Weird problem with web-video
If I open any video with firefox, squares appear on the edges of red or orange objects. I tried to open videos in Chrome and the issue didn’t appear. But I don’t want to use chrome, because it is much, much slower than firefox plus it has almost no really advanced settings.
:+1: Welcome to Manjaro! :+1:
Please read this:
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
:+1:
Here is it:
          Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
          parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
          root=UUID=5ec50595-a656-43cf-aac3-a43d64409b91 rw quiet apparmor=1
          security=apparmor resume=UUID=91492d41-dd27-4ad8-8a5f-b8b3a603ac5e
          udev.log_priority=3
          Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
          dm: LightDM 1.30.0 Distro: Manjaro Linux
          Type: Desktop System: ASUS product: All Series v: N/A serial: <filter>
          Mobo: ASUSTeK model: Z87-EXPERT v: Rev 1.xx serial: <filter>
          UEFI: American Megatrends v: 1504 date: 10/03/2013
          RAM: total: 7.71 GiB used: 2.77 GiB (35.9%)
          Topology: Quad Core model: Intel Core i7-4770K bits: 64 type: MT MCP
          arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 28
          L2 cache: 8192 KiB bogomips: 55987
          Speed: 3103 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 799 2: 800
          3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
          Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
          clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
          dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs ida
          invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr
          pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good sdbg sep smep ss
          ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust
          tsc_deadline_timer vme xsave xsaveopt xtopology xtpr
          Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
          Device-1: NVIDIA GF100 [GeForce GTX 480] driver: nvidia v: 390.132
          alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:06c0
          Display: x11 server: X.Org 1.20.9 driver: nvidia display ID: :0.0 screens: 1
          Screen-1: 0 s-res: 1680x1050 s-dpi: 96 s-size: 445x278mm (17.5x10.9")
          s-diag: 525mm (20.7")
          Monitor-1: DVI-I-2 res: 1680x1050 hz: 60 dpi: 90
          size: 474x296mm (18.7x11.7") diag: 559mm (22")
          OpenGL: renderer: GeForce GTX 480/PCIe/SSE2 v: 4.6.0 NVIDIA 390.132
          direct render: Yes
          Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
          driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:8c20
          Device-2: NVIDIA GF100 High Definition Audio driver: snd_hda_intel v: kernel
          bus ID: 01:00.1 chip ID: 10de:0be5
          Device-3: Logitech HD Webcam C525 type: USB driver: snd-usb-audio,uvcvideo
          bus ID: 2-3.1:4 chip ID: 046d:0826 serial: <filter>
          Device-4: C-Media USB Audio Device type: USB
          driver: hid-generic,snd-usb-audio,usbhid bus ID: 2-1:7 chip ID: 0d8c:0012
          Sound Server: ALSA v: k5.8.11-1-MANJARO
          Device-1: Intel Ethernet I217-V vendor: ASUSTeK driver: e1000e v: 3.2.6-k
          port: f040 bus ID: 00:19.0 chip ID: 8086:153b
          Device-2: Qualcomm Atheros AR9462 Wireless Network Adapter vendor: ASUSTeK
          driver: ath9k v: kernel port: d000 bus ID: 08:00.0 chip ID: 168c:0034
          IF: wlp8s0 state: up mac: <filter>
          Local Storage: total: 4.55 TiB used: 330.17 GiB (7.1%)
          ID-1: /dev/sda vendor: Hitachi model: HDS721010KLA330 size: 931.51 GiB
          block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s serial: <filter>
          rev: AB0A scheme: GPT
          ID-2: /dev/sdb vendor: Western Digital model: WD40EZRZ-22GXCB0
          size: 3.64 TiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
          rotation: 5400 rpm serial: <filter> rev: 0A80 scheme: GPT
          ID-1: / raw size: 922.42 GiB size: 906.94 GiB (98.32%)
          used: 19.69 GiB (2.2%) fs: ext4 dev: /dev/sda2 label: N/A
          uuid: 5ec50595-a656-43cf-aac3-a43d64409b91
          ID-2: /boot/efi raw size: 300.0 MiB size: 299.4 MiB (99.80%)
          used: 280 KiB (0.1%) fs: vfat dev: /dev/sda1 label: N/A uuid: 73B1-9586
          ID-3: /run/timeshift/backup raw size: 922.42 GiB
          size: <superuser/root required> used: <superuser/root required> fs: ext4
          dev: /dev/sda2 label: N/A uuid: 5ec50595-a656-43cf-aac3-a43d64409b91
          ID-4: /windrive raw size: 3.64 TiB size: 3.64 TiB (100.00%)
          used: 310.48 GiB (8.3%) fs: ntfs dev: /dev/sdb3 label: N/A
          uuid: 72409CF3409CBEF3
          ID-1: swap-1 type: partition size: 8.80 GiB used: 2.0 MiB (0.0%)
          priority: -2 dev: /dev/sda3 label: N/A
          uuid: 91492d41-dd27-4ad8-8a5f-b8b3a603ac5e
          ID-1: /dev/sdb1 size: 100.0 MiB fs: vfat label: N/A uuid: EE9B-4E51
          ID-2: /dev/sdb2 size: 16.0 MiB fs: <superuser/root required> label: N/A
          uuid: N/A
          ID-3: /dev/sdb4 size: 517.0 MiB fs: ntfs label: N/A uuid: F6ACD62EACD5E8DF
          Hub: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s
          chip ID: 1d6b:0002
          Hub: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
          speed: 480 Mb/s chip ID: 8087:8008
          Hub: 2-0:1 info: Full speed (or root) Hub ports: 14 rev: 2.0 speed: 480 Mb/s
          chip ID: 1d6b:0002
          Device-1: 2-1:7 info: C-Media USB Audio Device type: Audio,HID
          driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
          speed: 12 Mb/s chip ID: 0d8c:0012
          Hub: 2-3:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
          speed: 480 Mb/s chip ID: 174c:2074
          Device-1: 2-3.1:4 info: Logitech HD Webcam C525 type: Audio,Video
          Device-2: 2-3.3:5 info: Logitech G105 Gaming Keyboard type: Keyboard,HID
          chip ID: 046d:c248
          Device-3: 2-3.4:6 info: Logitech G203 Gaming Mouse type: Mouse,HID
          chip ID: 046d:c084 serial: <filter>
          Device-4: 2-4:3 info: ASUSTek type: Bluetooth driver: btusb interfaces: 2
          rev: 1.1 speed: 12 Mb/s chip ID: 0b05:17d0
          Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s
          chip ID: 1d6b:0002
          Hub: 3-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
          speed: 480 Mb/s chip ID: 8087:8000
          Hub: 4-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
          chip ID: 1d6b:0003
          Hub: 4-3:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
          speed: 5 Gb/s chip ID: 174c:3074
          System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 84 C
          Fan Speeds (RPM): N/A gpu: nvidia fan: 60%
          Processes: 247 Uptime: 3h 54m Init: systemd v: 246 Compilers: gcc: 10.2.0
          Packages: pacman: 1253 lib: 350 flatpak: 0 Shell: Bash v: 5.0.18
          running in: xfce4-terminal inxi: 3.1.05
As you have a GeForce GTX 480 the 390 series nVidia is indeed the correct one.
What can you find under about:support in FF under the Graphics title for the first 3 lines?
It should be something like this:
Compositing	Basic
Asynchronous Pan/Zoom	wheel input enabled; scrollbar drag enabled; keyboard enabled; autoscroll enabled
WebGL 1 Driver WSI Info	GLX 1.4
GLX_VENDOR(client): NVIDIA Corporation
GLX_VENDOR(server): NVIDIA Corporation
Extensions: GLX_EXT_visual_info GLX_EXT_visual_rating GLX_EXT_import_context GLX_SGIX_fbconfig GLX_SGIX_pbuffer GLX_SGI_video_sync GLX_SGI_swap_control GLX_EXT_swap_control GLX_EXT_swap_control_tear GLX_EXT_texture_from_pixmap GLX_EXT_buffer_age GLX_ARB_create_context GLX_ARB_create_context_profile GLX_EXT_create_context_es_profile GLX_EXT_create_context_es2_profile GLX_ARB_create_context_no_error GLX_ARB_create_context_robustness GLX_NV_delay_before_swap GLX_EXT_stereo_tree GLX_ARB_context_flush_control GLX_NV_robustness_video_memory_purge GLX_NV_multigpu_context GLX_ARB_multisample GLX_NV_float_buffer GLX_ARB_fbconfig_float GLX_EXT_framebuffer_sRGB GLX_NV_copy_image GLX_ARB_get_proc_address
