I unfortunately had to setup up Manjaro from scratch again. Last time I used the store I could switch between a snap/flatpak/aur version of the apps shown to install.
In my preferences section I only have General | Advanced | Official Repositories | AUR | Cache tabs. I don’t seem to be able to enable the normal Snap & Flatpak tabs that I normally had.
Any ideas on how to fix this? I would much prefer to just have the one store like I used to rather than multiple stores.
Yeah sorry I meant the org.manjaro.pamac.manager GUI version as apposed to the cli pamac
The gui used to have, before I had to re-install from scratch, a section that you could toggle between different versions of the same package from AUR, Flatpak etc
I had throught those options where normally part of the gui if the system had Flatpak repos availiable etc. ?
