU devices
[ 5.916] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 5.918] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 5.918] Entry deleted from font path.
[ 5.918] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 5.918] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[ 5.918] (Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[ 5.918] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[ 5.918] (Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[ 5.918] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 5.918] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 5.918] (II) The server relies on udev to provide the list of input devices.
[ 5.918] (II) Module ABI versions:
[ 5.918] X.Org ANSI C Emulation: 0.4
[ 5.918] X.Org Video Driver: 24.1
[ 5.918] X.Org XInput driver : 24.1
[ 5.918] X.Org Server Extension : 10.0
[ 5.919] (++) using VT number 1
[ 5.919] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 5.919] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 5.935] (--) PCI:*(1@0:0:0) 1002:67df:1458:22f0 rev 239, Mem @ 0xd0000000/268435456, 0xefe00000/2097152, 0xfbc80000/262144, I/O @ 0x0000ee00/256, BIOS @ 0x????????/131072
[ 5.935] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 5.935] (II) LoadModule: "glx"
[ 5.937] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 5.942] (II) Module glx: vendor="X.Org Foundation"
[ 5.943] compiled for 1.20.13, module version = 1.0.0
[ 5.943] ABI class: X.Org Server Extension, version 10.0
[ 5.943] (II) Applying OutputClass "AMDgpu" to /dev/dri/card0
[ 5.943] loading driver: amdgpu
[ 5.943] (==) Matched amdgpu as autoconfigured driver 0
[ 5.943] (==) Matched ati as autoconfigured driver 1
[ 5.943] (==) Matched modesetting as autoconfigured driver 2
[ 5.943] (==) Matched fbdev as autoconfigured driver 3
[ 5.943] (==) Matched vesa as autoconfigured driver 4
[ 5.943] (==) Assigned the driver to the xf86ConfigLayout
[ 5.943] (II) LoadModule: "amdgpu"
[ 5.943] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[ 5.944] (II) Module amdgpu: vendor="X.Org Foundation"
[ 5.944] compiled for 1.20.13, module version = 21.0.0
[ 5.944] Module class: X.Org Video Driver
[ 5.944] ABI class: X.Org Video Driver, version 24.1
[ 5.944] (II) LoadModule: "ati"
[ 5.944] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[ 5.944] (II) Module ati: vendor="X.Org Foundation"
[ 5.944] compiled for 1.20.8, module version = 19.1.0
[ 5.950] (II) LoadModule: "modesetting"
[ 5.950] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 5.951] (II) Module modesetting: vendor="X.Org Foundation"
[ 5.951] compiled for 1.20.13, module version = 1.20.13
[ 5.951] Module class: X.Org Video Driver
[ 5.951] ABI class: X.Org Video Driver, version 24.1
[ 5.951] (II) LoadModule: "fbdev"
[ 5.953] (WW) Warning, couldn't open module fbdev
[ 5.953] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 5.953] (II) LoadModule: "vesa"
[ 5.953] (WW) Warning, couldn't open module vesa
[ 5.953] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 5.953] (II) AMDGPU: Driver for AMD Radeon:
All GPUs supported by the amdgpu kernel driver
[ 5.953] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 5.954] (WW) Falling back to old probe method for modesetting
[ 5.954] (II) AMDGPU(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 5.954] (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[ 5.954] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[ 5.954] (==) AMDGPU(0): Default visual is TrueColor
[ 5.954] (==) AMDGPU(0): RGB weight 888
[ 5.954] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[ 5.954] (--) AMDGPU(0): Chipset: "Radeon RX 570 Series" (ChipID = 0x67df)
[ 5.954] (II) Loading sub module "fb"
[ 5.954] (II) LoadModule: "fb"
[ 5.954] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 5.955] (II) Module fb: vendor="X.Org Foundation"
[ 5.955] compiled for 1.20.13, module version = 1.0.0
[ 5.955] ABI class: X.Org ANSI C Emulation, version 0.4
[ 5.955] (II) Loading sub module "dri2"
[ 5.955] (II) LoadModule: "dri2"
[ 5.955] (II) Module "dri2" already built-in
[ 5.960] (II) Loading sub module "glamoregl"
[ 5.960] (II) LoadModule: "glamoregl"
[ 5.960] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 5.966] (II) Module glamoregl: vendor="X.Org Foundation"
[ 5.966] compiled for 1.20.13, module version = 1.0.1
[ 5.966] ABI class: X.Org ANSI C Emulation, version 0.4
[ 6.244] (II) AMDGPU(0): glamor X acceleration enabled on Radeon RX 570 Series
[ 6.244] (II) AMDGPU(0): glamor detected, initialising EGL layer.
[ 6.244] (==) AMDGPU(0): TearFree property default: auto
[ 6.244] (==) AMDGPU(0): VariableRefresh: disabled
[ 6.244] (II) AMDGPU(0): KMS Pageflipping: enabled
[ 6.244] (II) AMDGPU(0): Output DisplayPort-0 has no monitor section
[ 6.244] (II) AMDGPU(0): Output DisplayPort-1 has no monitor section
[ 6.244] (II) AMDGPU(0): Output DisplayPort-2 has no monitor section
[ 6.245] (II) AMDGPU(0): Output HDMI-A-0 has no monitor section
[ 6.245] (II) AMDGPU(0): Output DVI-D-0 has no monitor section
[ 6.251] (II) AMDGPU(0): EDID for output DisplayPort-0
[ 6.251] (II) AMDGPU(0): EDID for output DisplayPort-1
[ 6.251] (II) AMDGPU(0): EDID for output DisplayPort-2
[ 6.251] (II) AMDGPU(0): EDID for output HDMI-A-0
[ 6.251] (II) AMDGPU(0): Manufacturer: ACR Model: 9a Serial#: 2439096166
[ 6.251] (II) AMDGPU(0): Year: 2009 Week: 16
[ 6.251] (II) AMDGPU(0): EDID Version: 1.3
[ 6.251] (II) AMDGPU(0): Digital Display Input
[ 6.251] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 51 vert.: 29
[ 6.251] (II) AMDGPU(0): Gamma: 2.20
[ 6.251] (II) AMDGPU(0): DPMS capabilities: StandBy Suspend Off
[ 6.251] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 6.251] (II) AMDGPU(0): First detailed timing is preferred mode
[ 6.251] (II) AMDGPU(0): redX: 0.649 redY: 0.338 greenX: 0.289 greenY: 0.609
[ 6.251] (II) AMDGPU(0): blueX: 0.146 blueY: 0.070 whiteX: 0.313 whiteY: 0.329
[ 6.251] (II) AMDGPU(0): Supported established timings:
[ 6.251] (II) AMDGPU(0): 720x400@70Hz
[ 6.251] (II) AMDGPU(0): 640x480@60Hz
[ 6.251] (II) AMDGPU(0): 640x480@67Hz
[ 6.251] (II) AMDGPU(0): 800x600@56Hz
[ 6.251] (II) AMDGPU(0): 800x600@60Hz
[ 6.251] (II) AMDGPU(0): 1024x768@60Hz
[ 6.251] (II) AMDGPU(0): 1024x768@70Hz
[ 6.251] (II) AMDGPU(0): Manufacturer's mask: 0
[ 6.251] (II) AMDGPU(0): Supported standard timings:
[ 6.251] (II) AMDGPU(0): #0: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 6.251] (II) AMDGPU(0): #1: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 6.251] (II) AMDGPU(0): #2: hsize: 1280 vsize 800 refresh: 60 vid: 129
[ 6.251] (II) AMDGPU(0): #3: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 6.251] (II) AMDGPU(0): #4: hsize: 1600 vsize 1200 refresh: 60 vid: 16553
[ 6.251] (II) AMDGPU(0): Supported detailed timing:
[ 6.251] (II) AMDGPU(0): clock: 148.5 MHz Image Size: 510 x 287 mm
[ 6.251] (II) AMDGPU(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 6.251] (II) AMDGPU(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 6.251] (II) AMDGPU(0): Monitor name: X233H
[ 6.251] (II) AMDGPU(0): Ranges: V min: 56 V max: 76 Hz, H min: 31 H max: 83 kHz, PixClock max 185 MHz
[ 6.251] (II) AMDGPU(0): Serial No: LFM0C0234040
[ 6.251] (II) AMDGPU(0): clock: 27.0 MHz Image Size: 510 x 287 mm
[ 6.251] (II) AMDGPU(0): h_active: 720 h_sync: 736 h_sync_end 798 h_blank_end 858 h_border: 0
[ 6.251] (II) AMDGPU(0): v_active: 480 v_sync: 489 v_sync_end 495 v_blanking: 525 v_border: 0
[ 6.251] (II) AMDGPU(0): clock: 74.2 MHz Image Size: 510 x 287 mm
[ 6.251] (II) AMDGPU(0): h_active: 1280 h_sync: 1390 h_sync_end 1430 h_blank_end 1650 h_border: 0
[ 6.251] (II) AMDGPU(0): v_active: 720 v_sync: 725 v_sync_end 730 v_blanking: 750 v_border: 0
[ 6.251] (II) AMDGPU(0): v_active: 540 v_sync: 542 v_sync_end 547 v_blanking: 562 v_border: 0
[ 6.251] (II) AMDGPU(0): h_active: 1280 h_sync: 1720 h_sync_end 1760 h_blank_end 1980 h_border: 0
[ 6.251] (II) AMDGPU(0): h_active: 1920 h_sync: 1972 h_sync_end 2016 h_blank_end 2640 h_border: 0
[ 6.251] (II) AMDGPU(0): Number of EDID sections to follow: 1
[ 6.251] (II) AMDGPU(0): EDID (in hex):
[ 6.251] (II) AMDGPU(0): 00ffffffffffff0004729a0066a76191
[ 6.251] (II) AMDGPU(0): 1013010380331d78ea6085a6564a9c25
[ 6.251] (II) AMDGPU(0): 125054b30c008180714f81009500a940
[ 6.251] (II) AMDGPU(0): 010101010101023a801871382d40582c
[ 6.251] (II) AMDGPU(0): 4500fe1f1100001a000000fc00583233
[ 6.251] (II) AMDGPU(0): 33480a20202020202020000000fd0038
[ 6.251] (II) AMDGPU(0): 4c1f5312000a202020202020000000ff
[ 6.251] (II) AMDGPU(0): 004c464d3043303233343034300a01d6
[ 6.251] (II) AMDGPU(0): 020322f223097f074e01020384050607
[ 6.251] (II) AMDGPU(0): 10111215931f148301000066030c0012
[ 6.251] (II) AMDGPU(0): 00108c0ad08a20e02d10103e9600fe1f
[ 6.251] (II) AMDGPU(0): 11000018011d007251d01e206e285500
[ 6.251] (II) AMDGPU(0): fe1f1100001e011d8018711c1620582c
[ 6.251] (II) AMDGPU(0): 2500fe1f1100009e011d00bc52d01e20
[ 6.251] (II) AMDGPU(0): b8285540fe1f1100001e011d80d0721c
[ 6.251] (II) AMDGPU(0): 1620342c2500fe1f1100009e00000039
[ 6.251] (II) AMDGPU(0): Printing probed modes for output HDMI-A-0
[ 6.251] (II) AMDGPU(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync -vsync (67.5 kHz eP)
[ 6.251] (II) AMDGPU(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 6.251] (II) AMDGPU(0): Modeline "1920x1080"x50.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 6.251] (II) AMDGPU(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 6.251] (II) AMDGPU(0): Modeline "1600x1200"x60.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 6.251] (II) AMDGPU(0): Modeline "1680x1050"x60.0 148.50 1680 2008 2052 2200 1050 1084 1089 1125 +hsync -vsync (67.5 kHz e)
[ 6.251] (II) AMDGPU(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 6.251] (II) AMDGPU(0): Modeline "1440x900"x59.9 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 6.251] (II) AMDGPU(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz e)
[ 6.251] (II) AMDGPU(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 6.251] (II) AMDGPU(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 6.251] (II) AMDGPU(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 6.251] (II) AMDGPU(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 6.251] (II) AMDGPU(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 6.251] (II) AMDGPU(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 6.251] (II) AMDGPU(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 6.251] (II) AMDGPU(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 6.251] (II) AMDGPU(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 6.251] (II) AMDGPU(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 6.251] (II) AMDGPU(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 6.251] (II) AMDGPU(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 6.251] (II) AMDGPU(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 6.251] (II) AMDGPU(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 6.251] (II) AMDGPU(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 6.252] (II) AMDGPU(0): EDID for output DVI-D-0
[ 6.252] (II) AMDGPU(0): Manufacturer: WDE Model: 2202 Serial#: 16843009
[ 6.252] (II) AMDGPU(0): Year: 2006 Week: 28
[ 6.252] (II) AMDGPU(0): EDID Version: 1.3
[ 6.252] (II) AMDGPU(0): Digital Display Input
[ 6.252] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 47 vert.: 30
[ 6.252] (II) AMDGPU(0): Gamma: 2.20
[ 6.252] (II) AMDGPU(0): DPMS capabilities: Off
[ 6.252] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 6.252] (II) AMDGPU(0): Default color space is primary color space
[ 6.252] (II) AMDGPU(0): First detailed timing is preferred mode
[ 6.252] (II) AMDGPU(0): redX: 0.644 redY: 0.348 greenX: 0.286 greenY: 0.603
[ 6.252] (II) AMDGPU(0): blueX: 0.143 blueY: 0.070 whiteX: 0.313 whiteY: 0.329
[ 6.252] (II) AMDGPU(0): Supported established timings:
[ 6.252] (II) AMDGPU(0): 720x400@70Hz
[ 6.252] (II) AMDGPU(0): 640x480@60Hz
[ 6.252] (II) AMDGPU(0): 640x480@67Hz
[ 6.252] (II) AMDGPU(0): 640x480@72Hz
[ 6.252] (II) AMDGPU(0): 640x480@75Hz
[ 6.252] (II) AMDGPU(0): 800x600@56Hz
[ 6.252] (II) AMDGPU(0): 800x600@60Hz
[ 6.252] (II) AMDGPU(0): 800x600@72Hz
[ 6.252] (II) AMDGPU(0): 800x600@75Hz
[ 6.252] (II) AMDGPU(0): 832x624@75Hz
[ 6.252] (II) AMDGPU(0): 1024x768@60Hz
[ 6.252] (II) AMDGPU(0): 1024x768@70Hz
[ 6.252] (II) AMDGPU(0): 1024x768@75Hz
[ 6.252] (II) AMDGPU(0): 1280x1024@75Hz
[ 6.252] (II) AMDGPU(0): Manufacturer's mask: 0
[ 6.252] (II) AMDGPU(0): Supported standard timings:
[ 6.252] (II) AMDGPU(0): #0: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 6.252] (II) AMDGPU(0): #1: hsize: 1280 vsize 960 refresh: 60 vid: 16513
[ 6.252] (II) AMDGPU(0): #2: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 6.252] (II) AMDGPU(0): #3: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 6.252] (II) AMDGPU(0): #4: hsize: 1440 vsize 900 refresh: 75 vid: 3989
[ 6.252] (II) AMDGPU(0): #5: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 6.252] (II) AMDGPU(0): #6: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 6.252] (II) AMDGPU(0): Supported detailed timing:
[ 6.252] (II) AMDGPU(0): clock: 146.2 MHz Image Size: 473 x 296 mm
[ 6.252] (II) AMDGPU(0): h_active: 1680 h_sync: 1784 h_sync_end 1960 h_blank_end 2240 h_border: 0
[ 6.252] (II) AMDGPU(0): v_active: 1050 v_sync: 1053 v_sync_end 1059 v_blanking: 1089 v_border: 0
[ 6.252] (II) AMDGPU(0): Serial No: 0
[ 6.252] (II) AMDGPU(0): Ranges: V min: 56 V max: 67 Hz, H min: 30 H max: 82 kHz, PixClock max 165 MHz
[ 6.252] (II) AMDGPU(0): Monitor name: LCM-22w2
[ 6.252] (II) AMDGPU(0): EDID (in hex):
[ 6.252] (II) AMDGPU(0): 00ffffffffffff005c85022201010101
[ 6.252] (II) AMDGPU(0): 1c100103e82f1e782ec585a459499a24
[ 6.252] (II) AMDGPU(0): 125054bfef0081808140714f9500950f
[ 6.252] (II) AMDGPU(0): b30081c0010121399030621a274068b0
[ 6.252] (II) AMDGPU(0): 3600d9281100001c000000ff00300a20
[ 6.252] (II) AMDGPU(0): 20202020202020202020000000fd0038
[ 6.252] (II) AMDGPU(0): 431e5210000a202020202020000000fc
[ 6.252] (II) AMDGPU(0): 004c434d2d323277320a20202020001f
[ 6.252] (II) AMDGPU(0): Printing probed modes for output DVI-D-0
[ 6.252] (II) AMDGPU(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz eP)
[ 6.252] (II) AMDGPU(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 6.252] (II) AMDGPU(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 6.252] (II) AMDGPU(0): Modeline "1440x900"x75.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz e)
[ 6.252] (II) AMDGPU(0): Modeline "1440x900"x59.9 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 6.252] (II) AMDGPU(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 6.252] (II) AMDGPU(0): Modeline "1280x800"x60.0 146.25 1280 1784 1960 2240 800 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 6.252] (II) AMDGPU(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 6.252] (II) AMDGPU(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 6.252] (II) AMDGPU(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 6.252] (II) AMDGPU(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 6.252] (II) AMDGPU(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 6.252] (II) AMDGPU(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 6.252] (II) AMDGPU(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 6.252] (II) AMDGPU(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 6.252] (II) AMDGPU(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 6.252] (II) AMDGPU(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 6.252] (II) AMDGPU(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 6.252] (II) AMDGPU(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 6.252] (II) AMDGPU(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 6.252] (II) AMDGPU(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 6.252] (II) AMDGPU(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 6.252] (II) AMDGPU(0): Output DisplayPort-0 disconnected
[ 6.252] (II) AMDGPU(0): Output DisplayPort-1 disconnected
[ 6.252] (II) AMDGPU(0): Output DisplayPort-2 disconnected
[ 6.252] (II) AMDGPU(0): Output HDMI-A-0 connected
[ 6.252] (II) AMDGPU(0): Output DVI-D-0 connected
[ 6.252] (II) AMDGPU(0): Using spanning desktop for initial modes
[ 6.252] (II) AMDGPU(0): Output HDMI-A-0 using initial mode 1920x1080 +0+0
[ 6.252] (II) AMDGPU(0): Output DVI-D-0 using initial mode 1680x1050 +1920+0
[ 6.252] (II) AMDGPU(0): mem size init: gart size :ffc3a000 vram size: s:feae7000 visible:fad0000
[ 6.252] (==) AMDGPU(0): DPI set to (96, 96)
[ 6.252] (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
[ 6.252] (II) Loading sub module "ramdac"
[ 6.252] (II) LoadModule: "ramdac"
[ 6.252] (II) Module "ramdac" already built-in
[ 6.252] (II) UnloadModule: "modesetting"
[ 6.252] (II) Unloading modesetting
[ 6.252] (II) AMDGPU(0): [DRI2] Setup complete
[ 6.252] (II) AMDGPU(0): [DRI2] DRI driver: radeonsi
[ 6.252] (II) AMDGPU(0): [DRI2] VDPAU driver: radeonsi
[ 6.252] (II) AMDGPU(0): Front buffer pitch: 15360 bytes
[ 6.254] (II) AMDGPU(0): SYNC extension fences enabled
[ 6.254] (II) AMDGPU(0): Present extension enabled
[ 6.254] (==) AMDGPU(0): DRI3 enabled
[ 6.254] (==) AMDGPU(0): Backing store enabled
[ 6.254] (II) AMDGPU(0): Direct rendering enabled
[ 6.311] (II) AMDGPU(0): Use GLAMOR acceleration.
[ 6.311] (II) AMDGPU(0): Acceleration enabled
[ 6.311] (==) AMDGPU(0): DPMS enabled
[ 6.311] (==) AMDGPU(0): Silken mouse disabled
[ 6.311] (II) AMDGPU(0): Set up textured video (glamor)
[ 6.318] (II) Initializing extension Generic Event Extension
[ 6.318] (II) Initializing extension SHAPE
[ 6.318] (II) Initializing extension MIT-SHM
[ 6.318] (II) Initializing extension XInputExtension
[ 6.318] (II) Initializing extension XTEST
[ 6.318] (II) Initializing extension BIG-REQUESTS
[ 6.318] (II) Initializing extension SYNC
[ 6.318] (II) Initializing extension XKEYBOARD
[ 6.318] (II) Initializing extension XC-MISC
[ 6.318] (II) Initializing extension SECURITY
[ 6.319] (II) Initializing extension XFIXES
[ 6.319] (II) Initializing extension RENDER
[ 6.319] (II) Initializing extension RANDR
[ 6.319] (II) Initializing extension COMPOSITE
[ 6.319] (II) Initializing extension DAMAGE
[ 6.319] (II) Initializing extension MIT-SCREEN-SAVER
[ 6.319] (II) Initializing extension DOUBLE-BUFFER
[ 6.319] (II) Initializing extension RECORD
[ 6.319] (II) Initializing extension DPMS
[ 6.319] (II) Initializing extension Present
[ 6.319] (II) Initializing extension DRI3
[ 6.319] (II) Initializing extension X-Resource
[ 6.319] (II) Initializing extension XVideo
[ 6.319] (II) Initializing extension XVideo-MotionCompensation
[ 6.319] (II) Initializing extension GLX
[ 6.545] (II) AIGLX: Loaded and initialized radeonsi
[ 6.545] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 6.545] (II) Initializing extension XFree86-VidModeExtension
[ 6.545] (II) Initializing extension XFree86-DGA
[ 6.545] (II) Initializing extension XFree86-DRI
[ 6.545] (II) Initializing extension DRI2
[ 6.547] (II) AMDGPU(0): Setting screen physical size to 952 x 285
[ 6.605] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 6.605] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 6.605] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 6.605] (**) Power Button: Applying InputClass "system-keyboard"
[ 6.605] (II) LoadModule: "libinput"
[ 6.605] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 6.608] (II) Module libinput: vendor="X.Org Foundation"
[ 6.608] compiled for 1.20.11, module version = 1.1.0
[ 6.608] Module class: X.Org XInput Driver
[ 6.608] ABI class: X.Org XInput driver, version 24.1
[ 6.608] (II) Using input driver 'libinput' for 'Power Button'
[ 6.608] (**) Power Button: always reports core events
[ 6.608] (**) Option "Device" "/dev/input/event1"
[ 6.609] (**) Option "_source" "server/udev"
[ 6.616] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 6.616] (II) event1 - Power Button: device is a keyboard
[ 6.616] (II) event1 - Power Button: device removed
[ 6.647] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 6.647] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 6.647] (**) Option "xkb_model" "pc105"
[ 6.647] (**) Option "xkb_layout" "us"
[ 6.648] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 6.648] (II) event1 - Power Button: device is a keyboard
[ 6.648] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 6.648] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 6.648] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 6.648] (**) Power Button: Applying InputClass "system-keyboard"
[ 6.648] (II) Using input driver 'libinput' for 'Power Button'
[ 6.648] (**) Power Button: always reports core events
[ 6.648] (**) Option "Device" "/dev/input/event0"
[ 6.648] (**) Option "_source" "server/udev"
[ 6.649] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 6.649] (II) event0 - Power Button: device is a keyboard
[ 6.649] (II) event0 - Power Button: device removed
[ 6.677] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 6.677] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 6.677] (**) Option "xkb_model" "pc105"
[ 6.677] (**) Option "xkb_layout" "us"
[ 6.678] (II) event0 - Power Button: is tagged by udev as: Keyboard
[ 6.678] (II) event0 - Power Button: device is a keyboard
[ 6.678] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=3 (/dev/input/event7)
[ 6.678] (II) No input driver specified, ignoring this device.
[ 6.678] (II) This device may have been added with another device file.
[ 6.679] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=7 (/dev/input/event8)
[ 6.679] (II) No input driver specified, ignoring this device.
[ 6.679] (II) This device may have been added with another device file.
[ 6.679] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=8 (/dev/input/event9)
[ 6.679] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=9 (/dev/input/event10)
[ 6.679] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=10 (/dev/input/event11)
[ 6.680] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=11 (/dev/input/event12)
[ 6.680] (II) No input driver specified, ignoring this device.
[ 6.680] (II) This device may have been added with another device file.
[ 6.680] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event13)
[ 6.680] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event14)
[ 6.680] (II) config/udev: Adding input device HDA Intel PCH Line (/dev/input/event15)
[ 6.681] (II) config/udev: Adding input device HDA Intel PCH Line Out Front (/dev/input/event16)
[ 6.681] (II) No input driver specified, ignoring this device.
[ 6.681] (II) This device may have been added with another device file.
[ 6.681] (II) config/udev: Adding input device HDA Intel PCH Line Out Surround (/dev/input/event17)
[ 6.681] (II) config/udev: Adding input device HDA Intel PCH Line Out CLFE (/dev/input/event18)
[ 6.681] (II) config/udev: Adding input device HDA Intel PCH Line Out Side (/dev/input/event19)
[ 6.682] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event20)
[ 6.682] (II) No input driver specified, ignoring this device.
[ 6.682] (II) This device may have been added with another device file.
[ 6.682] (II) config/udev: Adding input device C-Media USB Audio Device (/dev/input/event2)
[ 6.682] (**) C-Media USB Audio Device : Applying InputClass "evdev keyboard catchall"
[ 6.682] (**) C-Media USB Audio Device : Applying InputClass "libinput keyboard catchall"
[ 6.682] (**) C-Media USB Audio Device : Applying InputClass "system-keyboard"
[ 6.682] (II) Using input driver 'libinput' for 'C-Media USB Audio Device '
[ 6.682] (**) C-Media USB Audio Device : always reports core events
[ 6.682] (**) Option "Device" "/dev/input/event2"
[ 6.682] (**) Option "_source" "server/udev"
[ 6.683] (II) event2 - C-Media USB Audio Device : is tagged by udev as: Keyboard
[ 6.683] (II) event2 - C-Media USB Audio Device : device is a keyboard
[ 6.683] (II) event2 - C-Media USB Audio Device : device removed
[ 6.787] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.7/2-1.7:1.3/0003:0D8C:0008.0001/input/input2/event2"
[ 6.787] (II) XINPUT: Adding extended input device "C-Media USB Audio Device " (type: KEYBOARD, id 8)
[ 6.787] (**) Option "xkb_model" "pc105"
[ 6.787] (**) Option "xkb_layout" "us"
[ 6.788] (II) event2 - C-Media USB Audio Device : is tagged by udev as: Keyboard
[ 6.788] (II) event2 - C-Media USB Audio Device : device is a keyboard
[ 6.789] (II) config/udev: Adding input device PC Speaker (/dev/input/event6)
[ 6.789] (II) No input driver specified, ignoring this device.
[ 6.789] (II) This device may have been added with another device file.
[ 6.794] (II) config/udev: removing device C-Media USB Audio Device
[ 6.794] (II) event2 - C-Media USB Audio Device : device removed
[ 6.847] (II) UnloadModule: "libinput"
[ 6.847] (II) config/udev: Adding input device C-Media USB Audio Device (/dev/input/event2)
[ 6.848] (**) C-Media USB Audio Device : Applying InputClass "evdev keyboard catchall"
[ 6.848] (**) C-Media USB Audio Device : Applying InputClass "libinput keyboard catchall"
[ 6.848] (**) C-Media USB Audio Device : Applying InputClass "system-keyboard"
[ 6.848] (II) Using input driver 'libinput' for 'C-Media USB Audio Device '
[ 6.848] (**) C-Media USB Audio Device : always reports core events
[ 6.848] (**) Option "Device" "/dev/input/event2"
[ 6.848] (**) Option "_source" "server/udev"
[ 6.848] (II) event2 - C-Media USB Audio Device : is tagged by udev as: Keyboard
[ 6.848] (II) event2 - C-Media USB Audio Device : device is a keyboard
[ 6.849] (II) event2 - C-Media USB Audio Device : device removed
[ 6.894] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.7/2-1.7:1.3/0003:0D8C:0008.0001/input/input2/event2"
[ 6.894] (II) XINPUT: Adding extended input device "C-Media USB Audio Device " (type: KEYBOARD, id 8)
[ 6.894] (**) Option "xkb_model" "pc105"
[ 6.894] (**) Option "xkb_layout" "us"
[ 6.895] (II) event2 - C-Media USB Audio Device : is tagged by udev as: Keyboard
[ 6.895] (II) event2 - C-Media USB Audio Device : device is a keyboard
[ 6.896] (II) config/udev: Adding input device HID 0c45:7403 (/dev/input/mouse0)
[ 6.896] (II) No input driver specified, ignoring this device.
[ 6.896] (II) This device may have been added with another device file.
[ 6.911] (II) config/udev: Adding input device HID 0c45:7403 (/dev/input/event3)
[ 6.911] (**) HID 0c45:7403: Applying InputClass "evdev keyboard catchall"
[ 6.911] (**) HID 0c45:7403: Applying InputClass "libinput keyboard catchall"
[ 6.911] (**) HID 0c45:7403: Applying InputClass "system-keyboard"
[ 6.911] (II) Using input driver 'libinput' for 'HID 0c45:7403'
[ 6.911] (**) HID 0c45:7403: always reports core events
[ 6.911] (**) Option "Device" "/dev/input/event3"
[ 6.911] (**) Option "_source" "server/udev"
[ 6.912] (II) event3 - HID 0c45:7403: is tagged by udev as: Keyboard
[ 6.912] (II) event3 - HID 0c45:7403: device is a keyboard
[ 6.913] (II) event3 - HID 0c45:7403: device removed
[ 6.940] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.8/2-1.8.2/2-1.8.2:1.0/0003:0C45:7403.0002/input/input3/event3"
[ 6.940] (II) XINPUT: Adding extended input device "HID 0c45:7403" (type: KEYBOARD, id 9)
[ 6.940] (**) Option "xkb_model" "pc105"
[ 6.940] (**) Option "xkb_layout" "us"
[ 6.942] (II) event3 - HID 0c45:7403: is tagged by udev as: Keyboard
[ 6.942] (II) event3 - HID 0c45:7403: device is a keyboard
[ 6.977] (II) config/udev: Adding input device HID 0c45:7403 (/dev/input/event4)
[ 6.977] (**) HID 0c45:7403: Applying InputClass "evdev pointer catchall"
[ 6.977] (**) HID 0c45:7403: Applying InputClass "libinput pointer catchall"
[ 6.977] (II) Using input driver 'libinput' for 'HID 0c45:7403'
[ 6.977] (**) HID 0c45:7403: always reports core events
[ 6.977] (**) Option "Device" "/dev/input/event4"
[ 6.977] (**) Option "_source" "server/udev"
[ 7.031] (II) event4 - HID 0c45:7403: is tagged by udev as: Mouse
[ 7.031] (II) event4 - HID 0c45:7403: device is a pointer
[ 7.032] (II) event4 - HID 0c45:7403: device removed
[ 7.074] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.8/2-1.8.2/2-1.8.2:1.1/0003:0C45:7403.0003/input/input4/event4"
[ 7.074] (II) XINPUT: Adding extended input device "HID 0c45:7403" (type: MOUSE, id 10)
[ 7.074] (**) Option "AccelerationScheme" "none"
[ 7.074] (**) HID 0c45:7403: (accel) selected scheme none/0
[ 7.074] (**) HID 0c45:7403: (accel) acceleration factor: 2.000
[ 7.074] (**) HID 0c45:7403: (accel) acceleration threshold: 4
[ 7.131] (II) event4 - HID 0c45:7403: is tagged by udev as: Mouse
[ 7.131] (II) event4 - HID 0c45:7403: device is a pointer
[ 7.415] (II) config/udev: Adding input device Logitech G604 (/dev/input/mouse1)
[ 7.415] (**) Logitech G604 : Applying InputClass "system-keyboard"
[ 7.415] (II) No input driver specified, ignoring this device.
[ 7.415] (II) This device may have been added with another device file.
[ 7.447] (II) config/udev: Adding input device Logitech G604 (/dev/input/event5)
[ 7.447] (**) Logitech G604 : Applying InputClass "evdev pointer catchall"
[ 7.447] (**) Logitech G604 : Applying InputClass "evdev keyboard catchall"
[ 7.447] (**) Logitech G604 : Applying InputClass "libinput pointer catchall"
[ 7.447] (**) Logitech G604 : Applying InputClass "libinput keyboard catchall"
[ 7.447] (**) Logitech G604 : Applying InputClass "system-keyboard"
[ 7.447] (II) Using input driver 'libinput' for 'Logitech G604 '
[ 7.447] (**) Logitech G604 : always reports core events
[ 7.447] (**) Option "Device" "/dev/input/event5"
[ 7.447] (**) Option "_source" "server/udev"
[ 7.449] (II) event5 - Logitech G604 : is tagged by udev as: Keyboard Mouse
[ 7.449] (II) event5 - Logitech G604 : device is a pointer
[ 7.449] (II) event5 - Logitech G604 : device is a keyboard
[ 7.449] (II) event5 - Logitech G604 : device removed
[ 7.461] (II) libinput: Logitech G604 : needs a virtual subdevice
[ 7.461] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.8/2-1.8.1/2-1.8.1.7/2-1.8.1.7:1.2/0003:046D:C539.0007/0003:046D:4085.0008/input/input15/event5"
[ 7.461] (II) XINPUT: Adding extended input device "Logitech G604 " (type: MOUSE, id 11)
[ 7.461] (**) Option "AccelerationScheme" "none"
[ 7.461] (**) Logitech G604 : (accel) selected scheme none/0
[ 7.461] (**) Logitech G604 : (accel) acceleration factor: 2.000
[ 7.461] (**) Logitech G604 : (accel) acceleration threshold: 4
[ 7.462] (II) event5 - Logitech G604 : is tagged by udev as: Keyboard Mouse
[ 7.462] (II) event5 - Logitech G604 : device is a pointer
[ 7.462] (II) event5 - Logitech G604 : device is a keyboard
[ 7.462] (**) Logitech G604 : Applying InputClass "evdev pointer catchall"
[ 7.462] (**) Logitech G604 : Applying InputClass "evdev keyboard catchall"
[ 7.462] (**) Logitech G604 : Applying InputClass "libinput pointer catchall"
[ 7.462] (**) Logitech G604 : Applying InputClass "libinput keyboard catchall"
[ 7.462] (**) Logitech G604 : Applying InputClass "system-keyboard"
[ 7.462] (II) Using input driver 'libinput' for 'Logitech G604 '
[ 7.462] (**) Logitech G604 : always reports core events
[ 7.462] (**) Option "Device" "/dev/input/event5"
[ 7.462] (**) Option "_source" "_driver/libinput"
[ 7.462] (II) libinput: Logitech G604 : is a virtual subdevice
[ 7.462] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.8/2-1.8.1/2-1.8.1.7/2-1.8.1.7:1.2/0003:046D:C539.0007/0003:046D:4085.0008/input/input15/event5"
[ 7.462] (II) XINPUT: Adding extended input device "Logitech G604 " (type: KEYBOARD, id 12)
[ 7.462] (**) Option "xkb_model" "pc105"
[ 7.462] (**) Option "xkb_layout" "us"
[ 21.393] (II) AMDGPU(0): EDID vendor "WDE", prod id 8706
[ 21.393] (II) AMDGPU(0): Using EDID range info for horizontal sync
[ 21.393] (II) AMDGPU(0): Using EDID range info for vertical refresh
[ 21.393] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 21.393] (II) AMDGPU(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz eP)
[ 21.393] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 21.393] (II) AMDGPU(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 21.393] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 21.393] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 21.393] (II) AMDGPU(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 21.393] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 21.393] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 21.393] (II) AMDGPU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 21.393] (II) AMDGPU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 21.393] (II) AMDGPU(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 21.393] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 21.393] (II) AMDGPU(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 21.393] (II) AMDGPU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 21.393] (II) AMDGPU(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 21.393] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 21.393] (II) AMDGPU(0): Modeline "1280x960"x0.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 21.393] (II) AMDGPU(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 21.393] (II) AMDGPU(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 21.393] (II) AMDGPU(0): Modeline "1440x900"x0.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz e)
[ 21.393] (II) AMDGPU(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.8 kHz e)
[ 21.875] (II) AMDGPU(0): EDID vendor "WDE", prod id 8706
[ 21.875] (II) AMDGPU(0): Using hsync ranges from config file
[ 21.875] (II) AMDGPU(0): Using vrefresh ranges from config file
[ 21.875] (II) AMDGPU(0): Printing DDC gathered Modelines:
[ 21.875] (II) AMDGPU(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz eP)
[ 21.875] (II) AMDGPU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 21.875] (II) AMDGPU(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 21.875] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 21.875] (II) AMDGPU(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 21.875] (II) AMDGPU(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 21.875] (II) AMDGPU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 21.875] (II) AMDGPU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 21.875] (II) AMDGPU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 21.875] (II) AMDGPU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 21.875] (II) AMDGPU(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 21.875] (II) AMDGPU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 21.875] (II) AMDGPU(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 21.875] (II) AMDGPU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 21.875] (II) AMDGPU(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 21.875] (II) AMDGPU(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 21.875] (II) AMDGPU(0): Modeline "1280x960"x0.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 21.875] (II) AMDGPU(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 21.875] (II) AMDGPU(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 21.875] (II) AMDGPU(0): Modeline "1440x900"x0.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz e)
[ 21.875] (II) AMDGPU(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.8 kHz e)
[ 111.190] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-4ms), your system is too slow
[ 230.647] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-1ms), your system is too slow
[ 255.956] (EE) event5 - Logitech G604 : client bug: event processing lagging behind by 31ms, your system is too slow
[ 280.748] (EE) event5 - Logitech G604 : client bug: event processing lagging behind by 24ms, your system is too slow
[ 280.749] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-12ms), your system is too slow
[ 282.857] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-0ms), your system is too slow
[ 287.242] (EE) event5 - Logitech G604 : client bug: event processing lagging behind by 14ms, your system is too slow
[ 287.242] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-2ms), your system is too slow
[ 290.136] (EE) event5 - Logitech G604 : client bug: event processing lagging behind by 22ms, your system is too slow
[ 290.332] (EE) event5 - Logitech G604 : client bug: event processing lagging behind by 35ms, your system is too slow
[ 290.333] (EE) event5 - Logitech G604 : WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 295.118] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-12ms), your system is too slow
[ 298.102] (EE) client bug: timer event5 debounce: scheduled expiry is in the past (-10ms), your system is too slow
[ 298.102] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-23ms), your system is too slow
[ 421.413] (EE) event3 - HID 0c45:7403: client bug: event processing lagging behind by 29ms, your system is too slow
[ 513.053] (EE) event3 - HID 0c45:7403: client bug: event processing lagging behind by 12ms, your system is too slow
[ 621.906] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-10ms), your system is too slow
[ 623.133] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-3ms), your system is too slow
[ 646.546] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-6ms), your system is too slow
[ 858.602] (EE) client bug: timer event5 debounce: scheduled expiry is in the past (-6ms), your system is too slow
[ 858.602] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-19ms), your system is too slow
[ 916.675] (EE) client bug: timer event5 debounce: scheduled expiry is in the past (-66ms), your system is too slow
[ 916.675] (EE) client bug: timer event5 debounce short: scheduled expiry is in the past (-79ms), your system is too slow
[ 987.798] (EE) event3 - HID 0c45:7403: client bug: event processing lagging behind by 14ms, your system is too slow
small snippet from journalctl -xe
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/exrthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/exr>
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/blenderthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins>
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/miloutextplugin.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_pci.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_clock.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/comicbookthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugi>
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_k3bsoxencoder.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_usb.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/kio_obexftp.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/kio_>
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_krunner_kill.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kstyle_breeze_config.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/msm_users.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kwin_scripts.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/imagethumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/i>
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_mouse.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/djvuthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/dj>
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/msm_locale.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/attica_kde.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/jpegthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/jp>
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kwinoptions.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/msm_kernel.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/ebookthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/e>
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/msm_timedate.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kfileaudiopreview.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_k3boggvorbisencoder.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kwintabbox.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_netpref.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_k3blameencoder.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kdeconnect.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/ffmpegthumbs.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffm>
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kamera.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/msm_keyboard.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_cddb.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_ssl.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_about_distro.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_info.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/msm_language_packages.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kwincompositing.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_devinfo.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/appimagethumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugin>
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/audiothumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/a>
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/cursorthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/>
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_cookies.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kdeconnect_share_config.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_opengl.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/baloofilepropertiesplugin.so" does not have a valid 'MetaData' object
Aug 20 14:44:52 rebel86 plasmashell[1442]: kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/rawthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/raw>
another small snippet
Aug 20 14:50:56 rebel86 kwin_x11[1400]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 20346, resource id: 35651822, major code: 18 (ChangeProperty), minor code: 0
Aug 20 14:50:56 rebel86 kwin_x11[1400]: file:///usr/share/kwin/aurorae/MenuButton.qml:11: TypeError: Cannot read property 'closeOnDoubleClickOnMenu' of null
Aug 20 14:50:58 rebel86 kwin_x11[1400]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 26634, resource id: 60827453, major code: 15 (QueryTree), minor code: 0
Aug 20 14:52:44 rebel86 kwin_x11[1400]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 52037, resource id: 81788934, major code: 15 (QueryTree), minor code: 0
Aug 20 14:52:44 rebel86 kwin_x11[1400]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 52158, resource id: 81789468, major code: 18 (ChangeProperty), minor code: 0
Aug 20 14:58:21 rebel86 plasmashell[1442]: qrc:/plasma/plasmoids/org.kde.plasma.volume/contents/ui/ListItemBase.qml:233: TypeError: Cannot read property 'visible' of null
Aug 20 14:58:39 rebel86 kwin_x11[1400]: file:///usr/share/kwin/aurorae/MenuButton.qml:11: TypeError: Cannot read property 'closeOnDoubleClickOnMenu' of null
Aug 20 14:58:44 rebel86 plasmashell[1442]: qrc:/plasma/plasmoids/org.kde.plasma.volume/contents/ui/ListItemBase.qml:233: TypeError: Cannot read property 'visible' of null
Aug 20 14:58:47 rebel86 kwin_x11[1400]: file:///usr/share/kwin/aurorae/MenuButton.qml:11: TypeError: Cannot read property 'closeOnDoubleClickOnMenu' of null
Aug 20 14:59:06 rebel86 plasmashell[1442]: qrc:/plasma/plasmoids/org.kde.plasma.volume/contents/ui/ListItemBase.qml:233: TypeError: Cannot read property 'visible' of null
Aug 20 15:00:35 rebel86 plasmashell[1442]: qrc:/plasma/plasmoids/org.kde.plasma.volume/contents/ui/ListItemBase.qml:233: TypeError: Cannot read property 'visible' of null
Aug 20 15:01:01 rebel86 CROND[6374]: (root) CMD (run-parts /etc/cron.hourly)
Aug 20 15:01:01 rebel86 CROND[6373]: (root) CMDEND (run-parts /etc/cron.hourly)
Aug 20 15:02:42 rebel86 plasmashell[1442]: QObject::disconnect: Unexpected nullptr parameter
Aug 20 15:03:15 rebel86 kwin_x11[1400]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 65273, resource id: 56623164, major code: 18 (ChangeProperty), minor code: 0
I have timeshift and can revert but perfer to fix first before reverting.
