Difficulty: ★☆☆☆☆
You have a PC. It often hangs or slows down terrifically, you cannot even move the cursor on the screen, you wait 5 minutes for the system to defrost from its cryogenic state. You tell yourself “maybe 200 tabs was too much…” But in life, there’s hope. Hope for a magical solution to appear right in front of you, as if the sky gifted you magnificence. Here is that solution. It is called Earlyoom. Yes, my friends, easiness never has been so easy!
“Okay, but what does that random piece of software does?”, you might ask.
It checks your memory about once every 10 seconds, or more if needed, and it will send the SIGTERM signal to the process that uses the most memory in the opinion of the kernel if you are running low in memory, say about 10% of total swap and available memory!
Step 1: Install earlyoom
You may open a terminal and enter:
sudo pacman -S earlyoom
Easy peasy!
Step 2: Enable the service
In the terminal, execute:
sudo systemctl enable earlyoom
sudo systemctl start earlyoom
to start the service.
Voilà! Finished!
Where is the configuration file located?
The configuration file is indeed located in
/etc/default/earlyoom
To edit, simply execute:
sudo nano /etc/default/earlyoom
- Press Ctrl+S to save,
- Press Ctrl+X to exit.
How to know if the daemon is running?
- Simply execute
sudo systemctl status earlyoom
What are the available commands/configurations?
You may execute
earlyoom -h
to list all available commands! -
The manual page is accessible by invoking
man earlyoom
That concludes this memory tip, shall your nugget not run like a potato any more!
Feel free to critique and/or leave suggestions below!
