journalctl --since=-30m | grep -A9999 "Starting Hybrid Suspend+Hibernate\.\.\." | grep "kernel:\|systemd\[\|audit\[\|systemd-sleep\["
May 16 20:50:31 King systemd[1]: Starting Hybrid Suspend+Hibernate...
May 16 20:50:31 King kernel: PM: Image not found (code -22)
May 16 20:50:31 King systemd-sleep[1293]: Suspending system...
May 16 20:50:31 King kernel: PM: hibernation: hibernation entry
May 16 20:51:28 King kernel: microcode: microcode updated early to revision 0x21, date = 2019-02-13
May 16 20:51:28 King kernel: Linux version 5.10.34-1-MANJARO (builduser@LEGION) (gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP Sun May 2 11:29:56 UTC 2021
May 16 20:51:28 King kernel: Command line: BOOT_IMAGE=/@/boot/vmlinuz-5.10-x86_64 root=UUID=ea6646fa-bee1-45ed-8dea-55aff6671605 rw rootflags=subvol=@ quiet apparmor=1 security=apparmor udev.log_priority=3
May 16 20:51:28 King kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
May 16 20:51:28 King kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
May 16 20:51:28 King kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
May 16 20:51:28 King kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
May 16 20:51:28 King kernel: x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
May 16 20:51:28 King kernel: BIOS-provided physical RAM map:
May 16 20:51:28 King kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009dfff] usable
May 16 20:51:28 King kernel: BIOS-e820: [mem 0x000000000009e000-0x000000000009ffff] reserved
May 16 20:51:28 King kernel: BIOS-e820: [mem 0x0000000000100000-0x00000000de2abfff] usable
May 16 20:51:28 King kernel: BIOS-e820: [mem 0x00000000de2ac000-0x00000000de753fff] reserved
May 16 20:51:28 King kernel: BIOS-e820: [mem 0x00000000de754000-0x00000000de763fff] ACPI data
May 16 20:51:28 King kernel: BIOS-e820: [mem 0x00000000de764000-0x00000000de872fff] ACPI NVS
May 16 20:51:28 King kernel: BIOS-e820: [mem 0x00000000de873000-0x00000000dee46fff] reserved
May 16 20:51:28 King kernel: BIOS-e820: [mem 0x00000000dee47000-0x00000000deee9fff] type 20
May 16 20:51:28 King kernel: BIOS-e820: [mem 0x00000000deeea000-0x00000000deeeafff] usable
May 16 20:51:28 King kernel: BIOS-e820: [mem 0x00000000deeeb000-0x00000000def2dfff] ACPI NVS
May 16 20:51:28 King kernel: BIOS-e820: [mem 0x00000000def2e000-0x00000000df7fffff] usable
May 16 20:51:28 King kernel: BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
May 16 20:51:28 King kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
May 16 20:51:28 King kernel: BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
May 16 20:51:28 King kernel: BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
May 16 20:51:28 King kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
May 16 20:51:28 King kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
May 16 20:51:28 King kernel: BIOS-e820: [mem 0x0000000100000000-0x000000041effffff] usable
May 16 20:51:28 King kernel: NX (Execute Disable) protection: active
May 16 20:51:28 King kernel: efi: EFI v2.31 by American Megatrends
May 16 20:51:28 King kernel: efi: ACPI=0xde758000 ACPI 2.0=0xde758000 SMBIOS=0xdee45518
May 16 20:51:28 King kernel: SMBIOS 2.7 present.
May 16 20:51:28 King kernel: DMI: /DH61HO, BIOS HOH6110H.86A.0816.2018.1031.1524 10/31/2018
May 16 20:51:28 King kernel: tsc: Fast TSC calibration using PIT
May 16 20:51:28 King kernel: tsc: Detected 3093.063 MHz processor
May 16 20:51:28 King kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
May 16 20:51:28 King kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
May 16 20:51:28 King kernel: last_pfn = 0x41f000 max_arch_pfn = 0x400000000
May 16 20:51:28 King kernel: MTRR default type: uncachable
May 16 20:51:28 King kernel: MTRR fixed ranges enabled:
May 16 20:51:28 King kernel: 00000-9FFFF write-back
May 16 20:51:28 King kernel: A0000-EFFFF uncachable
May 16 20:51:28 King kernel: F0000-FFFFF write-protect
May 16 20:51:28 King kernel: MTRR variable ranges enabled:
May 16 20:51:28 King kernel: 0 base 000000000 mask C00000000 write-back
May 16 20:51:28 King kernel: 1 base 400000000 mask FF0000000 write-back
May 16 20:51:28 King kernel: 2 base 410000000 mask FF8000000 write-back
May 16 20:51:28 King kernel: 3 base 418000000 mask FFC000000 write-back
May 16 20:51:28 King kernel: 4 base 41C000000 mask FFE000000 write-back
May 16 20:51:28 King kernel: 5 base 41E000000 mask FFF000000 write-back
May 16 20:51:28 King kernel: 6 base 0E0000000 mask FE0000000 uncachable
May 16 20:51:28 King kernel: 7 disabled
May 16 20:51:28 King kernel: 8 disabled
May 16 20:51:28 King kernel: 9 disabled
May 16 20:51:28 King kernel: x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
May 16 20:51:28 King kernel: total RAM covered: 16368M
May 16 20:51:28 King kernel: Found optimal setting for mtrr clean up
May 16 20:51:28 King kernel: gran_size: 64K chunk_size: 32M num_reg: 7 lose cover RAM: 0G
May 16 20:51:28 King kernel: e820: update [mem 0xe0000000-0xffffffff] usable ==> reserved
May 16 20:51:28 King kernel: last_pfn = 0xdf800 max_arch_pfn = 0x400000000
May 16 20:51:28 King kernel: check: Scanning 1 areas for low memory corruption
May 16 20:51:28 King kernel: Secure boot disabled
May 16 20:51:28 King kernel: RAMDISK: [mem 0x36a73000-0x37530fff]
May 16 20:51:28 King kernel: ACPI: Early table checksum verification disabled
May 16 20:51:28 King kernel: ACPI: RSDP 0x00000000DE758000 000024 (v02 INTEL )
May 16 20:51:28 King kernel: ACPI: XSDT 0x00000000DE758078 000074 (v01 INTEL DH61HO 00000330 AMI 00010013)
May 16 20:51:28 King kernel: ACPI: FACP 0x00000000DE761AF0 00010C (v05 INTEL DH61HO 00000330 AMI 00010013)
May 16 20:51:28 King kernel: ACPI: DSDT 0x00000000DE758180 009970 (v02 INTEL DH61HO 00000330 INTL 20051117)
May 16 20:51:28 King kernel: ACPI: FACS 0x00000000DE871080 000040
May 16 20:51:28 King kernel: ACPI: APIC 0x00000000DE761C00 000092 (v03 INTEL DH61HO 00000330 AMI 00010013)
May 16 20:51:28 King kernel: ACPI: FPDT 0x00000000DE761C98 000044 (v01 INTEL DH61HO 00000330 AMI 00010013)
May 16 20:51:28 King kernel: ACPI: MCFG 0x00000000DE761CE0 00003C (v01 INTEL DH61HO 00000330 MSFT 00000097)
May 16 20:51:28 King kernel: ACPI: HPET 0x00000000DE761D20 000038 (v01 INTEL DH61HO 00000330 AMI. 00000005)
May 16 20:51:28 King kernel: ACPI: SSDT 0x00000000DE761D58 00036D (v01 INTEL DH61HO 00000330 INTL 20091112)
May 16 20:51:28 King kernel: ACPI: SSDT 0x00000000DE7620C8 0009AA (v01 INTEL DH61HO 00000330 INTL 20051117)
May 16 20:51:28 King kernel: ACPI: SSDT 0x00000000DE762A78 000A92 (v01 INTEL DH61HO 00000330 INTL 20051117)
May 16 20:51:28 King kernel: ACPI: DMAR 0x00000000DE763510 000078 (v01 INTEL DH61HO 00000330 INTL 00000001)
May 16 20:51:28 King kernel: ACPI: BGRT 0x00000000DE763588 000038 (v00 INTEL DH61HO 00000330 AMI 00010013)
May 16 20:51:28 King kernel: ACPI: Reserving FACP table memory at [mem 0xde761af0-0xde761bfb]
May 16 20:51:28 King kernel: ACPI: Reserving DSDT table memory at [mem 0xde758180-0xde761aef]
May 16 20:51:28 King kernel: ACPI: Reserving FACS table memory at [mem 0xde871080-0xde8710bf]
May 16 20:51:28 King kernel: ACPI: Reserving APIC table memory at [mem 0xde761c00-0xde761c91]
May 16 20:51:28 King kernel: ACPI: Reserving FPDT table memory at [mem 0xde761c98-0xde761cdb]
May 16 20:51:28 King kernel: ACPI: Reserving MCFG table memory at [mem 0xde761ce0-0xde761d1b]
May 16 20:51:28 King kernel: ACPI: Reserving HPET table memory at [mem 0xde761d20-0xde761d57]
May 16 20:51:28 King kernel: ACPI: Reserving SSDT table memory at [mem 0xde761d58-0xde7620c4]
May 16 20:51:28 King kernel: ACPI: Reserving SSDT table memory at [mem 0xde7620c8-0xde762a71]
May 16 20:51:28 King kernel: ACPI: Reserving SSDT table memory at [mem 0xde762a78-0xde763509]
May 16 20:51:28 King kernel: ACPI: Reserving DMAR table memory at [mem 0xde763510-0xde763587]
May 16 20:51:28 King kernel: ACPI: Reserving BGRT table memory at [mem 0xde763588-0xde7635bf]
May 16 20:51:28 King kernel: ACPI: Local APIC address 0xfee00000
May 16 20:51:28 King kernel: No NUMA configuration found
May 16 20:51:28 King kernel: Faking a node at [mem 0x0000000000000000-0x000000041effffff]
May 16 20:51:28 King kernel: NODE_DATA(0) allocated [mem 0x41eff1000-0x41eff4fff]
May 16 20:51:28 King kernel: Zone ranges:
May 16 20:51:28 King kernel: DMA [mem 0x0000000000001000-0x0000000000ffffff]
May 16 20:51:28 King kernel: DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
May 16 20:51:28 King kernel: Normal [mem 0x0000000100000000-0x000000041effffff]
May 16 20:51:28 King kernel: Device empty
May 16 20:51:28 King kernel: Movable zone start for each node
May 16 20:51:28 King kernel: Early memory node ranges
May 16 20:51:28 King kernel: node 0: [mem 0x0000000000001000-0x000000000009dfff]
May 16 20:51:28 King kernel: node 0: [mem 0x0000000000100000-0x00000000de2abfff]
May 16 20:51:28 King kernel: node 0: [mem 0x00000000deeea000-0x00000000deeeafff]
May 16 20:51:28 King kernel: node 0: [mem 0x00000000def2e000-0x00000000df7fffff]
May 16 20:51:28 King kernel: node 0: [mem 0x0000000100000000-0x000000041effffff]
May 16 20:51:28 King kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000041effffff]
May 16 20:51:28 King kernel: On node 0 totalpages: 4184860
May 16 20:51:28 King kernel: DMA zone: 64 pages used for memmap
May 16 20:51:28 King kernel: DMA zone: 24 pages reserved
May 16 20:51:28 King kernel: DMA zone: 3997 pages, LIFO batch:0
May 16 20:51:28 King kernel: DMA zone: 28771 pages in unavailable ranges
May 16 20:51:28 King kernel: DMA32 zone: 14190 pages used for memmap
May 16 20:51:28 King kernel: DMA32 zone: 908159 pages, LIFO batch:63
May 16 20:51:28 King kernel: DMA32 zone: 5249 pages in unavailable ranges
May 16 20:51:28 King kernel: Normal zone: 51136 pages used for memmap
May 16 20:51:28 King kernel: Normal zone: 3272704 pages, LIFO batch:63
May 16 20:51:28 King kernel: Normal zone: 4096 pages in unavailable ranges
May 16 20:51:28 King kernel: ACPI: PM-Timer IO Port: 0x408
May 16 20:51:28 King kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
May 16 20:51:28 King kernel: IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
May 16 20:51:28 King kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
May 16 20:51:28 King kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
May 16 20:51:28 King kernel: ACPI: IRQ0 used by override.
May 16 20:51:28 King kernel: ACPI: IRQ9 used by override.
May 16 20:51:28 King kernel: Using ACPI (MADT) for SMP configuration information
May 16 20:51:28 King kernel: ACPI: HPET id: 0x8086a701 base: 0xfed00000
May 16 20:51:28 King kernel: e820: update [mem 0xdbd39000-0xdbd94fff] usable ==> reserved
May 16 20:51:28 King kernel: TSC deadline timer available
May 16 20:51:28 King kernel: smpboot: Allowing 8 CPUs, 0 hotplug CPUs
May 16 20:51:28 King kernel: PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
May 16 20:51:28 King kernel: PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
May 16 20:51:28 King kernel: PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
May 16 20:51:28 King kernel: PM: hibernation: Registered nosave memory: [mem 0xdbd39000-0xdbd94fff]
May 16 20:51:28 King kernel: PM: hibernation: Registered nosave memory: [mem 0xde2ac000-0xde753fff]
May 16 20:51:28 King kernel: PM: hibernation: Registered nosave memory: [mem 0xde754000-0xde763fff]
May 16 20:51:28 King kernel: PM: hibernation: Registered nosave memory: [mem 0xde764000-0xde872fff]
May 16 20:51:28 King kernel: PM: hibernation: Registered nosave memory: [mem 0xde873000-0xdee46fff]
May 16 20:51:28 King kernel: PM: hibernation: Registered nosave memory: [mem 0xdee47000-0xdeee9fff]
May 16 20:51:28 King kernel: PM: hibernation: Registered nosave memory: [mem 0xdeeeb000-0xdef2dfff]
May 16 20:51:28 King kernel: PM: hibernation: Registered nosave memory: [mem 0xdf800000-0xf7ffffff]
May 16 20:51:28 King kernel: PM: hibernation: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
May 16 20:51:28 King kernel: PM: hibernation: Registered nosave memory: [mem 0xfc000000-0xfebfffff]
May 16 20:51:28 King kernel: PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
May 16 20:51:28 King kernel: PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
May 16 20:51:28 King kernel: PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
May 16 20:51:28 King kernel: PM: hibernation: Registered nosave memory: [mem 0xfed04000-0xfed1bfff]
May 16 20:51:28 King kernel: PM: hibernation: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
May 16 20:51:28 King kernel: PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
May 16 20:51:28 King kernel: PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
May 16 20:51:28 King kernel: PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
May 16 20:51:28 King kernel: PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
May 16 20:51:28 King kernel: [mem 0xdf800000-0xf7ffffff] available for PCI devices
May 16 20:51:28 King kernel: Booting paravirtualized kernel on bare hardware
May 16 20:51:28 King kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
May 16 20:51:28 King kernel: setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:8 nr_node_ids:1
May 16 20:51:28 King kernel: percpu: Embedded 55 pages/cpu s188416 r8192 d28672 u262144
May 16 20:51:28 King kernel: pcpu-alloc: s188416 r8192 d28672 u262144 alloc=1*2097152
May 16 20:51:28 King kernel: pcpu-alloc: [0] 0 1 2 3 4 5 6 7
May 16 20:51:28 King kernel: Built 1 zonelists, mobility grouping on. Total pages: 4119446
May 16 20:51:28 King kernel: Policy zone: Normal
May 16 20:51:28 King kernel: Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-5.10-x86_64 root=UUID=ea6646fa-bee1-45ed-8dea-55aff6671605 rw rootflags=subvol=@ quiet apparmor=1 security=apparmor udev.log_priority=3
May 16 20:51:28 King kernel: Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
May 16 20:51:28 King kernel: Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
May 16 20:51:28 King kernel: mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
May 16 20:51:28 King kernel: Memory: 16292836K/16739440K available (14344K kernel code, 2055K rwdata, 4796K rodata, 1724K init, 4292K bss, 446344K reserved, 0K cma-reserved)
May 16 20:51:28 King kernel: random: get_random_u64 called from __kmem_cache_create+0x26/0x520 with crng_init=0
May 16 20:51:28 King kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
May 16 20:51:28 King kernel: Kernel/User page tables isolation: enabled
May 16 20:51:28 King kernel: ftrace: allocating 41721 entries in 163 pages
May 16 20:51:28 King kernel: ftrace: allocated 163 pages with 4 groups
May 16 20:51:28 King kernel: rcu: Hierarchical RCU implementation.
May 16 20:51:28 King kernel: rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=8.
May 16 20:51:28 King kernel: Rude variant of Tasks RCU enabled.
May 16 20:51:28 King kernel: Tracing variant of Tasks RCU enabled.
May 16 20:51:28 King kernel: rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
May 16 20:51:28 King kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
May 16 20:51:28 King kernel: NR_IRQS: 20736, nr_irqs: 488, preallocated irqs: 16
May 16 20:51:28 King kernel: Console: colour dummy device 80x25
May 16 20:51:28 King kernel: printk: console [tty0] enabled
May 16 20:51:28 King kernel: ACPI: Core revision 20200925
May 16 20:51:28 King kernel: clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
May 16 20:51:28 King kernel: APIC: Switch to symmetric I/O mode setup
May 16 20:51:28 King kernel: DMAR: Host address width 36
May 16 20:51:28 King kernel: DMAR: DRHD base: 0x000000fed90000 flags: 0x1
May 16 20:51:28 King kernel: DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap c9008020660262 ecap f0105a
May 16 20:51:28 King kernel: DMAR: RMRR base: 0x000000de6c7000 end: 0x000000de6e6fff
May 16 20:51:28 King kernel: DMAR-IR: IOAPIC id 2 under DRHD base 0xfed90000 IOMMU 0
May 16 20:51:28 King kernel: DMAR-IR: HPET id 0 under DRHD base 0xfed90000
May 16 20:51:28 King kernel: DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
May 16 20:51:28 King kernel: DMAR-IR: Enabled IRQ remapping in x2apic mode
May 16 20:51:28 King kernel: x2apic enabled
May 16 20:51:28 King kernel: Switched APIC routing to cluster x2apic.
May 16 20:51:28 King kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
May 16 20:51:28 King kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2c95aeb7f6f, max_idle_ns: 440795322227 ns
May 16 20:51:28 King kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 6186.12 BogoMIPS (lpj=30930630)
May 16 20:51:28 King kernel: pid_max: default: 32768 minimum: 301
May 16 20:51:28 King kernel: LSM: Security Framework initializing
May 16 20:51:28 King kernel: Yama: becoming mindful.
May 16 20:51:28 King kernel: AppArmor: AppArmor initialized
May 16 20:51:28 King kernel: Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
May 16 20:51:28 King kernel: Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
May 16 20:51:28 King kernel: mce: CPU0: Thermal monitoring enabled (TM1)
May 16 20:51:28 King kernel: process: using mwait in idle threads
May 16 20:51:28 King kernel: Last level iTLB entries: 4KB 512, 2MB 8, 4MB 8
May 16 20:51:28 King kernel: Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32, 1GB 0
May 16 20:51:28 King kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
May 16 20:51:28 King kernel: Spectre V2 : Mitigation: Full generic retpoline
May 16 20:51:28 King kernel: Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
May 16 20:51:28 King kernel: Spectre V2 : Enabling Restricted Speculation for firmware calls
May 16 20:51:28 King kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
May 16 20:51:28 King kernel: Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
May 16 20:51:28 King kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
May 16 20:51:28 King kernel: SRBDS: Vulnerable: No microcode
May 16 20:51:28 King kernel: MDS: Mitigation: Clear CPU buffers
May 16 20:51:28 King kernel: Freeing SMP alternatives memory: 36K
May 16 20:51:28 King kernel: smpboot: CPU0: Intel(R) Core(TM) i7-3770S CPU @ 3.10GHz (family: 0x6, model: 0x3a, stepping: 0x9)
May 16 20:51:28 King kernel: Performance Events: PEBS fmt1+, IvyBridge events, 16-deep LBR, full-width counters, Intel PMU driver.
May 16 20:51:28 King kernel: ... version: 3
May 16 20:51:28 King kernel: ... bit width: 48
May 16 20:51:28 King kernel: ... generic registers: 4
May 16 20:51:28 King kernel: ... value mask: 0000ffffffffffff
May 16 20:51:28 King kernel: ... max period: 00007fffffffffff
May 16 20:51:28 King kernel: ... fixed-purpose events: 3
May 16 20:51:28 King kernel: ... event mask: 000000070000000f
May 16 20:51:28 King kernel: rcu: Hierarchical SRCU implementation.
May 16 20:51:28 King kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
May 16 20:51:28 King kernel: smp: Bringing up secondary CPUs ...
May 16 20:51:28 King kernel: x86: Booting SMP configuration:
May 16 20:51:28 King kernel: .... node #0, CPUs: #1 #2 #3 #4
May 16 20:51:28 King kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
May 16 20:51:28 King kernel: #5 #6 #7
May 16 20:51:28 King kernel: smp: Brought up 1 node, 8 CPUs
May 16 20:51:28 King kernel: smpboot: Max logical packages: 1
May 16 20:51:28 King kernel: smpboot: Total of 8 processors activated (49489.00 BogoMIPS)
May 16 20:51:28 King kernel: devtmpfs: initialized
May 16 20:51:28 King kernel: x86/mm: Memory block size: 128MB
May 16 20:51:28 King kernel: PM: Registering ACPI NVS region [mem 0xde764000-0xde872fff] (1110016 bytes)
May 16 20:51:28 King kernel: PM: Registering ACPI NVS region [mem 0xdeeeb000-0xdef2dfff] (274432 bytes)
May 16 20:51:28 King kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
May 16 20:51:28 King kernel: futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
May 16 20:51:28 King kernel: pinctrl core: initialized pinctrl subsystem
May 16 20:51:28 King kernel: PM: RTC time: 20:51:27, date: 2021-05-16
May 16 20:51:28 King kernel: NET: Registered protocol family 16
May 16 20:51:28 King kernel: DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
May 16 20:51:28 King kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
May 16 20:51:28 King kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
May 16 20:51:28 King kernel: audit: initializing netlink subsys (disabled)
May 16 20:51:28 King kernel: audit: type=2000 audit(1621198286.070:1): state=initialized audit_enabled=0 res=1
May 16 20:51:28 King kernel: thermal_sys: Registered thermal governor 'fair_share'
May 16 20:51:28 King kernel: thermal_sys: Registered thermal governor 'bang_bang'
May 16 20:51:28 King kernel: thermal_sys: Registered thermal governor 'step_wise'
May 16 20:51:28 King kernel: thermal_sys: Registered thermal governor 'user_space'
May 16 20:51:28 King kernel: thermal_sys: Registered thermal governor 'power_allocator'
May 16 20:51:28 King kernel: cpuidle: using governor ladder
May 16 20:51:28 King kernel: cpuidle: using governor menu
May 16 20:51:28 King kernel: ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
May 16 20:51:28 King kernel: ACPI: bus type PCI registered
May 16 20:51:28 King kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
May 16 20:51:28 King kernel: PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
May 16 20:51:28 King kernel: PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
May 16 20:51:28 King kernel: PCI: Using configuration type 1 for base access
May 16 20:51:28 King kernel: core: PMU erratum BJ122, BV98, HSD29 worked around, HT is on
May 16 20:51:28 King kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
May 16 20:51:28 King kernel: Kprobes globally optimized
May 16 20:51:28 King kernel: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
May 16 20:51:28 King kernel: ACPI: Added _OSI(Module Device)
May 16 20:51:28 King kernel: ACPI: Added _OSI(Processor Device)
May 16 20:51:28 King kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
May 16 20:51:28 King kernel: ACPI: Added _OSI(Processor Aggregator Device)
May 16 20:51:28 King kernel: ACPI: Added _OSI(Linux-Dell-Video)
May 16 20:51:28 King kernel: ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
May 16 20:51:28 King kernel: ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
May 16 20:51:28 King kernel: ACPI: 4 ACPI AML tables successfully acquired and loaded
May 16 20:51:28 King kernel: ACPI: Dynamic OEM Table Load:
May 16 20:51:28 King kernel: ACPI: SSDT 0xFFFF999140B12000 00083B (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
May 16 20:51:28 King kernel: ACPI: SSDT 0xFFFF999140B1D400 000303 (v01 PmRef ApIst 00003000 INTL 20051117)
May 16 20:51:28 King kernel: ACPI: SSDT 0xFFFF999140F47600 000119 (v01 PmRef ApCst 00003000 INTL 20051117)
May 16 20:51:28 King kernel: ACPI: Interpreter enabled
May 16 20:51:28 King kernel: ACPI: (supports S0 S3 S4 S5)
May 16 20:51:28 King kernel: ACPI: Using IOAPIC for interrupt routing
May 16 20:51:28 King kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
May 16 20:51:28 King kernel: ACPI: Enabled 15 GPEs in block 00 to 3F
May 16 20:51:28 King kernel: ACPI: Power Resource [FN00] (off)
May 16 20:51:28 King kernel: ACPI: Power Resource [FN01] (off)
May 16 20:51:28 King kernel: ACPI: Power Resource [FN02] (off)
May 16 20:51:28 King kernel: ACPI: Power Resource [FN03] (off)
May 16 20:51:28 King kernel: ACPI: Power Resource [FN04] (off)
May 16 20:51:28 King kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
May 16 20:51:28 King kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
May 16 20:51:28 King kernel: acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME]
May 16 20:51:28 King kernel: acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability LTR DPC]
May 16 20:51:28 King kernel: acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
May 16 20:51:28 King kernel: PCI host bridge to bus 0000:00
May 16 20:51:28 King kernel: pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
May 16 20:51:28 King kernel: pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
May 16 20:51:28 King kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
May 16 20:51:28 King kernel: pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000c3fff window]
May 16 20:51:28 King kernel: pci_bus 0000:00: root bus resource [mem 0x000c4000-0x000c7fff window]
May 16 20:51:28 King kernel: pci_bus 0000:00: root bus resource [mem 0x000c8000-0x000cbfff window]
May 16 20:51:28 King kernel: pci_bus 0000:00: root bus resource [mem 0x000cc000-0x000cffff window]
May 16 20:51:28 King kernel: pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
May 16 20:51:28 King kernel: pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
May 16 20:51:28 King kernel: pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
May 16 20:51:28 King kernel: pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
May 16 20:51:28 King kernel: pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
May 16 20:51:28 King kernel: pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
May 16 20:51:28 King kernel: pci_bus 0000:00: root bus resource [mem 0x000e8000-0x000ebfff window]
May 16 20:51:28 King kernel: pci_bus 0000:00: root bus resource [mem 0x000ec000-0x000effff window]
May 16 20:51:28 King kernel: pci_bus 0000:00: root bus resource [mem 0xe0000000-0xfeafffff window]
May 16 20:51:28 King kernel: pci_bus 0000:00: root bus resource [bus 00-3e]
May 16 20:51:28 King kernel: pci 0000:00:00.0: [8086:0150] type 00 class 0x060000
May 16 20:51:28 King kernel: pci 0000:00:01.0: [8086:0151] type 01 class 0x060400
May 16 20:51:28 King kernel: pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
May 16 20:51:28 King kernel: pci 0000:00:16.0: [8086:1c3a] type 00 class 0x078000
May 16 20:51:28 King kernel: pci 0000:00:16.0: reg 0x10: [mem 0xf720a000-0xf720a00f 64bit]
May 16 20:51:28 King kernel: pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
May 16 20:51:28 King kernel: pci 0000:00:1a.0: [8086:1c2d] type 00 class 0x0c0320
May 16 20:51:28 King kernel: pci 0000:00:1a.0: reg 0x10: [mem 0xf7208000-0xf72083ff]
May 16 20:51:28 King kernel: pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
May 16 20:51:28 King kernel: pci 0000:00:1b.0: [8086:1c20] type 00 class 0x040300
May 16 20:51:28 King kernel: pci 0000:00:1b.0: reg 0x10: [mem 0xf7200000-0xf7203fff 64bit]
May 16 20:51:28 King kernel: pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
May 16 20:51:28 King kernel: pci 0000:00:1c.0: [8086:1c10] type 01 class 0x060400
May 16 20:51:28 King kernel: pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
May 16 20:51:28 King kernel: pci 0000:00:1c.4: [8086:1c18] type 01 class 0x060400
May 16 20:51:28 King kernel: pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
May 16 20:51:28 King kernel: pci 0000:00:1d.0: [8086:1c26] type 00 class 0x0c0320
May 16 20:51:28 King kernel: pci 0000:00:1d.0: reg 0x10: [mem 0xf7207000-0xf72073ff]
May 16 20:51:28 King kernel: pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
May 16 20:51:28 King kernel: pci 0000:00:1f.0: [8086:1c5c] type 00 class 0x060100
May 16 20:51:28 King kernel: pci 0000:00:1f.2: [8086:1c02] type 00 class 0x010601
May 16 20:51:28 King kernel: pci 0000:00:1f.2: reg 0x10: [io 0xf070-0xf077]
May 16 20:51:28 King kernel: pci 0000:00:1f.2: reg 0x14: [io 0xf060-0xf063]
May 16 20:51:28 King kernel: pci 0000:00:1f.2: reg 0x18: [io 0xf050-0xf057]
May 16 20:51:28 King kernel: pci 0000:00:1f.2: reg 0x1c: [io 0xf040-0xf043]
May 16 20:51:28 King kernel: pci 0000:00:1f.2: reg 0x20: [io 0xf020-0xf03f]
May 16 20:51:28 King kernel: pci 0000:00:1f.2: reg 0x24: [mem 0xf7206000-0xf72067ff]
May 16 20:51:28 King kernel: pci 0000:00:1f.2: PME# supported from D3hot
May 16 20:51:28 King kernel: pci 0000:00:1f.3: [8086:1c22] type 00 class 0x0c0500
May 16 20:51:28 King kernel: pci 0000:00:1f.3: reg 0x10: [mem 0xf7205000-0xf72050ff 64bit]
May 16 20:51:28 King kernel: pci 0000:00:1f.3: reg 0x20: [io 0xf000-0xf01f]
May 16 20:51:28 King kernel: pci 0000:01:00.0: [10de:1c82] type 00 class 0x030000
May 16 20:51:28 King kernel: pci 0000:01:00.0: reg 0x10: [mem 0xf6000000-0xf6ffffff]
May 16 20:51:28 King kernel: pci 0000:01:00.0: reg 0x14: [mem 0xe0000000-0xefffffff 64bit pref]
May 16 20:51:28 King kernel: pci 0000:01:00.0: reg 0x1c: [mem 0xf0000000-0xf1ffffff 64bit pref]
May 16 20:51:28 King kernel: pci 0000:01:00.0: reg 0x24: [io 0xe000-0xe07f]
May 16 20:51:28 King kernel: pci 0000:01:00.0: reg 0x30: [mem 0xf7000000-0xf707ffff pref]
May 16 20:51:28 King kernel: pci 0000:01:00.0: enabling Extended Tags
May 16 20:51:28 King kernel: pci 0000:01:00.0: BAR 1: assigned to efifb
May 16 20:51:28 King kernel: pci 0000:01:00.0: 32.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x16 link at 0000:00:01.0 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
May 16 20:51:28 King kernel: pci 0000:01:00.1: [10de:0fb9] type 00 class 0x040300
May 16 20:51:28 King kernel: pci 0000:01:00.1: reg 0x10: [mem 0xf7080000-0xf7083fff]
May 16 20:51:28 King kernel: pci 0000:01:00.1: enabling Extended Tags
May 16 20:51:28 King kernel: pci 0000:00:01.0: PCI bridge to [bus 01]
May 16 20:51:28 King kernel: pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
May 16 20:51:28 King kernel: pci 0000:00:01.0: bridge window [mem 0xf6000000-0xf70fffff]
May 16 20:51:28 King kernel: pci 0000:00:01.0: bridge window [mem 0xe0000000-0xf1ffffff 64bit pref]
May 16 20:51:28 King kernel: pci 0000:00:1c.0: PCI bridge to [bus 02]
May 16 20:51:28 King kernel: pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000
May 16 20:51:28 King kernel: pci 0000:03:00.0: reg 0x10: [io 0xd000-0xd0ff]
May 16 20:51:28 King kernel: pci 0000:03:00.0: reg 0x18: [mem 0xf7100000-0xf7100fff 64bit]
May 16 20:51:28 King kernel: pci 0000:03:00.0: reg 0x20: [mem 0xf2100000-0xf2103fff 64bit pref]
May 16 20:51:28 King kernel: pci 0000:03:00.0: supports D1 D2
May 16 20:51:28 King kernel: pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
May 16 20:51:28 King kernel: pci 0000:00:1c.4: PCI bridge to [bus 03]
May 16 20:51:28 King kernel: pci 0000:00:1c.4: bridge window [io 0xd000-0xdfff]
May 16 20:51:28 King kernel: pci 0000:00:1c.4: bridge window [mem 0xf7100000-0xf71fffff]
May 16 20:51:28 King kernel: pci 0000:00:1c.4: bridge window [mem 0xf2100000-0xf21fffff 64bit pref]
May 16 20:51:28 King kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
May 16 20:51:28 King kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 11 12 14 15) *0, disabled.
May 16 20:51:28 King kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
May 16 20:51:28 King kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
May 16 20:51:28 King kernel: ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
May 16 20:51:28 King kernel: ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
May 16 20:51:28 King kernel: ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
May 16 20:51:28 King kernel: ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
May 16 20:51:28 King kernel: iommu: Default domain type: Translated
May 16 20:51:28 King kernel: pci 0000:01:00.0: vgaarb: setting as boot VGA device
May 16 20:51:28 King kernel: pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
May 16 20:51:28 King kernel: pci 0000:01:00.0: vgaarb: bridge control possible
May 16 20:51:28 King kernel: vgaarb: loaded
May 16 20:51:28 King kernel: SCSI subsystem initialized
May 16 20:51:28 King kernel: libata version 3.00 loaded.
May 16 20:51:28 King kernel: ACPI: bus type USB registered
May 16 20:51:28 King kernel: usbcore: registered new interface driver usbfs
May 16 20:51:28 King kernel: usbcore: registered new interface driver hub
May 16 20:51:28 King kernel: usbcore: registered new device driver usb
May 16 20:51:28 King kernel: pps_core: LinuxPPS API ver. 1 registered
May 16 20:51:28 King kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
May 16 20:51:28 King kernel: PTP clock support registered
May 16 20:51:28 King kernel: EDAC MC: Ver: 3.0.0
May 16 20:51:28 King kernel: Registered efivars operations
May 16 20:51:28 King kernel: NetLabel: Initializing
May 16 20:51:28 King kernel: NetLabel: domain hash size = 128
May 16 20:51:28 King kernel: NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
May 16 20:51:28 King kernel: NetLabel: unlabeled traffic allowed by default
May 16 20:51:28 King kernel: PCI: Using ACPI for IRQ routing
May 16 20:51:28 King kernel: PCI: pci_cache_line_size set to 64 bytes
May 16 20:51:28 King kernel: e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
May 16 20:51:28 King kernel: e820: reserve RAM buffer [mem 0xdbd39000-0xdbffffff]
May 16 20:51:28 King kernel: e820: reserve RAM buffer [mem 0xde2ac000-0xdfffffff]
May 16 20:51:28 King kernel: e820: reserve RAM buffer [mem 0xdeeeb000-0xdfffffff]
May 16 20:51:28 King kernel: e820: reserve RAM buffer [mem 0xdf800000-0xdfffffff]
May 16 20:51:28 King kernel: e820: reserve RAM buffer [mem 0x41f000000-0x41fffffff]
May 16 20:51:28 King kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
May 16 20:51:28 King kernel: hpet0: 8 comparators, 64-bit 14.318180 MHz counter
May 16 20:51:28 King kernel: clocksource: Switched to clocksource tsc-early
May 16 20:51:28 King kernel: VFS: Disk quotas dquot_6.6.0
May 16 20:51:28 King kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
May 16 20:51:28 King kernel: AppArmor: AppArmor Filesystem Enabled
May 16 20:51:28 King kernel: pnp: PnP ACPI init
May 16 20:51:28 King kernel: system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved
May 16 20:51:28 King kernel: system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
May 16 20:51:28 King kernel: system 00:01: [io 0x0680-0x069f] has been reserved
May 16 20:51:28 King kernel: system 00:01: [io 0x1000-0x100f] has been reserved
May 16 20:51:28 King kernel: system 00:01: [io 0xffff] has been reserved
May 16 20:51:28 King kernel: system 00:01: [io 0x0400-0x0453] has been reserved
May 16 20:51:28 King kernel: system 00:01: [io 0x0458-0x047f] has been reserved
May 16 20:51:28 King kernel: system 00:01: [io 0x0500-0x057f] has been reserved
May 16 20:51:28 King kernel: system 00:01: [io 0x164e-0x164f] has been reserved
May 16 20:51:28 King kernel: system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
May 16 20:51:28 King kernel: pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
May 16 20:51:28 King kernel: system 00:03: [io 0x0454-0x0457] has been reserved
May 16 20:51:28 King kernel: system 00:03: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
May 16 20:51:28 King kernel: system 00:04: [io 0x0a10-0x0a2f] has been reserved
May 16 20:51:28 King kernel: system 00:04: [io 0x0a30-0x0a3f] has been reserved
May 16 20:51:28 King kernel: system 00:04: [io 0x0a20-0x0a2f] has been reserved
May 16 20:51:28 King kernel: system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
May 16 20:51:28 King kernel: pnp 00:05: [dma 0 disabled]
May 16 20:51:28 King kernel: pnp 00:05: Plug and Play ACPI device, IDs PNP0501 (active)
May 16 20:51:28 King kernel: system 00:06: [io 0x04d0-0x04d1] has been reserved
May 16 20:51:28 King kernel: system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
May 16 20:51:28 King kernel: system 00:07: [mem 0xfed1c000-0xfed1ffff] has been reserved
May 16 20:51:28 King kernel: system 00:07: [mem 0xfed10000-0xfed17fff] has been reserved
May 16 20:51:28 King kernel: system 00:07: [mem 0xfed18000-0xfed18fff] has been reserved
May 16 20:51:28 King kernel: system 00:07: [mem 0xfed19000-0xfed19fff] has been reserved
May 16 20:51:28 King kernel: system 00:07: [mem 0xf8000000-0xfbffffff] has been reserved
May 16 20:51:28 King kernel: system 00:07: [mem 0xfed20000-0xfed3ffff] has been reserved
May 16 20:51:28 King kernel: system 00:07: [mem 0xfed90000-0xfed93fff] could not be reserved
May 16 20:51:28 King kernel: system 00:07: [mem 0xfed45000-0xfed8ffff] has been reserved
May 16 20:51:28 King kernel: system 00:07: [mem 0xff000000-0xffffffff] has been reserved
May 16 20:51:28 King kernel: system 00:07: [mem 0xfee00000-0xfeefffff] could not be reserved
May 16 20:51:28 King kernel: system 00:07: [mem 0xf2200000-0xf2200fff] has been reserved
May 16 20:51:28 King kernel: system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
May 16 20:51:28 King kernel: pnp: PnP ACPI: found 8 devices
May 16 20:51:28 King kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
May 16 20:51:28 King kernel: NET: Registered protocol family 2
May 16 20:51:28 King kernel: tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
May 16 20:51:28 King kernel: TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
May 16 20:51:28 King kernel: TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
May 16 20:51:28 King kernel: TCP: Hash tables configured (established 131072 bind 65536)
May 16 20:51:28 King kernel: MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
May 16 20:51:28 King kernel: UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
May 16 20:51:28 King kernel: UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
May 16 20:51:28 King kernel: NET: Registered protocol family 44
May 16 20:51:28 King kernel: pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
May 16 20:51:28 King kernel: pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
May 16 20:51:28 King kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
May 16 20:51:28 King kernel: pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000c3fff window]
May 16 20:51:28 King kernel: pci_bus 0000:00: resource 8 [mem 0x000c4000-0x000c7fff window]
May 16 20:51:28 King kernel: pci_bus 0000:00: resource 9 [mem 0x000c8000-0x000cbfff window]
May 16 20:51:28 King kernel: pci_bus 0000:00: resource 10 [mem 0x000cc000-0x000cffff window]
May 16 20:51:28 King kernel: pci_bus 0000:00: resource 11 [mem 0x000d0000-0x000d3fff window]
May 16 20:51:28 King kernel: pci_bus 0000:00: resource 12 [mem 0x000d4000-0x000d7fff window]
May 16 20:51:28 King kernel: pci_bus 0000:00: resource 13 [mem 0x000d8000-0x000dbfff window]
May 16 20:51:28 King kernel: pci_bus 0000:00: resource 14 [mem 0x000dc000-0x000dffff window]
May 16 20:51:28 King kernel: pci_bus 0000:00: resource 15 [mem 0x000e0000-0x000e3fff window]
May 16 20:51:28 King kernel: pci_bus 0000:00: resource 16 [mem 0x000e4000-0x000e7fff window]
May 16 20:51:28 King kernel: pci_bus 0000:00: resource 17 [mem 0x000e8000-0x000ebfff window]
May 16 20:51:28 King kernel: pci_bus 0000:00: resource 18 [mem 0x000ec000-0x000effff window]
May 16 20:51:28 King kernel: pci_bus 0000:00: resource 19 [mem 0xe0000000-0xfeafffff window]
May 16 20:51:28 King kernel: pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
May 16 20:51:28 King kernel: pci_bus 0000:01: resource 1 [mem 0xf6000000-0xf70fffff]
May 16 20:51:28 King kernel: pci_bus 0000:01: resource 2 [mem 0xe0000000-0xf1ffffff 64bit pref]
May 16 20:51:28 King kernel: pci_bus 0000:03: resource 0 [io 0xd000-0xdfff]
May 16 20:51:28 King kernel: pci_bus 0000:03: resource 1 [mem 0xf7100000-0xf71fffff]
May 16 20:51:28 King kernel: pci_bus 0000:03: resource 2 [mem 0xf2100000-0xf21fffff 64bit pref]
May 16 20:51:28 King kernel: pci 0000:00:1a.0: quirk_usb_early_handoff+0x0/0x730 took 31721 usecs
May 16 20:51:28 King kernel: pci 0000:00:1d.0: quirk_usb_early_handoff+0x0/0x730 took 29277 usecs
May 16 20:51:28 King kernel: pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
May 16 20:51:28 King kernel: pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
May 16 20:51:28 King kernel: pci 0000:03:00.0: CLS mismatch (64 != 32), using 64 bytes
May 16 20:51:28 King kernel: Trying to unpack rootfs image as initramfs...
May 16 20:51:28 King kernel: Freeing initrd memory: 11000K
May 16 20:51:28 King kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
May 16 20:51:28 King kernel: software IO TLB: mapped [mem 0x00000000d7515000-0x00000000db515000] (64MB)
May 16 20:51:28 King kernel: check: Scanning for low memory corruption every 60 seconds
May 16 20:51:28 King kernel: Initialise system trusted keyrings
May 16 20:51:28 King kernel: Key type blacklist registered
May 16 20:51:28 King kernel: workingset: timestamp_bits=41 max_order=22 bucket_order=0
May 16 20:51:28 King kernel: zbud: loaded
May 16 20:51:28 King kernel: Key type asymmetric registered
May 16 20:51:28 King kernel: Asymmetric key parser 'x509' registered
May 16 20:51:28 King kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
May 16 20:51:28 King kernel: io scheduler mq-deadline registered
May 16 20:51:28 King kernel: io scheduler kyber registered
May 16 20:51:28 King kernel: io scheduler bfq registered
May 16 20:51:28 King kernel: atomic64_test: passed for x86-64 platform with CX8 and with SSE
May 16 20:51:28 King kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
May 16 20:51:28 King kernel: efifb: probing for efifb
May 16 20:51:28 King kernel: efifb: showing boot graphics
May 16 20:51:28 King kernel: efifb: framebuffer at 0xe0000000, using 7232k, total 7232k
May 16 20:51:28 King kernel: efifb: mode is 1600x900x32, linelength=8192, pages=1
May 16 20:51:28 King kernel: efifb: scrolling: redraw
May 16 20:51:28 King kernel: efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
May 16 20:51:28 King kernel: fbcon: Deferring console take-over
May 16 20:51:28 King kernel: fb0: EFI VGA frame buffer device
May 16 20:51:28 King kernel: intel_idle: MWAIT substates: 0x1120
May 16 20:51:28 King kernel: intel_idle: v0.5.1 model 0x3A
May 16 20:51:28 King kernel: intel_idle: Local APIC timer is reliable in all C-states
May 16 20:51:28 King kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
May 16 20:51:28 King kernel: ACPI: Power Button [PWRB]
May 16 20:51:28 King kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
May 16 20:51:28 King kernel: ACPI: Power Button [PWRF]
May 16 20:51:28 King kernel: thermal LNXTHERM:00: registered as thermal_zone0
May 16 20:51:28 King kernel: ACPI: Thermal Zone [TZ00] (28 C)
May 16 20:51:28 King kernel: thermal LNXTHERM:01: registered as thermal_zone1
May 16 20:51:28 King kernel: ACPI: Thermal Zone [TZ01] (30 C)
May 16 20:51:28 King kernel: Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
May 16 20:51:28 King kernel: 00:05: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
May 16 20:51:28 King kernel: Non-volatile memory driver v1.3
May 16 20:51:28 King kernel: AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
May 16 20:51:28 King kernel: AMD-Vi: AMD IOMMUv2 functionality not available on this system
May 16 20:51:28 King kernel: ahci 0000:00:1f.2: version 3.0
May 16 20:51:28 King kernel: ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 4 ports 3 Gbps 0x3 impl SATA mode
May 16 20:51:28 King kernel: ahci 0000:00:1f.2: flags: 64bit ncq pm led clo pio slum part ems apst
May 16 20:51:28 King kernel: scsi host0: ahci
May 16 20:51:28 King kernel: scsi host1: ahci
May 16 20:51:28 King kernel: scsi host2: ahci
May 16 20:51:28 King kernel: scsi host3: ahci
May 16 20:51:28 King kernel: ata1: SATA max UDMA/133 abar m2048@0xf7206000 port 0xf7206100 irq 28
May 16 20:51:28 King kernel: ata2: SATA max UDMA/133 abar m2048@0xf7206000 port 0xf7206180 irq 28
May 16 20:51:28 King kernel: ata3: DUMMY
May 16 20:51:28 King kernel: ata4: DUMMY
May 16 20:51:28 King kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
May 16 20:51:28 King kernel: ehci-pci: EHCI PCI platform driver
May 16 20:51:28 King kernel: ehci-pci 0000:00:1a.0: EHCI Host Controller
May 16 20:51:28 King kernel: ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
May 16 20:51:28 King kernel: ehci-pci 0000:00:1a.0: debug port 2
May 16 20:51:28 King kernel: ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
May 16 20:51:28 King kernel: ehci-pci 0000:00:1a.0: irq 16, io mem 0xf7208000
May 16 20:51:28 King kernel: ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
May 16 20:51:28 King kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
May 16 20:51:28 King kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
May 16 20:51:28 King kernel: usb usb1: Product: EHCI Host Controller
May 16 20:51:28 King kernel: usb usb1: Manufacturer: Linux 5.10.34-1-MANJARO ehci_hcd
May 16 20:51:28 King kernel: usb usb1: SerialNumber: 0000:00:1a.0
May 16 20:51:28 King kernel: hub 1-0:1.0: USB hub found
May 16 20:51:28 King kernel: hub 1-0:1.0: 2 ports detected
May 16 20:51:28 King kernel: ehci-pci 0000:00:1d.0: EHCI Host Controller
May 16 20:51:28 King kernel: ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
May 16 20:51:28 King kernel: ehci-pci 0000:00:1d.0: debug port 2
May 16 20:51:28 King kernel: ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
May 16 20:51:28 King kernel: ehci-pci 0000:00:1d.0: irq 23, io mem 0xf7207000
May 16 20:51:28 King kernel: ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
May 16 20:51:28 King kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
May 16 20:51:28 King kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
May 16 20:51:28 King kernel: usb usb2: Product: EHCI Host Controller
May 16 20:51:28 King kernel: usb usb2: Manufacturer: Linux 5.10.34-1-MANJARO ehci_hcd
May 16 20:51:28 King kernel: usb usb2: SerialNumber: 0000:00:1d.0
May 16 20:51:28 King kernel: hub 2-0:1.0: USB hub found
May 16 20:51:28 King kernel: hub 2-0:1.0: 2 ports detected
May 16 20:51:28 King kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
May 16 20:51:28 King kernel: ohci-pci: OHCI PCI platform driver
May 16 20:51:28 King kernel: uhci_hcd: USB Universal Host Controller Interface driver
May 16 20:51:28 King kernel: usbcore: registered new interface driver usbserial_generic
May 16 20:51:28 King kernel: usbserial: USB Serial support registered for generic
May 16 20:51:28 King kernel: rtc_cmos 00:02: RTC can wake from S4
May 16 20:51:28 King kernel: rtc_cmos 00:02: registered as rtc0
May 16 20:51:28 King kernel: rtc_cmos 00:02: setting system clock to 2021-05-16T20:51:27 UTC (1621198287)
May 16 20:51:28 King kernel: rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
May 16 20:51:28 King kernel: intel_pstate: Intel P-state driver initializing
May 16 20:51:28 King kernel: ledtrig-cpu: registered to indicate activity on CPUs
May 16 20:51:28 King kernel: hid: raw HID events driver (C) Jiri Kosina
May 16 20:51:28 King kernel: ashmem: initialized
May 16 20:51:28 King kernel: drop_monitor: Initializing network drop monitor service
May 16 20:51:28 King kernel: Initializing XFRM netlink socket
May 16 20:51:28 King kernel: NET: Registered protocol family 10
May 16 20:51:28 King kernel: Segment Routing with IPv6
May 16 20:51:28 King kernel: RPL Segment Routing with IPv6
May 16 20:51:28 King kernel: NET: Registered protocol family 17
May 16 20:51:28 King kernel: microcode: sig=0x306a9, pf=0x2, revision=0x21
May 16 20:51:28 King kernel: microcode: Microcode Update Driver: v2.2.
May 16 20:51:28 King kernel: IPI shorthand broadcast: enabled
May 16 20:51:28 King kernel: sched_clock: Marking stable (516615512, 165806)->(531416221, -14634903)
May 16 20:51:28 King kernel: registered taskstats version 1
May 16 20:51:28 King kernel: Loading compiled-in X.509 certificates
May 16 20:51:28 King kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 0c18afb99648acc3e28090e7666710442afd5efc'
May 16 20:51:28 King kernel: zswap: loaded using pool zstd/z3fold
May 16 20:51:28 King kernel: Key type ._fscrypt registered
May 16 20:51:28 King kernel: Key type .fscrypt registered
May 16 20:51:28 King kernel: Key type fscrypt-provisioning registered
May 16 20:51:28 King kernel: AppArmor: AppArmor sha1 policy hashing enabled
May 16 20:51:28 King kernel: PM: Magic number: 5:657:902
May 16 20:51:28 King kernel: RAS: Correctable Errors collector initialized.
May 16 20:51:28 King kernel: ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
May 16 20:51:28 King kernel: ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
May 16 20:51:28 King kernel: ata2.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
May 16 20:51:28 King kernel: ata2.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
May 16 20:51:28 King kernel: ata2.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
May 16 20:51:28 King kernel: ata2.00: supports DRM functions and may not be fully accessible
May 16 20:51:28 King kernel: ata2.00: ATA-10: CT500MX500SSD1, M3CR023, max UDMA/133
May 16 20:51:28 King kernel: ata2.00: 976773168 sectors, multi 1: LBA48 NCQ (depth 32), AA
May 16 20:51:28 King kernel: ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
May 16 20:51:28 King kernel: ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
May 16 20:51:28 King kernel: ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
May 16 20:51:28 King kernel: ata1.00: ATA-8: ST500DM002-1BD142, KC45, max UDMA/133
May 16 20:51:28 King kernel: ata1.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 32)
May 16 20:51:28 King kernel: ata2.00: configured for UDMA/133
May 16 20:51:28 King kernel: ata1.00: configured for UDMA/133
May 16 20:51:28 King kernel: scsi 0:0:0:0: Direct-Access ATA ST500DM002-1BD14 KC45 PQ: 0 ANSI: 5
May 16 20:51:28 King kernel: sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/466 GiB)
May 16 20:51:28 King kernel: sd 0:0:0:0: [sda] 4096-byte physical blocks
May 16 20:51:28 King kernel: sd 0:0:0:0: [sda] Write Protect is off
May 16 20:51:28 King kernel: sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
May 16 20:51:28 King kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
May 16 20:51:28 King kernel: scsi 1:0:0:0: Direct-Access ATA CT500MX500SSD1 023 PQ: 0 ANSI: 5
May 16 20:51:28 King kernel: sd 1:0:0:0: [sdb] 976773168 512-byte logical blocks: (500 GB/466 GiB)
May 16 20:51:28 King kernel: sd 1:0:0:0: [sdb] Write Protect is off
May 16 20:51:28 King kernel: sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
May 16 20:51:28 King kernel: sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
May 16 20:51:28 King kernel: sdb: sdb1 sdb2 sdb3 sdb4 sdb5 sdb6 sdb7
May 16 20:51:28 King kernel: sd 1:0:0:0: [sdb] supports TCG Opal
May 16 20:51:28 King kernel: sd 1:0:0:0: [sdb] Attached SCSI disk
May 16 20:51:28 King kernel: sda: sda1
May 16 20:51:28 King kernel: sd 0:0:0:0: [sda] Attached SCSI disk
May 16 20:51:28 King kernel: Freeing unused decrypted memory: 2036K
May 16 20:51:28 King kernel: Freeing unused kernel image (initmem) memory: 1724K
May 16 20:51:28 King kernel: usb 1-1: new high-speed USB device number 2 using ehci-pci
May 16 20:51:28 King kernel: usb 2-1: new high-speed USB device number 2 using ehci-pci
May 16 20:51:28 King kernel: Write protecting the kernel read-only data: 22528k
May 16 20:51:28 King kernel: Freeing unused kernel image (text/rodata gap) memory: 2036K
May 16 20:51:28 King kernel: Freeing unused kernel image (rodata/data gap) memory: 1348K
May 16 20:51:28 King kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
May 16 20:51:28 King kernel: rodata_test: all tests were successful
May 16 20:51:28 King kernel: x86/mm: Checking user space page tables
May 16 20:51:28 King kernel: Run /init as init process
May 16 20:51:28 King kernel: with arguments:
May 16 20:51:28 King kernel: /init
May 16 20:51:28 King kernel: with environment:
May 16 20:51:28 King kernel: HOME=/
May 16 20:51:28 King kernel: TERM=linux
May 16 20:51:28 King kernel: BOOT_IMAGE=/@/boot/vmlinuz-5.10-x86_64
May 16 20:51:28 King kernel: usb 1-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
May 16 20:51:28 King kernel: usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
May 16 20:51:28 King kernel: hub 1-1:1.0: USB hub found
May 16 20:51:28 King kernel: hub 1-1:1.0: 4 ports detected
May 16 20:51:28 King kernel: usb 2-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
May 16 20:51:28 King kernel: usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
May 16 20:51:28 King kernel: hub 2-1:1.0: USB hub found
May 16 20:51:28 King kernel: hub 2-1:1.0: 6 ports detected
May 16 20:51:28 King kernel: random: fast init done
May 16 20:51:28 King kernel: raid6: skip pq benchmark and using algorithm sse2x4
May 16 20:51:28 King kernel: raid6: using ssse3x2 recovery algorithm
May 16 20:51:28 King kernel: xor: automatically using best checksumming function avx
May 16 20:51:28 King kernel: Btrfs loaded, crc32c=crc32c-intel
May 16 20:51:28 King kernel: BTRFS: device fsid ea6646fa-bee1-45ed-8dea-55aff6671605 devid 1 transid 306 /dev/sdb6 scanned by systemd-udevd (167)
May 16 20:51:28 King kernel: BTRFS info (device sdb6): disk space caching is enabled
May 16 20:51:28 King kernel: BTRFS info (device sdb6): has skinny extents
May 16 20:51:28 King kernel: BTRFS info (device sdb6): enabling ssd optimizations
May 16 20:51:28 King kernel: BTRFS info (device sdb6): start tree-log replay
May 16 20:51:28 King kernel: usb 1-1.1: new high-speed USB device number 3 using ehci-pci
May 16 20:51:28 King kernel: tsc: Refined TSC clocksource calibration: 3092.973 MHz
May 16 20:51:28 King kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2c95594edb3, max_idle_ns: 440795220223 ns
May 16 20:51:28 King systemd[1]: RTC configured in localtime, applying delta of 330 minutes to system time.
May 16 20:51:28 King systemd[1]: systemd 247.6-1.0-manjaro running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
May 16 20:51:28 King systemd[1]: Detected architecture x86-64.
May 16 20:51:28 King kernel: usb 1-1.1: New USB device found, idVendor=0bda, idProduct=8179, bcdDevice= 0.00
May 16 20:51:28 King kernel: usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
May 16 20:51:28 King kernel: usb 1-1.1: Product: 802.11n NIC
May 16 20:51:28 King kernel: usb 1-1.1: Manufacturer: Realtek
May 16 20:51:28 King kernel: usb 1-1.1: SerialNumber: 00E04C0001
May 16 20:51:28 King systemd[1]: Set hostname to <King>.
May 16 20:51:28 King kernel: usb 1-1.2: new full-speed USB device number 4 using ehci-pci
May 16 20:51:28 King kernel: random: lvmconfig: uninitialized urandom read (4 bytes read)
May 16 20:51:28 King systemd[1]: Queued start job for default target Graphical Interface.
May 16 20:51:28 King systemd[1]: Created slice system-getty.slice.
May 16 20:51:28 King systemd[1]: Created slice system-modprobe.slice.
May 16 20:51:28 King systemd[1]: Created slice system-systemd\x2dfsck.slice.
May 16 20:51:28 King systemd[1]: Created slice User and Session Slice.
May 16 20:51:28 King systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
May 16 20:51:28 King systemd[1]: Started Forward Password Requests to Wall Directory Watch.
May 16 20:51:28 King systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
May 16 20:51:28 King systemd[1]: Reached target Local Encrypted Volumes.
May 16 20:51:28 King systemd[1]: Reached target Login Prompts.
May 16 20:51:28 King systemd[1]: Reached target Paths.
May 16 20:51:28 King systemd[1]: Reached target Remote File Systems.
May 16 20:51:28 King systemd[1]: Reached target Slices.
May 16 20:51:28 King systemd[1]: Listening on Device-mapper event daemon FIFOs.
May 16 20:51:28 King systemd[1]: Listening on LVM2 poll daemon socket.
May 16 20:51:28 King systemd[1]: Listening on Process Core Dump Socket.
May 16 20:51:28 King systemd[1]: Listening on Journal Audit Socket.
May 16 20:51:28 King systemd[1]: Listening on Journal Socket (/dev/log).
May 16 20:51:28 King systemd[1]: Listening on Journal Socket.
May 16 20:51:28 King systemd[1]: Listening on udev Control Socket.
May 16 20:51:28 King systemd[1]: Listening on udev Kernel Socket.
May 16 20:51:28 King systemd[1]: Mounting Huge Pages File System...
May 16 20:51:28 King systemd[1]: Mounting POSIX Message Queue File System...
May 16 20:51:28 King systemd[1]: Mounting Kernel Debug File System...
May 16 20:51:28 King systemd[1]: Mounting Kernel Trace File System...
May 16 20:51:28 King systemd[1]: Starting Create list of static device nodes for the current kernel...
May 16 20:51:28 King systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
May 16 20:51:28 King systemd[1]: Starting Load Kernel Module configfs...
May 16 20:51:28 King systemd[1]: Starting Load Kernel Module drm...
May 16 20:51:28 King systemd[1]: Starting Load Kernel Module fuse...
May 16 20:51:28 King kernel: random: lvm: uninitialized urandom read (4 bytes read)
May 16 20:51:28 King systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
May 16 20:51:28 King systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
May 16 20:51:28 King systemd[1]: Starting Load Kernel Modules...
May 16 20:51:28 King systemd[1]: Starting Remount Root and Kernel File Systems...
May 16 20:51:28 King systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
May 16 20:51:28 King systemd[1]: Starting Coldplug All udev Devices...
May 16 20:51:28 King systemd[1]: Mounted Huge Pages File System.
May 16 20:51:28 King systemd[1]: Mounted POSIX Message Queue File System.
May 16 20:51:28 King systemd[1]: Mounted Kernel Debug File System.
May 16 20:51:28 King systemd[1]: Mounted Kernel Trace File System.
May 16 20:51:28 King systemd[1]: Finished Create list of static device nodes for the current kernel.
May 16 20:51:28 King systemd[1]: modprobe@configfs.service: Succeeded.
May 16 20:51:28 King systemd[1]: Finished Load Kernel Module configfs.
May 16 20:51:28 King systemd[1]: modprobe@drm.service: Succeeded.
May 16 20:51:28 King kernel: BTRFS info (device sdb6): use zstd compression, level 3
May 16 20:51:28 King systemd[1]: Finished Load Kernel Module drm.
May 16 20:51:28 King systemd[1]: Finished Remount Root and Kernel File Systems.
May 16 20:51:28 King systemd[1]: Mounting Kernel Configuration File System...
May 16 20:51:28 King systemd[1]: Condition check resulted in First Boot Wizard being skipped.
May 16 20:51:28 King systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
May 16 20:51:28 King systemd[1]: Starting Load/Save Random Seed...
May 16 20:51:28 King systemd[1]: Condition check resulted in Create System Users being skipped.
May 16 20:51:28 King systemd[1]: Starting Create Static Device Nodes in /dev...
May 16 20:51:28 King kernel: fuse: init (API version 7.32)
May 16 20:51:28 King systemd[1]: modprobe@fuse.service: Succeeded.
May 16 20:51:28 King systemd[1]: Finished Load Kernel Module fuse.
May 16 20:51:28 King systemd[1]: Mounted Kernel Configuration File System.
May 16 20:51:28 King systemd[1]: Mounting FUSE Control File System...
May 16 20:51:28 King systemd[1]: Mounted FUSE Control File System.
May 16 20:51:28 King systemd[1]: Finished Create Static Device Nodes in /dev.
May 16 20:51:28 King systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm.
May 16 20:51:28 King systemd[1]: Starting Journal Service...
May 16 20:51:28 King systemd[1]: Starting Rule-based Manager for Device Events and Files...
May 16 20:51:28 King systemd[1]: Finished Coldplug All udev Devices.
May 16 20:51:28 King kernel: audit: type=1130 audit(1621178488.809:2): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:28 King kernel: usb 1-1.2: New USB device found, idVendor=046d, idProduct=c21d, bcdDevice=40.14
May 16 20:51:28 King kernel: usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
May 16 20:51:28 King kernel: usb 1-1.2: Product: Gamepad F310
May 16 20:51:28 King kernel: usb 1-1.2: Manufacturer: Logitech
May 16 20:51:28 King kernel: usb 1-1.2: SerialNumber: DA34FD44
May 16 20:51:28 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:28 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:28 King systemd[1]: Started Journal Service.
May 16 20:51:28 King kernel: audit: type=1130 audit(1621178488.839:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:28 King systemd[1]: Started Rule-based Manager for Device Events and Files.
May 16 20:51:28 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:28 King kernel: usb 1-1.3: new full-speed USB device number 5 using ehci-pci
May 16 20:51:28 King kernel: audit: type=1130 audit(1621178488.929:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:28 King kernel: nvidia: loading out-of-tree module taints kernel.
May 16 20:51:28 King kernel: nvidia: module license 'NVIDIA' taints kernel.
May 16 20:51:28 King kernel: Disabling lock debugging due to kernel taint
May 16 20:51:28 King kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
May 16 20:51:28 King kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 238
May 16 20:51:28 King kernel: nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
May 16 20:51:29 King kernel: EDAC ie31200: No ECC support
May 16 20:51:29 King kernel: input: PC Speaker as /devices/platform/pcspkr/input/input2
May 16 20:51:29 King kernel: i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
May 16 20:51:29 King kernel: i2c i2c-0: 2/2 memory slots populated (from DMI)
May 16 20:51:29 King kernel: i2c i2c-0: Successfully instantiated SPD at 0x51
May 16 20:51:29 King kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20200925/utaddress-204)
May 16 20:51:29 King kernel: ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
May 16 20:51:29 King kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200925/utaddress-204)
May 16 20:51:29 King kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200925/utaddress-204)
May 16 20:51:29 King kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200925/utaddress-204)
May 16 20:51:29 King kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
May 16 20:51:29 King kernel: usb 1-1.3: New USB device found, idVendor=04d9, idProduct=a1cd, bcdDevice= 2.00
May 16 20:51:29 King kernel: usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
May 16 20:51:29 King kernel: usb 1-1.3: Product: CB-GK-16 Firefly
May 16 20:51:29 King kernel: usb 1-1.3: Manufacturer: HT
May 16 20:51:29 King kernel: Linux agpgart interface v0.103
May 16 20:51:29 King kernel: r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
May 16 20:51:29 King kernel: libphy: r8169: probed
May 16 20:51:29 King kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 460.73.01 Thu Apr 1 21:40:36 UTC 2021
May 16 20:51:29 King kernel: r8169 0000:03:00.0 eth0: RTL8168e/8111e, 18:d6:c7:05:fd:e1, XID 2c2, IRQ 30
May 16 20:51:29 King kernel: r8169 0000:03:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
May 16 20:51:29 King kernel: random: crng init done
May 16 20:51:29 King systemd[1]: Finished Load/Save Random Seed.
May 16 20:51:29 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:29 King systemd[1]: Found device CT500MX500SSD1 5.
May 16 20:51:29 King kernel: audit: type=1130 audit(1621178489.119:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:29 King systemd[1]: Found device CT500MX500SSD1 7.
May 16 20:51:29 King systemd[1]: Condition check resulted in First Boot Complete being skipped.
May 16 20:51:29 King systemd[1]: Activating swap Swap Partition...
May 16 20:51:29 King kernel: snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
May 16 20:51:29 King kernel: snd_hda_intel 0000:01:00.1: Disabling MSI
May 16 20:51:29 King kernel: snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
May 16 20:51:29 King kernel: RAPL PMU: API unit is 2^-32 Joules, 2 fixed counters, 163840 ms ovfl timer
May 16 20:51:29 King kernel: RAPL PMU: hw unit of domain pp0-core 2^-16 Joules
May 16 20:51:29 King kernel: RAPL PMU: hw unit of domain package 2^-16 Joules
May 16 20:51:29 King kernel: cryptd: max_cpu_qlen set to 1000
May 16 20:51:29 King systemd[1]: Found device CT500MX500SSD1 6.
May 16 20:51:29 King kernel: input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input3
May 16 20:51:29 King kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input4
May 16 20:51:29 King kernel: input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input5
May 16 20:51:29 King kernel: input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input6
May 16 20:51:29 King kernel: input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input7
May 16 20:51:29 King kernel: input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input8
May 16 20:51:29 King kernel: AVX version of gcm_enc/dec engaged.
May 16 20:51:29 King kernel: AES CTR mode by8 optimization enabled
May 16 20:51:29 King kernel: nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 460.73.01 Thu Apr 1 21:32:31 UTC 2021
May 16 20:51:29 King kernel: [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
May 16 20:51:29 King kernel: [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
May 16 20:51:29 King kernel: usb 1-1.4: new low-speed USB device number 6 using ehci-pci
May 16 20:51:29 King systemd[1]: Activated swap Swap Partition.
May 16 20:51:29 King systemd[1]: Reached target Swap.
May 16 20:51:29 King kernel: Adding 2099196k swap on /dev/sdb7. Priority:-2 extents:1 across:2099196k SSFS
May 16 20:51:29 King kernel: r8169 0000:03:00.0 enp3s0: renamed from eth0
May 16 20:51:29 King systemd[1]: Finished Load Kernel Modules.
May 16 20:51:29 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:29 King systemd[1]: Starting Apply Kernel Variables...
May 16 20:51:29 King systemd[1]: Finished Apply Kernel Variables.
May 16 20:51:29 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:29 King systemd[1]: Starting CLI Netfilter Manager...
May 16 20:51:29 King kernel: audit: type=1130 audit(1621178489.239:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:29 King kernel: audit: type=1130 audit(1621178489.239:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:29 King systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
May 16 20:51:29 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:29 King systemd[1]: Reached target Local File Systems (Pre).
May 16 20:51:29 King systemd[1]: Mounting /tmp...
May 16 20:51:29 King systemd[1]: Condition check resulted in Virtual Machine and Container Storage (Compatibility) being skipped.
May 16 20:51:29 King systemd[1]: Starting File System Check on /dev/disk/by-uuid/C2B8-A608...
May 16 20:51:29 King systemd[1]: Starting File System Check on /dev/disk/by-uuid/ea6646fa-bee1-45ed-8dea-55aff6671605...
May 16 20:51:29 King systemd[1]: Mounted /tmp.
May 16 20:51:29 King systemd[1]: Finished File System Check on /dev/disk/by-uuid/ea6646fa-bee1-45ed-8dea-55aff6671605.
May 16 20:51:29 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck@dev-disk-by\x2duuid-ea6646fa\x2dbee1\x2d45ed\x2d8dea\x2d55aff6671605 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:29 King kernel: audit: type=1130 audit(1621178489.289:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:29 King kernel: audit: type=1130 audit(1621178489.289:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck@dev-disk-by\x2duuid-ea6646fa\x2dbee1\x2d45ed\x2d8dea\x2d55aff6671605 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:29 King systemd[1]: Mounting /home...
May 16 20:51:29 King systemd[1]: Mounting /var/cache...
May 16 20:51:29 King systemd[1]: Mounting /var/log...
May 16 20:51:29 King systemd[1]: Mounted /home.
May 16 20:51:29 King systemd[1]: Mounted /var/log.
May 16 20:51:29 King systemd[1]: Starting Flush Journal to Persistent Storage...
May 16 20:51:29 King systemd[1]: Mounted /var/cache.
May 16 20:51:29 King systemd[1]: Starting Load AppArmor profiles...
May 16 20:51:29 King kernel: iTCO_vendor_support: vendor-support=0
May 16 20:51:29 King kernel: at24 0-0051: supply vcc not found, using dummy regulator
May 16 20:51:29 King kernel: audit: type=1325 audit(1621178489.259:10): table=filter family=2 entries=0 op=xt_register pid=362 subj==unconfined comm="modprobe"
May 16 20:51:29 King kernel: at24 0-0051: 256 byte spd EEPROM, read-only
May 16 20:51:29 King kernel: snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC662 rev1: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
May 16 20:51:29 King kernel: snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
May 16 20:51:29 King kernel: snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
May 16 20:51:29 King kernel: snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
May 16 20:51:29 King kernel: snd_hda_codec_realtek hdaudioC0D0: inputs:
May 16 20:51:29 King kernel: snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
May 16 20:51:29 King kernel: snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
May 16 20:51:29 King kernel: snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
May 16 20:51:29 King kernel: input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
May 16 20:51:29 King kernel: input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
May 16 20:51:29 King kernel: input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
May 16 20:51:29 King kernel: iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
May 16 20:51:29 King kernel: iTCO_wdt: Found a Cougar Point TCO device (Version=2, TCOBASE=0x0460)
May 16 20:51:29 King kernel: iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
May 16 20:51:29 King kernel: usb 1-1.4: New USB device found, idVendor=046d, idProduct=c05a, bcdDevice=63.00
May 16 20:51:29 King kernel: usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
May 16 20:51:29 King kernel: usb 1-1.4: Product: USB Optical Mouse
May 16 20:51:29 King kernel: usb 1-1.4: Manufacturer: Logitech
May 16 20:51:29 King audit[362]: NETFILTER_CFG table=filter family=2 entries=0 op=xt_register pid=362 subj==unconfined comm="modprobe"
May 16 20:51:29 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck@dev-disk-by\x2duuid-C2B8\x2dA608 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:29 King systemd[1]: Finished File System Check on /dev/disk/by-uuid/C2B8-A608.
May 16 20:51:29 King apparmor.systemd[375]: Restarting AppArmor
May 16 20:51:29 King apparmor.systemd[375]: Reloading AppArmor profiles
May 16 20:51:29 King systemd[1]: Mounting /boot/efi...
May 16 20:51:29 King systemd[1]: Mounted /boot/efi.
May 16 20:51:29 King systemd[1]: Reached target Local File Systems.
May 16 20:51:29 King systemd[1]: Condition check resulted in Rebuild Dynamic Linker Cache being skipped.
May 16 20:51:29 King systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
May 16 20:51:29 King systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
May 16 20:51:29 King systemd[1]: Finished Flush Journal to Persistent Storage.
May 16 20:51:29 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:29 King systemd[1]: Starting Create Volatile Files and Directories...
May 16 20:51:29 King audit[390]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=390 comm="apparmor_parser"
May 16 20:51:29 King systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
May 16 20:51:29 King systemd[1]: Condition check resulted in First Boot Wizard being skipped.
May 16 20:51:29 King systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
May 16 20:51:29 King systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
May 16 20:51:29 King systemd[1]: Condition check resulted in Create System Users being skipped.
May 16 20:51:29 King audit[391]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=391 comm="apparmor_parser"
May 16 20:51:29 King audit[391]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=391 comm="apparmor_parser"
May 16 20:51:29 King systemd[1]: Finished Create Volatile Files and Directories.
May 16 20:51:29 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:29 King systemd[1]: Condition check resulted in Rebuild Journal Catalog being skipped.
May 16 20:51:29 King systemd[1]: Starting Network Time Synchronization...
May 16 20:51:29 King systemd[1]: Condition check resulted in Update is Completed being skipped.
May 16 20:51:29 King systemd[1]: Starting Update UTMP about System Boot/Shutdown...
May 16 20:51:29 King audit[404]: SYSTEM_BOOT pid=404 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
May 16 20:51:29 King systemd[1]: Finished Update UTMP about System Boot/Shutdown.
May 16 20:51:29 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:29 King audit[393]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-script-login" pid=393 comm="apparmor_parser"
May 16 20:51:29 King audit[392]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="php-fpm" pid=392 comm="apparmor_parser"
May 16 20:51:29 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:29 King systemd[1]: Started Network Time Synchronization.
May 16 20:51:29 King systemd[1]: Reached target System Time Set.
May 16 20:51:29 King systemd[1]: Reached target System Time Synchronized.
May 16 20:51:29 King audit[389]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session" pid=389 comm="apparmor_parser"
May 16 20:51:29 King audit[389]: AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session//chromium" pid=389 comm="apparmor_parser"
May 16 20:51:29 King systemd[1]: Finished Load AppArmor profiles.
May 16 20:51:29 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=apparmor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:29 King audit[431]: NETFILTER_CFG table=filter family=10 entries=0 op=xt_register pid=431 subj==unconfined comm="modprobe"
May 16 20:51:29 King audit[433]: NETFILTER_CFG table=filter family=2 entries=4 op=xt_replace pid=433 subj==unconfined comm="iptables-restor"
May 16 20:51:29 King audit[437]: NETFILTER_CFG table=filter family=2 entries=4 op=xt_replace pid=437 subj==unconfined comm="iptables-restor"
May 16 20:51:29 King audit[439]: NETFILTER_CFG table=filter family=2 entries=58 op=xt_replace pid=439 subj==unconfined comm="iptables-restor"
May 16 20:51:29 King audit[443]: NETFILTER_CFG table=filter family=2 entries=60 op=xt_replace pid=443 subj==unconfined comm="iptables-restor"
May 16 20:51:29 King audit[446]: NETFILTER_CFG table=filter family=2 entries=64 op=xt_replace pid=446 subj==unconfined comm="iptables-restor"
May 16 20:51:29 King audit[447]: NETFILTER_CFG table=filter family=2 entries=73 op=xt_replace pid=447 subj==unconfined comm="iptables-restor"
May 16 20:51:29 King audit[455]: NETFILTER_CFG table=filter family=2 entries=99 op=xt_replace pid=455 subj==unconfined comm="iptables-restor"
May 16 20:51:29 King audit[468]: NETFILTER_CFG table=filter family=2 entries=106 op=xt_replace pid=468 subj==unconfined comm="iptables-restor"
May 16 20:51:29 King audit[472]: NETFILTER_CFG table=filter family=2 entries=122 op=xt_replace pid=472 subj==unconfined comm="iptables-restor"
May 16 20:51:29 King audit[482]: NETFILTER_CFG table=filter family=2 entries=130 op=xt_replace pid=482 subj==unconfined comm="iptables-restor"
May 16 20:51:29 King audit[484]: NETFILTER_CFG table=filter family=10 entries=4 op=xt_replace pid=484 subj==unconfined comm="ip6tables-resto"
May 16 20:51:29 King audit[487]: NETFILTER_CFG table=filter family=10 entries=4 op=xt_replace pid=487 subj==unconfined comm="ip6tables-resto"
May 16 20:51:29 King audit[489]: NETFILTER_CFG table=filter family=10 entries=58 op=xt_replace pid=489 subj==unconfined comm="ip6tables-resto"
May 16 20:51:29 King audit[492]: NETFILTER_CFG table=filter family=10 entries=60 op=xt_replace pid=492 subj==unconfined comm="ip6tables-resto"
May 16 20:51:29 King audit[495]: NETFILTER_CFG table=filter family=10 entries=64 op=xt_replace pid=495 subj==unconfined comm="ip6tables-resto"
May 16 20:51:30 King audit[496]: NETFILTER_CFG table=filter family=10 entries=73 op=xt_replace pid=496 subj==unconfined comm="ip6tables-resto"
May 16 20:51:30 King audit[500]: NETFILTER_CFG table=filter family=10 entries=138 op=xt_replace pid=500 subj==unconfined comm="ip6tables-resto"
May 16 20:51:30 King audit[503]: NETFILTER_CFG table=filter family=10 entries=144 op=xt_replace pid=503 subj==unconfined comm="ip6tables-resto"
May 16 20:51:30 King audit[504]: NETFILTER_CFG table=filter family=10 entries=160 op=xt_replace pid=504 subj==unconfined comm="ip6tables-resto"
May 16 20:51:30 King audit[508]: NETFILTER_CFG table=filter family=10 entries=168 op=xt_replace pid=508 subj==unconfined comm="ip6tables-resto"
May 16 20:51:30 King systemd[1]: Finished CLI Netfilter Manager.
May 16 20:51:30 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ufw comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:30 King systemd[1]: Reached target System Initialization.
May 16 20:51:30 King systemd[1]: Started Discard unused blocks once a week.
May 16 20:51:30 King systemd[1]: Started Daily rotation of log files.
May 16 20:51:30 King systemd[1]: Started Daily man-db regeneration.
May 16 20:51:30 King systemd[1]: Started Monthly clean packages cache.
May 16 20:51:30 King systemd[1]: Started Generate mirrorlist weekly.
May 16 20:51:30 King systemd[1]: Started Daily verification of password and group files.
May 16 20:51:30 King systemd[1]: Started Daily Cleanup of Temporary Directories.
May 16 20:51:30 King systemd[1]: Reached target Timers.
May 16 20:51:30 King systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
May 16 20:51:30 King systemd[1]: Listening on D-Bus System Message Bus Socket.
May 16 20:51:30 King systemd[1]: Reached target Sockets.
May 16 20:51:30 King systemd[1]: Reached target Basic System.
May 16 20:51:30 King systemd[1]: System is tainted: local-hwclock
May 16 20:51:30 King systemd[1]: Condition check resulted in Save/Restore Sound Card State being skipped.
May 16 20:51:30 King systemd[1]: Condition check resulted in Manage Sound Card State (restore and store) being skipped.
May 16 20:51:30 King systemd[1]: Reached target Sound Card.
May 16 20:51:30 King systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
May 16 20:51:30 King systemd[1]: Started Periodic Command Scheduler.
May 16 20:51:30 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:30 King systemd[1]: Started D-Bus System Message Bus.
May 16 20:51:30 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:30 King systemd[1]: Starting Network Manager...
May 16 20:51:30 King systemd[1]: Starting Authorization Manager...
May 16 20:51:30 King systemd[1]: Starting User Login Management...
May 16 20:51:30 King systemd[1]: Started User Login Management.
May 16 20:51:30 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:30 King systemd[1]: Started Avahi mDNS/DNS-SD Stack.
May 16 20:51:30 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=avahi-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:30 King systemd[1]: Started Network Manager.
May 16 20:51:30 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:30 King systemd[1]: Reached target Network.
May 16 20:51:30 King systemd[1]: Starting Permit User Sessions...
May 16 20:51:30 King systemd[1]: Starting Hostname Service...
May 16 20:51:30 King systemd[1]: Finished Permit User Sessions.
May 16 20:51:30 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:30 King systemd[1]: Starting Light Display Manager...
May 16 20:51:30 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:30 King systemd[1]: Started Authorization Manager.
May 16 20:51:30 King systemd[1]: Starting Modem Manager...
May 16 20:51:30 King systemd[1]: Started Light Display Manager.
May 16 20:51:30 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:30 King systemd[1]: Reached target User and Group Name Lookups.
May 16 20:51:30 King systemd[1]: Starting Accounts Service...
May 16 20:51:30 King systemd[1]: Started Accounts Service.
May 16 20:51:30 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=accounts-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:30 King systemd[1]: Started Hostname Service.
May 16 20:51:30 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:30 King systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
May 16 20:51:30 King kernel: intel_rapl_common: Found RAPL domain package
May 16 20:51:30 King kernel: intel_rapl_common: Found RAPL domain core
May 16 20:51:30 King systemd[1]: Starting Network Manager Script Dispatcher Service...
May 16 20:51:30 King kernel: RTL8211DN Gigabit Ethernet r8169-300:00: attached PHY driver [RTL8211DN Gigabit Ethernet] (mii_bus:phy_addr=r8169-300:00, irq=IGNORE)
May 16 20:51:30 King systemd[1]: Started Modem Manager.
May 16 20:51:30 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:30 King systemd[1]: Reached target Multi-User System.
May 16 20:51:30 King systemd[1]: Reached target Graphical Interface.
May 16 20:51:30 King systemd[1]: Starting TLP system startup/shutdown...
May 16 20:51:30 King systemd[1]: Started Network Manager Script Dispatcher Service.
May 16 20:51:30 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:31 King kernel: input: HT CB-GK-16 Firefly as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:04D9:A1CD.0001/input/input12
May 16 20:51:31 King kernel: input: Logitech Gamepad F310 as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.0/input/input13
May 16 20:51:31 King kernel: hid-generic 0003:04D9:A1CD.0001: input,hidraw0: USB HID v1.10 Keyboard [HT CB-GK-16 Firefly] on usb-0000:00:1a.0-1.3/input0
May 16 20:51:31 King kernel: usbcore: registered new interface driver xpad
May 16 20:51:31 King kernel: input: HT CB-GK-16 Firefly as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:04D9:A1CD.0002/input/input14
May 16 20:51:31 King kernel: input: HT CB-GK-16 Firefly Consumer Control as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:04D9:A1CD.0002/input/input15
May 16 20:51:31 King kernel: r8169 0000:03:00.0 enp3s0: Link is Down
May 16 20:51:31 King kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
May 16 20:51:31 King kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
May 16 20:51:31 King kernel: hid-generic 0003:04D9:A1CD.0002: input,hiddev96,hidraw1: USB HID v1.10 Device [HT CB-GK-16 Firefly] on usb-0000:00:1a.0-1.3/input1
May 16 20:51:31 King kernel: hid-generic 0003:04D9:A1CD.0003: hiddev97,hidraw2: USB HID v1.10 Device [HT CB-GK-16 Firefly] on usb-0000:00:1a.0-1.3/input2
May 16 20:51:31 King kernel: input: HT CB-GK-16 Firefly as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3/1-1.3:1.3/0003:04D9:A1CD.0004/input/input16
May 16 20:51:31 King kernel: hid-generic 0003:04D9:A1CD.0004: input,hidraw3: USB HID v1.10 Mouse [HT CB-GK-16 Firefly] on usb-0000:00:1a.0-1.3/input3
May 16 20:51:31 King kernel: input: Logitech USB Optical Mouse as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:046D:C05A.0005/input/input17
May 16 20:51:31 King kernel: hid-generic 0003:046D:C05A.0005: input,hidraw4: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-0000:00:1a.0-1.4/input0
May 16 20:51:31 King kernel: usbcore: registered new interface driver usbhid
May 16 20:51:31 King kernel: usbhid: USB HID core driver
May 16 20:51:31 King kernel: mousedev: PS/2 mouse device common for all mice
May 16 20:51:31 King kernel: lib80211: common routines for IEEE802.11 drivers
May 16 20:51:31 King kernel: lib80211_crypt: registered algorithm 'NULL'
May 16 20:51:31 King kernel: r8188eu: module is from the staging directory, the quality is unknown, you have been warned.
May 16 20:51:31 King systemd[1]: Finished TLP system startup/shutdown.
May 16 20:51:31 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:31 King systemd[1]: Startup finished in 4.387s (firmware) + 1.673s (loader) + 1.485s (kernel) + 2.933s (userspace) = 10.479s.
May 16 20:51:31 King kernel: Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_D_CUT_1T1R_RomVer(0)
May 16 20:51:31 King kernel: usbcore: registered new interface driver r8188eu
May 16 20:51:31 King kernel: r8188eu 1-1.1:1.0 wlp0s26u1u1: renamed from wlan0
May 16 20:51:32 King kernel: MAC Address = 50:3e:aa:60:6b:6f
May 16 20:51:32 King kernel: R8188EU: indicate disassoc
May 16 20:51:32 King audit[801]: CRED_ACQ pid=801 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 16 20:51:32 King systemd[1]: Created slice User Slice of UID 971.
May 16 20:51:32 King kernel: kauditd_printk_skb: 53 callbacks suppressed
May 16 20:51:32 King kernel: audit: type=1103 audit(1621178492.449:64): pid=801 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 16 20:51:32 King systemd[1]: Starting User Runtime Directory /run/user/971...
May 16 20:51:32 King systemd[1]: Finished User Runtime Directory /run/user/971.
May 16 20:51:32 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:32 King systemd[1]: Starting User Manager for UID 971...
May 16 20:51:32 King kernel: audit: type=1130 audit(1621178492.469:65): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:32 King systemd[805]: pam_systemd_home(systemd-user:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
May 16 20:51:32 King audit[805]: USER_ACCT pid=805 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:32 King audit[805]: CRED_ACQ pid=805 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
May 16 20:51:32 King systemd[805]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[lightdm] ruser=[<unknown>] rhost=[<unknown>]
May 16 20:51:32 King systemd[805]: pam_unix(systemd-user:session): session opened for user lightdm(uid=971) by (uid=0)
May 16 20:51:32 King systemd[805]: pam_env(systemd-user:session): deprecated reading of user environment enabled
May 16 20:51:32 King audit[805]: USER_START pid=805 uid=0 auid=971 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:32 King kernel: audit: type=1101 audit(1621178492.479:66): pid=805 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:32 King kernel: audit: type=1103 audit(1621178492.479:67): pid=805 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
May 16 20:51:32 King kernel: audit: type=1006 audit(1621178492.479:68): pid=805 uid=0 subj==unconfined old-auid=4294967295 auid=971 tty=(none) old-ses=4294967295 ses=1 res=1
May 16 20:51:32 King kernel: audit: type=1105 audit(1621178492.479:69): pid=805 uid=0 auid=971 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:32 King kernel: audit: type=1334 audit(1621178492.489:70): prog-id=11 op=LOAD
May 16 20:51:32 King kernel: audit: type=1334 audit(1621178492.489:71): prog-id=11 op=UNLOAD
May 16 20:51:32 King systemd[1]: Starting WPA supplicant...
May 16 20:51:32 King systemd[1]: Started WPA supplicant.
May 16 20:51:32 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:32 King kernel: audit: type=1130 audit(1621178492.519:72): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:32 King kernel: r8169 0000:03:00.0 enp3s0: Link is Up - 100Mbps/Full - flow control rx/tx
May 16 20:51:32 King kernel: IPv6: ADDRCONF(NETDEV_CHANGE): enp3s0: link becomes ready
May 16 20:51:32 King systemd[805]: Queued start job for default target Main User Target.
May 16 20:51:32 King systemd[805]: -.slice: Failed to migrate controller cgroups from /user.slice/user-971.slice/user@971.service, ignoring: Permission denied
May 16 20:51:32 King systemd[805]: Created slice User Application Slice.
May 16 20:51:32 King systemd[805]: Reached target Paths.
May 16 20:51:32 King systemd[805]: Reached target Timers.
May 16 20:51:32 King systemd[805]: Starting D-Bus User Message Bus Socket.
May 16 20:51:32 King systemd[805]: Listening on GnuPG network certificate management daemon.
May 16 20:51:32 King systemd[805]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
May 16 20:51:32 King systemd[805]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
May 16 20:51:32 King systemd[805]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
May 16 20:51:32 King systemd[805]: Listening on GnuPG cryptographic agent and passphrase cache.
May 16 20:51:32 King systemd[805]: Listening on p11-kit server.
May 16 20:51:32 King systemd[805]: Listening on Sound System.
May 16 20:51:32 King systemd[805]: Listening on D-Bus User Message Bus Socket.
May 16 20:51:32 King systemd[805]: Reached target Sockets.
May 16 20:51:32 King systemd[805]: Reached target Basic System.
May 16 20:51:32 King systemd[1]: Started User Manager for UID 971.
May 16 20:51:32 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:32 King systemd[805]: Starting Update XDG user dir configuration...
May 16 20:51:32 King systemd[1]: Started Session c1 of user lightdm.
May 16 20:51:32 King systemd[805]: xdg-user-dirs-update.service: Succeeded.
May 16 20:51:32 King systemd[805]: Finished Update XDG user dir configuration.
May 16 20:51:32 King systemd[805]: Reached target Main User Target.
May 16 20:51:32 King systemd[805]: Startup finished in 113ms.
May 16 20:51:32 King audit[801]: USER_START pid=801 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_open grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 16 20:51:32 King kernel: audit: type=1130 audit(1621178492.599:73): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:33 King systemd[805]: Started D-Bus User Message Bus.
May 16 20:51:33 King systemd[805]: Starting Accessibility services bus...
May 16 20:51:33 King systemd[805]: Started Accessibility services bus.
May 16 20:51:33 King systemd[805]: Starting Virtual filesystem service...
May 16 20:51:33 King systemd[805]: Started Virtual filesystem service.
May 16 20:51:36 King audit[844]: USER_AUTH pid=844 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="avra" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 16 20:51:36 King audit[844]: USER_ACCT pid=844 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="avra" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 16 20:51:36 King systemd[1]: Stopping Session c1 of user lightdm.
May 16 20:51:36 King audit[801]: USER_END pid=801 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 16 20:51:36 King audit[801]: CRED_DISP pid=801 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 16 20:51:36 King systemd[1]: session-c1.scope: Succeeded.
May 16 20:51:36 King systemd[1]: Stopped Session c1 of user lightdm.
May 16 20:51:36 King audit[844]: CRED_ACQ pid=844 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="avra" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 16 20:51:36 King systemd[1]: Created slice User Slice of UID 1000.
May 16 20:51:36 King systemd[1]: Starting User Runtime Directory /run/user/1000...
May 16 20:51:36 King systemd[1]: Finished User Runtime Directory /run/user/1000.
May 16 20:51:36 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:36 King systemd[1]: Starting User Manager for UID 1000...
May 16 20:51:36 King systemd[857]: pam_systemd_home(systemd-user:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
May 16 20:51:36 King audit[857]: USER_ACCT pid=857 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="avra" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:36 King audit[857]: CRED_ACQ pid=857 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="avra" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
May 16 20:51:36 King systemd[857]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[avra] ruser=[<unknown>] rhost=[<unknown>]
May 16 20:51:36 King systemd[857]: pam_unix(systemd-user:session): session opened for user avra(uid=1000) by (uid=0)
May 16 20:51:36 King systemd[857]: pam_env(systemd-user:session): deprecated reading of user environment enabled
May 16 20:51:36 King audit[857]: USER_START pid=857 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="avra" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:37 King systemd[857]: Queued start job for default target Main User Target.
May 16 20:51:37 King systemd[857]: -.slice: Failed to migrate controller cgroups from /user.slice/user-1000.slice/user@1000.service, ignoring: Permission denied
May 16 20:51:37 King systemd[857]: Created slice User Application Slice.
May 16 20:51:37 King systemd[857]: Reached target Paths.
May 16 20:51:37 King systemd[857]: Reached target Timers.
May 16 20:51:37 King systemd[857]: Starting D-Bus User Message Bus Socket.
May 16 20:51:37 King systemd[857]: Listening on GnuPG network certificate management daemon.
May 16 20:51:37 King systemd[857]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
May 16 20:51:37 King systemd[857]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
May 16 20:51:37 King systemd[857]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
May 16 20:51:37 King systemd[857]: Listening on GnuPG cryptographic agent and passphrase cache.
May 16 20:51:37 King systemd[857]: Listening on p11-kit server.
May 16 20:51:37 King systemd[857]: Listening on Sound System.
May 16 20:51:37 King systemd[857]: Listening on D-Bus User Message Bus Socket.
May 16 20:51:37 King systemd[857]: Reached target Sockets.
May 16 20:51:37 King systemd[857]: Reached target Basic System.
May 16 20:51:37 King systemd[1]: Started User Manager for UID 1000.
May 16 20:51:37 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:37 King systemd[857]: Starting Update XDG user dir configuration...
May 16 20:51:37 King systemd[1]: Started Session 2 of user avra.
May 16 20:51:37 King systemd[857]: xdg-user-dirs-update.service: Succeeded.
May 16 20:51:37 King systemd[857]: Finished Update XDG user dir configuration.
May 16 20:51:37 King systemd[857]: Reached target Main User Target.
May 16 20:51:37 King systemd[857]: Startup finished in 122ms.
May 16 20:51:37 King audit[844]: USER_START pid=844 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct="avra" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
May 16 20:51:37 King audit[844]: USER_LOGIN pid=844 uid=0 auid=1000 ses=2 subj==unconfined msg='op=login id=1000 exe="/usr/bin/lightdm" hostname=King addr=? terminal=/dev/tty7 res=success'
May 16 20:51:37 King systemd[857]: Started D-Bus User Message Bus.
May 16 20:51:37 King systemd[857]: Starting Virtual filesystem service...
May 16 20:51:37 King systemd[857]: Started Virtual filesystem service.
May 16 20:51:37 King systemd[857]: Starting Accessibility services bus...
May 16 20:51:37 King systemd[857]: Started Accessibility services bus.
May 16 20:51:37 King systemd[857]: Starting Sound Service...
May 16 20:51:37 King systemd[1]: Starting RealtimeKit Scheduling Policy Service...
May 16 20:51:37 King systemd[1]: Started RealtimeKit Scheduling Policy Service.
May 16 20:51:37 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:37 King kernel: kauditd_printk_skb: 17 callbacks suppressed
May 16 20:51:37 King kernel: audit: type=1130 audit(1621178497.549:91): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:38 King systemd[857]: Starting User preferences database...
May 16 20:51:38 King systemd[857]: Started User preferences database.
May 16 20:51:38 King systemd[1]: Starting Manage, Install and Generate Color Profiles...
May 16 20:51:38 King kernel: audit: type=1334 audit(1621178498.209:92): prog-id=13 op=LOAD
May 16 20:51:38 King kernel: audit: type=1334 audit(1621178498.209:93): prog-id=14 op=LOAD
May 16 20:51:38 King systemd[1]: Starting Daemon for power management...
May 16 20:51:38 King systemd[857]: Starting Zeitgeist activity log service...
May 16 20:51:38 King systemd[1]: Started Manage, Install and Generate Color Profiles.
May 16 20:51:38 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=colord comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:38 King kernel: audit: type=1130 audit(1621178498.269:94): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=colord comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:38 King systemd[857]: Started Zeitgeist activity log service.
May 16 20:51:38 King systemd[857]: Starting Zeitgeist full-text search indexer...
May 16 20:51:38 King systemd[857]: Started Zeitgeist full-text search indexer.
May 16 20:51:38 King systemd[1]: Condition check resulted in Bluetooth service being skipped.
May 16 20:51:38 King systemd[1]: Started Daemon for power management.
May 16 20:51:38 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:38 King kernel: audit: type=1130 audit(1621178498.469:95): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:38 King systemd[857]: Started Sound Service.
May 16 20:51:38 King systemd[857]: Starting Virtual filesystem service - disk device monitor...
May 16 20:51:38 King systemd[1]: Starting Disk Manager...
May 16 20:51:38 King systemd[1]: Started Disk Manager.
May 16 20:51:38 King audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:38 King kernel: audit: type=1130 audit(1621178498.739:96): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:38 King systemd[857]: Started Virtual filesystem service - disk device monitor.
May 16 20:51:38 King systemd[857]: Starting Virtual filesystem service - Media Transfer Protocol monitor...
May 16 20:51:38 King systemd[857]: Started Virtual filesystem service - Media Transfer Protocol monitor.
May 16 20:51:38 King systemd[857]: Starting Virtual filesystem service - digital camera monitor...
May 16 20:51:38 King systemd[857]: Starting Evolution source registry...
May 16 20:51:38 King systemd[857]: Started Virtual filesystem service - digital camera monitor.
May 16 20:51:38 King systemd[857]: Starting Virtual filesystem service - Apple File Conduit monitor...
May 16 20:51:38 King systemd[857]: Started Virtual filesystem service - Apple File Conduit monitor.
May 16 20:51:38 King systemd[857]: Started Evolution source registry.
May 16 20:51:38 King systemd[857]: Starting Evolution calendar service...
May 16 20:51:38 King systemd[857]: Started Evolution calendar service.
May 16 20:51:38 King systemd[857]: Starting Evolution address book service...
May 16 20:51:39 King systemd[857]: Started Evolution address book service.
May 16 20:51:40 King systemd[1]: NetworkManager-dispatcher.service: Succeeded.
May 16 20:51:40 King audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:41 King kernel: audit: type=1131 audit(1621178500.989:97): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:47 King systemd[1]: Stopping User Manager for UID 971...
May 16 20:51:47 King systemd[805]: Stopped target Main User Target.
May 16 20:51:47 King systemd[805]: Stopping Accessibility services bus...
May 16 20:51:47 King systemd[805]: Stopping D-Bus User Message Bus...
May 16 20:51:47 King systemd[805]: Stopping Virtual filesystem service...
May 16 20:51:47 King systemd[805]: at-spi-dbus-bus.service: Succeeded.
May 16 20:51:47 King systemd[805]: Stopped Accessibility services bus.
May 16 20:51:47 King systemd[805]: dbus.service: Succeeded.
May 16 20:51:47 King systemd[805]: Stopped D-Bus User Message Bus.
May 16 20:51:47 King systemd[857]: run-user-971-gvfs.mount: Succeeded.
May 16 20:51:47 King systemd[805]: run-user-971-gvfs.mount: Succeeded.
May 16 20:51:47 King systemd[1]: run-user-971-gvfs.mount: Succeeded.
May 16 20:51:47 King systemd[805]: gvfs-daemon.service: Succeeded.
May 16 20:51:47 King systemd[805]: Stopped Virtual filesystem service.
May 16 20:51:47 King systemd[805]: Stopped target Basic System.
May 16 20:51:47 King systemd[805]: Stopped target Paths.
May 16 20:51:47 King systemd[805]: Stopped target Sockets.
May 16 20:51:47 King systemd[805]: Stopped target Timers.
May 16 20:51:47 King systemd[805]: dbus.socket: Succeeded.
May 16 20:51:47 King systemd[805]: Closed D-Bus User Message Bus Socket.
May 16 20:51:47 King systemd[805]: dirmngr.socket: Succeeded.
May 16 20:51:47 King systemd[805]: Closed GnuPG network certificate management daemon.
May 16 20:51:47 King systemd[805]: gpg-agent-browser.socket: Succeeded.
May 16 20:51:47 King systemd[805]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
May 16 20:51:47 King systemd[805]: gpg-agent-extra.socket: Succeeded.
May 16 20:51:47 King systemd[805]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
May 16 20:51:47 King systemd[805]: gpg-agent-ssh.socket: Succeeded.
May 16 20:51:47 King systemd[805]: Closed GnuPG cryptographic agent (ssh-agent emulation).
May 16 20:51:47 King systemd[805]: gpg-agent.socket: Succeeded.
May 16 20:51:47 King systemd[805]: Closed GnuPG cryptographic agent and passphrase cache.
May 16 20:51:47 King systemd[805]: p11-kit-server.socket: Succeeded.
May 16 20:51:47 King systemd[805]: Closed p11-kit server.
May 16 20:51:47 King systemd[805]: pulseaudio.socket: Succeeded.
May 16 20:51:47 King systemd[805]: Closed Sound System.
May 16 20:51:47 King systemd[805]: Removed slice User Application Slice.
May 16 20:51:47 King systemd[805]: Reached target Shutdown.
May 16 20:51:47 King systemd[805]: systemd-exit.service: Succeeded.
May 16 20:51:47 King systemd[805]: Finished Exit the Session.
May 16 20:51:47 King systemd[805]: Reached target Exit the Session.
May 16 20:51:47 King systemd[806]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[lightdm] ruser=[<unknown>] rhost=[<unknown>]
May 16 20:51:47 King systemd[1]: user@971.service: Succeeded.
May 16 20:51:47 King systemd[1]: Stopped User Manager for UID 971.
May 16 20:51:47 King audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:47 King systemd[1]: Stopping User Runtime Directory /run/user/971...
May 16 20:51:47 King kernel: audit: type=1131 audit(1621178507.109:98): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:47 King systemd[857]: run-user-971.mount: Succeeded.
May 16 20:51:47 King systemd[1]: run-user-971.mount: Succeeded.
May 16 20:51:47 King systemd[1]: user-runtime-dir@971.service: Succeeded.
May 16 20:51:47 King systemd[1]: Stopped User Runtime Directory /run/user/971.
May 16 20:51:47 King audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:51:47 King systemd[1]: Removed slice User Slice of UID 971.
May 16 20:51:47 King kernel: audit: type=1131 audit(1621178507.119:99): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@971 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:52:02 King systemd[1]: systemd-hostnamed.service: Succeeded.
May 16 20:52:02 King audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:52:02 King kernel: audit: type=1131 audit(1621178522.113:100): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
May 16 20:52:02 King kernel: audit: type=1334 audit(1621178522.453:101): prog-id=10 op=UNLOAD
May 16 20:52:02 King kernel: audit: type=1334 audit(1621178522.453:102): prog-id=9 op=UNLOAD
What is different between editing partition.conf and choosing btrfs in Calamares during manual partition ?
I didnât try that so I donât know actually⌠As long as it creates subvols correctly and mount those everything should b fine.
Calamares looks at the partition.conf for the default fs typeâŚso it can configure everything correctly.
Changing how swap is referenced in /etc/default/grub
worked for me.
Edited to add: Also check that the offset in that line is set. There is a recommendation to use btrfs_map_physical
instead of filefrag
(I got the same value from both, fwiw). And donât forget to divide by page size. More info.
I donât have UUID either as I am using gpt, swap should mount automatically, no need to include in fstab or grub. Hibernation is working fine but for hybrid-sleep to work properly I think I must have swap partition size atleast similar to my total ram size, 16GB in my case. My problem was with gnome, where even suspend wasnât waking up, thought it was actually hybrid sleep in gnome labelled as âsuspendâ. Will check it with gnome again & if it is actually hybrid-sleep then I have to find a way to make it âsuspendâ instead of hybrid-sleep.
Calamares seems to have an issue with loading a module, I think it is the btrfs module. If you start to start the install too quickly, Calamares will sit an spin trying to load 1 module. If it takes longer than 30 secs, the install will fail when it tries to partition the drive. Better to boot the install and and then give it a few minutes, and then start the install.
