I used Linux Mint for quite some years, after switching to Manjaro on my Lenovo computer today. I already tested Manjaro on an old Dell computer with similar hardware to check if everything works OK, and it did.
How did I install Manjaro? I formatted the original Mint partition and installed Manjaro on it. I kept the /home
and the /swap
partition from the original Mint installation.
Unfortunately the starting process on the Lenovo is causing some trouble (which I do not have on my old Dell): After booting the Lenovo, it ends up in a blank screen. If I switch e.g. to TTY2 pressing CTRL + ALT + F2 and then – without logging in – press CTRL + ALT + F7 the login manager appears and I just logon normally. However, the login screen of lightdm
does not start without intermediately switching to TTY2 or another TTY.
I investigated the status of lightdm
for two different cases:
Case 1: Logging on TTY2 before switching to CTRL + ALT + F7:
> systemctl status lightdm.service
lightdm.service - Light Display Manager
Loaded: loaded (/usr/lib/systemd/system/lightdm.service; enabled; vendor preset: disabled)
Active: active (running) since Sat 2021-01-30 18:49:45 CET; 3min 1s ago
Docs: man:lightdm(1)
Main PID: 426 (lightdm)
Tasks: 12 (limit: 9403)
Memory: 50.8M
CGroup: /system.slice/lightdm.service
├─ 426 /usr/bin/lightdm
├─ 441 /usr/lib/Xorg :0 -seat seat0 -auth /run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
└─1142 lightdm --session-child 12 19
Jan 30 18:49:45 Yogix systemd[1]: Starting Light Display Manager...
Jan 30 18:49:45 Yogix systemd[1]: Started Light Display Manager.
Jan 30 18:49:49 Yogix lightdm[1097]: pam_unix(lightdm-greeter:session): session opened for user lightdm(uid=969) by (uid=0)
Case 2 After switching back with CTRL + ALT+ F7 and logging in with lightdm
��� lightdm.service - Light Display Manager
Active: active (running) since Sat 2021-01-30 18:49:45 CET; 20min ago
Tasks: 11 (limit: 9403)
Memory: 180.9M
������426 /usr/bin/lightdm
������441 /usr/lib/Xorg :0 -seat seat0 -auth /run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
Jan 30 18:52:52 Yogix lightdm[1142]: gkr-pam: unable to locate daemon control file
Jan 30 18:52:52 Yogix lightdm[1142]: gkr-pam: stashed password to try later in open session
Jan 30 18:52:52 Yogix lightdm[1142]: pam_systemd_home(lightdm:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Jan 30 18:52:52 Yogix lightdm[1142]: pam_unix(lightdm:session): session opened for user christian(uid=1000) by (uid=0)
Jan 30 18:52:53 Yogix lightdm[1142]: pam_env(lightdm:session): deprecated reading of user environment enabled
Jan 30 18:52:53 Yogix lightdm[1142]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
There is one message written in RED color: gkr-pam: unable to locate daemon control file
Additional information
After some warnings on locale settings which I think are not relevant, inxi -Gazy
shows:
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:5917
Device-2: Lite-On Integrated Camera type: USB driver: uvcvideo bus ID: 1-5:3
chip ID: 04ca:7070
Display: x11 server: X.Org 1.20.10 driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa display ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 dpi: 168 size: 290x170mm (11.4x6.7")
diag: 336mm (13.2")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.3.3
direct render: Yes
I am using Kernel 5.10.7-3-MANJARO
as some forum entries with similar issues recommended to upgrade to 5.10 from 5.9. So it did not work in 5.9 either.
Please help.
