Manjaro-Cinnamon 18.0.4 released
community-edition
cinnamon
#1
Manjaro-Cinnamon 18.0.4 install media are now ready for download
of course featuring the latest and greatest
  • Cinnamon Desktop 4.0.9
  • x-apps 2.0.2 and
  • kernel linux 419.
Some little adjustments have been made:
Thanks to @Frog’s testing and suggestions I have
  • adjusted cinnamon-settings to include qt5ct and Kvantum-manager aswell as blueman which now replaces blueberry,
  • re-enabled access to Cinnamon’s native user and group settings. So you can decide for yourself now if you prefer to use this or rather manjaro-settings-manager:wink:
  • added etcher to replace isousb and also yay.
  • nemo’s rather buggy bulk-rename plugin has been removed for now.
full edition:
direct | sig | sha1 | sha256 | torrent
minimal-edition:
#2
Nice and thank you for your work!
Just a little problem with Cinnamon Settings, details below.
Not worth doing a rebuild of the ISO just for that though in my opinion. Just need to fix the patch, rebuild the package and publish it.
#4
OK, thanks. Fixed in cinnamon 4.0.9-1.6 package.
As always, thank you for your amazing work and contribution to the community!!
Sweet! Thank you!
This looks nice, great work. I will try it out on my desktop.
Nice wallpaper :smile:
Awesome, many thanks for your great work!
:sunglasses:
@oberon ISO image for Cinnamon got deleted. Rebuild planned with those updates?
#12
Hah! The folder was hidden on the server, I forgot to unhide it :laughing:
Well, now it should be visible for the world!
#13
Although - the direct download with the links posted would have worked all the time… Just the folder was not visible on the OSDN site. Fixed now in any case.
#14
I downloaded the ISO and installed on a flash drive this morning. I’ve been using it throughout the day at work and have not had any issues.
Updated on my laptop when I got home without any issues on there either.
Great job @oberon
Looks nice! - Will try it in an VM.
Works like a brave! Great Job!!!
What is this? Found it in fresh install.
#18
It’s Disk Usage Analyzer (or baobab). It allows you to see with a nice chart how the disk space is used between files.
Pretty nice to have when doing some clean up.
#19
Thank You lovelie frog - I’m sorry, my question was misundertantable (or what the word shell be); I ment, what is firmware netronome.
#20
Just some firmware for Linux, included in manjaro-firmware package.
The Disk usage analyser is most likely complaining that it can’t analyse b43 folder because it doesn’t have the permission to access that folder.
#21
I’m afraid I don’t know any real details, but here’s what I can tell you:
$ pacman -Qo /usr/lib/firmware/b43
/usr/lib/firmware/b43/ is owned by manjaro-firmware 20160419-1
Version         : 20160419-1
Description     : Extra firmwares for Manjaro Linux
Provides        : nouveau-fw  b43-firmware-classic  b43-firmware-legacy
                  wd719x-firmware  aic94xx-firmware  bcm20702a1-firmware
specifically firmware netronome
