Kernel: 6.0.2-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
root=UUID=0fb091fc-3271-483e-818a-5dc21ccbd08d rw quiet apparmor=1
security=apparmor resume=UUID=e4ab7b14-ec9e-4155-b5eb-28717df67c17
udev.log_priority=3
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: Latitude 3420 v: N/A
Mobo: Dell model: 0KMD3M v: A00 serial: <superuser required> UEFI: Dell
v: 1.3.1 date: 04/23/2021
ID-1: BAT0 charge: 27.4 Wh (67.2%) condition: 40.8/40.8 Wh (100.0%)
volts: 11.7 min: 11.2 model: SMP DELL MGCM514 type: Li-poly serial: <filter>
status: discharging
Device-1: hidpp_battery_0 model: Logitech M350 Wireless Mouse
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
RAM: total: 7.51 GiB used: 2.29 GiB (30.5%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xA4
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 1400 min/max: 400/4200 scaling: driver: intel_pstate
governor: powersave cores: 1: 1400 2: 1400 3: 1400 4: 1400 5: 1400 6: 1400
7: 1400 8: 1400 bogomips: 22120
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-6:2 chip-ID: 0c45:6d1a class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: BOE Display 0x07e8 built: 2019 res: 1366x768
hz: 60 dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
Sound API: ALSA v: k6.0.2-2-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.58 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
vendor: Dell driver: r8169 v: kernel pcie: speed: Unknown lanes: 63
link-max: gen: 6 speed: 64 GT/s port: 3000 bus-ID: 2c:00.0
IF: enp44s0 state: down mac: <filter>
bus-ID: 3-10:4 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 1.36 TiB used: 39.85 GiB (2.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNVS500G
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: EDFK0N01 temp: 28.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
type: HDD rpm: 5400 serial: <filter> rev: 01 scheme: GPT
ID-1: / raw-size: 78.12 GiB size: 76.35 GiB (97.73%) used: 31.68 GiB (41.5%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 0fb091fc-3271-483e-818a-5dc21ccbd08d
ID-2: /boot/efi raw-size: 301 MiB size: 300.4 MiB (99.79%) used: 304 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: NO_LABEL
uuid: 1C6D-8153
ID-3: /home raw-size: 381.48 GiB size: 374.43 GiB (98.15%) used: 8.17 GiB
(2.2%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: ae4fdda7-02c7-4b07-847d-0ca5d01636a3
ID-1: swap-1 type: partition size: 5.86 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: e4ab7b14-ec9e-4155-b5eb-28717df67c17
ID-1: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: ext4 label: N/A
uuid: ebded15a-90fe-4211-a912-c3bd9a69e1c8
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-6:2 info: Microdia Integrated_Webcam_HD type: Video
Device-2: 3-7:3 info: Logitech Unifying Receiver type: Mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c52f class-ID: 0300
Device-3: 3-10:4 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Use of uninitialized value $unit in concatenation (.) or string at /usr/bin/inxi line 24087.
Use of uninitialized value $value in concatenation (.) or string at /usr/bin/inxi line 24087.
Src: /sys System Temperatures: cpu: 24.0 C mobo: N/A
Power: 12v: N/A 5v: 5 3.3v: N/A vbat: N/A
Processes: 252 Uptime: 8m wakeups: 222 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: 1438 pm: pacman pkgs: 1422 libs: 385 tools: pamac,yay pm: flatpak
pkgs: 16 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.22
Hola, buen día, existe Manjaro con sistema de archivos Btrfs?, se puede instalar sobre lo que ya tengo o debo hacer una nueva instalación ? .
Muchas gracias
