Confirmation that the Dolphin network connection wizard gives an error on SFTP?
Hello, everyone, I’m migrating to Dolphin from Nautilus and noticed a problem when adding SFTP connections via the wizard in “Network”: when I enter a folder in the designated field (and fill in all other needed fields) - I get an error that a folder was given but a file was expected. If I enter a file (valid one on the remote machine) - the connection gets added and the file gets open (in a weird tmp folder).
Can someone confirm that in order to file it upstream ?
I’m willing to be guinea pig.
What did you do exactly to arrive at this situation? I.E. did you try:
  • File
  • Create New
  • Link to Location (URL)
  • and then this:
