Manjaro boots to non-graphical login screen after selecting KDE
Hi All,
Can someone help be about that case:
I installed a Manjaro multiboot system in Lenovo MIIX 520, after selected the KDE version boot, it went direct to a commande console in black screen (tty1) asking login and password. How can I come back to desktop screen? I’d like to avoid a reinstall. ALT+CTL+F(n), 1-2-3-4-5-6-7 don’t work… Please help.
Hello @vivius :slight_smile:
No idea what you did. But it is definitely not the installation process.
If it boots to the basic video login screen, then you have set multi-user.target instead of graphical.target to default or you disabled the display-manager.service.
sudo systemctl set-default graphical.target
sudo systemctl enable --now display-manager.service
Hope it helps :wink:
