I just bought a new headset, the Corsair Void Elite USB
But I don’t know how to make the audio and the microphone work at the same time
I’ve tested both separately and my mic is recognized and usable by Discord, but the audio has to be disabled and vice versa
Is there any way to have both?
I’m using PipeWire btw
Here’s my config:
Kernel: 5.17.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
root=UUID=bf848bef-83c7-43d0-80a1-be1f176b2904 rw quiet apparmor=1
security=apparmor intel_iommu=on iommu=pt udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: Micro-Star model: Z590-A PRO (MS-7D09) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.30
date: 09/06/2021
RAM: total: 15.51 GiB used: 3.15 GiB (20.3%)
RAM Report:
Info: model: 11th Gen Intel Core i5-11600K bits: 64 type: MT MCP
arch: Rocket Lake family: 6 model-id: 0xA7 (167) stepping: 1 microcode: 0x50
L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 high: 801 min/max: 800/4900 scaling:
driver: intel_pstate governor: powersave cores: 1: 801 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 93924
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma
avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est
f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed
rdtscp rep_good sdbg sep sha_ni smap smep smx ss ssbd sse sse2 sse4_1
tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid
x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: PC Partner driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 ports: active: HDMI-A-1,HDMI-A-2 empty: DP-1,DP-2,DVI-D-1
bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
gpu: amdgpu display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2")
s-diag: 1055mm (41.5")
Monitor-1: HDMI-A-0 mapped: HDMI-A-1 pos: right
model: LG (GoldStar) IPS FULLHD built: 2014 res: 1920x1080 hz: 60 dpi: 102
gamma: 1.2 size: 480x270mm (18.9x10.6") diag: 551mm (21.7") ratio: 16:9
modes: max: 1920x1080 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-2 pos: primary,left
model: LG (GoldStar) IPS277 built: 2012 res: 1920x1080 hz: 60 dpi: 81
gamma: 1.2 size: 600x340mm (23.6x13.4") diag: 690mm (27.2") ratio: 16:9
modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD Radeon RX 480 Graphics (POLARIS10 DRM 3.44.0
5.17.0-1-MANJARO LLVM 13.0.1)
v: 4.6 Mesa 21.3.7 direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: PC Partner driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-3: Corsair VOID ELITE USB Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4.3:7 chip-ID: 1b1c:0a56
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.17.0-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.48 running: yes
Device-1: Intel Ethernet I225-V vendor: Micro-Star MSI driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 03:00.0
chip-ID: 8086:15f3 class-ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-4.4:8 chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
Local Storage: total: 1.82 TiB used: 395.44 GiB (21.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000BX500SSD1
type: SSD serial: <filter> rev: 030 scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 389.5 GiB (42.5%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: bf848bef-83c7-43d0-80a1-be1f176b2904
used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
uuid: E6E8-C8B8
ID-3: /media/scualala raw-size: 931.51 GiB size: 915.82 GiB (98.32%)
used: 5.94 GiB (0.6%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 01496faf-a9ba-41a5-81ea-b40c87e82ba3
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-2:9 info: Micro Star MYSTIC LIGHT type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 1462:7d09 class-ID: 0300 serial: <filter>
Hub-2: 1-4:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-4.1:5 info: Logitech G502 SE HERO Gaming Mouse type: Mouse,HID
power: 300mA chip-ID: 046d:c08b class-ID: 0300 serial: <filter>
Device-2: 1-4.2:6 info: Corsair K70 RGB MK.2 Mechanical Gaming Keyboard
type: Keyboard,HID driver: usbfs interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 1b1c:1b49 class-ID: 0300 serial: <filter>
Device-3: 1-4.3:7 info: Corsair VOID ELITE USB Gaming Headset
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 1b1c:0a56 class-ID: 0300
serial: <filter>
Device-4: 1-4.4:8 info: Realtek Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Hub-3: 1-13:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-4: 2-0:1 info: Super-speed hub ports: 9 rev: 3.1 speed: 20 Gb/s
System Temperatures: cpu: 27.8 C mobo: N/A gpu: amdgpu temp: 53.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 692
Processes: 337 Uptime: 50m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1543 apt: 0 pacman: 1526
lib: 450 flatpak: 17 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.13```
