Manjaro Cinnamon 18.1.5 - Window behavior setting : bugged ?
Hi everyone,
Running Manjaro Cinnamon for some days...
Perfectly matching my needs + nice + seems to be stable :slightly_smiling_face:
One question though.
In the "Windows" settings under the "Behavior" tab, there are 2 options (sorry for the translation... I run it in French) :
  • "Put windows that need attention in the current workspace"
  • " Forbid windows that require attention to get focus"
Now the problem is following.
To rip my CD collection, I use a program called "Cantata". When it's done ripping, it displays a window asking if I would like to calculate Replay Gain.
As soon as that window pops-up, the Cantata app comes to the foreground on the current workspace.
Whatever settings I apply in the Windows settings, it doesn't change anything... Still same behavior :frowning:
Are those settings bugged ?
Is Cantata the culprit ?
Or do I simply not understand what those settings are supposed to do ?
Needless to say that there is no setting in Cantata about this.
I would also like to stress that this did not happen in MATE desktop environment (at least I think).
Thanks for your answers.
There's supposed to be an option "Prevent focus stealing" that should keep that from happening - is that the same as your "Forbid windows that require attention to get focus"?
https://distrowatch.com/weekly.php?issue=20190225#qa
Hi Ferdinand,
Thanks for taking time to reply...
Yes, it is the same item.
I assume Cinnamon labelled it to be a little more explicit :slight_smile:
But checking dconf editor, it is indeed the "Prevent Focus Stealing" feature.
And that one is enabled, so I should not have focus stealing.
But none of both options are working : when the rip of my CD is done, Cantata still gets focus AND is pushed to current workspace :frowning:
So either Cantata overpasses the system settings in some way or Cinnamon settings are a little buggy :slight_smile:
This is mine that seems to work
From top to Bottom
Click
off
off
Smart
on
Automatic
Disabled
24
on
Hi Robin0800,
Thanks for your reply.
I've applied your settings. I will try to rip a CD with Cantata and report.
But I am not optimistic. It seems the settings are indeed working. So I suspect the culprit is Cantata that, in a way or another, bypasses the system settings :frowning:
