Manjaro Deepin new bugs & problems after 10.02.2019 update
deepin
#1
On this test-machine:
inxi -Fxxz
System:    Host: x133-pc Kernel: 4.19.20-1-MANJARO x86_64 bits: 64 compiler: gcc v: 8.2.1 Desktop: Deepin 15.9 tk: Qt 5.12.0
           wm: DeepinWM dm: LightDM Distro: Manjaro Linux
Machine:   Type: Laptop System: Dell product: Precision 7730 v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
           Mobo: Dell model: 0VC5H3 v: A00 serial: <filter> UEFI: Dell v: 1.6.0 date: 12/25/2018
Battery:   ID-1: BAT0 charge: 94.1 Wh condition: 94.1/97.0 Wh (97%) volts: 13.0/11.4 model: BYD DELL GW0K986 serial: <filter>
           status: Full
CPU:       Topology: 6-Core model: Intel Core i9-8950HK bits: 64 type: MT MCP arch: Kaby Lake rev: A L2 cache: 12.0 MiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 69720
           Speed: 941 MHz min/max: 800/4800 MHz Core speeds (MHz): 1: 1394 2: 1178 3: 1685 4: 932 5: 1846 6: 1592 7: 1606
           8: 4449 9: 1065 10: 1483 11: 1038 12: 1672
Graphics:  Device-1: NVIDIA GP104GLM [Quadro P5200 Mobile] vendor: Dell driver: nvidia v: 415.27 bus ID: 01:00.0
           chip ID: 10de:1bb5
           Display: x11 server: X.Org 1.20.3 driver: nvidia resolution: 3840x2160~60Hz
           OpenGL: renderer: Quadro P5200/PCIe/SSE2 v: 4.6.0 NVIDIA 415.27 direct render: Yes
Audio:     Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel v: kernel bus ID: 00:1f.3
           chip ID: 8086:a348
           Device-2: NVIDIA GP104 High Definition Audio vendor: Dell driver: snd_hda_intel v: kernel bus ID: 01:00.1
           chip ID: 10de:10f0
           Sound Server: ALSA v: k4.19.20-1-MANJARO
Network:   Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: 3.2.6-k port: efa0 bus ID: 00:1f.6
           chip ID: 8086:15bb
           Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel port: 3000 bus ID: 6f:00.0 chip ID: 8086:2526
           IF: wlp111s0 state: up mac: <filter>
Drives:    Local Storage: total: 267.35 GiB used: 39.24 GiB (14.7%)
           ID-1: /dev/nvme0n1 vendor: Samsung model: PM981 NVMe 256GB size: 238.47 GiB speed: 31.6 Gb/s lanes: 4
           serial: <filter>
           ID-2: /dev/sda type: USB vendor: Kingston model: DataTraveler 3.0 size: 28.88 GiB serial: <filter>
Partition: ID-1: / size: 54.30 GiB used: 10.05 GiB (18.5%) fs: ext4 dev: /dev/nvme0n1p3
Sensors:   System Temperatures: cpu: 59.0 C mobo: N/A gpu: nvidia temp: 61 C
           Fan Speeds (RPM): cpu: 1688 fan-2: 1681
Info:      Processes: 261 Uptime: 3m Memory: 62.75 GiB used: 1.17 GiB (1.9%) Init: systemd v: 239 Compilers: gcc: 8.2.1
           Shell: bash v: 5.0.0 running in: deepin-terminal inxi: 3.0.30
  1. After update each time on booting it up to OS - there’s insanely loud beeper signal, i almost have heart stroke and fell from chair. Usually beeper indicates some hardcore errors.
    There are few new erorrs in journal:
    sudo journalctl -p 3 -xb
feb 09 23:15:15 x133-pc kernel: iTCO_wdt iTCO_wdt: can't request region for resource [mem 0x00c5fffc-0x00c5ffff]
feb 09 23:15:16 x133-pc kernel: iwlwifi 0000:6f:00.0: BIOS contains WGDS but no WRDS
feb 09 23:15:21 x133-pc daemon/dde-system-daemon[1011]: main.go:67: name "com.deepin.daemon.Daemon" already has the owner
                                                             ->  proc.go:201
                                                             ->  asm_amd64.s:1333
feb 09 23:17:08 x133-pc kernel: usb 1-1: device descriptor read/64, error -71
I really need help with this one.
  1. Shutdown now takes veeery long time, after it shows what seems to be some terminal errors on brief moment, just before shutdown.
  2. On 4k screen deepin-exlorer RMB - Open in new window as admin opens admin root-explorer without scaling, it happens all the time, just as root-Filemanager from programs.
  3. Login pasword input field after suspend / logout have exceptionally large dots, almost as big as field itself.
On that test-machine:
           tk: Qt 5.12.0 wm: DeepinWM dm: LightDM Distro: Manjaro Linux
Machine:   Type: Laptop System: Sony product: VGN-Z11VRN_B v: J003DTPY serial: <filter> Chassis: type: 10
           serial: <filter>
           Mobo: Sony model: VAIO serial: <filter> BIOS: INSYDE v: R5031M3 date: 11/10/2009
Battery:   ID-1: BAT0 charge: 33.9 Wh condition: 36.3/59.5 Wh (61%) volts: 12.2/10.8 model: Sony Corporation
           serial: N/A status: Unknown
CPU:       Topology: Dual Core model: Intel Core2 Duo P9500 bits: 64 type: MCP arch: Penryn rev: 6
           L2 cache: 6144 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx bogomips: 10111
           Speed: 2047 MHz min/max: 1600/2533 MHz Core speeds (MHz): 1: 1668 2: 1779
Graphics:  Device-1: Intel Mobile 4 Series Integrated Graphics vendor: Sony driver: i915 v: kernel
           bus ID: 00:02.0 chip ID: 8086:2a42
           Display: x11 server: X.Org 1.20.3 driver: intel unloaded: modesetting alternate: fbdev,vesa
           resolution: 1600x900~60Hz
           OpenGL: renderer: Mesa DRI Mobile Intel GM45 Express v: 2.1 Mesa 18.3.2 direct render: Yes
Audio:     Device-1: Intel 82801I HD Audio vendor: Sony driver: snd_hda_intel v: kernel bus ID: 00:1b.0
           chip ID: 8086:293e
Network:   Device-1: Intel 82567LM Gigabit Network vendor: Sony driver: e1000e v: 3.2.6-k port: 7100
           bus ID: 00:19.0 chip ID: 8086:10f5
           IF: enp0s25 state: down mac: <filter>
           Device-2: Qualcomm Atheros AR928X Wireless Network Adapter vendor: Foxconn driver: ath9k v: kernel
           port: 7000 bus ID: 06:00.0 chip ID: 168c:002a
           IF: wlp6s0 state: up mac: <filter>
Drives:    Local Storage: total: 1.36 TiB used: 145.08 GiB (10.4%)
           ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS541515A9E630 size: 1.36 TiB speed: 3.0 Gb/s
           serial: <filter>
Partition: ID-1: / size: 172.02 GiB used: 10.25 GiB (6.0%) fs: ext4 dev: /dev/sda1
Sensors:   System Temperatures: cpu: 44.0 C mobo: N/A
Info:      Processes: 148 Uptime: 5m Memory: 3.78 GiB used: 414.4 MiB (10.7%) Init: systemd v: 239 Compilers:
           gcc: 8.2.1 Shell: bash v: 5.0.0 running in: deepin-terminal inxi: 3.0.30
  1. Before this machine had no errors at all, now:
feb 09 23:49:37 x133-pc daemon/dde-system-daemon[923]: main.go:89: failed to request name: name com.deepin.daemon.Daemon already taken
                                                            ->  proc.go:201
                                                            ->  asm_amd64.s:1333
feb 09 23:49:37 x133-pc daemon/dde-system-daemon[942]: main.go:67: name "com.deepin.daemon.Daemon" already has the owner
                                                            ->  proc.go:201
                                                            ->  asm_amd64.s:1333
feb 09 23:49:37 x133-pc daemon/dde-system-daemon[948]: main.go:67: name "com.deepin.daemon.Daemon" already has the owner
                                                            ->  proc.go:201
                                                            ->  asm_amd64.s:1333
feb 09 23:49:37 x133-pc daemon/dde-system-daemon[959]: main.go:67: name "com.deepin.daemon.Daemon" already has the owner
                                                            ->  proc.go:201
                                                            ->  asm_amd64.s:1333
dmesg | grep -iE "error|failed|Time"
[    0.717245] acpi PNP0A08:00: _OSC failed (AE_SUPPORT); disabling ASPM
  1. Today i’ve found that i have no keyboard layots now in settings and forced to use only english, before i had 2.
On all machines and VM:
  1. After changing system language to another language, logout, enter system - language in deepin settings doesn’t change.
I’m not sure if i’m on Manjaro stable, feels more like testing :grinning:
Anyway, hope together we’ll make it better!
[Stable Update] 2019-02-09 - Kernels, Deepin, Firefox, Wine, Python, Haskell
Manjaro-Deepin 18.0.4-rc (testing branch)
Suggestions to improve Manjaro Deepin
#2
sudo rmmod pcspkr
sudo echo "blacklist pcspkr" > /etc/modprobe.d/nobeep.conf
the rest of the issues, no idea.
Thank you for saving my life & health! :star_struck:
As far as i understand that’s killing effect, rather than reason, and i’m really interested in what caused this after update.
But at least now i’ll be alive to continue debug journey)
P.S. For newcomers here:
this part haven’t worked, i had to manually create and add, but it’s easy)
sudo nano /etc/modprobe.d/nobeep.conf
and go for it!
Updated OP for VAIO test-machine:
2. Today i’ve found that i have no keyboard layots now in settings and forced to use only english, before i had 2.
#5
Looks like you keep on having a lot of troubles with Manjaro Deepin. As usual I can’t reproduce them. Deepin works flawlessly here…
May I suggest you something radical mate? How about backing up important data and go for a brand new fresh install?
#6
Both of this test systems are extremely fresh, in fact first one is done yesterday morning and have no user-specific software installed.
Second is like week long.
Hence i call them test-systems, i’m not moving to Manjaro full-time yet, just very active hardware / software test.
So it’s not some radical voodoo-magic on my side)
And most of this bugs i can easily reproduce on VM in virtualbox, so wonder how come you don’t have them (excluding 4k, if you don’t have 4k monitor) :thinking:
All of this systems installed from, checsums checked:
manjaro-deepin-18.0.2-stable-x86_64.iso
#7
Ok, maybe a lot of troubles are related to the 4k monitor then (yes, I don’t have one on my Deepin machine).
I tend to suggest radical solutions because after fighting for years with my ex-wife one day I realized the solution was very simple… :smile: (1)
(1) No, I haven’t killed her.
#8
FIXED:
For beeper:
and add
blacklist pcspkr
For errors:
After some updates all kernel errors vanished.
                                                             ->  proc.go:201
                                                             ->  asm_amd64.s:1333
And i've talked with Deepin devs, they stated this is not an actual error, but warning, hopefully soon they will lower this message level to warning, so it wouldn't pollute strictly error logs anymore.
2. Shutdown now takes veeery long time, after it shows what seems to be some terminal errors on brief moment, just before shutdown.
Also solved, probably because no kernel errors now.
3. On 4k screen deepin-exlorer RMB - Open in new window as admin opens admin root-explorer without scaling, it happens all the time, just as root-Filemanager from programs.
Solved with this https://github.com/linuxdeepin/developer-center/issues/894, thx to BLumia.
5. Today i’ve found that i have no keyboard layots now in settings and forced to use only english, before i had 2.
6. After changing system language to another language, logout, enter system - language in deepin settings doesn’t change.
Solved long ago here, it wasn't easy.
https://github.com/linuxdeepin/developer-center/issues/893
NOT FIXED:
4. Login pasword input field after suspend / logout have exceptionally large dots, almost as big as field itself.
https://github.com/linuxdeepin/developer-center/issues/896
though it's minor, a workaround could be having xrandr automaticallly set dpi when waking from suspend using a service. but it's a workaround and for something im assuming is not all that important
#10
Still it's bug and must be fixed by Deepin, because it wasn't there prior 10.02.2019 update :wink:
