Using 2 manjaro laptops. One with the issue, One the read the forum, and write this documentation
Boot pc
choose manjaro
Black screen. Start with terminal work :
CTRL Alt F3
pacman -Syu
... nothing to do
mhwd -li
Name Version Freedriver Type
video-linux 2024.05.06 true PCI
The list does not contain video-hybrid-intel-nvidia-prime
mhwd -i pci video-hybrid-intel-nvidia-prime
Lot of responce. I should 'tee' the listing to a textfile.
picture made. parts of it :
> Succesfully installed dependency video-modesetting
> Installing video-hybrid-intel-nvidia-prime...
Sourcing ...
Has lib32 ...
Sourcing ...
Processing ...
Sourcing ...
afhankelijkheden controleren (dutch for Dependencies checking )
fout:fout bij het voorbereiden van transactie (kan niet aan afhankelijkheden voldoen)
:: verwijderen van linux616-nvidia doorbreekt afhankelijkheid 'linux616-nvidia' vereist door linux-nvidia-meta
Translated : error while preparing the transaction (cannot meet dependency requirements)
removing linux616-nvidia breaks dependency 'linux616-nvidia' required by linux-nvidia-meta
Error: pacman failed! (Color = green)
Error:script failed! (Color = red)
about
To utilize the Nvidia card for a certain application or game - use primerun <appname> to launch it.
I dont use heavy applications, despite using a gaming capable laptop.
pacman -Syu envycontrol => Done !
which envycontrol
/usr/bin/envycontrol
How to use / what to do with envycontrol ? Check as normal user ?
Using it to switch, as normal user, the options are listed after issueing the bare command.
and also with : envycontrol -h
envycontrol -s integrated
envycontrol -s hybrid
envycontrol -s nvidia
envycontrol --use-nvidia-current
I do not see an option to investigate current setting
I believe you do advise me to do one of these :
I will try first one, and be back soon. Thanks so far.
executed as user root. It took several ? minutes !
Switching to nvidia mode
Enable ForceCompositionPipeline: False
Enable Coolbits: False
Succesfully enabled nvidia-persistenced.service
Rebuilding the initramfs...
Succesfully rebuilt the initramfs!
Operation completed succesfully
Please reboot your computer for changes to take effect.
# reboot.
choose Manjaro Linux in the bootloader … Linux desktop login show up ! Greeeeaaaaat !!!
So I should try “envycontrol -s hybrid” !?? Thanks for the advise. I will try it on sort term.
What also is good to notice (I think it might be of interest) : with connected my 2nd monitor by hdmi, booting into Linux, the login screen does show up on the additional monitor, not on the laptop screen.
Somewhere the command “CTRL Alt F4” was mentioned. Is there any difference wrt “CTRL Alt F3” ? I remember from the past that this works with “CTRL Alt F2 up to F7”, and that “CTRL Alt F8” was some exit / “return to previous state” function !?? Also some CTRL Alt Backspace had some function ?
That depends on the chosen display manager and desktop environment. With sddm, it is usually tty1 or tty2 — it’s not consistent though, and may vary between boots.
Also, it deserves noting that switching back to the GUI environment does not close the text-mode tty session one was logged into earlier. So if you are logged into tty3 and you switch back to the tty with the graphical session, then your login at tty3 still remains active until you properly exit that session.
