manjaro deepin login error
Hello,
I'm working on deepin manjaro OS from like 2 years, keeping it always updated on the stable version, I kept the application got throught AUR updated too. yesterday I've shutdown the pc and today when I start the PC I got this problem: login page -> type correct password -> loading desktop (I see my icons), after 2 secs it goes in black screen with "failed to start postresql ...." at the first line (the only one) and it backs to the login screen.
That's my PC https://www.asus.com/it/Laptops/N551JW/
Thanks for help
I second this. Had the exact same problem. If I do access the ctrl-alt-F3 terminal I can login. Tried to revert the update to previews days but with no success. I need to work so please help.
Link to video
Ok, after scavenging some other topics (1st, 2nd) I concluded that this is the correct solution:
sudo pacman -R manjaro-deepin-settings
sudo pacman -Syyu deepin-desktop-schemas
Tested it myself with success.
