Hello.
I recently got a new computer, and made a system wide installation of manjaro kde on it. However, I do need a small partition with windows 10 on it, so I made the partition, and burnt the iso into an usb stick, but when I go to the boot menu and select my usb stick, the screen just goes black for some time, and then goes back to the boot menu. There is also an option in the boot menu called windows boot manajer, but it does the same, just goes black for some seconds and goes back to boot menu. I do know I can install windows on this machine, as it came with it preinstalled, maibe that is why there is a windows boot manajer on the boot menu.
Any help is apreciated
You will likely find more help on a Windows support forum.
This is not a Windows support forum.
