Manjaro disappeared from GRUB boot menu in double boot
I actually did.
But obviously that didn’t register.
It’s hopelessly to early to feel like this!
It errored again?
[manjaro /]# ls -al /boot
total 8033
drwxr-xr-x  5 root root    4096 Oct 11 18:27 .
drwxr-xr-x 17 root root    4096 Aug 12 21:05 ..
-rw-r--r--  1 root root   81920 Sep 29 01:35 amd-ucode.img
drwxr-xr-x  4 root root    1024 Jan  1  1970 efi
drwxr-xr-x  7 root root    4096 Oct 12 16:18 grub
-rw-r--r--  1 root root 8126464 Sep 11 04:18 intel-ucode.img
drwxr-xr-x  2 root root    4096 Aug 12 21:01 memtest86+
[manjaro /]# mhwd-kernel -i
 core is up to date
 extra is up to date
 multilib is up to date
error: no targets specified (use -h for help)
[manjaro /]# -h
bash: -h: command not found
[manjaro /]# mhwd-kernel -h
Usage: mhwd-kernel [option]
    -h  --help              Show this help message
    -i  --install           Install a new kernel        [kernel(s)] [optional: rmc = remove current kernel]
    -l  --list              List all available kernels
    -li --listinstalled     List installed kernels
    -r  --remove            Remove a kernel             [kernel(s)]
[manjaro /]# mhwd-kernel -l
available kernels:
   * linux419
   * linux510
   * linux515
   * linux54
   * linux61
   * linux610
   * linux611
   * linux612
   * linux66
   * linux61-rt
   * linux610-rt
   * linux611-rt
   * linux66-rt
[manjaro /]# pacman -S linux_612
error: target not found: linux_612
[manjaro /]# pacman -S linux612
resolving dependencies...
Packages (3) linux-firmware-20240928.c979a065-1  linux-firmware-whence-20240928.c979a065-1  linux612-6.12.0rc2-2
Total Download Size:    139.70 MiB
Total Installed Size:  1244.57 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
 linux612-6.12.0rc2-2-x86_64        139.7 MiB  2.38 MiB/s 00:59 [###########################################################################################] 100%
(3/3) checking keys in keyring        [###########################################################################################] 100%
(3/3) checking package integrity        [###########################################################################################] 100%
(3/3) loading package files        [###########################################################################################] 100%
(3/3) checking for file conflicts        [###########################################################################################] 100%
(3/3) checking available disk space        [###########################################################################################] 100%
(1/3) installing linux-firmware-whence        [###########################################################################################] 100%
(2/3) installing linux-firmware        [###########################################################################################] 100%
(3/3) installing linux612        [###########################################################################################] 100%
Optional dependencies for linux612
    wireless-regdb: to set the correct wireless channels of your country [installed]
(1/5) Arming ConditionNeedsUpdate...
(2/5) Updating module dependencies...
(3/5) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
  -> -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64.img
==> Starting build: '6.12.0-rc2-2-MANJARO'
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [kms]
==> WARNING: No module containing the symbol 'drm_privacy_screen_register' found in: 'drivers/platform'
loadkeys: Unable to open file: au: No such file or directory
  -> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
  -> Running build hook: [plymouth]
  -> Running build hook: [fsck]
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.12-x86_64.img'
==> Initcpio image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux612.preset: 'fallback'
  -> -k /boot/vmlinuz-6.12-x86_64 -g /boot/initramfs-6.12-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: 'ast'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'wd719x'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> WARNING: Possibly missing firmware for module: 'aic94xx'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'xhci_pci_renesas'
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.12-x86_64-fallback.img'
(4/5) Refreshing PackageKit...
Error connecting: Could not connect: No such file or directory
error: command failed to execute correctly
(5/5) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-6.12-x86_64
Found initrd image: /boot/intel-ucode.img /boot/amd-ucode.img /boot/initramfs-6.12-x86_64.img
Found initrd fallback image: /boot/initramfs-6.12-x86_64-fallback.img
ERROR: mkdir /var/lock/dmraid
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
[manjaro /]# mkinitcpio -P
[manjaro /]# grub-mkconfig -o /boot/grub/grub.cfg
done
this
you should be done
reboot and test
and run that command again to get your windows detected again
Thank you so much, it worked! I thought I was going to have to reinstall.
Now install a LTS kernel from the tool Manjaro Settings Manager like 6.6 for example. Then reboot on this kernel by selecting it in the Grub menu (Advanced options), and then remove the kernel 6.12 you installed from Manjaro Settings Manager, as you’ll come back later with issues because kernel 6.12 will disappear shortly (a month or two?) as it is a development kernel, not a Long Term Support one.
