After the update of firefox to 96 I can’t save pictures (via the right-click menu) anymore. Once I click on save image firefox freezes completely so I have to kill it manually. Anyone else having this problem as well? My installation is pretty much standard and on the stable channel.
Try to re-install Firefox.
Try with a clean profile with no extensions. Most FF issues can be traced back to a corrupt profile and/or uncooperative extensions.
I did quite a few different things (like reboots, reset, etc.) and it finally worked; I just can’t say which step(s) was the resolution. Anyhow - many thanks for all your quick help and support! Very much appreciated!
same version. Not happen such thing. If sloved, you can edit this q&a
